07-Sampler Commands
Chapters Download (19.04 KB)
display sampler [ sampler-name ] [ slot slot-number ]
View
Default Level
1: Monitor level
sampler-name: Specifies the sampler name, a string of up to 32 characters.
slot slot-number: Displays sampler information of the specified device. The slot-number is the ID of a member device of the current IRF virtual device, which you can display with the display irf command. The slot number range depends on the numbering rules and the number of member devices of the current IRF virtual device. If no IRF virtual device exists, the slot-number argument is the current device number.
Use the display sampler command to view configuration and status information about a sampler.
# Display the configuration and status information about the specified sampler on a switch.
<Sysname> display sampler abc slot 1
Sampler name: abc
Index: 1, Mode: Fixed, Packet-interval: 8
Table 1-1 display sampler command output description
Sampler name |
Name of the sampler |
Index |
Sampler index |
Mode |
Sampling mode |
Packet-interval |
Sampling rate |
sampler sampler-name mode fixed packet-interval rate
undo sampler sampler-name
View
Default Level
2: System level
sampler-name: Specifies the sampler name, a case insensitive string of 1 to 32 characters.
fixed: Sets the sampling mode to fixed.
rate: Specifies the sampling interval, which means one packet out of the two to the power of rate packets is sampled. The value is in the range of 1 to 16.
Use the sampler command to create or modify a sampler.
Use the undo sampler command to delete a sampler.
# Create a fixed sampler with the name abc. Set the sampling interval to 8, which means one packet out of 256 packets (two to the power of eight) is sampled.
[Sysname] sampler abc mode fixed packet-interval 8
