01-Ethernet Interface Commands
Chapters Download (180.04 KB)
Table of Contents
1 Ethernet Interface Configuration Commands
General Ethernet Interface Configuration Commands
loopback-detection control enable
loopback-detection interval-time
broadcast-suppression { ratio | pps max-pps | kbps max-bps }
undo broadcast-suppression
View
Ethernet interface view, port group view
Default Level
2: System level
ratio: Maximum percentage of broadcast traffic to the total transmission capability of an Ethernet interface, in the range 1 to 100. The smaller the ratio, the less broadcast traffic is allowed
pps max-pps: Specifies the maximum number of broadcast packets that can be forwarded on an Ethernet port per second (in pps, representing packets per second).
l For a Gigabit port, the value range is 1 to 1488100.
l For a 10-Gigabit port, the value range is 1 to 1488100.
kbps max-bps: Specifies the maximum number of broadcast bits that can be forwarded on an Ethernet port per second (in kbps, representing kilobits per second).
l For a Gigabit port, the value range is 1 to 1024000.
l For a 10-Gigabit port, the value range is 1 to 10240000..
Note that:
l When a suppression granularity larger than 1 is specified on the device, the value of the pps or kbps keyword should be no smaller than and an integral multiple of the granularity. The broadcast suppression threshold value configured through this keyword on an Ethernet interface may not be the one that actually takes effect. To display the actual broadcast suppression threshold value on an Ethernet interface, you can use the display interface command.
l When no suppression granularity is specified or the suppression granularity is set to 1, the value of the pps or kbps keyword should be no smaller than 1, and the broadcast suppression threshold value is the one that actually takes effect on the Ethernet interface.
Use the broadcast-suppression command to set a broadcast traffic threshold on one or multiple Ethernet ports.
Use the undo broadcast-suppression command to restore the default.
By default, broadcast traffic is not suppressed.
If you execute this command in Ethernet interface view, the configuration takes effect only on the current interface. If you execute this command in port-group view, the configuration takes effect on all the ports in the port group.
When broadcast traffic exceeds the broadcast traffic threshold, the system begins to discard broadcast packets until the broadcast traffic drops below the threshold to ensure operation of network services.
l If you set different suppression ratios in Ethernet interface view or port-group view for multiple times, the latest configuration takes effect.
l Do not use the broadcast-suppression command along with the storm-constrain command. Otherwise, the broadcast storm suppression ratio configured may get invalid.
# For Ethernet interface GigabitEthernet1/0/1, allow broadcast traffic equivalent to 20% of the total transmission capability of GigabitEthernet1/0/1 to pass.
[Sysname-GigabitEthernet1/0/1] broadcast-suppression 20
# Configure manual port group named group1 so that each port in the port group allows broadcast traffic equivalent to up to 20% of its total transmission capability to pass and suppresses excessive broadcast packets.
[Sysname] port-group manual group1
[Sysname-port-group manual group1] group-member gigabitethernet 1/0/2
[Sysname-port-group manual group1] group-member gigabitethernet 1/0/3
[Sysname-port-group manual group1] broadcast-suppression 20
View
Default Level
2: System level
text: Description of an Ethernet interface, a string of 1 to 80 characters. Currently, the device supports the following types of characters or symbols: standard English characters (numbers and case-sensitive letters), special English characters, spaces, and other characters or symbols that conform to the Unicode standard.
l A port description can be the mixture of English characters and other Unicode characters. The mixed description cannot exceed the specified length.
l To use a type of Unicode characters or symbols in a port description, you need to install the corresponding Input Method Editor (IME) and log in to the device through remote login software that supports this character type.
l Each Unicode character or symbol (non-English characters) takes the space of two regular characters. When the length of a description string reaches or exceeds the maximum line width on the terminal software, the software starts a new line, possibly breaking a Unicode character into two. As a result, garbled characters may be displayed at the end of a line.
Use the description command to set the description string of the current interface.
Use the undo description command to restore the default.
By default, the description of an interface is the interface name followed by the “interface” string, GigabitEthernet1/0/1 Interface for example.
Related commands: display interface.
# Configure the description string of interface GigabitEthernet1/0/1 as lanswitch-interface.
[Sysname-GigabitEthernet1/0/1] description lanswitch-interface
display brief interface [ interface-type [ interface-number ] ] [ | { begin | exclude | include } regular-expression ]
View
Default Level
1: Monitor level
interface-type: Type of a specified interface.
interface-number: Number of a specified interface.
|: Uses a regular expression to filter output information. For detailed description on regular expression, refer to Basic System Configuration in the System Volume.
begin: Displays the line that matches the regular expression and all the subsequent lines.
exclude: Displays the lines that do not match the regular expression.
include: Displays the lines that match the regular expression.
regular-expression: Regular expression, a string of 1 to 256 characters. Note that this argument is case-sensitive.
Use the display brief interface command to display brief interface information.
l If neither interface type nor interface number is specified, all interface information will be displayed.
l If only interface type is specified, then only information of this particular type of interface will be displayed.
l If both interface type and interface number are specified, then only information of the specified interface will be displayed.
