01-Fundamentals Configuration Examples
00-S12500_Login_Authentication_Configuration_Examples
Chapters Download  (130.69 KB)
Introduction
This document provides authentication configuration examples for console and Telnet logins.
The H3C S12500 switch supports the following login authentication modes:
·     None—Disables authentication. This mode allows access without authentication and is insecure.
·     Password—Requires a password for login authentication.
·     Scheme—Requires a username and password for login authentication.
To log in to the switch, you can use the methods shown in Table 1.
Table 1 Login methods at a glance
Login method
Default settings and minimum configuration requirements
Console, AUX
By default, login through the console port is enabled and no username or password is required. After login, configure password or scheme authentication mode to improve device security.
By default, login through the AUX port is enabled and requires a password, but no password is configured. To use the AUX port for login, log in through any other method and complete the following configuration tasks:
·     Configure a password for password authentication, or change the authentication mode and configure parameters for the new authentication mode.
·     Assign a user role (network-operator by default).
Telnet
By default, Telnet login is disabled.
To log in through Telnet, complete the following configuration tasks:
·     Enable the Telnet server function.
·     Assign an IP address to a Layer 3 interface. Make sure the interface and the Telnet client can reach each other.
·     Configure an authentication mode for VTY login users. By default, password authentication is used but no password is configured.
·     Assign a user role to VTY login users (network-operator by default).
SSH
By default, SSH login is disabled.
To log in through SSH, complete the following configuration tasks:
·     Enable the SSH server function and configure SSH attributes.
·     Assign an IP address to a Layer 3 interface. Make sure the interface and the SSH client can reach each other.
·     Configure scheme authentication for VTY users (password authentication by default).
For SSH configuration examples, see H3C S12500 SSH Configuration Examples.
This document assumes that you have basic knowledge of login authentication.
Example: Configuring password authentication for console users
Network requirements
Configure password authentication for console users on the switch in Figure 1. Require console users to provide the password test at login.
Figure 1 Network diagram
Requirements analysis
To require a console user to provide a password at login, configure password authentication for the console user interface on the switch.
You do not need to change the user role setting for a console user when password authentication is used. The user role depends on the user role setting for the console user interface and is network-admin by default.
Software version used
This configuration example was created and verified on S12500-CMW710-R7129.
Configuration procedures
# Enable password authentication for the console user interface, and set the password to test.
<Switch1> system-view
[Switch1] user-interface console 0
[Switch1-ui-console0] authentication-mode password
[Switch1-ui-console0] set authentication password simple test
[Switch1-ui-console0] quit
# Log in to the switch through the console port. Verify that the system displays a prompt for the console login password.
* Copyright (c) 2004-2013 Hewlett-Packard Development Company, L.P.            *
* Without the owner's prior written consent,                                        *
* no decompiling or reverse-engineering shall be allowed.                        *
User interface con0 is available.
Press ENTER to get started.
Password:
# Enter the correct password to verify that you can access the CLI.
[Switch1]
Configuration files
user-interface con 0
 user-role network-admin
 set authentication password hash $h$6$4PKgIe09Fnyq3ZGB$Gjw9CActpVa5IJm9oGEgMBxt
opkZkEYv7CriP31oqNJOpAyBPwxIvOds+7XcJ5aGz2xaO77H3CsaSMpRzKenq0Q==
Example: Configuring local scheme authentication for console users
Configure local scheme authentication for console users on the switch in Figure 2. Require console users to provide the username test and password test at login.
Figure 2 Network diagram
To meet the network requirements, perform the following tasks:
·     To require a console user to provide a username and password at login, configure scheme authentication for the console user interface.
·     Because local authentication is the default authentication method for login users, you only need to configure a local user on the switch.
·     To allow the local user to log in to the switch, authorize the local user to use the terminal service.
·     To allow the local user to use all commands, assign the user role network-admin to the local user. The user role of a login user depends on the user role setting for the local user. It is network-operator by default when local scheme authentication is used.
