H3C EPON OLT Installation Manual(Release 5200 SeriesV1.02)
DownLoad Chapters Download(67 KB)
00-1Cover
H3C EPON
Hangzhou H3C Technologies Co., Ltd.
http://www.h3c.com
Manual Version: T2-08046W-20070415-C-1.02
Product Version: Release 5200 Series
Copyright   2006-2007, Hangzhou H3C Technologies Co., Ltd. and its licensors
All Rights Reserved
No part of this manual may be reproduced or transmitted in any form or by any means without prior written consent of Hangzhou H3C Technologies Co., Ltd.
Trademarks
H3C, , Aolynk, , H3Care, , TOP G, , IRF, NetPilot, Neocean, NeoVTL, SecPro, SecPoint, SecEngine, SecPath, Comware, Secware, Storware, NQA, VVG, V2G, VnG, PSPT, XGbus, N-Bus, TiGem, InnoVision and HUASAN are trademarks of Hangzhou H3C Technologies Co., Ltd.
All other trademarks that may be mentioned in this manual are the property of their respective owners.
Notice
The information in this document is subject to change without notice. Every effort has been made in the preparation of this document to ensure accuracy of the contents, but all statements, information, and recommendations in this document do not constitute the warranty of any kind, express or implied.
To obtain the latest information, please access:
http://www. h3c.com
Technical Support
[email protected]
http://www. h3c.com
About This Manual
Related Documentation
In addition to this manual, each H3C EPON  OLT documentation set includes the following:
Manual
H3C EPON  OLT Operation Manual
It introduces EPON system configuration, OLT configuration, ONU configuration, ONU UNI configuration, alarm configuration, and supported features.
H3C EPON  OLT Command Manual
It provides the commands for EPON system configuration, OLT configuration, ONU configuration, ONU UNI configuration, and alarm configuration.
Organization
H3C EPON  OLT Installation Manual is organized as follows:
Chapter
1 Product Overview
Gives a brief introduction to Compatibility between S7500 Series Ethernet Switch SRPUs and EPON LPUs.
2 EPON LPUs
Introduces the four EPON LPUs available on the S7500 Series Ethernet Switches.
3 Installation Preparation
Introduces such topics as the precautions and the environmental requirements of S7500 Series Ethernet Switches, the instructions for the installation, the installation tools and so on.
4 Switch Installation
Introduces the installation of the S7500 Series Ethernet Switches, module installation, connections of the power cable, ground wire and the console cable.
5 System Debugging
introduces the booting process of S7500 Series Ethernet Switches, including the power-on booting of the switch and the system initialization.
6 Switch Monitoring and Maintenance
Introduces hardware and software maintenance of the S7500 Series Ethernet Switches, and ONU software upgrade.
Appendix A Installation of B68 Cabinet
Introduces the installation of B68 cabinet.
Appendix B Installation of Lightning Arrester for AC Power
Introduces lightning protection for the S7500 Series Ethernet Switches.
Conventions
The manual uses the following conventions:
I. Command conventions
Convention
Boldface
The keywords of a command line are in Boldface.
italic
Command arguments are in italic.
Items (keywords or arguments) in square brackets [ ] are optional.
{ x | y | ... }
Alternative items are grouped in braces and separated by vertical bars. One is selected.
[ x | y | ... ]
Optional alternative items are grouped in square brackets and separated by vertical bars. One or none is selected.
{ x | y | ... } *
Alternative items are grouped in braces and separated by vertical bars. A minimum of one or a maximum of all can be selected.
[ x | y | ... ] *
Optional alternative items are grouped in square brackets and separated by vertical bars. Many or none can be selected.
&<1-n>
The argument(s) before the ampersand (&) sign can be entered 1 to n times.
A line starting with the # sign is comments.
II. GUI conventions
Convention
Boldface
Window names, button names, field names, and menu items are in Boldface. For example, the New User window appears; click OK.
Convention
Button names are inside angle brackets. For example, click <OK>.
Window names, menu items, data table and field names are inside square brackets. For example, pop up the [New User] window.
Multi-level menus are separated by forward slashes. For example, [File/Create/Folder].
III. Symbols
Convention
  Caution
Means reader be careful. Improper operation may cause data loss or damage to equipment.
&  Note
Means a complementary description.
Environmental Protection
This product has been designed to comply with the requirements on environmental protection. For the proper storage, use and disposal of this product, national laws and regulations must be observed.
H3C reserves the right to modify its collaterals without any prior notice. For the latest information of the collaterals, please consult H3C sales or call 400 hotline.
