01-Access Volume
06-LLDP Commands
Chapters Download  (107.47 KB)
06-LLDP Commands
1  LLDP Configuration Commands
display lldp local-information
View
Default level
1: Monitor level
global: Displays the global LLDP information to be transmitted.
interface interface-type interface-number: Displays the LLDP information to be sent out the interface specified by its type and number.
Use the display lldp local-information command to display the global LLDP information to be transmitted, which will be contained in the LLDP TLVs and sent to neighbor devices.
If no keyword or argument is specified, this command displays all the LLDP information to be sent, including the global LLDP information and the LLDP information about the LLDP-enabled ports in the up state.
# Display all the LLDP information to be sent.
<Sysname> display lldp local-information
  Chassis ID         : 00e0-fc00-5600
  System name        : H3C
  System description : H3C Comware Platform Software
  System capabilities supported : Bridge,Router
  System capabilities enabled   : Bridge,Router
  MED information
  Device class: Connectivity device
  HardwareRev               : REV.A
  FirmwareRev               : 109
  SoftwareRev               : 5.20 Alpha 2101
  SerialNum                 : NONE
  Manufacturer name         : H3C
  Model name                : H3C Comware
  Asset tracking identifier : Unknown
LLDP local-information of port 1[GigabitEthernet1/0/1]:
  Port ID subtype  : Interface name
  Port ID          : GigabitEthernet1/0/1
  Port description : GigabitEthernet1/0/1 Interface
  Management address type           : ipv4
  Management address                : 192.168.1.11
  Management address interface ID   : 54
  Management address OID            : 0
  Port VLAN ID(PVID): 1
  Port and protocol VLAN ID(PPVID) : 1
  Port and protocol VLAN supported : Yes
  Port and protocol VLAN enabled   : No
  VLAN name of VLAN 1: VLAN 0001
  Auto-negotiation enabled   : Yes
  OperMau                    : speed(1000)/duplex(Full)
  PoE supported: No
  Link aggregation enabled   : No
  Aggregation port ID        : 0
  Maximum frame Size: 1536
  MED information
  Media policy type        : Unknown
  Unknown Policy           : Yes
  VLAN tagged              : No
  Media policy VlanID      : 0
  Media policy L2 priority : 0
  Media policy Dscp        : 0
Table 1-1 display lldp local-information command output description
The global LLDP information to be sent
Chassis ID
ID that identifies the LLDP sending device, which can be a MAC address, a network address, an interface or some other value depending on the chassis type.
System name
System name
System description
System description
Supported capabilities, which can be:
l      Bridge, indicating switching
l      Router, indicating routing
Currently enabled capabilities, which can be:
l      Bridge, indicating switching is currently enabled.
l      Router, indicating routing is currently enabled.
MED information
MED information
Device class
Device type, which can be:
l      Connectivity device, indicating an intermediate device.
l      ClassⅠ, indicating a normal terminal device. All terminal devices that are LLDP-enabled are of this type.
l      Class Ⅱ, indicating a media terminal device. A device of this type is media-capable. That is, besides the capabilities of a normal terminal device, it also supports media streams.
l      Class Ⅲ, indicating a communication terminal device. A device of this type supports IP communication systems of end user. A device of this type supports all the capabilities of a normal terminal device and a media terminal device and can be used directly by end users.
HardwareRev
Hardware version
FirmwareRev
Firmware version
SoftwareRev
Software version
SerialNum
Serial number
Manufacturer name
Device manufacturer
Model name
Device model
Asset tracking ID
LLDP information to be sent out port 1
Port ID subtype
Port ID type, which can be MAC address or interface name
Port ID
Port ID, the value of which depends on the port ID type
Port description
Port description
Management address
Management address
Type of the interface identified by the management address
ID of the interface identified by the management address
Management address object ID
Port VLAN ID(PVID)
Port VLAN ID
Port protocol VLAN ID
Indicates whether protocol VLAN is supported on the port.
Indicates whether protocol VLAN is enabled on the port.
VLAN name of VLAN 1
Name of VLAN 1
Indicates whether auto-negotiation is supported on the port.
State of auto-negotiation
OperMau
Current speed and duplex state of the port
PoE supported
Indicates whether PoE is supported on the port.
Indicates whether or not link aggregation is supported.
Indicates whether or not link aggregation is enabled.
Aggregation port ID
Aggregation group ID, which is 0 if link aggregation is not enabled.
