H3C EPON OLT Installation Manual(Release 5200 SeriesV1.02)
DownLoad Chapters Download(116 KB)
05-Chapter5 System Debugging
Chapter 5  System Debugging
5.1  Set up Configuration Environment
5.1.1  Setting up Configuration Environment
l           Terminal (a PC in this example) is connected to the switch console port through a console cable.
Figure 5-1 Setting up a configuration environment
5.1.2  Connecting Console Cable
Step 1: Plug the DB-9 female plug of the console cable to the serial port of the PC or the terminal where the switch is to be configured.
Step 2: Connect the RJ-45 connector of the console cable to the console port of the switch.
5.1.3  Setting Terminal Parameters
Parameter requirements:
l           Baud rate is 9600. Data bits is 8.
l           Parity check is none. Stop bits is 1.
l           Flow control is none.
l           Terminal emulation is VT100.
Take the PC running Windows98 hyper terminal as an example, this section introduces how to set the terminal parameters.
Step 1: Start PC and run the terminal emulator (such as Terminal on Windows3.1, and the HyperTerminal on Windows95/Windows98/Windows 2000/Windows NT/Windows XP/Windwos ME).
Step 2: Set the parameters for Windows98 HyperTerminal.
Take the following steps:
Click [Start/Program/Accessories/Communications/Hyper Terminal] to enter the Hyper Terminal window in which click  to establish a new connection and the system will pop up the connection description interface.
Figure 5-2 Connection description of hyper terminal
Input the name of the new connection and click <OK>. Then there pops up the interface as shown in the following figure. Select the serial port to be used from [Connect using].
Figure 5-3 Set serial port for hyper terminal connection
After selecting serial ports, click <OK> button. The following interface will pop up for setting serial port parameters. Set the baud rate to 9600, data bits to 8, parity check to none, stop bits to 1 and flow control to none.
Figure 5-4 Set serial port parameters
After setting serial port parameters, click <OK> button. Then the system will enter the hyper terminal dialogue box as shown in the following figure.
Figure 5-5 HyperTerminal interface
In the above dialogue box, select [Properties] and enter the window. Click [Settings] to set the attributes (see the following figure). In this interface, select the terminal emulation to VT100 and then click <OK>.
Figure 5-6 Set terminal emulation in the property setting window
5.2  Power on and Boot
5.2.1  Check before Powering on
Before powering on an Ethernet Switch, check if:
l           The switch is mounted steadily.
l           All the cards are correctly installed.
l           All the communication cables, fibers, power cords, and ground wires are correctly connected.
l           If the voltage of power supply can meet the requirements on the switch.
l           The console cable is correctly connected. The computer or terminal for configuration is started and the terminal parameters are properly set.
  Caution:
Before powering on the switch, make sure where the power switch of the equipment room is located, so that you can cut the power in case of accident.
5.2.2  Powering on
l           Turn on the power supply of the switch.
l           Power on the switch.
5.2.3  Check after Powering on (Recommended)
You are recommended to check as follows after powering on the switch to ensure the configurations thereafter.
l           After a switch is powered on, the heat dissipation system starts working. You can hear the noise as the fan rotates and feel air flow out from the vent.
l           Check if any system indicator on the SRPU indicates abnormal condition.
  Caution:
It is necessary to make sure each fan operates properly.
5.2.4  Booting Interface
As the switch is started, the configuration terminal will yield the following output:
&  Note:
The following information may be a little different for different switch models.
Starting......
RAM Line....OK
System is booting................
            *  H3C S7506 BOOTROM, Version 100    *
      Copyright(C) 2004-2007 Hangzhou H3C Technologies Co., Ltd.
      Creation date   : May 26 2006, 16:57:31
      CPU type         : MPC8260
      CPU Clock Speed : 200Mhz
      BUS Clock Speed : 66Mhz
      Memory Size      : 128MB
S7506 main board self testing...............................
60X_SDRAM Data lines Selftest.............................OK!
60X_SDRAM Address lines Selftest..........................OK!
60X_SDRAM fast selftest...................................OK!
LOCAL_SDRAM Data lines Selftest...........................OK!
LOCAL_SDRAM Address lines Selftest........................OK!
LOCAL_SDRAM fast selftest.................................OK!
Please check leds................ .....Led selftest finished!
Switch chip selftest......................................OK!
CPLD selftest.............................................OK!
Press Ctrl-B to enter Boot Menu... 5
Auto-booting...
Auto booting file is srpuprj.app
Decompress  Image...................................................
.......................................................OK!
Starting at 0x60000...
User interface Aux0/0 is available
Press ENTER to get started.
The displaying of the above indications indicates the completion of the switch auto-booting.
Press <Enter> and get the following output. By this time, you can start configuring the switch.
<H3C>
&  Note:
It takes H3C S7506 Switch about 2 minutes and 45 seconds to enter the above interface after the switch is powered on. It takes S7503 Switch about 2 minutes and 38 seconds, and it takes S7506R about 3 minutes and 25 seconds.
&  Note:
H3C S7500 series switches provide a variety of command views. For information about the commands and command line interface, refer to H3C S7500 Series Ethernet Switches  Operation Manual and H3C S7500 Series Ethernet Switches  Command Manual.
H3C reserves the right to modify its collaterals without any prior notice. For the latest information of the collaterals, please consult H3C sales or call 400 hotline.
