Create a network
  • To use the network and security services provided by UIS-Sec, select network egress uis when you create the network.
  • If network egress uis does not exist, add the network egress on the Cloud O&M > Infrastructure > Network Planning > Enhanced Network Mode page.
  1. On UIS Cloud, click Cloud Services on the top navigation bar.
  1. On the UIS-Sec portal of UIS Manager Standard Edition, click Network Services on the top navigation bar.
  1. From the left navigation pane, select Network & Security > Networks.
  1. Click Create.
  1. Configure network parameters as needed.
Table-1 Configuring network parameters
Parameter
Network Egress
Select the network egress that is specified when you deploy the compute node.
Resource Zone
Select AZs for the network. Only AZs that match the selected network egress are available. When you create a cloud host, the system filters networks based on the AZs.
Shared
Select whether to share the network among different organizations. This parameter is available only when you log in to the system as the cloud administrator.
Segment ID
Enter a VLAN ID for the network.
  1. Click Create.