Maximum frame Size
Maximum frame size supported
MED information
MED LLDP information
Media policy type
Media policy type, which can be:
l      unknown
l      voice
l      voiceSignaling
l      guestVoice
l      guestVoiceSignaling
l      softPhoneVoice
l      videoconferencing
l      streamingVideo
l      videoSignaling
Unknown Policy
Indicates whether or not the media policy is unknown.
VLAN tagged
Indicates whether packets of the media VLAN are tagged.
Media Policy VlanID
ID of the media VLAN
Media Policy L2 priority
Layer 2 priority
Media Policy Dscp
DSCP precedence
Location format
Location information format, which can be:
l      Invalid, indicating the format of the location information is invalid.
l      Coordinate-based LCI, indicating the location information is coordinate-based.
l      Civic Address LCI, indicating normal address information.
l      ECS ELIN, indicating a telephone number for urgencies.
Location Information
display lldp neighbor-information
display lldp neighbor-information [ interface interface-type interface-number ] [ brief ]
View
Default level
1: Monitor level
interface interface-type interface-number: Specifies a port by its type and number.
brief: Displays the received LLDP information in brief.
Use the display lldp neighbor-information command to display the received LLDP information about the neighboring devices received through a port.
With no keyword/argument specified, this command displays the LLDP information received through all the ports.
# Display the LLDP information received through all the ports.
<Sysname> display lldp neighbor-information
LLDP neighbor-information of port 1[GigabitEthernet1/0/1]:
  Neighbor index   : 1
  Update time      : 0 days,0 hours,1 minutes,1 seconds
  Chassis type     : MAC address
  Chassis ID       : 000f-0055-0002
  Port ID type     : Interface name
  System name        : H3C
  System capabilities supported : Repeater,Bridge,Router
  System capabilities enabled   : Repeater,Bridge,Router
  Management address                : 192.168.1.55
  Management address interface ID   : Unknown
  Power port class          : PD
  PSE power supported       : No
  PSE power enabled         : No
  PSE pairs control ability : No
  Power pairs               : Signal
  Port power classification : Class 0
Table 1-2 display lldp neighbor-information command output description
LLDP information received through port 1
Neighbor index
Neighbor index
Update time
Time when the LLDP information about a neighboring device is latest updated.
Chassis type
Chassis information, which can be:
l      Chassis component
l      Interface alias
l      Port component
l      MAC address
l      Network address
l      Interface name
l      Locally assigned (indicating the local configuration)
Chassis ID
Port ID type
Port information, which can be:
l      Interface alias
l      Port component
l      MAC address
l      Network Address
l      Interface name
l      Agent circuit ID
Port ID
Port description
Port description
System name
System name of the neighboring device
System description
System description of the neighboring device
Capabilities supported on the neighboring device, which can be:
l      Repeater, indicating forwarding
Capabilities currently enabled on the neighboring device, which can be:
l      Repeater, indicating forwarding is currently enabled.
Management address
Management address
Port VLAN ID
Port VLAN ID
Indicates whether protocol VLAN is supported.
Indicates whether protocol VLAN is enabled.
VLAN name of VLAN 1
Name of VLAN 1
Indicates whether auto-negotiation is supported.
OperMau
Power port class
PoE device type, which can be:
l      PSE, indicating a power supply device.
l      PD, indicating a powered device.
PSE power supported
Indicates whether or not the device can operate as a PSE.
PSE power enabled
Indicates whether or not the device is operating as a PSE.
Indicates whether or not the PSE-PD pair control is available.
Power pairs
PoE mode, which can be Signal or Spare.
Port power classification of the PD, which can be the following:
l      Class0
l      Class1
l      Class2
l      Class3
l      Class4
Aggregation port ID
Maximum frame Size
Location format
l      ECS ELIN, indicating a telephone for urgencies.
PoE PSE power source
PSE type, which can be:
l      Primary, indicating a primary power supply
l      Backup, indicating a backup power supply
PoE service type
PoE service type
Port PSE Priority
Port PSE priority, which can be:
l      Unknown
l      Critical
l      High
l      Low
Available power value
PoE power
Unknown basic TLV
Unknown basic TLV
TLV type
Unknown basic TLV type
TLV information
Information contained in the unknown basic TLV type
Unknown organizationally-defined TLV
Unknown organizationally specific TLV
TLV OUI
OUI of the unknown organizationally specific TLV
TLV subtype
Unknown organizationally specific TLV subtype
Index
Unknown organization index
TLV information
Information contained in unknown organizationally specific TLV
display lldp statistics
display lldp statistics [ global | interface interface-type interface-number ]
View
Default level
1: Monitor level
global: Displays the global LLDP statistics.
