03-Priority Mapping Configuration Commands
Chapters Download (37.81 KB)
Table of Contents
1 Priority Mapping Configuration Commands
Priority Mapping Table Configuration Commands
Port Priority Configuration Commands
Per-Port Priority Trust Mode Configuration Commands
display qos map-table [ dot1p-dp | dot1p-lp | dscp-dot1p| dscp-dp | dscp-dscp ]
View
Default Level
1: Monitor level
dot1p-dp: 802.1p-to-drop priority mapping table.
dot1p-lp: 802.1p-to-local priority mapping table.
dscp-dot1p: DSCP-to-802.1p priority mapping table.
dscp-dp: DSCP-to-drop priority mapping table.
dscp-dscp: DSCP-to-DSCP priority mapping table.
Use the display qos map-table command to display the configuration of a priority mapping table.
If no priority mapping table is specified, the configuration information of all priority mapping tables is displayed.
Related commands: qos map-table.
# Display the configuration information of the 802.1p-to-drop priority mapping table.
<Sysname> display qos map-table dot1p-dp
MAP-TABLE NAME: dot1p-dp TYPE: pre-define
IMPORT : EXPORT
0 : 0
1 : 0
2 : 0
3 : 0
4 : 0
5 : 0
6 : 0
7 : 0
Table 1-1 display qos map-table command output description
MAP-TABLE NAME |
Name of the priority mapping table |
TYPE |
Type of the priority mapping table |
IMPORT |
Input values of the priority mapping table |
EXPORT |
Output values of the priority mapping table |
View
Priority mapping table view
Default Level
2: System level
import-value-list: List of input values.
export-value: Output value.
all: Deletes all the mappings in the priority mapping table.
Use the import command to configure a mapping from one or multiple input values to an output value.
Use the undo import command to restore the specified mapping or all mappings to the default.
Related commands: display qos map-table, display qos map-table color.
# Configure the 802.1p-to-drop priority mapping table to map 802.1p priority values 4 and 5 to drop precedence value 1.
[Sysname] qos map-table dot1p-dp
[Sysname-maptbl-dot1p-dp] import 4 5 export 1
qos map-table { dot1p-dp | dot1p-lp | dscp-dot1p | dscp-dp | dscp-dscp }
View
Default Level
2: System level
Use the qos map-table command to enter the specified priority mapping table view.
Related commands: display qos map-table.
# Enter the 802.1p-to-drop priority mapping table view.
qos priority priority-value
undo qos priority
View
Interface view, port group view
Default Level
2: System level
priority-value: Port priority value. The port priority is local precedence, which defaults to 0 and ranges from 0 to 7.
Use the qos priority command to change the port priority of an interface.
Use the undo qos priority command to restore the default.
By default, the port priority is 0.
In interface view, the setting is effective on the current interface only. In port group view, the setting is effective on all the ports in the port group.
# Set the port priority of interface GigabitEthernet 1/0/1 to 2.
[Sysname-GigabitEthernet1/0/1] qos priority 2
View
Default Level
1: Monitor level
interface-type interface-number: Specifies an interface by type and number.
Use the display qos trust interface command to display priority trust mode and port priority information of an interface.
If no interface is specified, the command display priority trust mode and port priority information for all interfaces.
# Display the priority trust mode and port priority settings of interface Ethernet 1/1 (on a single port priority-type device).
<Sysname> display qos trust interface gigabitethernet 1/0/1
Port priority information
Port priority: 0
Port priority trust type: untrust
Table 1-2 display qos trust interface command output description
Interface type and interface number |
Port priority |
The port priority set for the interface |
Port priority trust type |
Priority trust mode on the interface, which can be: l dscp: indicates that the DSCP precedence value of the received packets is used for priority mapping l dot1p: indicates that the 802.1p priority of the received packets is used for priority mapping l untrust: indicates that the port priority is used for priority mapping |
qos trust { dot1p | dscp }
undo qos trust
View
Default Level
2: System level
dot1p: Uses the 802.1p priority in incoming packets for priority mapping.
dscp: Uses the DSCP value in incoming packets for priority mapping.
Use the qos trust command to configure an interface to use a particular priority field carried in packets for priority mapping.
Use the undo qos trust command to restore the default priority trust mode.
By default, the port priority is used for priority mapping.
When packets enter the device, the device assigns a set of parameters (including 802.1p priority, DSCP values, IP precedence, local precedence, and drop precedence) to the packets as configured.
The local precedence and drop precedence are defined as follows:
l A local precedence is locally significant and corresponds to an output queue.
l A drop precedence is used for packet drop. The value 2 corresponds to red packets, 1 corresponds to yellow packets, and 0 corresponds to green packets.
# Configure interface GigabitEthernet 1/0/1 to use the 802.1p priority in incoming packets for priority mapping.
[Sysname-GigabitEthernet1/0/1] qos trust dot1p
