03-ACSEI Commands
Chapters Download (30.79 KB)
acsei client close client-id
View
ACSEI server view
Default Level
2: System level
client-id: ID of the ACSEI client to be closed. An ACSEI client ID is assigned by the ACSEI server, in the range of 1 to 10.
Use the acsei client close command to close the specified ACSEI client.
# Close ACSEI client 1.
[Sysname] acsei server
[Sysname-acsei-server] acsei client close 1
acsei client reboot client-id
View
ACSEI server view
Default Level
2: System level
client-id: ID of the ACSEI client to be restarted, in the range of 1 to 10.
Use the acsei client reboot command to restart the specified ACSEI client.
# Restart ACSEI client 1.
[Sysname-acsei-server] acsei client reboot 1
acsei server
View
Default Level
2: System level
None
Use the acsei server command to enter ACSEI server view.
# Enter ACSEI server view.
acsei server enable
undo acsei server enable
View
Default Level
2: System level
None
Use the acsei server enable command to enable ACSEI server.
Use the undo acsei server enable command to disable ACSEI server.
By default, ACSEI server is disabled.
# Enable ACSEI server.
[Sysname] acsei server enable
acsei timer clock-sync minutes
undo acsei timer clock-sync
View
ACSEI server view
Default Level
2: System level
minutes: Value of the synchronization timer that is used for clock synchronization from ACSEI server to ACSEI client. It ranges from 0 to 1440 (in minutes), where value 0 specifies to disable the clock synchronization from ACSEI server to ACSEI client.
Use the acsei timer clock-sync command to set the synchronization timer that is used for clock synchronization from ACSEI server to ACSEI client.
Use the undo acsei timer clock-sync command to restore the default.
By default, the clock sychronization timer is set to five minutes.
# Set the clock synchronization timer from ACSEI server to ACSEI client to 20 minutes.
[Sysname-acsei-server] acsei timer clock-sync 20
acsei timer monitor seconds
undo acsei timer monitor
View
ACSEI server view
Default Level
2: System level
seconds: Value of the monitoring timer that is used for ACSEI server to monitor ACSEI clients. It ranges from 0 to 10 (in seconds), where 0 specifies to disable ACSEI server from monitoring ACSEI client.
Use the acsei timer monitor command to set the monitoring timer for ACSEI server to monitor ACSEI client.
Use the undo acsei timer monitor command to restore the default.
By default, the monitoring timer is set to 5 seconds.
# Set the monitor timer for ACSEI server to monitor ACSEI client to 6 seconds.
[Sysname-acsei-server] acsei timer monitor 6
display acsei client info [ client-id ]
View
Default Level
1: Monitor level
client-id: ID of an ACSEI client, in the range of 1 to 10.
Use the display acsei client info command to display the ACSEI client information. The client information is retrieved from the advertisement packet sent by the client, so that when there is no ACSEI client information, the command displays the information keywords only.
If executed without the client-id argument, the command displays information about all the ACSEI clients in order of registration time.
# Display information about ACSEI client 1.
<Sysname> display acsei client info 1
Total Client Number: 1
Client ID: 1
Client Description:
Hardware:
System Software:
Application Software:
CPU: Intel(R) Pentium(R) M processor 1.40GHz
PCB Version: 3.00
CPLD Version: 1.00
Bootrom Version: 1.12
CF card: 256 MB
Memory: 512 MB
Harddisk: 40.0 GB
# Display information about all ACSEI clients.
Total Client Number: 2
Client ID: 1
Client Description:
Hardware:
System Software:
PCB Version: 3.00
CPLD Version: 1.00
CF card: 256 MB
Memory: 512 MB
Harddisk: 40.0 GB
Client ID: 2
Client Description:
Hardware:
System Software:
PCB Version: 3.00
CPLD Version: 1.00
CF card: 256 MB
Memory: 512 MB
Harddisk: 40.0 GB
Table 1-1 display acsei client info command output description
Client ID |
ID of the ACSEI client |
Client Description |
ACSEI client description |
Hardware |
Hardware version of the ACSEI client |
System Software |
System software name and version of the ACSEI client |
Application Software |
Application name and version of the ACSEI client |
CPU |
CPU information of the ACSEI client |
PCB Version |
PCB version of the ACSEI client |
CPLD Version |
CPLD version of the ACSEI client |
Bootrom Version |
Boot ROM version of the ACSEI client |
CF card |
CF card information of the ACSEI client |
Memory |
Memory information of the ACSEI client |
Harddisk |
Harddisk information of the ACSEI client |
display acsei client summary [ client-id ]
View
Default Level
1: Monitor level
client-id: ID of an ACSEI client whose summary is to be displayed, in the range of 1 to 10.
Use the display acsei client summary command to display ACSEI client summary information. Summary information of multiple ACSEI clients is displayed in order of registration time.
If executed without the client-id argument, the command displays summary information about all the ACSEI clients.
# Display the summary of ACSEI client 1.
<Sysname> display acsei client summary 1
Client ID: 1
Status: Open
MAC Address: 00e0-fc0a-c3ef
Interface: GigabitEthernet5/0
Last registered: 02/08/2007 12:00:00
# Display the summary of all ACSEI clients.
Client ID: 1
Status: Open
Client ID: 2
Status: Open
MAC Address: 00e0-fa1e-03da
Interface: GigabitEthernet6/0
Last registered: 02/08/2007 13:00:00
Table 1-2 display acsei client summary command output description
Client ID |
Status |
ACSEI client status |
MAC Address |
MAC address of the ACSEI client |
Interface carrying the ACSEI client |
Last registered |
The last registration time of the ACSEI client |