Use the display lldp statistics command to display the global LLDP statistics or the LLDP statistics of a port.
If no keyword/argument is specified, this command displays all the LLDP statistics.
# Display all the LLDP statistics.
LLDP statistics global Information:
LLDP neighbor information last change time:0 days,0 hours,4 minutes,40 seconds
The number of LLDP neighbor information deleted  : 1
The number of LLDP neighbor information dropped  : 0
LLDP statistics Information of port 1 [GigabitEthernet1/0/1]:
The number of LLDP frames transmitted            : 0
The number of LLDP frames received               : 0
The number of LLDP frames discarded              : 0
The number of LLDP error frames                  : 0
The number of LLDP TLVs discarded                : 0
The number of LLDP TLVs unrecognized             : 0
The number of CDP frames transmitted             : 0
The number of CDP frames received                : 0
The number of CDP frames discarded               : 0
The number of CDP error frames                   : 0
Table 1-3 display lldp statistics command output description
LLDP statistics global information
Global LLDP statistics
Time the neighbor information is latest updated
Number of times of adding neighbor information
Number of times of removing neighbor information
Number of times of dropping neighbor information due to lack of available memory space
Number of the neighbor information entries that have aged out
LLDP statistics of port 1
Total number of the LLDP frames transmitted
Total number of the LLDP frames received
Total number of the LLDP frames dropped
Total number of the LLDP error frames received
Total number of the LLDP TLVs dropped
Total number of the LLDP TLVs that cannot be recognized
Number of the LLDP neighbor information entries that have aged out
Total number of the CDP frames transmitted
Total number of the CDP frames received
Total number of the CDP frames dropped
Total number of the CDP error frames received
display lldp status
display lldp status [ interface interface-type interface-number ]
View
Default level
1: Monitor level
Use the display lldp status command to display the LLDP status of a port.
If no port is specified, this command displays the LLDP status of all the ports.
# Display the LLDP status of all the ports.
<Sysname> display lldp status
Global status of LLDP: Enable
The current number of LLDP neighbors: 0
LLDP neighbor information last changed time: 0 days,0 hours,4 minutes,40 seconds
Transmit interval              : 30s
Hold multiplier                : 4
Reinit delay                   : 2s
Transmit delay                 : 2s
Trap interval                  : 5s
Fast start times               : 3
Port 1 [GigabitEthernet1/0/1]:
Port status of LLDP            : Enable
Admin status                   : Tx_Rx
Trap flag                      : No
Rolling interval               : 0s
Number of neighbors            : 5
Number of MED neighbors        : 2
Number of CDP neighbors        : 0
Number of sent optional TLV    : 12
Table 1-4 display lldp status command output description
Indicating whether or not LLDP is globally enabled
Total number of the LLDP neighbor devices
Transmit interval
Interval to send LLDPDU
Hold multiplier
TTL multiplier
Reinit delay
Initialization delay
Transmit delay
Delay period to send LLDPDUs
Trap interval
Interval to send traps
Fast start times
Number of the LLDPDUs to be sent successively when a new neighboring device is detected
Port 1
LLDP status of port 1
Port status of LLDP
Indicates whether or not LLDP is enabled on the port.
Admin status
LLDP mode of the port, which can be:
l      TxRx. A port in this mode sends and receives LLDPDUs.
l      Rx_Only. A port in this mode receives LLDPDUs only.
l      Tx_Only. A port in this mode sends LLDPDUs only.
l      Disable. A port in this mode does not send or receive LLDPDUs.
Trap Flag
Indicates whether or not trap is enabled.
Rolling interval
LLDP polling interval. A value of 0 indicates LLDP polling is disabled.
Number of neighbors
Number of the LLDP neighbors connecting to the port
Number of MED neighbors connecting to the port
Number of the CDP neighbors connecting to the port
Number of the optional TLVs contained in an LLDPDU sent through the port
Number of the unknown TLVs contained in a received LLDPDU
display lldp tlv-config
display lldp tlv-config [ interface interface-type interface-number ]
View
Default level
1: Monitor level
Use the display lldp tlv-config command to display the advertisable TLVs of a port.
If no port is specified, this command displays the advertisable TLVs of each port.
