On the top navigation bar, click Cloud Services.
From the left navigation pane, select Compute & Storage > Cloud Hosts.
If you are a cloud administrator, click Create. If you are an organization administrator, click Request.
Configure cloud host parameters as needed.
Click Create.
Table-1 Configuring cloud host parameters
Parameter |
Creation Method |
Select the cloud host creation method. Normal Creation indicates that you can configure cloud host parameters as needed. |
Owner |
Specify the user that uses the cloud host. |
AZ |
Select the AZ that provides compute resources for the cloud host. |
Physical Host |
Specify the physical host on which the cloud host will be deployed. |
Image Source |
Specify the type of the image to be used, Public, or Private. |
Storage Type |
Specify the storage type, through which you can specify the storage pool where the cloud host's storage volumes reside. For more information, see "Manage cloud host storage." |
System Disk Data Disk |
Set the size of the system disk and select a data disk for the cloud host. The system disk is created during cloud host creation, and the data disk is a hard disk provided by the hard disk service. After a cloud host is destroyed, its system disk is cleared but data in the data disk retains. To use a data disk, you can assign a hard disk to the cloud host at cloud host creation, or attach a hard disk to the cloud host after cloud host creation. For more information about how to attach a hard disk to a cloud host, see "Attach disks to a cloud host." For more information about how to create cloud disks, see cloud disks in Compute and Storage. |
Network |
Specify a network for the cloud host as needed. |
Security Group |
Specify a security group. If you do not specify any security group, the cloud host belongs to the default security group. |
Authentication Policy |
Auto Generated Password |
Use a
system-generated password. After the cloud host has been created, you can
access the detailed information page of the cloud host and click the |
Manually Specified Password |
Set the password for the cloud host. |
Key |
Enable key authentication. This feature is available only for Linux cloud hosts. If you enable key authentication, select a key pair from the SSH Key list. |
Image Default Password |
Use the default password for the image. The default password of an image is the password used to log in to the cloud host to create the image. |
Tenancy |
Set the tenancy for the cloud host. After the cloud host has been created, you can view the start time, end time, and action upon expiration for the cloud host on the detailed information page of the cloud host. For more information, see "View detailed information about a cloud host." |
