Chapters Download(114 KB)
Table of Contents
5.1 Set up Configuration Environment
5.1.1 Setting up Configuration Environment
5.1.2 Connecting Console Cable
5.1.3 Setting Terminal Parameters
5.2.1 Check before Powering on
5.2.3 Check after Powering on (Recommended)
l Terminal (a PC in this example) is connected to the switch console port through a console cable.
Figure 5-1 Switch configuration networking
Step 1: Plug the DB-9 female plug of the console cable to the serial port of the PC or the terminal where the switch is to be configured.
Step 2: Connect the RJ-45 connector of the console cable to the console port of the switch.
Parameter requirements:
l Baud rate is 9600. Data bits is 8.
l Parity check is none. Stop bits is 1.
l Flow control is none.
l Terminal emulation is VT100.
Take the PC running Windows98 hyper terminal as an example, this section introduces how to set the terminal parameters.
Step 1: Start PC and run the terminal emulator (such as Terminal on Windows3.1, and the HyperTerminal on Windows95/Windows98/Windows 2000/Windows NT/Windows XP/Windwos ME).
Step 2: Set the parameters for Windows98 HyperTerminal.
Take the following steps:
Click
[Start/Program/Accessories/Communications/Hyper Terminal] to enter the Hyper
Terminal window in which click
to establish a new
connection and the system will pop up the connection description interface.
Figure 5-2 Connection description of hyper terminal
Input the name of the new connection and click <OK>. Then there pops up the interface as shown in the following figure. Select the serial port to be used from [Connect using].
Figure 5-3 Set serial port for hyper terminal connection
After selecting serial ports, click <OK> button. The following interface will pop up for setting serial port parameters. Set the baud rate to 9600, data bits to 8, parity check to none, stop bits to 1 and flow control to none.
Figure 5-4 Set serial port parameters
After setting serial port parameters, click <OK> button. Then the system will enter the hyper terminal dialogue box as shown in the following figure.
Figure 5-5 HyperTerminal interface
In the above dialogue box, select [Properties] and enter the window. Click [Settings] to set the attributes (see the following figure). In this interface, select the terminal emulation to VT100 and then click <OK>.
Figure 5-6 Set terminal emulation in the property setting window
Before powering on an Ethernet Switch, check if:
l The switch has been mounted steadily.
l All the cards have been correctly installed.
l All the communication cables, fibers, power cords, and ground wires have been correctly connected.
l If the voltage of power supply can meet the requirements on the switch.
l The console cable has been correctly connected. The computer or terminal for configuration has been started and the terminal parameter settings have been done.
Caution:
Before powering on the switch, make sure where the power switch of the equipment room is located, so that you will be able to power off when meeting accidence.
l Turn on the power supply of the switch.
l Power on the switch.
You are recommended to check as follows after powering on the switch to ensure the configurations thereafter.
l After a switch is powered on, the heat dissipation system starts working. You can hear the noise as the fan rotates and feel air flow out from the vent.
l Check if any system indicator on the SRPU indicates abnormal condition.
As the switch is started, the configuration terminal will yield the following output:
& Note:
The following information may be a little different for different switch models.
RAM Line....OK
System is booting................
* H3C S7506 BOOTROM, Version 100 *
Copyright(C) 2004-2007 Hangzhou H3C Technologies Co., Ltd.
Creation date : May 26 2006, 16:57:31
CPU type : MPC8260
CPU Clock Speed : 200Mhz
BUS Clock Speed : 66Mhz
Memory Size : 128MB
S7506 main board self testing...............................
60X_SDRAM Data lines Selftest.............................OK!
60X_SDRAM Address lines Selftest..........................OK!
60X_SDRAM fast selftest...................................OK!
LOCAL_SDRAM Data lines Selftest...........................OK!
LOCAL_SDRAM Address lines Selftest........................OK!
LOCAL_SDRAM fast selftest.................................OK!
Please check leds................ .....Led selftest finished!
Switch chip selftest......................................OK!
CPLD selftest.............................................OK!
Press Ctrl-B to enter Boot Menu... 5
Auto-booting...
Auto booting file is srpuprj.app
Decompress Image...................................................
.......................................................OK!
Starting at 0x60000...
User interface Aux0/0 is available
Press ENTER to get started.
The displaying of the above indications indicates the completion of the switch auto-booting.
Press <Enter> and get the following output. By this time, you can start configuring the switch.
<H3C>
& Note:
It takes H3C S7506 Switch about 2 minutes and 45 seconds to enter the above interface after the switch is powered on. It takes S7503 Switch about 2 minutes and 38 seconds, and it takes S7506R about 3 minutes and 25 seconds.
& Note:
H3C S7500 series switches provide a variety of command views. For the specific descriptions on the configuration commands and command line interfaces, refer to H3C S7500 Series Ethernet Switches Operation Manual.
