10-VLAN Commands
Chapters Download (88.4 KB)
View
VLAN view, VLAN interface view
Default Level
2: System level
text: Description of a VLAN or VLAN interface. Currently, the device supports the following types of characters or symbols: standard English characters (numbers and case-sensitive letters), special English characters, spaces, and other characters or symbols that conform to the Unicode standard.
l For a VLAN, the description string contains 1 to 32 characters.
l For a VLAN interface, the description string contains 1 to 80 characters.
l A port description can be the mixture of English characters and other Unicode characters. The mixed description cannot exceed the specified length.
l To use a type of Unicode characters or symbols in a port description, you need to install the corresponding Input Method Editor (IME) and log in to the device through remote login software that supports this character type.
l Each Unicode character or symbol (non-English characters) takes the space of two regular characters. When the length of a description string reaches or exceeds the maximum line width on the terminal software, the software starts a new line, possibly breaking a Unicode character into two parts. As a result, garbled characters may be displayed at the end of a line.
Case-sensitive string that describes the current VLAN or VLAN interface. Spaces can be included in the description.
l For a VLAN, this is a string of 1 to 32 characters.
l For a VLAN interface, this is a string of 1 to 80 characters.
Use the description command to configure the description of the current VLAN or VLAN interface.
Use the undo description command to restore the default.
For a VLAN, the default description is the VLAN ID, for example, VLAN 0001; for a VLAN interface, the default description is the name of the interface, for example, Vlan-interface 1 Interface.
You can configure a description to describe the function or connection of a VLAN or VLAN interface for management sake.
# Configure the description of VLAN 1 as RESEARCH.
[Sysname] vlan 1
[Sysname-vlan1] description RESEARCH
# Configure the description of VLAN-interface 2 as VLAN-INTERFACE-2.
[Sysname] vlan 2
[Sysname-vlan2] quit
[Sysname-Vlan-interface2] description VLAN-INTERFACE-2
display interface vlan-interface [ vlan-interface-id ]
View
Default Level
1: Monitor level
vlan-interface-id: VLAN interface number.
Use the display interface vlan-interface command to display information about a specified or all VLAN interfaces if no interface is specified.
Related commands: interface vlan-interface.
# Display the information of VLAN-interface 2.
<Sysname> display interface vlan-interface 2
Vlan-interface2 current state: DOWN
Line protocol current state: DOWN
Description: Vlan-interface2 Interface
The Maximum Transmit Unit is 1500
Internet protocol processing : disabled
IP Packet Frame Type: PKTFMT_ETHNT_2, Hardware Address: 000f-e249-8050
Last 300 seconds input: 0 bytes/sec 0 packets/sec
Last 300 seconds output: 0 bytes/sec 0 packets/sec
0 packets input, 0 bytes, 0 drops
0 packets output, 0 bytes, 0 drops
Table 1-1 display interface vlan-interface command output description
Vlan-interface2 current state |
The physical state of the VLAN interface, which can be one of the following: l Administratively DOWN: The administrative state of the VLAN interface is down because it has been manually shut down with the shutdown command. l DOWN: The administrative state of this VLAN interface is up, but its physical state is down. It indicates that the VLAN corresponding to this interface does not contain any port in the UP state (possibly because the ports are not well connected or the lines have failed). l UP: both the administrative state and the physical state of this VLAN interface are up. |
Line protocol current state |
The link layer protocol state of a VLAN interface, which can be one of the following: l DOWN: The protocol state of this VLAN interface is down, usually because no IP address is configured. l UP: The protocol state of this VLAN interface is up. |
The description string of a VLAN interface |
The Maximum Transmit Unit |
The MTU of a VLAN interface |
Internet protocol processing : |
IP packets processing ability. Disabled indicates that the interface is not configured with an IP address. |
IP Packet Frame Type |
IPv4 outgoing frame format |
Hardware address |
MAC address corresponding to a VLAN interface |
Last 300 seconds input: 0 bytes/sec 0 packets/sec Last 300 seconds output: 0 bytes/sec 0 packets/sec |
Average rate of input packets and output packets in the last 300 seconds (in bps and pps) |
0 packets input, 0 bytes, 0 drops |
Total number and size (in bytes) of the received packets of the interface and the number of the dropped packets |
0 packets output, 0 bytes, 0 drops |
Total number and size (in bytes) of the transmitted packets of the interface and the number of the dropped packets |
display vlan [ vlan-id1 [ to vlan-id2 ] | all | dynamic | reserved | static ]
View
Default Level
1: Monitor level
vlan-id1: Displays the information of a VLAN specified by VLAN ID in the range of 1 to 4094.