Related commands: interface.
# Display the brief information of interfaces.
<Sysname> display brief interface
The brief information of interface(s) under route mode:
Interface Link Protocol-link Protocol type Main IP
Loop1 UP UP(spoofing) LOOP 2.2.2.1
NULL0 UP UP(spoofing) NULL --
Vlan1 UP UP ETHERNET 192.168.0.153
Vlan10 DOWN DOWN ETHERNET 1.1.1.1
Vlan100 ADM DOWN DOWN ETHERNET --
The brief information of interface(s) under bridge mode:
BAGG1 DOWN auto auto access 1
GE1/0/1 DOWN auto auto access 1
GE1/0/2 DOWN auto auto access 1
GE1/0/3 DOWN auto auto access 1
GE1/0/4 UP 1G(a) full(a) access 1
GE1/0/5 DOWN auto auto access 1
GE1/0/6 DOWN auto auto access 1
GE1/0/7 DOWN auto auto access 1
GE1/0/8 DOWN auto auto access 1
GE1/0/9 DOWN auto auto access 1
GE1/0/10 DOWN auto auto access 1
GE1/0/11 DOWN auto auto trunk 1
GE1/0/12 DOWN auto auto trunk 1
# Display the information of interfaces beginning with the string “spoof”.
<Sysname> display brief interface | begin spoof
Loop0 UP UP(spoofing) LOOP 5.5.5.5
Vlan999 UP UP ETHERNET 10.1.1.1
# Display the brief information of all UP interfaces.
<Sysname> display brief interface | include UP
Interface Link Speed Duplex Link-type PVID
GE1/0/7 UP 100M(a) full(a) trunk 303
GE1/0/9 UP 100M(a) full(a) access 999
# Display the brief information of all interfaces excluding Ethernet interfaces.
<Sysname> display brief interface | exclude Eth
Table 1-1 display brief interface command output description
Abbreviated interface name |
Link |
Interface physical link state, which can be up or down |
Protocol-link |
Interface protocol link state, which can be up or down |
Protocol type |
Interface protocol type |
Speed |
Interface rate, in bps |
Duplex |
Duplex mode, which can be half (half duplex), full (full duplex), or auto (auto-negotiation). |
PVID |
Default VLAN ID |
display interface [ interface-type [ interface-number ] ]
View
Default Level
1: Monitor level
Use the display interface command to display the current state of a specified interface and related information.
# Display the current state of Layer 2 interface GigabitEthernet1/0/1 and related information.
<Sysname> display interface gigabitethernet 1/0/1
GigabitEthernet1/0/1 current state: DOWN
IP Packet Frame Type: PKTFMT_ETHNT_2, Hardware Address: 00e0-fc00-5832
Description: GigabitEthernet1/0/1 Interface
Loopback is not set
Media type is twisted pair, Port hardware type is 1000_BASE_T
Flow-control is not enabled
The Maximum Frame Length is 10240
Broadcast MAX-ratio: 100%
Unicast MAX-ratio: 100%
Multicast MAX-ratio: 100%
PVID: 1
Mdi type: auto
Port link-type: access
Tagged VLAN ID : none
Untagged VLAN ID : 1
Port priority: 0
Peak value of input: 0 bytes/sec, at 00-00-00 00:00:00
Peak value of output: 0 bytes/sec, at 00-00-00 00:00:00
Last 300 seconds input: 0 packets/sec 0 bytes/sec -%
Last 300 seconds output: 0 packets/sec 0 bytes/sec -%
Input (total): 0 packets, 0 bytes
0 unicasts, 0 broadcasts, 0 multicasts
Input (normal): 0 packets, 0 bytes
Input: 0 input errors, 0 runts, 0 giants, 0 throttles
0 CRC, 0 frame, 0 overruns, 0 aborts
0 ignored, 0 parity errors
Output (normal): 0 packets, 0 bytes
Output: 0 output errors, 0 underruns, 0 buffer failures
0 lost carrier, 0 no carrier
Table 1-2 display interface command output description
GigabitEthernet1/0/1 current state |
Current physical link state of the Ethernet interface |
IP Packet Frame Type |
Frame type of the Ethernet interface |
Description of the interface |
Unknown-speed mode |
Unknown-speed mode, in which mode speed is negotiated between the current host and the peer. |
unknown-duplex mode |
Unknown-duplex mode, in which mode speed is negotiated between the current host and the peer. |
The Maximum Frame Length |
The maximum frame length allowed on an interface |
Broadcast MAX-ratio |
Broadcast storm suppression ratio (the maximum ratio of allowed number of broadcast packets to overall traffic through an interface) |
Unicast MAX-ratio |
Unicast storm suppression ratio (the maximum ratio of allowed number of unknown unicast packets to overall traffic over an interface) |
Multicast MAX-ratio |
Multicast storm suppression ratio (the maximum ratio of allowed number of multicast packets to overall traffic through an interface) |
PVID |
Default VLAN ID |
Mdi type |
Cable type |
Port link-type |
Interface link type, which could be access, trunk, and hybrid. |
Tagged VLAN ID |
VLANs whose packets are sent through the port with VLAN tag kept |
Untagged VLAN ID |
VLANs whose packets are sent through the port with VLAN tag stripped off |
Peak value of input |
Peak value of inbound traffic, in bytes/sec. |
Peak value of output |
Peak value of outbound traffic, in bytes/sec. |
Last 300 seconds input: 0 packets/sec 0 bytes/sec Last 300 seconds output: 0 packets/sec 0 bytes/sec |