# Display the advertisable TLVs of each port.
<Sysname> display lldp tlv-config
LLDP tlv-config of port 1[GigabitEthernet1/0/1]:
NAME                              STATUS    DEFAULT
Basic optional TLV:
Port Description TLV              YES       YES
System Name TLV                   YES       YES
System Description TLV            YES       YES
System Capabilities TLV           YES       YES
Management Address TLV            YES       YES
IEEE 802.1 extend TLV:
Port VLAN ID TLV                  YES       YES
Port And Protocol VLAN ID TLV     YES       YES
VLAN Name TLV                     YES       YES
IEEE 802.3 extend TLV:
MAC-Physic TLV                    YES       YES
Power via MDI TLV                 YES       YES
Link Aggregation TLV              YES       YES
Maximum Frame Size TLV            YES       YES
LLDP-MED extend TLV:
Network Policy TLV                YES        YES
Location Identification TLV       NO         NO
Extended Power via MDI TLV        YES        YES
Inventory TLV                     YES        YES
Table 1-5 display lldp tlv-config command output description
Advertisable TLVs of port 1
NAME
TLV type
STATUS
Indicates whether or not TLVs of a specific type are currently sent through a port
DEFAULT
Indicates whether or not TLVs of a specific type are sent through a port by default
Basic optional TLV
Basic TLVs, including:
l      Port description TLV
l      System name TLV
l      System description TLV
l      System capabilities TLV
l      Management address TLV
IEEE 802.1 extended TLV
IEEE 802.1 organizationally specific TLVs, including:
l      Port VLAN ID TLV
l      Port and protocol VLAN ID TLV
l      VLAN name TLV
IEEE 802.3 extended TLV
IEEE 802.3 organizationally specific TLVs, including:
l      MAC-Physic TLV
l      Power via MDI TLV
l      Link aggregation TLV
l      Maximum frame size TLV
LLDP-MED extend TLV
MED related LLDP TLVs, including:
l      Capabilities TLV
l      Network Policy TLV
l      Extended Power-via-MDI TLV
l      Location Identification TLV
l      Inventory TLV, which can be hardware revision TLV, firmware revision TLV, software revision TLV, serial number TLV, manufacturer name TLV, model name TLV, and asset id TLV.
lldp admin-status
lldp admin-status { disable | rx | tx | txrx }
undo lldp admin-status
View
Ethernet interface view, port group view
Default level
2: System level
disable: Specifies the Disable mode. A port in this mode does not send or receive LLDPDUs.
rx: Specifies the Rx mode. A port in this mode receives LLDPDUs only.
tx: Specifies the Tx mode. A port in this mode sends LLDPDUs only.
txrx: Specifies the TxRx mode. A port in this mode sends and receives LLDPDUs.
Use the lldp admin-status command to specify the LLDP operating mode for a port or all the ports in a port group.
Use the undo lldp admin-status command to restore the default LLDP operating mode.
The default LLDP operating mode is TxRx.
# Configure the LLDP operating mode as Rx for GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] lldp admin-status rx
lldp check-change-interval
lldp check-change-interval interval
undo lldp check-change-interval
View
Default level
2: System level
interval: LLDP polling interval to be set, in the range 1 to 30 (in seconds).
Use the lldp check-change-interval command to enable LLDP polling and set the polling interval.
Use the undo lldp check-change-interval command to restore the default.
By default, LLDP polling is disabled.
# Enable LLDP polling on GigabitEthernet 1/0/1, setting the polling interval to 30 seconds.
[Sysname-GigabitEthernet1/0/1] lldp check-change-interval 30
lldp enable
lldp enable
undo lldp enable
View
System view, Ethernet interface view, port group view
Default level
2: System level
None
Use the lldp enable command to enable LLDP.
Use the undo lldp enable command to disable LLDP.
By default, LLDP is enabled on a port and disabled globally.
Note that LLDP takes effect on a port only when it is enabled both globally and on the port.
# Disable LLDP on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] undo lldp enable
lldp encapsulation snap
undo lldp encapsulation [ snap ]
View
Default level
2: System level
None
Use the lldp encapsulation snap command to configure the encapsulation format for LLDPDUs as SNAP on a port or a group of ports.
Use the undo lldp encapsulation command to restore the default encapsulation format for LLDPDUs.
By default, Ethernet II encapsulation applies.
The command does not apply to LLDP-CDP packets, which use only SNAP encapsulation.
# Configure the encapsulation format for LLDPDUs as SNAP on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] lldp encapsulation snap
lldp fast-count
lldp fast-count count
undo lldp fast-count
View
Default level
2: System level
count: Number of the LLDPDUs to be sent successively when a new neighboring device is detected. This argument ranges from 1 to 10.
