Chapters Download(228 KB)
Table of Contents
2.1 LS81PT4GA-4-Port 1000BASE-PX10 (EPON) Ethernet Card
2.2 LS81PT8GA-8-Port 1000BASE-PX10 (EPON) Ethernet Card
Figure 2-1 LS81PT4GA appearance
The LS81PT4GA provides four SC EPON optical ports and can be connected to ONU devices at the user end through a passive optical splitter (POS).
Table 2-1 LS81PT4GA attributes
Attribute |
LS81PT4GA |
CPU |
MPC8241 |
Boot ROM |
512 KB |
SDRAM |
128 MB |
Dimensions (L W) |
366.7 340 mm (14.4 13.4 in.) |
Maximum power consumption |
20 W |
Connector |
SC |
Number of interfaces |
Four |
Interface transmission speed |
1000 Mbps full duplex |
SFF module |
1000Base-PX-SFF-SC (single mode optical fiber, transmit: 1490 nm, receive: 1310 nm, 10 km) |
Supported standard |
IEEE802.3ah |
Matching engine |
LS81T12PE, LS81P12TE, and Salience III series |
The following table describes the LED state.
Table 2-2 LED state description of LS81PT4GA
LED |
State |
LINK |
OFF |
No link is present. |
ON |
A link is present. |
Table 2-3 Matching cable available for LS81PT4GA
SFF module |
Central wavelength |
Connector |
Matching cable |
Maximum transmission distance |
1000Base-PX-SFF-SC |
Transmit: 1490 nm Receive: 1310 nm |
SC |
9/125 m single mode optical fiber cable |
10 km (6.2 mi) |
Figure 2-3 LS81PT8GA appearance
The LS81PT8GA provides eight SC EPON optical ports and can be connected to ONU devices at the user end through a passive optical splitter (POS).
Table 2-4 LS81PT8GA attributes
Attribute |
LS81PT8GA |
CPU |
MPC8241 |
Boot ROM |
512 KB |
SDRAM |
128 MB |
Dimensions (L W) |
366.7 340mm (14.4 13.4 in.) |
30 W |
Connector |
SC |
Eight |
SFF module |
IEEE802.3ah |
Matching engine |
LS81T12PE, LS81P12TE, and Salience III series (excluding Salience III Lite and Salience III-Plus) |
LS81PT8GA can work only with the LS81T12PE, LS81P12TE, Salience III and Salience III Edge engines.
When the Salience III or Salience III Edge engine is used, LS81PT8GA cannot be inserted in the sixth LPU slot on the S7506 and S7506R, but it can be inserted in any slot on the S7503.
Table 2-5 LED state description of LS81PT8GA
LED |
State |
LINK |
OFF |
ON |
Table 2-6 Matching cable available for LS81PT8GA
SFF module |
Connector |
Matching cable |
SC |
10 km (6.2 mi) |
