 Chapters Download(67  KB)
| H3C EPON |
| OLT Installation Manual |
| Hangzhou H3C Technologies Co., Ltd. http://www.h3c.com
 Manual Version: T2-08046X-20070415-C-1.02 Product Version: Release 5100 Series |
Copyright 2006-2007, Hangzhou H3C Technologies Co., Ltd. and its licensors
All Rights Reserved
No part of this manual may be reproduced or transmitted in any form or by any means without prior written consent of Hangzhou H3C Technologies Co., Ltd.
Trademarks
H3C,  , Aolynk,
, Aolynk,  , H3Care,
, H3Care,  , TOP G,
, TOP G,  , IRF, NetPilot, Neocean, NeoVTL, SecPro, SecPoint,
SecEngine, SecPath, Comware, Secware, Storware, NQA, VVG, V2G, VnG,
PSPT, XGbus, N-Bus, TiGem, InnoVision and HUASAN are trademarks of Hangzhou H3C
All other trademarks that may be mentioned in this manual are the property of their respective owners.
Notice
The information in this document is subject to change without notice. Every effort has been made in the preparation of this document to ensure accuracy of the contents, but all statements, information, and recommendations in this document do not constitute the warranty of any kind, express or implied.
To obtain the latest information, please access:
http://www. h3c.com
Technical Support
http://www. h3c.com
About This Manual
Related Documentation
In addition to this manual, each H3C EPON OLT documentation set includes the following:
| Manual | Description |
| H3C EPON OLT Operation Manual | It introduces EPON system configuration, OLT configuration, ONU configuration, ONU UNI configuration, alarm configuration, and supported features. |
| H3C EPON OLT Command Manual | It provides the commands for EPON system configuration, OLT configuration, ONU configuration, ONU UNI configuration and alarm configuration. |
Organization
H3C EPON OLT Installation Manual is organized as follows:
| Chapter | Contents |
| 1 Product Overview | Gives a brief introduction to H3C S7500 Series Ethernet Switches from the perspective of switching engines. |
| 2 EPON LPUs | Introduces the two EPON LPUs available on the H3C S7500 Series Ethernet Switches. |
| 3 Installation Preparation | Introduces such topics as the precautions and the environmental requirements of H3C S7500 Series Ethernet Switches, the instructions for the installation, the installation tools and so on. |
| 4 Switch Installation | Introduces the installation of the H3C S7500 Series Ethernet Switches, module installation, connections of the power cable, ground wire and the console cable. |
| 5 System Debugging | Introduces the booting process of H3C S7500 Series Ethernet Switches, including the power-on booting of the switch and the system initialization. |
| 6 Switch Monitoring and Maintenance | Introduces hardware and software maintenance of the H3C S7500 Series Ethernet Switches, and ONU software upgrade. |
| Appendix A Installation of B68 Cabinet | Introduces the installation of B68 cabinet. |
| Appendix B Installation of Lightning Arrester for AC Power | Introduces lightning protection for the H3C S7500 Series Ethernet Switches. |
Conventions
The manual uses the following conventions:
| Convention | Description |
| Boldface | The keywords of a command line are in Boldface. |
| italic | Command arguments are in italic. |
| [ ] | Items (keywords or arguments) in square brackets [ ] are optional. |
| { x | y | ... } | Alternative items are grouped in braces and separated by vertical bars. One is selected. |
| [ x | y | ... ] | Optional alternative items are grouped in square brackets and separated by vertical bars. One or none is selected. |
| { x | y | ... } * | Alternative items are grouped in braces and separated by vertical bars. A minimum of one or a maximum of all can be selected. |
| [ x | y | ... ] * | Optional alternative items are grouped in square brackets and separated by vertical bars. Many or none can be selected. |
| &<1-n> | The argument(s) before the ampersand (&) sign can be entered 1 to n times. |
| # | A line starting with the # sign is comments. |
| Boldface | Window names, button names, field names, and menu items are in Boldface. For example, the New User window appears; click OK. |
| > | Multi-level menus are separated by angle brackets. For example, File > Create > Folder. |
| < > | Button names are inside angle brackets. For example, click <OK>. |
| [ ] | Window names, menu items, data table and field names are inside square brackets. For example, pop up the [New User] window. |
| / | Multi-level menus are separated by forward slashes. For example, [File/Create/Folder]. |
 | Means reader be careful. Improper operation may cause data loss or damage to equipment. |
| & Note | Means a complementary description. |
Environmental Protection
This product has been designed to comply with the requirements on environmental protection. For the proper storage, use and disposal of this product, national laws and regulations must be observed.