Use the lldp fast-count command to set the number of the LLDPDUs to be sent successively when a new neighboring device is detected.
Use the undo lldp fast-count command to restore the default.
By default, the number is 3.
# Configure to send four LLDP successively when a new neighboring device is detected.
[Sysname] lldp fast-count 4
lldp hold-multiplier
lldp hold-multiplier value
undo lldp hold-multiplier
View
Default level
2: System level
value: TTL multiplier, in the range 2 to 10.
Use the lldp hold-multiplier command to set the TTL multiplier.
Use the undo lldp hold-multiplier command to restore the default.
The TTL multiplier defaults to 4.
You can set the TTL of the local device information by configuring the TTL multiplier.
The TTL of the information about a device is determined by the following expression:
TTL multiplier × LLDPDU transmit interval
You can set the TTL of the local device information by configuring the TTL multiplier. Note that the TTL can be up to 65535 seconds. TTLs longer than it will be rounded off to 65535 seconds.
Related commands: lldp timer tx-interval.
# Set the TTL multiplier to 6.
lldp management-address-format string
undo lldp management-address-format
View
Default Level
2: System level
None
Use the lldp management-address-format string command to configure the encapsulation format of the management address as strings in TLVs.
Use the undo lldp management-address-format command to restore the default.
By default, the management address is encapsulated in the form of numbers in TLVs.
# Configure GigabitEthernet 1/0/1 to encapsulate the management address in the form of strings in management address TLVs.
[Sysname-GigabitEthernet1/0/1] lldp management-address-format string
lldp management-address-tlv
lldp management-address-tlv [ ip-address ]
undo lldp management-address-tlv
View
Default level
2: System level
ip-address: Management address to be set.
Use the lldp management-address-tlv command to enable the management address sending. This command also sets the management address.
Use the undo lldp management-address-tlv command to disable management address sending.
By default, the management address is sent through LLDPDUs, and the management address is the primary IP address of the VLAN with the smallest VLAN ID among the VLANs whose packets are permitted on the port. If the primary IP address is not configured, the management address is 127.0.0.1.
Note that an LLDPDU carries only one management address. If you set the management address repeatedly, the latest one takes effect.
# Set the management address to 192.6.0.1 for GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] lldp management-address-tlv 192.6.0.1
lldp notification remote-change enable
undo lldp notification remote-change enable
View
Default level
2: System level
None
Use the lldp notification remote-change enable command to enable trap for a port or all the ports in a port group.
Use the undo lldp notification remote-change enable command to restore the default.
By default, trap is disabled on a port.
# Enable LLDP trap for GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] lldp notification remote-change enable
lldp timer notification-interval
undo lldp timer notification-interval
View
Default level
2: System level
interval: Interval to send LLDP trap messages, in the range 5 to 3600 (in seconds).
Use the lldp timer notification-interval command to set the interval to send LLDP trap messages.
Use the undo lldp timer notification-interval command to restore the default.
By default, the interval to send LLDP trap messages is 5 seconds.
# Set the interval to send LLDP trap messages to 8 seconds.
lldp timer reinit-delay
lldp timer reinit-delay delay
undo lldp timer reinit-delay
View
Default level
2: System level
delay: Initialization delay period to be set, in the range 1 to 10 (in seconds).
Use the lldp timer reinit-delay command to set the initialization delay period.
Use the undo lldp timer reinit-delay command to restore the default.
By default, the initialization delay period is 2 seconds.
# Set the initialization delay period to 4 seconds.
lldp timer tx-delay
lldp timer tx-delay delay
undo lldp timer tx-delay
View
Default level
2: System level
delay: Delay period to send LLDPDUs, in the range 1 to 8192 (in seconds).
Use the lldp timer tx-delay command to set the delay period to send LLDPDUs.
Use the undo lldp timer tx-delay command to restore the default.
By default, the delay period to send LLDPDUs is 2 seconds.
# Set the delay period to send LLDPDUs to 4 seconds.
[Sysname] lldp timer tx-delay 4
undo lldp timer tx-interval
View
Default level
2: System level
interval: Interval to send LLDPDUs, in the range 5 to 32768 (in seconds).
Use the lldp timer tx-interval command to set the interval to send LLDPDUs.
Use the undo lldp timer tx-interval command to restore the default.
By default, the interval to send LLDPDUs is 30 seconds.
To enable local device information to be updated on neighboring devices before being aged out, make sure the interval to send LLDPDUs is shorter than the TTL of the local device information.
