02-ACFP Commands
Chapters Download (61.27 KB)
acfp server enable
undo acfp server enable
View
Default Level
2: System level
None
Use the acfp server enable command to enable the ACFP server.
Use the undo acfp server enable command to disable the ACFP server.
By default, the ACFP server is disabled.
If the ACSEI server is enabled on the device, when you first disable and then enable the ACFP server, you must also disable and then enable the ACSEI server to ensure that the ACFP collaboration rules can be resent to the ACFP server.
Related commands: acsei server enable in ACSEI Commands in the Command Reference - Part 11 - OAA.
# Enable the ACFP server.
[Sysname] acfp server enable
display acfp client-info [ client-id ]
View
Default Level
1: Monitor level
client-id: Displays information about the specified ACFP client, where client-id is the ACFP client identifier, in the range of 1 to 2147483647.
Use the display acfp client-info command to display information about the specified ACFP client(s).
Note that if no ACFP client ID is specified, information about all the ACFP clients is displayed.
# Display the information about all the ACFP clients.
<Sysname> display acfp client-info
ACFP client total number: 1
ClientID: 4
Description: IPS
Hw-Info: 1.0
OS-Info: Linux Kernel 2.4.20-8
App-Info: 2.0
Client IP: 10.1.1.1
Client Mode: mirror
Table 1-1 display acfp client-info command output description
ACFP client total number |
Total number of ACFP clients |
ClientID |
Client ID, index of client list |
Description information of client |
Hw-Info |
Hardware information of the client |
OS-Info |
Operating system information of the client |
App-Info |
Application software information of the client |
Client IP |
Client IP address |
Client Mode |
Working mode supported on the client: l redirect: redirect mode l mirror: mirror mode |
display acfp policy-info [ client client-id [ policy-index ] | dest-interface interface-type interface-number | in-interface interface-type interface-number | out-interface interface-type interface-number ] [ active | inactive ]
View
Default Level
1: Monitor level
client client-id: Displays the policy sent by the specified ACFP client, where client-id is the ACFP client ID, in the range of 1 to 2147483647.
policy-index: Policy index, in the range of 1 to 2147483647.
dest-interface interface-type interface-number: Displays all the policies that use the specified interface (destination interface) for connecting to the ACFP client, where interface-type interface-number is the interface type and interface number.
in-interface interface-type interface-number: Displays all the policies that use the specified interface as the inbound interface, where interface-type interface-number is the interface type and interface number..
out-interface interface-type interface-number: Displays all the policies that use the specified interface as the outbound interface, where interface-type interface-number is the interface type and interface number.
active: Displays active policies only.
inactive: Displays inactive policies only.
Use the display acfp policy-info command to display the ACFP policy information.
Note that:
l When you use this command to display the policy information sent by the specified ACFP client, if you specify the policy-index argument, the command displays the information about the policy whose number is policy-index applied by the ACFP client with an ID of client-id. Otherwise, the command displays information about all the policies sent by the ACFP client with an ID of client-id.
l If neither the active nor inactive keyword is specified, the command displays all the active or inactive policies.
l If no argument is specified, the command displays information about all the policies.
# Display information about the effective policies for all packets that use GigabitEthernet 1/0/1 as the inbound interface.
<Sysname> display acfp policy-info in-interface gigabitethernet 1/0/1 active
ACFP policy total number: 1
ClientID: 1 Policy-Index: 2
Rule-Num: 20 ContextID: 2007
Exist-Time: 100000(s) Life-Time: 864000(s)
Start-Time: 9:00 End-Time: 12:00
Admin-Status: enable Effect-Status: active
DestIfFailAction: reserve Priority: 4
In-Interface: GigabitEthernet1/0/1
Out-Interface: GigabitEthernet1/0/2
Dest-Interface: Ten-GigabitEthernet1/3/1
Table 1-2 display acfp policy-info command output description
ACFP policy total number |
Total number of ACFP policies |
ClientID |
Policy-Index |
Policy index |
Rule-Num |
Number of rules under the policy |
ContextID |
Context ID |
Exist-Time |
For how long the policy existed, in seconds |
Life-Time |
Policy expiration time, in seconds |
Start-Time |
Policy start time |
End-Time |
Policy end time |
Admin-Status |
Policy administration status |
Effect-Status |
Whether the policy is effective. |
DestIfFailAction |
If the policy dest-interface is down, the actions to all rules under the policy are as follows: l delete: Keep the redirected and mirrored packets being forwarded (for forwarding first devices, select the delete action); l reserve: Discard the redirected and mirrored packets (for security first devices, select the reserve action). |
Priority |
Priority of a policy, number notation, in the range of 1 to 8 (the bigger the number, the higher the priority). |
In-Interface |
Inbound interface of the packet |
Out-Interface |
Outbound interface of the packet |
Dest-Interface |
Interface connected to the ACFP client |
display acfp rule-info { in-interface [ interface-type interface-number ] | out-interface [ interface-type interface-number ] | policy [ client-id policy-index ] }
View
Default Level
1: Monitor level
in-interface: Displays ACFP rule information in order of inbound interface. The ACFP rule information which does not include the inbound interface is not displayed.
out-interface: Displays ACFP rule information in order of outbound interface. The ACFP rule information which does not include the outbound interface is not displayed.
policy: Displays the ACFP rule information in order of policy.
client-id: ACFP client ID, in the range of 1 to 2147483647.