Average rate of input and output traffic in the last 300 seconds, in pps and Bps |
Input (total): 0 packets, 0 bytes 0 unicasts, 0 broadcasts, 0 multicasts |
Packet statistics on the inbound direction of the interface, including the statistics of normal packets, and abnormal packets, in packets and bytes Number of unicast packets, broadcast packets, and multicast packets on the inbound direction of the interface |
Input (normal): 0 packets, 0 bytes 0 unicasts, 0 broadcasts, 0 multicasts |
Normal packet statistics on the inbound direction of the interface, including the statistics of normal packets, in packets and bytes Number of unicast packets, broadcast packets, and multicast packets on the inbound direction of the interface, |
input errors |
Input packets with errors |
runts |
Frames received that were shorter than 64 bytes, yet in correct formats, and contained valid CRCs |
giants |
Frames received that were longer than 1536 bytes (without VLAN tags) or 151540 bytes (with VLAN tags) |
throttles |
The number of times the receiver on the interface was disabled, possibly because of buffer or CPU overload |
CRC |
Total number of packets received that had a normal length, but contained checksum errors |
frame |
Total number of frames that contained checksum errors and a non-integer number of bytes |
overruns |
Number of times the receive rate of the interface exceeded the capacity of the input queue, causing packets to be discarded |
aborts |
Total number of illegal packets received, including: l Fragment frames: Frames that were shorter than 64 bytes (with an integral or non-integral length) and contained checksum errors l Jabber frames: Frames that were longer than 1536 or 1540 bytes and contained checksum errors (the frame lengths in bytes may or may not be integers) l Symbol error frames: Frames that contained at least one undefined symbol l Unknown operation code frames: Frames that were MAC control frames but not pause frames l Length error frames: Frames whose 802.3 length fields did not match the actual frame lengths (46 bytes to 1500 bytes) |
ignored |
Number of received packets ignored by the interface because the interface hardware ran low on internal buffers |
parity errors |
Total number of frames with parity errors |
Output (total): 0 packets, 0 bytes 0 unicasts, 0 broadcasts, 0 multicasts, 0 pauses |
Packet statistics on the outbound direction of the interface, including the statistics of normal packets, abnormal packets, and normal pause frames, in packets and bytes Number of unicast packets, broadcast packets, multicast packets, and pause frames on the outbound direction of the interface |
Output (normal): 0 packets,0 bytes 0 unicasts, 0 broadcasts, 0 multicasts, 0 pauses |
Normal packet statistics on the outbound direction of the interface, including the statistics of normal packets and pause frames, in packets and bytes Number of unicast packets, broadcast packets, multicast packets, and pause frames on the outbound direction of the interface |
output errors |
Output packets with errors |
underruns |
Number of times the transmit rate of the interface exceeded the capacity of the output queue, causing packets to be discarded. This is a very rare hardware-related problem. |
buffer failures |
Number of packets dropped because the interface ran low on output buffers |
aborts |
Number of packets that failed to be transmitted due to causes such as Ethernet collisions |
deferred |
Number of frames whose first transmission attempt was delayed, due to traffic on the network media, and that were successfully transmitted later |
collisions |
Number of times frames were delayed due to Ethernet collisions detected during the transmission |
late collisions |
Number of times frames were delayed due to the detection of collisions after the first 512 bits of the frames were already on the network |
lost carrier |
Number of times the carrier was lost during transmission. This counter applies to serial WAN interfaces. |
no carrier |
Number of times the carrier was not present in the transmission. This counter applies to serial WAN interfaces. |
display loopback-detection
View
Default Level
1: Monitor level
None
Use the display loopback-detection command to display loopback detection information on a port.
If loopback detection is already enabled, this command will also display the detection interval and information on the ports currently detected with a loopback.
# Display loopback detection information on a port.
<Sysname> display loopback-detection
Loopback-detection is running
Detection interval time is 30 seconds
No port is detected with loopback
display port combo
View
Default Level
1: Monitor level
None
Use the display port combo command to display the Combo ports of a device and the corresponding optical ports and electrical ports.