vlan-id1 to vlan-id2: Displays the information of a range of VLANs specified by a VLAN ID range.
all: Displays all current VLAN information except for the reserved VLANs.
dynamic: Displays the number of dynamic VLANs and the ID of each dynamic VLAN. Dynamic VLANs refer to VLANs that are generated through GVRP or those distributed by a RADIUS server.
reserved: Displays information of the reserved VLANs. Protocol modules determine which VLANs are reserved VLANs according to function implementation, and reserved VLANs serve protocol modules. You cannot do any configuration on reserved VLANs.
static: Displays the number of static VLANs and the ID of each static VLAN. Static VLANs refer to VLANs manually created.
Use the display vlan command to display VLAN information.
Related commands: vlan.
# Display VLAN 2 information.
<Sysname> display vlan 2
VLAN ID: 2
VLAN Type: static
Route interface: not configured
Description: VLAN 0002
Tagged Ports: none
Untagged Ports:
GigabitEthernet1/0/1 GigabitEthernet1/0/2 GigabitEthernet1/0/3
# Display VLAN 3 information.
<Sysname> display vlan 3
VLAN ID: 3
VLAN Type: static
Route Interface: configured
IP Address: 1.1.1.1
Subnet Mask: 255.255.255.0
Description: VLAN 0003
Tagged Ports: none
Untagged Ports: none
Table 1-2 display vlan command output description
VLAN Type |
VLAN type (static or dynamic) |
Route interface |
Whether a VLAN interface is configured for the VLAN: not configured or configured |
Description of the VLAN |
Name |
Name configured for the VLAN |
IP Address |
Primary IP address of the VLAN interface (available only on a VLAN interface configured with an IP address). You can use the display interface vlan-interface command in any view or the display this command in VLAN interface view to display its secondary IP address(es), if any. |
Subnet Mask |
Subnet mask of the primary IP address (available only on a VLAN interface configured with an IP address) |
Tagged Ports |
Ports through which packets of the VLAN are sent tagged |
Untagged Ports |
Ports through which packets of the VLAN are sent untagged |
interface vlan-interface vlan-interface-id
undo interface vlan-interface vlan-interface-id
View
Default Level
2: System level
vlan-interface-id: VLAN interface number, in the range of 1 to 4094.
Use the interface vlan-interface command to create a VLAN interface and enter its view or enter the view of an existing VLAN interface.
Before you can create the VLAN interface of a VLAN, create the VLAN first.
Use the undo interface vlan-interface command to remove the specified VLAN interface.
You can use the ip address command in VLAN interface view to configure an IP address for a VLAN interface to perform IP routing.
Related commands: display interface Vlan-interface.
# Create VLAN-interface 2.
[Sysname] vlan 2
undo ip address [ ip-address { mask | mask-length } [ sub ] ]
View
VLAN interface view
Default Level
2: System level
ip-address: IP address to be assigned to the current VLAN interface, in dotted decimal format.
mask: Subnet mask in dotted decimal notation.
mask-length: Subnet mask length, the number of consecutive ones in the mask. The value range is 0 to 32.
sub: Indicates the address is a secondary IP address.
Use the ip address command to assign an IP address and subnet mask to a VLAN interface.
Use the undo ip address command to remove the IP address and subnet mask for a VLAN interface.
By default, no IP address is assigned to any VLAN interface.
In general conditions, you need to assign only one IP address for a VLAN interface. For a VLAN to connect to multiple subnets, you need to assign multiple IP addresses for the VLAN interface. Among these IP addresses, one is primary and the others are secondary. On an S5810 switch, you can assign up to ten IP addresses for a VLAN interface.