Use the display acfp rule-info command to display ACFP rule information.
Note that:
l When you use this command to display ACFP rule information in order of policy, if you specify neither client ID nor policy index, the rule information about all the policies is displayed.
l When you use this command to display ACFP rule information in order of outbound/inbound interface, if you specify no interface, the rule information about all the inbound interfaces or outbound interfaces is displayed.
# Display ACFP rule information in order of inbound interface.
<Sysname> display acfp rule-info in-interface gigabitethernet 1/0/1
ACFP rule total number: 1
ClientID:2 Policy-Index:2 Rule-Index:5
SMAC:00-01-02-03-04-05 DMAC:01-02-03-04-05-06
StartVLAN:2000 EndVLAN:2004
PackRate:128 Kbps
Action:rate Status:active OperationStatus:succeeded
# Display ACFP rule information in order of policy.
<Sysname> display acfp rule-info policy 1 1
ACFP Rule total number: 1
ClientID:1 Policy-Index:1 Rule-Index:1
SIP:192.168.132.122 SMask:0.0.0.255 SPort:65500 to 65535
DIP:192.168.112.115 DMask:0.0.0.255 DPort:65500 to 65535
Protocol:ipinip Fragment:false DSCP:AF11
Action:redirect Status:inactive OperationStatus:succeeded
Table 1-3 display acfp rule-info command output description
In-Interface |
ACFP rule total number |
Total number of ACFP rules |
ClientID |
Policy-Index |
Policy index |
Rule-Index |
Rule index |
SMAC |
Source MAC address |
DMAC |
Destination MAC address |
StartVLAN |
Start VLAN of the source VLAN |
EndVLAN |
End VLAN of the source VLAN |
PackRate |
Value of the restricted rate of packets, in kbps. |
SIP |
Source IP address |
SMask |
Inverse mask of source IP address |
SPort |
Source port number |
DIP |
Destination IP address |
DMask |
Inverse mask of destination IP address |
DPort |
Destination port number |
Protocol |
Protocol of the packet: GRE, ICMP, IGMP, IPinIP, OSPF, TCP, UDP, IP, and so on. |
Fragment |
Whether the packet is a fragment: l true: Indicates the packet is a fragment l false: Indicates all the packets, not concerned about whether the packet is a fragment or not |
ToS |
Type of Service, indicated by a number in the range of 0 to 15 |
Pre |
Packet precedence, indicated by a number in the range of 0 to 7 |
DSCP |
Differentiated Services Code Point, indicated by characters for Be, Ef, Af11, Af12, Af13, Af21, Af22, Af23, Af31, Af32, Af33, Af41, Af42, Af43, Cs1, Cs2, Cs3, Cs4, Cs5, Cs6, and Cs7 and indicated by a number in the range 0 to 63 for other code points |
TCPFlag |
The value is six bits, which represents URG, ACK, PSH, RST, SYN, and FIN respectively from low to high. |
TCPMask |
The value is six bits, which represents URG mask, ACK mask, PSH mask, RST mask, SYN mask, and FIN mask respectively from low to high. For each bit, the value 1 indicates that this bit is concerned, and the value 0 indicates that this bit is not concerned. |
Action |
Action, including: l permit l deny l mirror l redirect l rate: rate limit |
Status |
Rule status: active or inactive |
OperationStatus |
Rule application status: succeeded or failed |
display acfp server-info
View
Default Level
1: Monitor level
None
Use the display acfp server-info command to display ACFP server information.
# Display ACFP server information.
<Sysname> display acfp server-info
Server-Info: redirect mirror
Max Life-Time: 2147483647(s)
PersistentRules: false
ContextType: HGPlus-context
Table 1-4 display acfp server-info command output description
Server-Info |
ACFP client working mode supported by the ACFP server: l redirect: redirect mode l mirror: mirror mode |
Max Life-Time |
Maximum expiration time (in seconds) of the collaboration policy supported by the server |
PersistentRules |
Whether the server supports permanent collaboration rules. |
ContextType |
Context ID types currently supported by the server: l no-context: No context ID is carried. l HG-context: Carrying the preamble HG as the context ID. l HGPlus-context: Carrying the preamble HGPlus as the context ID. l FlowID-context: Carrying the preamble Flow ID as the context ID. l VLANID-context: Carrying VLAN ID as the context ID. The S5800&S5820X series Ethernet switches support carrying the preamble HGPlus as the context ID (the HGPlus-context) only. |