# Display the Combo ports of the device and the corresponding optical ports and electrical ports.
<Sysname> display port combo
Combo-group Active Inactive
1 GigabitEthernet1/0/47 GigabitEthernet1/0/49
2 GigabitEthernet1/0/48 GigabitEthernet1/0/50
Table 1-3 display port combo command output description
Combo-group |
Combo ports of the device, represented by Combo port number, which is generated by the system. |
Active |
Ports of the Combo ports that are active |
Inactive |
Ports of the Combo ports that are inactive |
As for the optical port and the electrical port of a Combo port, the one with the smaller port number is active by default. You can determine whether a port is an optical port or an electrical port by checking the “Media type is” field of the display interface command.
display port-group manual [ all | name port-group-name ]
View
Default Level
2: System level
all: Specifies all the manual port groups.
name port-group-name: Specifies the name of a manual port group, a string of 1 to 32 characters.
Use the display port-group manual command to display the information about a manual port group or all the manual port groups.
l If you provide the port-group-name argument, this command displays the details for a specified manual port group, including its name and the Ethernet interface ports included.
l If you provide the all keyword, this command displays the details for all manual port groups, including their names and the Ethernet interface ports included.
l Absence of parameters indicates that the names of all the port groups will be displayed.
# Display the names of all the port groups.
<Sysname> display port-group manual
The following manual port group exist(s):
group1 group2
# Display details of all the manual port groups.
<Sysname> display port-group manual all
Member of group1:
GigabitEthernet1/0/3 GigabitEthernet1/0/4 GigabitEthernet1/0/5
GigabitEthernet1/0/6 GigabitEthernet1/0/7 GigabitEthernet1/0/8
Member of group2:
None
# Display details of the port group named group1.
<Sysname> display port-group manual name group1
Member of group1:
Table 1-4 display port-group manual command output description
Member of group |
Member of the manual port group |
display storm-constrain [ broadcast | multicast | unicast ] [ interface interface-type interface-number ]
View
Default Level
1: Monitor level
broadcast: Displays the information about storm constrain for broadcast packets.
multicast: Displays the information about storm constrain for multicast packets.
unicast: Displays the information about storm constrain for unicast packets.
Use the display storm-constrain command to display the information about storm constrain.
If you provide no argument or keyword, this command displays the information about storm constrain for all types of packets on all the interfaces.
# Display the information about storm constrain for all types of packets on all the interfaces.
<Sysname> display storm-constrain
Abbreviation: BC - broadcast; MC - multicast; UC - unicast
Flow Statistic Interval: 5(second)
PortName Type LowerLimit UpperLimit CtrMode Status Trap Log SwiNum Unit
GE1/0/2 BC 1 2 N/A normal on on 0 pps
GE1/0/2 MC 1 5 N/A normal on on 0 pps
Table 1-5 display storm-constrain command output description
Flow Statistic Interval |
Interval for generating storm constrain statistics |
PortName |
Abbreviated port name |
StormType |
Type of the packets for which storm constrain function is enabled, which can be broadcast (for broadcast packets), multicast (for multicast packets), and unicast (for unicast packets). |
LowerLimit |
Lower threshold (in pps) |
UpperLimit |
Upper threshold (in pps) |
Ctr-mode |
Action to be taken when the upper threshold is reached, which can be block, shutdown, and N/A. |
Status |
Interface state, which can be normal (indicating the interface operates properly), control (indicating the interface is blocked or shut down). |
Trap |
State of trap messages sending. “on” indicates trap message sending is enabled; “off” indicates trap message sending is disabled. |
Log |
State of log sending. “on” indicates log sending is enabled; “off” indicates log sending is disabled. |
Swi-num |
Number of the forwarding state switching. This field is numbered modulo 65,535. |
Unit |
Threshold unit |
duplex { auto | full | half }
undo duplex
View
Default Level
2: System level
auto: Indicates that the interface is in auto-negotiation state.
full: Indicates that the interface is in full-duplex state.
half: Indicates that the interface is in half-duplex state. The optical interface of a Combo port and the electrical interfaces of Ethernet ports whose port rate is configured as 1000 Mbps do not support the half keyword.
Use the duplex command to configure the duplex mode for an Ethernet interface.
Use the undo duplex command to restore the duplex mode for an Ethernet interface to the default.
By default, the duplex mode for an Ethernet interface is auto.
Related commands: speed.
# Configure the interface GigabitEthernet1/0/1 to work in full-duplex mode.
[Sysname-GigabitEthernet1/0/1] duplex full
10-Gigabit Ethernet ports do not support the duplex command.
flow-control
undo flow-control
View
Default Level
2: System level
None
Use the flow-control command to enable flow control on an Ethernet interface.
Use the undo flow-control command to disable flow control on an Ethernet interface.
By default, flow control on an Ethernet interface is disabled.
The flow control function takes effect on the local Ethernet interface only when it is enabled on both the local and peer devices.
# Enable flow control on interface GigabitEthernet1/0/1.
[Sysname-GigabitEthernet1/0/1] flow-control
flow-interval interval
undo flow-interval
View
Default Level
2: System level
interval: Interval at which the interface collects statistics. It ranges from 5 to 300 seconds and must be a multiple of 5. The default value is 300 seconds.
