05-Congestion Management Configuration Commands
Chapters Download (58.89 KB)
Table of Contents
1 Congestion Management Configuration Commands
SP Queuing Configuration Commands
WRR Queuing Configuration Commands
display qos sp interface [ interface-type interface-number ]
View
Default Level
1: Monitor level
interface-type interface-number: Specifies an interface by type and number.
Use the display qos sp interface command to view the strict priority (SP) queuing configuration of an interface.
If no interface is specified, the SP queuing configuration of all the interfaces is displayed.
Related commands: qos sp.
# Display the SP queuing configuration of interface GigabitEthernet 1/0/1.
<Sysname> display qos sp interface gigabitethernet 1/0/1
Output queue: Strict-priority queue
Table 1-1 display qos sp interface command output description
Interface type and interface number |
Output queue |
Pattern of the current output queue |
Strict-priority queue |
SP queuing is used for queue scheduling |
qos sp
undo qos sp
View
Interface view, port group view
Default Level
2: System level
None
Use the qos sp command to configure SP queuing on an interface.
Use the undo qos sp command to restore the default.
The default queuing algorithm on an interface is WRR queuing.
Settings in interface view are effective on the current interface. Settings in port group view are effective on all ports in the port group.
Related commands: display qos sp interface.
# Enable SP queuing on interface GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] qos sp
display qos wrr interface [ interface-type interface-number ]
View
Default Level
1: Monitor level
Use the display qos wrr interface command to display the weighted round robin (WRR) queuing configuration on an interface.
If no interface is specified, the WRR queuing configuration of all the interfaces is displayed.
Related commands: qos wrr.
# Display the WRR queuing configuration of interface GigabitEthernet 1/0/1.
<Sysname> display qos wrr interface gigabitethernet 1/0/1
Output queue: Weighted round robin queue
Queue ID Group Byte-count
0 1 1
1 1 2
2 1 3
3 1 4
4 1 5
5 1 9
6 1 13
7 sp N/A
Table 1-2 display qos wrr interface command output description
Output queue |
Queue ID |
ID of a queue |
Group |
Number of the group to which a queue is assigned. By default, all queues belong to group 1. |
Weight |
Queue weight based on which queues are scheduled. N/A indicates that the queue uses the SP queuing. |
qos wrr
undo qos wrr
View
Default Level
2: System level
None
Use the qos wrr command to enable WRR queuing on the interface.
Use the undo qos wrr command to disable WRR queuing on the interface.
Before performing WRR configuration, you must enable WRR queuing on an interface by using the qos wrr command.
# Enable WRR queuing on interface GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] qos wrr
qos wrr queue-id group 1 byte-count schedule-value
undo qos wrr queue-id group 1 byte-count
View
Default Level
2: System level
queue-id: Queue ID, in the range of 0 to 7.
1: Assigns the queue to group 1.
byte-count schedule-value: Specifies the number of bytes to be sent from the queue during a cycle. The schedule-value argument ranges from 1 to 15.
Use the qos wrr byte-count command to configure or modify the WRR queuing parameters for a queue on the interface.
Use the undo qos wrr byte-count command to restore the default WRR queuing parameters for a queue on the interface.
For queues configured as WRR queues on an interface, the interface uses WRR scheduling. Other queues on the interface use the default WRR scheduling weight and belong to the default WRR priority group.
Related commands: display qos wrr interface.
# Enable WRR queuing on interface GigabitEthernet 1/0/1, configure the scheduling weight as 10 for queue 0, and assign queue 0 to group 1.
[Sysname-GigabitEthernet1/0/1] qos wrr 0 group 1 byte-count 10
qos wrr queue-id group sp
undo qos wrr queue-id group sp
View
Default Level
2: System level
sp: Strict priority (SP) queuing algorithm.
Use the qos wrr group sp command to configure SP+WRR queuing on the interface and assign a queue to the SP group.
Use the undo qos wrr group sp command to remove a queue on the interface from the SP group.
Before configuring this command on an interface, make sure that WRR queuing is enabled on the interface. An SP group differs from a common WRR priority group. Queues in an SP group are scheduled by using the SP queuing algorithm, and not the WRR queuing algorithm.
Settings in interface view are effective on the current interface only. Settings in port group view are effective on all the ports in the port group.
# Enable WRR queuing on GigabitEthernet 1/0/1, and assign queue 0 to the SP group.
[Sysname-GigabitEthernet1/0/1] qos wrr 0 group sp
display qos wfq interface [ interface-type interface-number ]
View
Default Level
1: Monitor level
Use the display qos wfq interface command to display the weighted fair queuing (WFQ) configuration on an interface.
If no interface is specified, the WFQ configuration of all the interfaces is displayed.
Related commands: qos wfq.
# Display the WFQ configuration of interface GigabitEthernet 1/0/1.
<Sysname> display qos wfq interface gigabitethernet 1/0/1
Output queue: Hardware weighted fair queue
Queue ID Weight Min-Bandwidth
0 1 64
1 1 64
2 1 64
3 1 64
4 1 64
5 1 64
6 1 64
7 1 64
Table 1-3 display qos wfq interface command output description
Output queue |
Queue ID |
ID of a queue |
Weight |
Queue scheduling weight |
Min-Bandwidth |
Minimum guaranteed bandwidth |
undo qos bandwidth queue queue-id [ min bandwidth-value ]
View
Default Level
2: System level
bandwidth-value: Minimum guaranteed bandwidth (in kbps), which is the minimum bandwidth guaranteed for a queue when the port is congested. The range for the bandwidth-value argument is from 64 to 1048576.
Use the qos bandwidth queue command to set the minimum guaranteed bandwidth for a specified queue on the port/port group.
Use the undo qos bandwidth queue command to cancel the configuration.
# Set the minimum guaranteed bandwidth to 100 kbps for queue 0 on interface GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] qos wfq
[Sysname-GigabitEthernet1/0/1] qos bandwidth queue 0 min 100
qos wfq
undo qos wfq
View
Default Level
2: System level
Use the qos wfq command to enable WFQ on an interface.
Use the undo qos wfq command to restore the default queuing algorithm on an interface.
# Enable WFQ on interface GigabitEthernet 1/0/1.
qos wfq queue-id weight schedule-value
undo qos wfq queue-id weight
View
Default Level
2: System level
schedule-value: Scheduling weight of the queue. The value range for the schedule-value argument is from 1 to 15.
Use the qos wfq weight command to configure a scheduling weight for an WFQ queue on the interface.
Use the undo qos wfq weight command to restore the default scheduling weight for an WFQ queue on the interface.
By default, the scheduling weight of each queue is 1.
Related commands: display qos wfq interface, qos bandwidth queue.
# Configure the scheduling weight as 10 for WFQ queue 0 on interface GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] qos wfq 0 weight 10