When configuring IP addresses for a VLAN interface, consider the following:
l You can assign only one primary IP address to an interface.
l Before removing the primary IP address, remove all secondary IP addresses.
l To remove all IP addresses, use the undo ip address command without any parameter.
l To remove the primary IP address, use the undo ip address ip-address { mask | mask-length } command.
l To remove a secondary IP address, use the undo ip address ip-address { mask | mask-length } sub command.
Related commands: display ip interface (IP Address Commands in the IP Services Volume).
# Specify the IP address as 1.1.0.1, the subnet mask as 255.255.255.0 for VLAN-interface 1.
[Sysname-Vlan-interface1] ip address 1.1.0.1 255.255.255.0
name text
undo name
View
VLAN view
Default Level
2: System level
text: VLAN name, a string of 1 to 32 characters. Spaces and special characters can be included in the name.
Use the name command to configure a name for the current VLAN.
Use the undo name command to restore the default name of the VLAN.
The default name of a VLAN is its VLAN ID, VLAN 0001 for example.
You can use a RADIUS server to issue VLAN configuration to ports that have passed the authentication. Some servers can send IDs or names of the issued VLANs to the switch. When there are a large number of VLANs, you can use VLAN names rather than VLAN IDs to better locate VLANs.
# Configure the name of VLAN 2 as test vlan.
[Sysname] vlan 2
[Sysname-vlan2] name test vlan
shutdown
View
VLAN interface view
Default Level
2: System level
None
Use the shutdown command to shut down a VLAN interface.
Use the undo shutdown command to bring up a VLAN interface.
By default, a VLAN interface is up except when all ports in the VLAN are down.
You can use the undo shutdown command to bring up a VLAN interface after configuring related parameters and protocols for the VLAN interface. When a VLAN interface fails, you can shut down the interface with the shutdown command and then bring it up with the undo shutdown command. In this way, the interface may resume.
The state of any Ethernet port in a VLAN is independent of the VLAN interface state.
# Shut down VLAN interface 2 and then bring it up.
[Sysname-Vlan-interface2] shutdown
[Sysname-Vlan-interface2] undo shutdown
vlan { vlan-id1 [ to vlan-id2 ] | all }
undo vlan { vlan-id1 [ to vlan-id2 ] | all }
View
Default Level
2: System level
vlan-id1, vlan-id2: VLAN ID, in the range 1 to 4094.
vlan-id1 to vlan-id2: Specifies a VLAN range. A VLAN ID is in the range 1 to 4094.
all: Creates or removes all VLANs except reserved VLANs. The keyword is not supported when the maximum number of VLANs that can be created on a device is less than 4094.
Use the vlan vlan-id command to create a VLAN and enter its view or enter the view of an existing VLAN.
Use the vlan vlan-id1 to vlan-id2 command to create a range of VLANs specified by vlan-id1 to vlan-id2, except reserved VLANs.
Use the undo vlan command to remove the specified VLAN(s).
l As the default VLAN, VLAN 1 cannot be created or removed.
l You cannot create/remove reserved VLANs reserved for specific functions.
l You cannot use the undo vlan command to directly remove reserved VLANs, management VLANs, dynamic VLANs, VLANs configured with QoS policies, control VLANs configured for SmartLink, or remote probe VLANs configured for port mirroring. To remove these VLANs, you need to first remove related configurations.
Related commands: display vlan.
# Enter VLAN 2 view.
[Sysname] vlan 2
[Sysname-vlan2]
# Create VLAN 4 through VLAN 100.
[Sysname] vlan 4 to 100
Please wait............. Done.
View
Default Level
1: Monitor level
hybrid: Displays hybrid ports.
trunk: Displays trunk ports.
Use the display port command to display information about the hybrid or trunk ports on the device, including the port names, default VLAN IDs, and allowed VLAN IDs.