# Enable scheme authentication for the console user interface.
[Switch1-ui-console0] authentication-mode scheme
# Configure a local user with the username test and password test.
[Switch1] local-user test class manage
[Switch1-luser-manage-test] password simple test
# Assign the user role network-admin and the terminal service to the user.
[Switch1-luser-manage-test] authorization-attribute user-role network-admin
[Switch1-luser-manage-test] service-type terminal
[Switch1-luser-manage-test] quit
# Log in to the switch through the console port. Verify that the system displays a prompt for the console login username and password.
login: test
Password:
# Enter the correct username and password to verify that you can access the CLI.
[Switch1]
Configuration files
 domain default enable system
 password hash $h$6$DaTNpkN/T5vDTCTX$knzvBlMhlFZ77CORDl55gdS8+oMzxCsxe/xH+qoSllg
AEyWm7wW70ZB5O2QqlvHEUg8nkLaM/1/xK/6Cvq5shQ==
Example: Configuring password authentication for Telnet users
Configure password authentication for Telnet users on the switch in Figure 3. Require Telnet users to provide the password test at login.
Figure 3 Network diagram
·     To allow Telnet logins, enable the Telnet server on the switch.
·     To require a Telnet user to provide a password at login, configure password authentication for the VTY user interfaces on the switch.
·     To allow a Telnet user to use all commands, assign the user role network-admin to the VTY user interfaces. The default user role is network-operator for a Telnet user.
# Enable Telnet server.
<switch1> system-view
[switch1] telnet server enable
# Configure interface GigabitEthernet 7/0/35.
[switch1] interface Vlan-interface 5
[switch1-Vlan-interface5] ip address 15.15.1.1 16
[switch1-Vlan-interface5] quit
[switch1] interface GigabitEthernet 7/0/35
[switch1-GigabitEthernet7/0/35] port link-mode bridge
[switch1-GigabitEthernet7/0/35] port access vlan 5
[switch1-GigabitEthernet7/0/35] quit
# For all VTY user interfaces, enable password authentication, set the password to test, and assign the user role network-admin.
[switch1] user-interface vty 0 15
[switch1-ui-vty0-15] authentication-mode password
[switch1-ui-vty0-15] set authentication password simple test
[switch1-ui-vty0-15] user-role network-admin
[switch1-ui-vty0-15] quit
# Telnet to the switch. Verify that the system displays a prompt for the password.
Password:
[Switch1]
Configuration files
vlan 5
interface Vlan-interface5
 ip address 15.15.1.1 255.255.0.0
interface GigabitEthernet7/0/35
 port access vlan 5
 set authentication password hash $h$6$ifF6RyM3SrB7BiSA$2zNo5WkQc2Oz8GXYOq7FkL2s
98vO13C11511sWzNn+J/NcqmEKGuwbMubqY0r8gA5iGy7ojYux/m1A+ux+F5yw==
 idle-timeout 0 0
Example: Configuring local scheme authentication for Telnet users
Configure local scheme authentication for Telnet users on the switch in Figure 4. Require Telnet users to provide the username test and password test at login.
Figure 4 Network diagram
·     To allow Telnet logins, enable Telnet server on the switch.
·     To require a Telnet user to provide a username and password at login, configure scheme authentication for the VTY user interfaces.
·     To allow the local user to Telnet to the switch, authorize the local user to use the Telnet service.
# Enable scheme authentication for all VTY user interfaces.
[Switch1-ui-vty0-15] authentication-mode scheme
[Switch1-ui-vty0-15] quit
# Assign the user role network-admin and the Telnet service to the user.
[Switch1-luser-manage-test] service-type telnet
# Telnet to the switch. Verify that the system displays a prompt for the username and password.
login: test
Password:
[Switch1]
Configuration files
vlan 5
 port access vlan 5
 idle-timeout 0 0
 password hash $h$6$uUxUbGGD00+3wYOs$cVq29Rs+FEp5GSCfTmCw3Wkg43lLKHtUaWOf7LkHDAP
7B2VqITsm5OK7vIgd3W2HGDHXzjc1g/Z4PNPIkFN2WQ==
 service-type telnet
Related documentation
·     H3C S12500 Routing Switch Series Fundamentals Configuration Guide
·     H3C S12500 Routing Switch Series Fundamentals Command Reference
