H3C EPON OLT Installation Manual(Release 5200 SeriesV1.02)
DownLoad Chapters Download(345 KB)
02-Chapter2 EPON LPUs
Chapter 2  EPON LPUs
2.1  LS81PT4GA-4-Port 1000Base-PX10 (EPON) Ethernet LPU
Figure 2-1 The appearance of an LS81PT4GA LPU
2.1.1  Introduction to LS81PT4GA LPU
An LS81PT4GA LPU provides four SC/PC EPON optical ports. The distance between an SC/PC EPON port on it and an ONU device can be up to 10 km (6.2 mi).
Table 2-1 LS81PT4GA LPU specifications
Item
LS81PT4GA
CPU
MPC8241
Boot ROM
512 KB
SDRAM
128 MB
Dimensions (L   W)
366.7   340 mm (14.4   13.4 in.)
Maximum power consumption
34 W
Port type
SC/PC
Number of ports
4
Port transmission speed
1000 Mbps
Conformed port standard
1000Base-PX10
Conformed standard
IEEE802.3ah
Matched SRPU
LS81T12PE, LS81P12TE, and Salience III series SRPUs
2.1.2  Panel and LEDs
Figure 2-2 The panel of an LS81PT4GA LPU
Table 2-2 describes the LED states.
Table 2-2 Description of LS81PT4GA LPU LED states
LED
LINK
OFF
No link is present.
ON
A link is present.
2.1.3  Matched Cable
Table 2-3 Matched cables for LS81PT4GA LPU
SFF module
Central wavelength
Connector
Matched cable
Maximum transmission distance
1000Base-PX-SFF-SC
Transmit: 1490 nm
Receive: 1310 nm
SC/PC
9/125  m single mode optical fiber
10 km (6.2 mi)
2.2  LS81PT8GA-8-Port 1000Base-PX10 (EPON) Ethernet LPU
Figure 2-3 The appearance of an LS81PT8GA LPU
2.2.1  Introduction to LS81PT8GA LPU
An LS81PT8GA LPU provides eight SC/PC EPON optical ports. The distance between an SC/PC EPON port on it and an ONU device can be up to 10 km (6.2 mi).
Table 2-4 LS81PT8GA LPU specifications
Item
LS81PT8GA
CPU
MPC8241
Boot ROM
512 KB
SDRAM
128 MB
Dimensions (L   W)
50 W
Connector
SC/PC
Number of ports
8
1000 Mbps
1000Base-PX10
Conformed standard
IEEE802.3ah
Matched SRPU
LS81T12PE, LS81P12TE, and Salience III series (excluding Salience III-Plus) SRPUs
l      An LS81PT8GA LPU can operate with the presence of an LS81T12PE, an LS81P12TE, a Salience III, or a Salience III Edge SRPUs only.
l      For S7500 series switches with Salience III or Salience III Edge SRPUs installed, an LS81PT8GA LPU cannot be installed in the sixth LPU slot of an S7506 or S7506R switch, but it can be installed in any LPU slot of an S7503 switch.
2.2.2  Panel and LEDs
Figure 2-4 The panel of an LS81PT8GA LPU
Table 2-5 describes the LED states.
Table 2-5 Description of LS81PT8GA LPU LED states
LED
LINK
OFF
No link is present.
ON
A link is present.
2.2.3  Matched Cable
Table 2-6 Matched cables for LS81PT8GA LPU
SFF module
Central wavelength
Connector
Cable
1000Base-PX-SFF-SC
Transmit: 1490 nm
Receive: 1310 nm
SC/PC
10 km (6.2 mi)
2.3  LS8M1PT4GB0-4-Port 1000Base-PX20 (EPON) LPU
Figure 2-5 The appearance of an LS8M1PT4GB0 LPU
2.3.1  Introduction to LS8M1PT4GB0 LPU
An LS8M1PT4GB0 LPU provides four SC/PC EPON optical ports. The distance between an SC/PC EPON port on it and an ONU device can be up to 20 km (12.4 miles).
Table 2-7 LS8M1PT4GB0 LPU specifications
Item
LS8M1PT4GB0
CPU
MPC8241
BootROM
512 KB
SDRAM
128 MB
Dimensions (L x W)
38 W
Connector
SC/PC
Number of ports
4
1000 Mbps
1000Base-PX20
Conformed standard
IEEE 802.3ah
Matched SRPU
2.3.2  Panel and LEDs
Figure 2-6 shows the panel of an LS8M1PT4GB0 LPU.
Figure 2-6 The front panel of an LS8M1PT4GB0 LPU
Table 2-8 describes the LED states.
Table 2-8 Description of LS8M1PT4GB0 LPU LED states
LED
LINK
OFF
No link is present.
ON
A link is present.
2.3.3  Matched Cable
Table 2-9 Matched cables for LS8M1PT4GB0 LPU
SFF module
Central wavelength
Connector
Cable
1000Base-PX-SFF-SC
Transmit: 1490 nm
Receive: 1310 nm
SC/PC
9/125  m single mode fiber
20 km (12.4 mi)
2.4  LS8M1PT8GB0-8-Port 1000Base-PX20 (EPON) LPU
Figure 2-7 The appearance of an LS8M1PT8GB0 LPU
2.4.1  Introduction to LS8M1PT8GB0 LPU
An LS8M1PT8GB0 LPU provides eight SC/PC EPON optical ports. The distance between an SC/PC EPON port on it and an ONU device can be up to 20 km (12.4 miles).
Table 2-10 LS8M1PT8GB0 LPU specifications
Item
LS8M1PT8GB0
CPU
MPC8241
BootROM
512 KB
SDRAM
128 MB
Dimensions (L x W)
366.7   340mm (14.4   13.4 in.)
58 W
Connector
SC/PC
Number of interfaces
8
Interface transmission speed
1000 Mbps
Confirmed port standard
1000Base-PX20
Confirmed standard
IEEE 802.3ah
Matched SRPU
LS81T12PE, LS81P12TE, and Salience III series SRPUs excluding Salience III Plus
&  Note:
l      An LS8M1PT8GB0 LPU can operate with the presence of an LS81T12PE, an LS81P12TE, a Salience III, or a Salience III Edge SRPU only.
l       For S7500 series switches with Salience III or Salience III Edge SRPUs installed, an LS8M1PT8GB0 LPU cannot be installed in the sixth LPU slot of an S7506 or S7506R switch, but it can be installed in any LPU slot of an S7503 switch.
2.4.2  Panel and LEDs
Figure 2-8 shows the front panel of an LS8M1PT8GB0 LPU.
Figure 2-8 The front panel of an LS8M1PT8GB0 LPU
Table 2-11 describes the LS8M1PT8GB0 LPU LED states.
Table 2-11 LED state description of the LS8M1PT8GB0
LED
LINK
OFF
No link is present.
ON
A link is present.
2.4.3  Matched Cable
Table 2-12 Matched cable for LS8M1PT8GB0 LPU
SFF module
Central wavelength
Connector
Matching cable
1000Base-PX-SFF-SC
Transmit: 1490 nm
Receive: 1310 nm
SC/PC
20 km (12.4 mi)
H3C reserves the right to modify its collaterals without any prior notice. For the latest information of the collaterals, please consult H3C sales or call 400 hotline.