# Display information about the hybrid ports in the system.
<Sysname> display port hybrid
Interface PVID VLAN passing
GE1/0/4 100 Tagged: 1000, 1002, 1500, 1600-1611, 2000,
2555-2558, 3000, 4000
Untagged:1, 10, 15, 18, 20-30, 44, 55, 67, 100,
150-160, 200, 255, 286, 300-302
# Display information about the trunk ports in the system.
<Sysname> display port trunk
GE1/0/8 2 1-4, 6-100, 145, 177, 189-200, 244, 289, 400,
555, 600-611, 1000, 2006-2008
Table 1-3 display port command output description
Port name |
PVID |
Default VLAN ID of the port |
VLAN passing |
VLANs whose packets are allowed to pass through the port. |
Tagged |
VLANs whose packets are required to pass through the port tagged. |
Untagged |
VLANs whose packets are required to pass through the port untagged. |
port interface-list
undo port interface-list
View
VLAN view
Default Level
2: System level
interface interface-list: Specifies an Ethernet port list, in the format of interface-list = { interface-type interface-number [ to interface-type interface-number ] }&<1-10>, where &<1-10> indicates that you can specify up to 10 ports or port ranges.
Use the port command to assign the specified access port(s) to the current VLAN.
Use the undo port command to remove the specified access port(s) from the current VLAN.
By default, all ports are in VLAN 1.
Note that:
l This command is only applicable on access ports.
l All ports are access ports by default. However, you can manually configure the port type. For more information, refer to port link-type.
l This command not support the Layer-2 aggregate interface.
# Assign GigabitEthernet 1/0/1 through GigabitEthernet 1/0/3 to VLAN 2.
[Sysname] vlan 2
[Sysname-vlan2] port gigabitethernet 1/0/1 to gigabitethernet 1/0/3
port access vlan vlan-id
undo port access vlan
View
Ethernet interface view, Ethernet subinterface view, port group view, Layer-2 aggregate interface view
Default Level
2: System level
vlan-id: VLAN ID, in the range of 1 to 4094. Be sure that the VLAN specified by the VLAN ID already exists.
Use the port access vlan command to assign the current access port(s) to the specified VLAN.
Use the undo port access vlan command to restore the default.
By default, all access ports belong to VLAN 1.
You can assign an access port to only one VLAN. When doing that, note the following:
l In port group view, this command applies to all ports in the port group. For information about port groups, refer to Ethernet Interface Configuration in the Access Volume.
l In Layer-2 aggregate interface view, this command applies to the Layer-2 aggregate interface and all its member ports. After you perform the configuration, the system starts applying the configuration to the aggregate interface and its aggregation member ports. If the system fails to do that on the aggregate interface, it stops applying the configuration to the aggregation member ports. If it fails to do that on an aggregation member port, it simply skips the port and moves to the next port. For information about Layer-2 aggregate interfaces, refer to Link Aggregation Configuration in the Access Volume.
# Assign GigabitEthernet 1/0/1 to VLAN 3.
[Sysname] vlan 3
[Sysname-vlan3] quit
[Sysname-GigabitEthernet1/0/1] port access vlan 3
# Assign Layer-2 aggregate interface Bridge-aggregation 1 and its member ports to VLAN 3.
[Sysname] vlan 3
[Sysname-Bridge-Aggregation1] port access vlan 3
port hybrid pvid vlan vlan-id
undo port hybrid pvid
View
Ethernet interface view, port group view, Layer-2 aggregate interface view
Default Level
2: System level
Use the port hybrid pvid vlan command to configure the default VLAN ID of the hybrid port.
Use the undo port hybrid pvid command to restore the default.
By default, the default VLAN of a hybrid port is VLAN 1.
You can use a nonexistent VLAN as the default VLAN for a hybrid port. Removing the default VLAN of a hybrid port with the undo vlan command does not affect the setting of the default VLAN on the port.
l You are recommended to set the same default VLAN ID for the local and remote hybrid ports.
l After configuring the default VLAN for a hybrid port, you must use the port trunk permit vlan command to configure the hybrid port to allow packets from the default VLAN to pass through, so that the port can forward packets from the default VLAN.
Related commands: port link-type, port hybrid vlan.