Use the flow-interval command to configure the time interval for collecting interface statistics.
Use the undo flow-interval command to restore the default interval.
# Set the time interval for collecting interface statistics to 100 seconds.
[Sysname-GigabitEthernet1/0/1] flow-interval 100
group-member interface-list
undo group-member interface-list
View
Port group view
Default Level
2: System level
interface-list: Ethernet interface list, in the form of interface-type interface-number [ to interface-type interface-number ] &<1-10>, where &<1-10> indicates that you can specify up to 10 port or port ranges.
Use the group-member command to assign an Ethernet interface or a list of Ethernet interfaces to the manual port group.
Use the undo group-member command to remove an Ethernet interface or a list of Ethernet interfaces from the manual port group.
By default, there is no Ethernet interface in a manual port group.
# Add interface GigabitEthernet1/0/1 to the manual port group named group1.
[Sysname-port-group-manual-group1] group-member gigabitethernet 1/0/1
View
Default Level
2: System level
None
Use the interface command to enter interface view.
# Enter GigabitEthernet1/0/1 interface view (assuming that the interface is a Ethernet interface).
[Sysname- GigabitEthernet1/0/1]
jumboframe enable
undo jumboframe enable
View
Default Level
2: System level
None
Use the jumboframe enable command to allow frames no longer than 9216 bytes to pass through an Ethernet interface.
Use the undo jumboframe enable command to prevent frames longer than 1536 bytes from passing through an Ethernet interface.
By default, the device allows jumbo frames with the length of 9216 bytes to pass through all Ethernet interfaces.
# Enable jumbo frames to pass through all the Ethernet interfaces.
[Sysname] jumboframe enable
View
Default Level
2: System level
external: Enables external loopback testing on an Ethernet interface.
internal: Enables internal loopback testing on an Ethernet interface.
Use the loopback command to enable Ethernet interface loopback testing.
By default, Ethernet interface loopback testing is disabled.
l Ethernet interface loopback testing should be enabled while testing certain functionalities, such as during the initial identification of any network failure.
l While enabled, Ethernet interface loopback testing will work in full-duplex mode. The interface will return to its original state upon completion of the loopback testing.
# Enable loopback testing on GigabitEthernet1/0/1.
[Sysname-GigabitEthernet1/0/1] loopback internal
undo loopback-detection control enable
View
Default Level
2: System level
None
Use the loopback-detection control enable command to enable loopback detection for a Trunk port or Hybrid port.
Use the undo loopback-detection control enable command to restore the default.
By default, loopback detection for a Trunk port or Hybrid port is disabled.
l When the loopback detection is enabled, if a port has been detected with loopback, it will be shut down. A Trap message will be sent to the terminal and the corresponding MAC address forwarding entries will be deleted.
l When the loopback detection is disabled, if a port has been detected with loopback, a Trap message will be sent to the terminal. The port is still working properly.
Note that this command is inapplicable to an Access port as its loopback detection is enabled by default.
# Enable loopback detection for the trunk port GigabitEthernet1/0/1.
[Sysname] loopback-detection enable
[Sysname-GigabitEthernet1/0/1] loopback-detection enable
[Sysname-GigabitEthernet1/0/1] loopback-detection control enable
undo loopback-detection enable
View
System view, Ethernet interface view
Default Level
2: System level
None
Use the loopback-detection enable command to enable loopback detection globally or on a specified port.
Use the undo loopback-detection enable command to disable loopback detection globally or on a specified port.
By default, loopback detection is disabled for an Access, Trunk, or Hybrid port.
l If an Access port has been detected with loopback, the device puts the port in control mode. In this mode, inbound packets on the port are all discarded, while outbound packets on the port are forwarded normally. Meanwhile, the device sends trap messages to the terminal, and deletes the corresponding MAC address forwarding entry.
l If a Trunk port or Hybrid port has been detected with loopback, the device sends trap messages and log information to the terminal. If loopback detection control is also enabled on the port, the device operates on the port according to the pre-configured loopback detection actions, sends trap messages and log information to the terminals, and deletes the corresponding MAC address forwarding entry.
Related commands: loopback-detection control enable.
l Loopback detection on a given port is enabled only after the loopback-detection enable command has been configured in both system view and interface view of the port.
l Loopback detection on all ports will be disabled after the configuration of the undo loopback-detection enable command in system view.
# Enable loopback detection on the interface GigabitEthernet1/0/1.
loopback-detection interval-time time
undo loopback-detection interval-time
View
Default Level
2: System level
time: Time interval for performing port loopback detection, in the range 5 to 300 (in seconds).
Use the loopback-detection interval-time command to configure time interval for performing port loopback detection.
Use the undo loopback-detection interval-time command to restore the default time interval for port loopback detection, which is 30 seconds.
Related commands: display loopback-detection.
# Set the time interval for performing port loopback detection to 10 seconds.
[Sysname] loopback-detection interval-time 10
loopback-detection per-vlan enable
undo loopback-detection per-vlan enable
View
Default Level
2: System level
None
Use the loopback-detection per-vlan enable command to enable loopback detection in all VLANs with Trunk ports or Hybrid ports.
