00-1Cover
Chapters Download (78.68 KB)
H3C S3600 Series EPON OLT Switches |
Operation Manual |
Hangzhou H3C Technologies Co., Ltd. http://www.h3c.com
Manual Version: 6W100-20090520 Product Version: Release 3103 |
Copyright © 2009, Hangzhou H3C Technologies Co., Ltd. and its licensors
All Rights Reserved
No part of this manual may be reproduced or transmitted in any form or by any means without prior written consent of Hangzhou H3C Technologies Co., Ltd.
Trademarks
H3C,
, Aolynk,
, H3Care,
, TOP G,
, IRF, NetPilot, Neocean, NeoVTL, SecPro,
SecPoint, SecEngine, SecPath, Comware, Secware, Storware, NQA, VVG, V2G,
VnG, PSPT, XGbus, N-Bus, TiGem, InnoVision and HUASAN are trademarks
All other trademarks that may be mentioned in this manual are the property of their respective owners.
Notice
The information in this document is subject to change without notice. Every effort has been made in the preparation of this document to ensure accuracy of the contents, but all statements, information, and recommendations in this document do not constitute the warranty of any kind, express or implied.
Technical Support
http://www.h3c.com
About This Manual
Organization
H3C S3600 Series EPON OLT Switches Operation Manual-Release 3103 is organized as follows:
Part |
Contents |
01-EPON-OLT Configuration |
l OLT configuration |
02-Login Configuration |
l Introduction to User Interface |
03-Port Configuration |
l Configuring the broadcast storm suppression ratio l Test the optical link between the ONU and the OLT |
04-MAC Address Table Configuration |
l Configuring MAC Address Aging Timer l Disabling Global MAC Address Learning l Disabling MAC Address Learning on Port |
05-Link Aggregation Configuration |
l Configuring a Static Aggregation Group l Configuring a Dynamic Aggregation Group l Configuring a Load Sharing Mode for Load-Sharing Link Aggregation Groups |
06-Port Isolation Configuration |
07-Port Mirroring Configuration |
l Configuring local port mirroring l Configuring remote port mirroring |
08-Smart Link Configuration |
l Configuring Smart Link |
09-DLDP-Fiber Backup Configuration |
l Configuring DLDP l Configuring fiber backup |
10-Extended OAM Configuration |
11-VLAN Configuration |
l Configuring Basic VLAN Settings l Configuring port-based VLAN l Configuring protocol-based VLAN |
12-QinQ Configuration |
l Configuring basic QinQ l Configuring selective QinQ |
13-BPDU Tunneling Configuration |
l Configuring BPDU Transparent Transmission l Configuring Destination Multicast MAC Address for BPDU Tunnel Frames |
14-VLAN Mapping Configuration |
l Configuring one-to-one VLAN mapping |
15-MSTP Configuration |
l Configuring MSTP |
16-RRPP Configuration |
l Configuring RRPP |
17-IP Addressing-IP Performance Optimization Configuration |
18-ARP Configuration |
l Configuring the Maximum Number of ARP Entries for an Interface |
19-DHCP Snooping Configuration |
l Configuring DHCP snooping |
20-Static Routing Configuration |
l Configuring static route l Configuring default route |
21-Mulitcast Configuration |
l Configuring the IGMP Snooping Mode for the ONU Device l Configuring IGMP Snooping l Configuring multicast VLAN |
22-ACL Configuration |
l Configuring a basic IPv4 ACL l Configuring an advanced IPv4 ACL l Configuring an Ethernet Frame Header ACL l Configuring a Basic IPv6 ACL |
23-QoS Configuration |
l Configuring a QoS policy l Configuring traffic policy l Configuring line rate l Configuring SP/WRR/SP+WRR queuing l Configuring priority mapping l Configuring traffic mirroring |
24-AAA Configuration |
l Configuring RADIUS l Configuring HWTACACS |
25-SSH2.0 Configuration |
l Configuring SSH 2.0 l Configuring SFTP |
26-Public Key Configuration |
27-SNMP-RMON Configuration |
28-NTP Configuration |
l Configuring the Operation Modes of NTP l Configuring Optional Parameters of NTP |
29-Information Center Configuration |
l Configuring Information Center l Configure the output direction of information |
30-DNS Configuration |
31-File System Management Configuration |
l Configuration file management l Configuring FTP server/client l Configuring TFTP client |
32-System Configuration and Debugging |
l Configuring User Privilege Levels and Command Levels l Updating ONUs l Hotfix configuration |
33-Appendix |
l List of acronyms used in this manual. |
Conventions
The manual uses the following conventions:
Convention |
Boldface |
The keywords of a command line are in Boldface. |
italic |
Command arguments are in italic. |
Items (keywords or arguments) in square brackets [ ] are optional. |
{ x | y | ... } |
Alternative items are grouped in braces and separated by vertical bars. One is selected. |
[ x | y | ... ] |
Optional alternative items are grouped in square brackets and separated by vertical bars. One or none is selected. |
{ x | y | ... } * |
Alternative items are grouped in braces and separated by vertical bars. A minimum of one or a maximum of all can be selected. |
[ x | y | ... ] * |
Optional alternative items are grouped in square brackets and separated by vertical bars. Many or none can be selected. |
&<1-n> |
The argument(s) before the ampersand (&) sign can be entered 1 to n times. |
A line starting with the # sign is comments. |
Convention |
Boldface |
Window names, button names, field names, and menu items are in Boldface. For example, the New User window appears; click OK. |
Convention |
Means reader be extremely careful. Improper operation may cause bodily injury. |
Means reader be careful. Improper operation may cause data loss or damage to equipment. |
Means an action or information that needs special attention to ensure successful configuration or good performance. |
Means a complementary description. |
Means techniques helpful for you to make configuration with ease. |
Related Documentation
In addition to this manual, each H3C S3600 series EPON OLT switch documentation set includes the following:
Manual |
H3C S3600 Series EPON OLT Switches Installation Manual |
It introduces the installation procedure, commissioning, maintenance and monitoring of the S3600 Series EPON OLT switches. |
H3C S3600 Series EPON OLT Switches Command Manual-Release 3103 |
It is used for assisting the users in using various commands. |
Obtaining Documentation
You can access the most up-to-date H3C product documentation on the World Wide Web at this URL: http://www.h3c.com.
The following are the columns from which you can obtain different categories of product documentation:
[Products & Solutions]: Provides information about products and technologies, as well as solutions.
[Technical Support & Document > Technical Documents]: Provides several categories of product documentation, such as installation, operation, and maintenance.
[Technical Support & Document > Product Support > Software]: Provides the documentation released with the software version.
Documentation Feedback
We appreciate your comments.