# Configure VLAN 100 as the default VLAN of the hybrid port GigabitEthernet 1/0/1.
[Sysname] vlan 100
[Sysname-vlan100] quit
[Sysname-GigabitEthernet1/0/1] port link-type hybrid tagged 100
[Sysname-GigabitEthernet1/0/1] port hybrid pvid vlan 100
# Configure VLAN 100 as the default VLAN of the hybrid Layer-2 aggregate interface Bridge-aggregation 1.
[Sysname-Bridge-Aggregation1] port hybrid pvid vlan 100
undo port hybrid vlan vlan-id-list
View
Default Level
2: System level
vlan-id-list: VLANs that the hybrid ports will be assigned to. This argument is expressed in the format of [ vlan-id1 [ to vlan-id2 ] ]&<1-10>, where vlan-id ranges from 1 to 4094 and &<1-10> indicates that you can specify up to 10 VLAN IDs or VLAN ID ranges. Be sure that the specified VLANs already exist.
tagged: Configures the port(s) to send the packets of the specified VLAN(s) with the tags kept.
untagged: Configures the port to send the packets of the specified VLAN(s) with the tags removed.
Use the port hybrid vlan command to assign the current hybrid port(s) to the specified VLAN(s).
Use the undo port hybrid vlan command to remove the current hybrid port(s) from the specified VLAN(s).
By default, a hybrid port only allows packets from VLAN 1 to pass through untagged.
A hybrid port can carry multiple VLANs. If you execute the port hybrid vlan command multiple times, the VLANs the hybrid port carries are the set of VLANs specified by vlan-id-list in each execution.
Related commands: port link-type.
# Assign the hybrid port GigabitEthernet 1/0/1 to VLAN 2, VLAN 4, and VLAN 50 through VLAN 100, and configure GigabitEthernet 1/0/1 to send packets of these VLANs with tags kept.
[Sysname-GigabitEthernet1/0/1] port hybrid vlan 2 4 50 to 100 tagged
# Assign hybrid ports in port group 2 to VLAN 2, and configure these hybrid ports to send packets of VLAN 2 with VLAN tags removed.
[Sysname] vlan 2
[Sysname] port-group manual 2
[Sysname-port-group-manual-2] group-member gigabitethernet 1/0/1 to gigabitethernet 1/0/6
[Sysname-port-group-manual-2] port link-type hybrid
[Sysname-port-group-manual-2] port hybrid vlan 2 untagged
Configuring GigabitEthernet1/0/1... Done.
Configuring GigabitEthernet1/0/2... Done.
Configuring GigabitEthernet1/0/3... Done.
Configuring GigabitEthernet1/0/4... Done.
Configuring GigabitEthernet1/0/5... Done.
Configuring GigabitEthernet1/0/6... Done.
# Assign the hybrid Layer-2 aggregate interface Bridge-aggregation 1 and its member ports to VLAN 2, and configure them to send packets of VLAN 2 with tags removed.
[Sysname-Bridge-Aggregation1] port link-type hybrid
[Sysname-Bridge-Aggregation1] port hybrid vlan 2 untagged
Please wait... Done.
Note that GigabitEthernet1/0/2 and GigabitEthernet1/0/3 are the member ports of the aggregation group corresponding to Bridge-aggregation 1.
undo port link-type
View
Default Level
2: System level
access: Configures the link type of a port as access.
hybrid: Configures the link type of a port as hybrid.
trunk: Configures the link type of a port as trunk.
Use the port link-type command to configure the link type of a port.
Use the undo port link-type command to restore the default link type of a port.
By default, any port is an access port.
To change the link type of a port from trunk to hybrid or vice versa, you must set the link type to access first.
# Configure GigabitEthernet 1/0/1 as a trunk port.
# Configure all the ports in the manual port group group1 as hybrid ports.
[Sysname] port-group manual group1
[Sysname-port-group manual group1] group-member GigabitEthernet 1/0/0
[Sysname-port-group manual group1] group-member GigabitEthernet 1/0/1
[Sysname-port-group manual group1] port link-type hybrid
# Configure Layer-2 aggregate interface Bridge-aggregation 1 and its member ports as hybrid ports.
undo port trunk permit vlan { vlan-id-list | all }
View
Default Level
2: System level
vlan-id-list: VLANs that the trunk port(s) will be assigned to. This argument is expressed in the format of [vlan-id1 [ to vlan-id2 ] ]&<1-10>, where vlan-id ranges from 1 to 4094 and &<1-10> indicates that you can specify up to 10 VLAN IDs or VLAN ID ranges.
all: Permits all VLANs to pass through the trunk port(s). On GVRP-enabled trunk ports, you must configure the port trunk permit vlan all command to ensure that the traffic of all dynamically registered VLANs can pass through. However, When GVRP is disabled on a port, you are discouraged to configure the command on the port. This is to prevent users of unauthorized VLANs from accessing restricted resources through the port.
