08-BFD Commands
Chapters Download (49.45 KB)
bfd authentication-mode { md5 key-id key | sha1 key-id key | simple key-id password }
undo bfd authentication-mode
View
Interface view
Default Level
2: System level
md5: Uses message digest 5 (MD5) authentication.
sha1: Uses secure hash algorithm (SHA-1) authentication.
simple: Uses plaint text authentication.
key-id: Authentication key ID, in the range 1 to 255.
key: A string of 1 to 16 characters. It is displayed as a 24-byte cipher text string when the display current-configuration command is executed.
password: Password, a string of 1 to 16 characters when the simple keyword is used. It can be displayed with the display current-configuration command.
Use the bfd authentication-mode command to configure the BFD authentication mode on the interface.
Use the undo bfd authentication-mode command to restore the default.
By default, no authentication is configured on an interface.
The authentication mode, key-id, key (or password) used by both ends trying to establish a BFD session must be the same. If one end changes its authentication mode, it sends the authentication packets in both the new and the old mode at the same time until the other end also changes to the same authentication mode.
# Configure VLAN-interface 1 to support MD5 authentication, and set the authentication key-id to 15 and authentication key to BfdKey.
[Sysname-Vlan-interface1] bfd authentication-mode md5 15 BfdKey
bfd detect-multiplier value
undo bfd detect-multiplier
View
Interface view
Default Level
2: System level
value: Maximum number of consecutive BFD packets that the remote device fails to receive from the interface before considering the BFD session down, in the range of 3 to 50.
Use the bfd detect-multiplier command to configure the maximum number of consecutive BFD packets that the remote device fails to receive from the local interface before considering the BFD session down.
Use the undo bfd detect-multiplier command to restore the default.
The default is 5.
# Configure the detect multiplier as 6 on VLAN-interface 1.
[Sysname-Vlan-interface1] bfd detect-multiplier 6
bfd echo-source-ip ip-address
undo bfd echo-source-ip
View
Default Level
2: System level
ip-address: Source IP address of BFD echo packets.
Use the bfd echo-source-ip command to configure the source IP address of BFD echo packets.
Use the undo bfd echo-source-ip command to remove the configured source IP address of BFD echo packets.
Do not configure the source IP address of the BFD echo packets to belong to the same network segment as any interface address of the device. Otherwise a large amount of ICMP redirect packets may be sent by the remote device, causing network congestion.
# Configure the source IP address of echo packets as 10.1.1.1.
[Sysname] bfd echo-source-ip 10.1.1.1
bfd min-echo-receive-interval value
undo bfd min-echo-receive-interval
View
Interface view
Default Level
2: System level
value: Minimum echo receiving interval, in milliseconds. The value ranges from 200 to 1000.
Use the bfd min-echo-receive-interval command to configure the minimum echo packet receiving interval on the interface.
Use the undo bfd min-echo-receive-interval command to restore the default minimum echo packet receiving interval on the interface.
The default minimum echo packet receiving interval is 400 milliseconds.
# Configure the minimum echo receiving interval on VLAN-interface 1 as 500 milliseconds.
[Sysname-Vlan-interface1] bfd min-echo-receive-interval 500
bfd min-receive-interval value
undo bfd min-receive-interval
View
Interface view
Default Level
2: System level
value: Minimum interval for receiving BFD control packets, in milliseconds. The value ranges from 200 to 1000.
Use the bfd min-receive-interval command to configure the minimum interval for receiving BFD control packets.
Use the undo bfd min-receive-interval command to restore the default minimum interval for receiving BFD control packets.
The default minimum interval for receiving BFD control packets is 400 milliseconds.
Note that, if the remote device sends BFD control packets at an interval shorter than the minimum receiving interval of the local device, the remote device changes its sending interval to the minimum receiving interval of the local device.
# Configure the minimum interval for receiving BFD control packets on VLAN-interface 1 as 500 milliseconds.
[Sysname-Vlan-interface1] bfd min-receive-interval 500
bfd min-transmit-interval value
undo bfd min-transmit-interval
View
Interface view
Default Level
2: System level
value: Minimum interval for transmitting BFD control packets, in milliseconds. The value ranges from 200 to 1000.
Use the bfd min-transmit-interval command to configure the minimum interval for transmitting BFD control packets.
Use the undo bfd min-transmit-interval command to restore the default minimum interval for transmitting BFD control packets.
The default minimum interval for transmitting BFD control packets is 400 milliseconds
Note that, a proper interval ensures that BFD control packets are not transmitted faster than the device can deal with. The actual interval for transmitting BFD control packets at the local device should be the greater between the minimum interval for sending BFD control packets configured on the local interface and the minimum interval for receiving BFD control packets on the remote device.
# Configure the minimum interval for transmitting BFD control packets on VLAN-interface 1 as 500 milliseconds.
[Sysname-Vlan-interface1] bfd min-transmit-interval 500
undo bfd multi-hop destination-port
View
Default Level
2: System level
port-number: Destination port number of multi-hop BFD control packets, 3784 or 4784.
Use the bfd multi-hop destination-port command to configure the destination port number for multi-hop BFD control packets as 3784 or 4784.
Use the undo bfd multi-hop destination-port command to restore the default.
By default, the destination port number for multi-hop BFD control packets is 4784.
