Part 12 - System Monitoring
09-MIB Commands
Chapters Download  (17.62 KB)
09-MIB Commands
MIB Configuration Commands
display mib-style
display mib-style
View
Default Level
3: Manage level
None
Use the display mib-style command to display the MIB style of the device.
Two MIB styles are available on the device: new and compatible. After obtaining the MIB style, select matched H3C network management software based on the MIB style.
Related commands: mib-style.
# After getting the device ID from node sysObjectID, check the current MIB style or the MIB style after next boot of the device.
<Sysname> display mib-style
 Current MIB style: new
 Next reboot MIB style: new
The above output information shows that the current MIB style of the device is new, and the MIB style after next boot is still new.
mib-style
mib-style [ new | compatible ]
View
Default Level
3: Manage level
new: Specifies the MIB style of the device as H3C new, which means both sysOID and private MIB of the device are located under the H3C enterprise ID 25506.
compatible: Specifies the MIB style of the device as H3C compatible, which means sysOID of the device is located under the H3C enterprise ID 25506, and private MIB is located under the enterprise ID 2011.
Use the mib-style command to set the MIB style of the device.
By default, the MIB style of the device is new.
Note that the configuration takes effect only after the device reboots.
# Change the MIB style of the device to compatible.
[Sysname] mib-style compatible
[Sysname] quit
 Next reboot MIB style: compatible
<Sysname> reboot
H3C reserves the right to modify its collaterals without any prior notice. For the latest information of the collaterals, please consult H3C sales or call 400 hotline.