Use the undo loopback-detection per-vlan enable command to enable loopback detection in the default VLAN with Trunk ports or Hybrid ports.
By default, loopback detection is only enabled in the default VLAN(s) with Trunk ports or Hybrid ports.
Note that the loopback-detection per-vlan enable command is not applicable to Access ports.
# Enable loopback detection in all the VLANs to which the Hybrid port GigabitEthernet1/0/1 belongs.
[Sysname-GigabitEthernet1/0/1] loopback-detection per-vlan enable
mdi { across | auto | normal }
undo mdi
View
Default Level
2: System level
across: Specifies the MDI mode as across, that is,the Ethernet interface recognizes crossover cables..
auto: Specifies the MDI mode as auto, that is, the Ethernet interface determines the cable type through negotiation.
normal: Specifies the MDI mode as normal, the Ethernet interface recognizes straight-through cables.
Use the mdi command to configure the MDI mode for an Ethernet interface.
Use the undo mdi command to restore the system default.
By default, the MDI mode of an Ethernet interface is auto, that is, the Ethernet interface determines the physical pin roles (transmit or receive) through negotiation.
The command is not applicable to Combo ports operating as optical interfaces or 10-Gigabit Ethernet ports.
# Set the MDI mode of GigabitEthernet1/0/1 to across.
[Sysname-GigabitEthernet1/0/1] mdi across
multicast-suppression { ratio | pps max-pps | kbps max-bps }
undo multicast-suppression
View
Default Level
2: System level
ratio: Maximum percentage of multicast traffic to the total transmission capability of an Ethernet interface, in the range 1 to 100. The smaller the ratio is, the less multicast traffic is allowed to pass through the interface.
pps max-pps: Specifies the maximum number of multicast packets allowed on an Ethernet port per second ( in pps, representing packets per second).
kbps max-bps: Specifies the maximum number of multicast bits that can be forwarded on an Ethernet port per second (in kbps, representing kilobits per second).
Note that:
l When a suppression granularity larger than 1 is specified on the device, the value of the pps or kbps keyword should be no smaller than and an integral multiple of the granularity. The multicast suppression threshold value configured through this keyword on an Ethernet interface may not be the one that actually takes effect. To display the actual multicast suppression threshold value on an Ethernet interface, you can use the display interface command.
l When no suppression granularity is specified or the suppression granularity is set to 1, the value of the pps or kbps keyword should be no smaller than 1, and the multicast suppression threshold value is the one that actually takes effect on the Ethernet interface.
Use the multicast-suppression command to configure multicast storm suppression ratio on an interface.
Use the undo multicast-suppression command to restore the default multicast suppression ratio.
By default, multicast traffic is not suppressed.
If you execute this command in Ethernet interface/subinterface view, the configurations take effect only on the current interface/subinterface. If you execute this command in port-group view, the configurations take effect on all ports in the port group.
Note that when multicast traffic exceeds the maximum value configured, the system will discard the extra packets so that the multicast traffic ratio can drop below the limit to ensure that the network functions properly.
l Do not use the multicast-suppression command along with the storm-constrain command. Otherwise, the multicast storm suppression ratio configured may get invalid.
# For Ethernet interface GigabitEthernet1/0/1, allow multicast traffic equivalent to 20% of the total transmission capability of GigabitEthernet1/0/1 to pass.
[Sysname-GigabitEthernet1/0/1] multicast-suppression 20
# Configure manual port group named group1 so that each port in the port group allows multicast traffic equivalent to up to 20% of its total transmission capability to pass and suppresses excessive multicast packets.
[Sysname-port-group manual group1] multicast-suppression 20
port-group manual port-group-name
undo port-group manual port-group-name
View
Default Level
2: System level
port-group-name: Specifies name of a manual port group, a string of 1 to 32 characters.
Use the port-group manual command to create a manual port group and enter manual port group view.
Use the undo port-group manual command to remove a manual port group.
By default, no manual port group is created.
# Create a manual port group named group1.
port auto-power-down
undo port auto-power-down
View
Default Level
2: System level
None
Use the port auto-power-down command to enable auto power down on an Ethernet interface.
Use the undo port auto-power-down to restore the default.
By default, auto power down is not enabled on an Ethernet interface.
For an S5810 series Ethernet switch, the configuration of auto power down does not take effect on GigabitEthernet 1/0/45 through GigabitEthernet 1/0/48.
# Enable auto power down on GigabitEthernet1/0/1.
[Sysname-GigabitEthernet1/0/1] port auto-power-down
# Enable auto power down on all member ports of manual port group group1.
[Sysname-port-group-manual-group1] group-member gigabitethernet 1/0/2
[Sysname-port-group-manual-group1] group-member gigabitethernet 1/0/3
[Sysname-port-group-manual-group1] port auto-power-down
port bridge enable
undo port bridge enable
View
Default Level
2: System level
None
Use the port bridge enable command to enable bridging on an Ethernet port. When bridging is enabled on an Ethernet port, the device forwards packets received on the interface through the receiving interface itself when both the following conditions are met:
l The destination MAC addresses of the received packets are already in the MAC address table of the device.
l The egress interfaces in the corresponding MAC address table entries are the receiving interface.
