12-Index
Chapters Download (437.79 KB)
A
B
C
D
data-fill,1-1
data-size,1-2
description (any NQA test type view),1-2
destination ip,1-3
destination port,1-4
display channel,1-1
display ip netstream cache,1-1
display ip netstream export,1-3
display ip netstream template,1-4
display ipv6 netstream cache,1-1
display ipv6 netstream export,1-3
display ipv6 netstream template,1-4
display nqa server status,1-37
display sampler,1-1
display sflow,1-1
display snmp-agent community,1-1
display snmp-agent local-engineid,1-3
display snmp-agent mib-view,1-3
display snmp-agent statistics,1-5
display snmp-agent sys-info,1-6
display snmp-agent trap queue,1-7
display snmp-agent trap-list,1-7
display snmp-agent usm-user,1-8
E
enable,1-6
enable,1-6
F
filename,1-12
frequency,1-13
G
H
http-version,1-15
I
info-center console channel,1-10
info-center enable,1-10
info-center logfile enable,1-11
info-center logfile frequency,1-12
info-center logfile size-quota,1-12
info-center logfile switch-directory,1-13
info-center loghost,1-14
info-center loghost source,1-15
info-center monitor channel,1-16
info-center source,1-17
info-center syslog channel,1-20
info-center timestamp loghost,1-22
ip netstream,1-6
ip netstream aggregation advanced,1-8
ip netstream export source,1-10
ip netstream export v9-template refresh-rate packet,1-11
ip netstream export v9-template refresh-rate time,1-12
ip netstream export version,1-12
ip netstream filter,1-13
ip netstream sampler,1-14
ip netstream timeout active,1-15
ip netstream timeout inactive,1-15
ipv6 netstream aggregation,1-7
ipv6 netstream aggregation advanced,1-8
ipv6 netstream export host,1-8
ipv6 netstream export rate,1-9
ipv6 netstream export source,1-10
ipv6 netstream export v9-template refresh-rate packet,1-11
ipv6 netstream export v9-template refresh-rate time,1-12
ipv6 netstream export version 9,1-12
J
K
L
logfile save,1-23
M
mib-style,1-1
mirroring-group,1-2
mirroring-group mirroring-cpu,1-3
mirroring-group mirroring-port,1-4
mirroring-group monitor-egress,1-5
mirroring-group monitor-port,1-6
mirroring-group remote-probe vlan,1-7
mirroring-port,1-7
mirror-to cpu,1-1
monitor-port,1-8
N
netstream filter,1-16
next-hop,1-16
nqa,1-17
nqa agent enable,1-17
nqa schedule,1-19
nqa server enable,1-38
nqa server udp-echo,1-39
O
operation (FTP test type view),1-20
operation (HTTP test type view),1-20
operation interface,1-21
P
password (FTP test type view),1-21
probe count,1-22
probe packet-number,1-24
probe packet-timeout,1-24
probe timeout,1-25
Q
R
reaction,1-26
reaction trap,1-27
reset ip netstream statistics,1-16
reset ipv6 netstream statistics,1-13
reset logbuffer,1-24
reset trapbuffer,1-24
resolve-target,1-27
rmon alarm,1-9
rmon event,1-11
rmon history,1-12
rmon prialarm,1-13
rmon statistics,1-15
route-option bypass-route,1-28
S
sampler,1-1
sflow agent,1-2
sflow collector,1-3
sflow enable,1-4
sflow interval,1-4
snmp-agent,1-10
snmp-agent calculate-password,1-11
snmp-agent community,1-12
snmp-agent group,1-14
snmp-agent local-engineid,1-15
snmp-agent log,1-15
snmp-agent mib-view,1-16
snmp-agent packet max-size,1-17
snmp-agent sys-info,1-18
snmp-agent trap if-mib link extended,1-22
snmp-agent trap life,1-23
snmp-agent trap queue-size,1-24
snmp-agent usm-user { v1 | v2c },1-25
source interface,1-29
source ip,1-30
source port,1-30
statistics hold-time,1-31
statistics interval,1-32
statistics max-group,1-32
T
terminal debugging,1-25
terminal logging,1-25
terminal monitor,1-26
terminal trapping,1-27
tos,1-33
ttl,1-34
type,1-34
U
url,1-35
username (FTP test type view),1-36
V
vpn-instance (ICMP echo test type view),1-36
W
X
Y