# Configure the destination port number for multi-hop BFD control packets as 3784.
[Sysname] bfd multi-hop destination-port 3784
undo bfd session init-mode
View
Default Level
2: System level
active: Uses the active mode. In the active mode, BFD actively transmits BFD control packets to the remote device.
passive: Uses the passive mode. In the passive mode, BFD does not actively transmit a BFD control packet to the remote end; it transmits a BFD control packet only after receiving a BFD control packet from the remote end.
Use the bfd session init-mode command to configure the mode for establishing a BFD session.
Use the undo bfd session init-mode command to restore the default.
By default, BFD uses the active mode.
# Configure the session establishment mode as passive.
[Sysname] bfd session init-mode passive
display bfd debugging-switches
View
Default Level
2: System level
None
Use the display bfd debugging-switches command to display enabled BFD debugging switches.
# Display enabled BFD debugging switches.
<Sysname> display bfd debugging-switches
BFD Error debugging is on
BFD Event debugging is on
BFD FSM debugging is on
BFD Packet Receive debugging is on
BFD Packet Send debugging is on
BFD SCM debugging is on
BFD Timer debugging is on
display bfd interface [ verbose ]
View
Default Level
2: System level
verbose: Displays detailed interface information.
Use the display bfd interface command to display information about BFD-enabled interfaces.
# Display brief information about BFD-enabled interfaces.
<Sysname> display bfd interface
Total Interface Num: 1
Interface: Vlan-interface21 Session Num: 1
Min Trans Inter: 200ms Min Recv Inter: 200ms
DetectMult: 3 Min Echo Recv Inter: 400ms
Auth mode: Simple
# Display detailed information about BFD-enabled interfaces.
<Sysname> display bfd interface verbose
Auth mode: Simple
LD/RD SourceAddr DestAddr ConnType State Mode
2/2 192.168.11.11 192.168.11.10 Direct Up Ctrl
Table 1-1 display bfd interface command output description
Interface name |
Session Num |
Number of sessions established on the local interface |
Min Trans Inter |
Minimum transmit interval configured on the interface |
Min Recv Inter |
Minimum receive interval configured on the interface |
DetectMult |
Session detection multiplier |
Auth mode |
Session authentication mode: simple, MD5, or SHA-1 |
LD |
Local ID of the session |
RD |
Remote ID of the session |
SourceAddr |
Source IP address of the session |
DestAddr |
Destination IP address of the session |
ConnType |
Connection type of the interface |
State |
Session state |
Mode |
Working mode of the session: control (Ctrl) mode or echo (Echo) mode. |
display bfd session [ slot slot-number [ all | verbose ] | verbose ]
View
Default Level
2: System level
verbose: Displays detailed session information.
slot slot-number: Displays the session information of the specified IRF member device. The slot-number argument is the number of the IRF member device, which you can display with the display irf command. The value range for the slot-number argument depends on the number of members and numbering conditions in the current IRF virtual device.
all: Displays detailed information about all the BFD sessions.
Use the display bfd session command to display BFD session information.
With no slot number specified, this command displays information about all current BFD sessions on the IRF member device.
# Display detailed information about all the sessions.
<Sysname> display bfd session verbose
Total Session Num: 2 Init Mode: Active
Session Working Under Ctrl Mode:
Local Discr: 1 Remote Discr: 1
Source IP: 192.168.11.11 Destination IP: 192.168.11.10
Session State: Up Interface: Vlan-interface20
Min Trans Inter: 200ms Act Trans Inter: 200ms
Min Recv Inter: 200ms Act Detect Inter: 1000ms
Running Up for: 00:02:36 Auth mode: None
Connect Type: Direct Board Num: 1
Protocol: OSPF
Diag Info: No Diagnostic
Table 1-2 display bfd session command output description
LD/ Local Discr |
RD/Remote Discr |
SourceAddr/ Source IP |
DestAddr/ Destination IP |
State/Session State |
Session state |
Holdtime |
Length of time before session detection timer expires |
Name of the interface on the session |
Min Trans Inter |
Expected minimum transmit interval configured on the interface |
Min Recv Inter |
Expected minimum receive interval configured on the interface |
Act Trans Inter |
Actual transmit interval |
Act Detect Inter |
Actual session detection timer |
Recv Pkt Num |
Number of packets received |
Send Pkt Num |
Number of packets sent |
Auth mode |
Connect Type |
Running up for |
Time interval for which the session has been up |
Board Num |
The member device maintaining the session |
Protocol |
Registered protocol |
Diag Info |
Diagnostic information about the session |
reset bfd session statistics [slot slot-number ]
View
Default Level
2: System level
slot slot-number: Clears the session statistics of the specified IRF member device. The slot-number argument is the number of the IRF member device, which you can display with the display irf command. The value range for the slot-number argument depends on the number of members and numbering conditions in the current IRF virtual device.
Use the reset bfd session statistics command to clear BFD session statistics.
# Clear BFD session statistics on No.6 IRF member device.
<Sysname> reset bfd session statistics slot 6
snmp-agent trap enable bfd
undo snmp-agent trap enable bfd
View
Default Level
3: Manage level
None
Use the snmp-agent trap enable bfd command to enable sending BFD traps.
Use the undo snmp-agent trap enable bfd command to disable sending BFD traps.
By default, sending BFD traps is enabled.
# Disable sending BFD traps.
[Sysname] undo snmp-agent trap enable bfd