Use the undo port bridge enable command to disable bridging on an Ethernet interface.
By default, bridging is not enabled on an Ethernet interface.
# Enable bridging on Ethernet interface GigabitEthernet1/0/1.
[Sysname-GigabitEthernet1/0/1] port bridge enable
reset counters interface [ interface-type [ interface-number ] ]
View
Default Level
2: System level
interface-type: Interface type.
interface-number: Interface number.
Use the reset counters interface command to clear the statistics of an interface/subinterface.
Before sampling network traffic within a specific period of time on an interface, you need to clear the existing statistics.
l If neither interface type nor interface number is specified, this command clears the statistics of all the interfaces.
l If only the interface type is specified, this command clears the statistics of the interfaces that are of the interface type specified.
l If both the interface type and interface/subinterface number are specified, this command clears the statistics of the specified interface/subinterface.
# Clear the statistics of GigabitEthernet1/0/1.
<Sysname> reset counters interface gigabitethernet 1/0/1
shutdown
View
Default Level
2: System level
None
Use the shutdown command to shut down an Ethernet interface.
Use the undo shutdown command to bring up an Ethernet interface.
By default, an Ethernet interface is in the up state.
In certain circumstances, modification to the interface parameters does not immediately take effect, and therefore, you need to shut down the relative interface to make the modification work.
Note that in case of a double Combo port, only one interface (either the optical port or the electrical port) is active at a time. That is, once the optical port is active (after you execute the undo shutdown command), the electrical port will be inactive automatically, and vice versa.
# Shut down interface GigabitEthernet1/0/1.
[Sysname-GigabitEthernet1/0/1] shutdown
# Bring up interface GigabitEthernet1/0/1.
[Sysname-GigabitEthernet1/0/1] undo shutdown
speed { 10 | 100 | 1000 | auto }
undo speed
View
Default Level
2: System level
10: Specifies the interface rate as 10 Mbps. The optical interface of a Combo port does not support the 10 keyword.
100: Specifies the interface rate as 100 Mbps.
1000: Specifies the interface rate as 1,000 Mbps.
auto: Specifies to determine the interface rate through auto-negotiation.
Use the speed command to configure Ethernet interface data rate.
Use the undo speed command to restore Ethernet interface data rate.
The default, the rate of an Ethernet interface is determined through auto negotiation.
Related commands: duplex, speed auto.
# Configure the interface rate as 100 Mbps for interface GigabitEthernet1/0/1.
[Sysname-GigabitEthernet1/0/1] speed 100
10-Gigabit Ethernet ports do not support the speed command.
storm-constrain { broadcast | multicast | unicast } { pps | kbps | ratio } max-values min-values
undo storm-constrain { all | broadcast | multicast | unicast }
View
Default Level
2: System level
all: Disables the storm constrain function for all types of packets (that is, unicast packets, multicast packets, and broadcast packets).
broadcast: Enables/Disables the storm constrain function for broadcast packets.
multicast: Enables/Disables the storm constrain function for multicast packets.
unicast: Enables/Disables the storm constrain function for unicast packets.
pps: Specifies the storm constrain threshold in packets.
kbps: Specifies the storm constrain threshold in kilobits per second (kbps).
ratio: Specifies the storm constrain threshold in percentage of the received packets to the whole transmission capacity.
max-values: Upper threshold to be set, in pps, kbps, or percentage.
min-values: Lower threshold to be set, in pps, kbps, or percentage.
Use the storm-constrain command to enable the storm constrain function for specific type of packets and set the upper and lower thresholds.
Use the undo storm-constrain command to disable the storm constrain function for specific type of packets.
By default, the storm constrain function is not enabled.
l Do not use the storm-constrain command along with the unicast-suppression command, the multicast-suppression command, or the broadcast-suppression command. Otherwise, traffics may be suppressed in an unpredictable way.
l An upper threshold cannot be less than the corresponding lower threshold. Besides, do not configure the two thresholds as the same value.
# Enable the storm constrain function for unicast packets on GigabitEthernet1/0/1, setting the upper and lower threshold to 200 pps and 150 pps.
[Sysname-GigabitEthernet1/0/1] storm-constrain unicast pps 200 150
undo storm-constrain control
View
Default Level
2: System level
block: Blocks the traffic of a specific type on a port when the traffic detected exceeds the upper threshold.
shutdown: Shuts down a port when a type of traffic exceeds the corresponding upper threshold. A port shut down by the storm constrain function stops forwarding all types of packets.
Use the storm-constrain control command to set the action to be taken when a type of traffic exceeds the corresponding upper threshold.
Use the undo storm-constrain control command to restore the default.
By default, no action is taken when a type of traffic exceeds the corresponding threshold.