# Set the interval to send LLDPDUs to 20 seconds.
lldp tlv-enable
lldp tlv-enable { basic-tlv { all | port-description | system-capability | system-description | system-name } | dot1-tlv { all | port-vlan-id | protocol-vlan-id [ vlan-id ] | vlan-name [ vlan-id ] } | dot3-tlv { all | link-aggregation | mac-physic | max-frame-size | power } | med-tlv { all | capability | inventory | location-id { civic-address device-type country-code { ca-type ca-value }&<1-10> | elin-address tel-number } | network-policy | power-over-ethernet } }
undo lldp tlv-enable { basic-tlv { all | port-description | system-capability | system-description | system-name } | dot1-tlv { all | port-vlan-id | protocol-vlan-id | vlan-name } | dot3-tlv { all | link-aggregation | mac-physic | max-frame-size | power } | med-tlv { all | capability | inventory | location-id | network-policy | power-over-ethernet } }
View
Default level
2: System level
all: Sends all the basic LLDP TLVs, all the IEEE 802.1 organizationally specific LLDP TLVs, or all the IEEE 802.3 organizationally specific LLDP TLVs when the all keyword is specified for basic-tlv, dot1-tlv, or dot3-tlv; or sends all the MED related LLDP TLVs except location identification TLVs when the all keyword is specified for med-tlv.
basic-tlv: Sends basic LLDP TLVs.
port-description: Sends port description TLVs.
system-capability: Sends system capabilities TLVs.
system-description: Sends system description TLVs.
system-name: Sends system name TLVs.
dot1-tlv: Sends IEEE 802.1 organizationally specific LLDP TLVs.
port-vlan-id: Sends port VLAN ID TLVs.
protocol-vlan-id: Sends port and protocol VLAN ID TLVs.
vlan-name: Sends VLAN name TLVs.
vlan-id: ID of the VLAN in the TLVs (port and protocol VLAN ID TLVs or VLAN name TLVs) to be sent. This argument ranges from 1 to 4094 and defaults to the least protocol VLAN ID.
dot3-tlv: Sends IEEE 802.3 organizationally specific LLDP TLVs.
link-aggregation: Sends link aggregation group TLVs.
mac-physic: Sends MAC/PHY configuration/status TLVs.
max-frame-size: Sends maximum frame size TLVS.
power: Sends power via MDI TLVs.
med-tlv: Sends MED related LLDP TLVs.
capability: Sends LLDP-MED capabilities TLVs.
inventory: Sends hardware revision TLVs, firmware revision TLVs, software revision TLVs, serial number TLVs, manufacturer name TLVs, model name TLVs, and asset ID TLVs.
location-id: Sends location identification TLVS.
civic-address: Inserts the address information about the intermediate device in location identification TLVs .
device-type: Device type value. A value of 0 specifies DHCP server; a value of 1 specifies switch, and a value of 2 specifies LLDP-MED endpoint.
country-code: Country code, confirming to ISO 3166.
{ ca-type ca-value }&<1-10>: Configures address information, where ca-type represents the address information type, in the range 0 to 255, ca-value represents address information, a string of 1 to 250 characters, and &<1-10> indicates that you can enter up to ten such parameters.
elin-address: Inserts telephone numbers for urgencies in location identification TLVs.
tel-number: Telephone number for urgencies, a string of 10 to 25 characters.
network-policy: Sends network policy TLVs.
power-over-ethernet: Sends extended power-via-MDI TLVs.
Use the lldp tlv-enable command to configure advertisable TLVs for a port or all the ports in a port group.
Use the undo lldp tlv-enable command to disable the sending of specific TLVs.
By default, all the TLVs except location identification TLVs are advertisable on a port.
Note that:
l          To enable MED related LLDP TLV sending, you need to enable LLDP-MED capabilities TLV sending first. Conversely, to disable LLDP-MED capabilities TLV sending, you need to disable the sending of other MED related LLDP TLV.
l          To disable MAC/PHY configuration/status TLV sending, you need to disable LLDP-MED capabilities TLV sending first.
l          Enabling the sending of LLDP-MED capabilities TLVs also enables the sending of MAC/PHY configuration/status TLVs.
l          You can specify to send multiple types of TLVs by executing the lldp tlv-enable command repeatedly.
# Enable the sending of link aggregation group TLVs of the IEEE 802.3 organizationally specific TLVs on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] lldp tlv-enable dot3-tlv link-aggregation
H3C reserves the right to modify its collaterals without any prior notice. For the latest information of the collaterals, please consult H3C sales or call 400 hotline.