Use the port trunk permit vlan command to assign the current trunk port(s) to the specified VLAN(s).
Use the undo port trunk permit vlan command to remove the trunk port(s) from the specified VLANs.
By default, a trunk port allows only packets from VLAN 1 to pass through.
A trunk port can carry multiple VLANs. If you execute the port trunk permit vlan command multiple times, the VLANs the trunk port carries are the set of VLANs specified by vlan-id-list in each execution.
Note that on a trunk port, only traffic of the default VLAN can pass through untagged.
# Assign the trunk port GigabitEthernet 1/0/1 to VLAN 2, VLAN 4, and VLAN 50 through VLAN 100.
[Sysname-GigabitEthernet1/0/1] port trunk permit vlan 2 4 50 to 100
Please wait........... Done.
# Assign the trunk Layer-2 aggregate interface Bridge-aggregation 1 to VLAN 2, assuming that Bridge-aggregation 1 does not have member ports.
[Sysname-Bridge-Aggregation1] port trunk permit vlan 2
# Assign the trunk Layer-2 aggregate interface Bridge-aggregation 1 to VLAN 13 and VLAN 15. Among the member ports of the aggregation group corresponding to Bridge-aggregation 1, GigabitEthernet 1/0/2 is an access port, and GigabitEthernet 1/0/3 is a trunk port.
[Sysname-Bridge-Aggregation1] port trunk permit vlan 13 15
Error: Failed to configure on interface GigabitEthernet 1/0/2! This port is not a Trunk port!
Configuring GigabitEthernet 1/0/3... Done.
Among the output fields above, the message “Please wait... Done” indicates that the configuration on Bridge-aggregation 1 succeeded; “Error: Failed to configure on interface GigabitEthernet 1/0/2! This port is not a Trunk port!” indicates that the configuration failed on GigabitEthernet 1/0/2 because GigabitEthernet 1/0/2 was not a trunk port; “Configuring GigabitEthernet 1/0/3... Done” indicates that the configuration on GigabitEthernet 1/0/3 succeeded.
port trunk pvid vlan vlan-id
undo port trunk pvid
View
Default Level
2: System level
Use the port trunk pvid vlan command to configure the default VLAN ID for the trunk port.
Use the undo port trunk pvid command to restore the default.
By default, the default VLAN of a trunk port is VLAN 1.
You can use a nonexistent VLAN as the default VLAN for a trunk port. Removing the default VLAN of a trunk port with the undo vlan command does not affect the setting of the default VLAN on the port.
l The local and remote trunk ports must use the same default VLAN ID for the traffic of the default VLAN to be transmitted properly.
l After configuring the default VLAN for a trunk port, you must use the port trunk permit vlan command to configure the trunk port to allow packets from the default VLAN to pass through, so that the port can forward packets from the default VLAN.
Related commands: port link-type, port trunk permit vlan.
# Configure VLAN 100 as the default VLAN of the trunk port GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] port trunk pvid vlan 100
# Configure VLAN 100 as the default VLAN of the trunk Layer-2 aggregate interface Bridge-aggregation 1, assuming Bridge-aggregation 1 does not have member ports.
[Sysname-Bridge-Aggregation1] port trunk pvid vlan 100
# Configure VLAN 100 as the default VLAN of the trunk Layer-2 aggregate interface Bridge-aggregation 1. Among the member ports of the aggregation group corresponding to Bridge-aggregation 1, GigabitEthernet 1/0/2 is an access port and GigabitEthernet 1/0/3 is a trunk port.
The output above shows that the configuration on Bridge-aggregation 1 and the member port GigabitEthernet 1/0/3 succeeded; the configuration on GigabitEthernet 1/0/2 failed because GigabitEthernet 1/0/2 was not a trunk port.