# Configure to block interface GigabitEthernet1/0/1 when a type of traffic reaching it exceeds the corresponding upper threshold.
[Sysname-GigabitEthernet1/0/1] storm-constrain control block
storm-constrain enable log
undo storm-constrain enable log
View
Default Level
2: System level
None
Use the storm-constrain enable log command to enable log sending. With log sending enabled, the system sends log when traffic reaching a port exceeds the corresponding threshold or the traffic drops down below the lower threshold after exceeding the upper threshold.
Use the undo storm-constrain enable log command to disable log sending.
By default, log sending is enabled.
# Disable log sending for GigabitEthernet1/0/1.
[Sysname-GigabitEthernet1/0/1] undo storm-constrain enable log
storm-constrain enable trap
undo storm-constrain enable trap
View
Default Level
2: System level
None
Use the storm-constrain enable trap command to enable trap message sending. With trap message sending enabled, the system sends trap messages when traffic reaching a port exceeds the corresponding threshold or the traffic drops down below the lower threshold after exceeding the upper threshold.
Use the undo storm-constrain enable trap command to disable trap message sending.
By default, trap message sending is enabled.
# Disable trap message sending for GigabitEthernet1/0/1.
[Sysname-GigabitEthernet1/0/1] undo storm-constrain enable trap
storm-constrain interval seconds
undo storm-constrain interval
View
Default Level
2: System level
seconds: Interval for generating traffic statistics, in the range 1 to 300 (in seconds).
Use the storm-constrain interval command to set the interval for generating traffic statistics.
Use the undo storm-constrain interval command to restore the default.
By default, the interval for generating traffic statistics is 10 seconds.
l The interval set by the storm-constrain interval command is specifically for the storm constrain function. It is different form that set by the flow-interval command.
l For network stability consideration, configure the interval for generating traffic statistics to a value that is not shorter than the default.
# Set the interval for generating traffic statistics to 60 seconds.
[Sysname] storm-constrain interval 60
unicast-suppression { ratio | pps max-pps | kbps max-bps }
undo unicast-suppression
View
Default Level
2: System level
ratio: Maximum percentage of unicast traffic to the total transmission capability of an Ethernet interface, in the range of 1 to 100. The smaller the ratio is, the less unicast traffic is allowed through the interface.
Note that:.
l When a suppression granularity larger than 1 is specified on the device, the value of the pps or kbps keyword should be no smaller than and an integral multiple of the granularity. The unicast suppression threshold value configured through this keyword on an Ethernet interface may not be the one that actually takes effect. To display the actual unicast suppression threshold value on an Ethernet interface, you can use the display interface command.
l When no suppression granularity is specified or the suppression granularity is set to 1, the value of the pps or kbps keyword should be no smaller than 1, and the unicast suppression threshold value is the one that actually takes effect on the Ethernet interface.
Use the unicast-suppression command to configure a unicast storm suppression ratio.
Use the undo unicast-suppression command to restore the default unicast suppression ratio.
By default, unicast traffic is not suppressed.
If you execute this command in Ethernet interface view, the configurations take effect only on the current interface. If you execute this command in port-group view, the configurations take effect on all ports in the port group
Note that when unicast traffic exceeds the maximum value configured, the system will discard the extra packets so that the unknown unicast traffic ratio can drop below the limit to ensure that the network functions properly.
l If you set different suppression ratios in Ethernet interface view or port-group view repeatedly, the latest configuration takes effect.
l Do not use the unicast-suppression command along with the storm-constrain command. Otherwise, the unicast storm suppression ratio configured may get invalid.
# For Ethernet interface GigabitEthernet1/0/1, allow unknown unicast traffic equivalent to 20% of the total transmission capability of the interface to pass and suppress the excessive unknown unicast packets.
[Sysname-GigabitEthernet1/0/1] unicast-suppression 20
# Configure manual port group named group1 so that each port in the port group allows unicast traffic equivalent to up to 20% of its total transmission capability to pass and suppresses excessive unicast packets..
[Sysname-port-group manual group1] unicast-suppression 20
virtual-cable-test
View
Default Level
2: System level
None
Use the virtual-cable-test command to test the cable connected to the Ethernet interface once and to display the testing result. The tested items include:
Note that:
l When the cable is functioning properly, the cable length in the test result represents the total cable length;
l When the cable is not functioning properly, the cable length in the test result represents the length from the current interface to the failed position.
l 10-Gigabit ports and Combo ports operating as optical interfaces do not support this command.
l The test result is for your information only. The maximum error in the tested cable length is 5 m. A hyphen “-” indicates that the corresponding test item is not supported.
# Enable the virtual cable test for the interface GigabitEthernet1/0/1.
[Sysname-GigabitEthernet1/0/1] virtual-cable-test
Cable status: normal, 1 metres
Pair Impedance mismatch: -
Pair skew: - ns
Pair swap: -
Pair polarity: -
Insertion loss: - db
Return loss: - db
Near-end crosstalk: - db
