On UIS Cloud, click Cloud Services on the top navigation bar.
On the UIS-Sec portal of UIS Manager Standard Edition, click Network Services on the top navigation bar.
From the left navigation pane, select Network & Security > Routers.
Click Create.
Enter a name and description and select a firewall for the router.
A firewall is in inactive state when it is not attached to any resources. Each router can be attached to only one firewall.
