Perform this task to attach cloud disks to cloud hosts or detach cloud disks from cloud hosts. Cloud disks provide block storage, which can be formatted or used to create file systems like physical disks. For more information, see "About cloud disks."
This section contains the following topics:
On the top navigation bar, click Cloud Services.
From the left navigation pane, select Compute & Storage > Cloud Hosts.
Click Attach for the target disks.
Detaching cloud disks from a cloud host will interrupt services running on that cloud host. Make sure you are fully aware of the impact of this operation on your network. |
