09-User Profile Commands
Chapters Download (63.23 KB)
display user-profile
View
Default Level
2: System level
None
Use the display user-profile command to display information about all the user profiles that have been created.
# Display information about all the user profiles that have been created.
<Sysname> display user-profile
Status User profile AuthType
disabled a123 PORTAL
enabled b123 DOT1X
----Total user profiles: 2-------
----Enabled user profiles: 1-------
Table 1-1 display user-profile command output description
Status |
Status of the current user profile: l enabled l disabled |
User profile |
User profile name |
AuthType |
Authentication type of the current user profile, which may take the following values: l DOT1X: 802.1X authentication l PORTAL: portal authentication |
Total user profiles |
Total number of user profiles that have been created |
Enabled user profiles |
Total number of user profiles that have been enabled |
user-profile profile-name enable
undo user-profile profile-name enable
View
Default Level
2: System level
profile-name: Use profile name, a case sensitive string of 1 to 31 characters. It can only contain English letters, digits, underlines, and must start with an English letter.
Use the user-profile enable command to enable a user profile that has been created.
Use the undo user-profile enable command to disable the specified user profile.
By default, a created user profile is disabled.
Note that:
l When you execute the command, the specified user profile must be created; otherwise, the command fails.
l Only enabled user profiles can be applied for authenticated users.
l You cannot modify or remove the configurations in a user profile until the user profile is disabled.
l Disabling a user profile logs out the users that are using the user profile.
# Enable user profile a123.
[Sysname] user-profile a123 enable
View
Default Level
2: System level
profile-name: Use profile name, a case sensitive string of 1 to 31 characters. It can only contain English letters, digits, underlines, and must start with an English letter. A user profile name must be globally unique.
Use the user-profile command to create a user profile and enter the user profile view. If the specified user profile already exists, you directly enter the user profile view.
Use the undo user-profile command to remove an existing disabled user profile.
By default, no user profiles exist on the device.
Note that an enabled user profile cannot be removed.
Related commands: user-profile enable.
# Create user profile a123.
[Sysname-user-profile-a123]
# Enter the user profile view of a123.
