01-Access Volume
09-Monitor Link Commands
Chapters Download  (120.5 KB)
1  Monitor Link Configuration Commands
display monitor-link group
display monitor-link group { group-id | all }
View
Default Level
1: Monitor level
group-id: Monitor link group ID, in the range 1 to 25.
all: Specifies all monitor link groups.
Use the display monitor-link group command to display information about the specified or all smart link groups.
# Display information about monitor link group 1.
<Sysname> display monitor-link group 1
Monitor link group 1 information:
  Group status: DOWN
  Last-up-time: 16:37:20 2006/4/21
  Last-down-time: 16:38:26 2006/4/21
  Member                   Role      Status
  GigabitEthernet1/0/1     UPLINK    DOWN
  GigabitEthernet1/0/2     DOWNLINK  DOWN
Table 1-1 display monitor-link group command output description
Group status
Monitor link group state, which can be up or down
Last-up-time
Last time when the monitor link group was up
Last-down-time
Last time when the monitor link group was down
Member
Member ports of the monitor link group
Role
Port role, which can be uplink or downlink
Status
Member link state, which can be up or down
monitor-link group
monitor-link group group-id
undo monitor-link group group-id
View
Default Level
2: System level
Use the monitor-link group command to create a monitor link group and enter monitor link group view. If the specified monitor link group already exists, you enter monitor link group view directly.
Use the undo monitor-link group command to remove a monitor link group.
Related commands: port monitor-link group, port.
# Create monitor link group 1.
[Sysname] monitor-link group 1
[Sysname-mtlk-group1]
port
port interface-type interface-number { uplink | downlink }
undo port interface-type interface-number
View
Monitor link group view
Default Level
2: System level
interface-type interface-number: Port type and port number.
uplink: Specifies an uplink port.
downlink: Specifies a downlink port.
Use the port command to assign a port to the monitor link group.
Use the undo port command to remove a port from the monitor link group.
l          Both Ethernet ports and Layer-2 aggregate interfaces can be assigned to a monitor link group.
l          A port can be assigned to only one monitor link group.
l          Alternatively, you can assign a port to a monitor link group with the port monitor-link group command in Ethernet interface view or Layer-2 aggregate interface view.
Related commands: port monitor-link group.
# Configure member ports for monitor link group 1.
[Sysname-mtlk-group1] port gigabitethernet 1/0/1 uplink
[Sysname-mtlk-group1] port gigabitethernet 1/0/2 downlink
port monitor-link group group-id { uplink | downlink }
undo port monitor-link group group-id
View
Ethernet interface view, Layer-2 aggregate interface view
Default Level
2: System level
Use the port monitor-link group command to assign the port to the specified monitor link group.
Use the undo port monitor-link group command to remove the port from the specified monitor link group.
l          Alternatively, you can assign a port to a monitor link group with the port command in monitor link group view.
Related commands: port.
# Configure GigabitEthernet 1/0/1 as an uplink port of monitor link group 1.
[Sysname-mtlk-group1] quit
[Sysname-GigabitEthernet1/0/1] port monitor-link group 1 uplink
H3C reserves the right to modify its collaterals without any prior notice. For the latest information of the collaterals, please consult H3C sales or call 400 hotline.
