33-Appendix
Chapters Download (52.8 KB)
# A B C D E F G H I K L M N O P Q R S T U V W X Z
Acronyms |
Full spelling |
# Return |
10GE |
Ten-GigabitEthernet |
AAA |
Authentication, Authorization and Accounting |
ABC |
Activity Based Costing |
ABR |
Area Border Router |
AC |
Alternating Current |
ACK |
ACKnowledgement |
ACL |
Access Control List |
ADSL |
Asymmetric Digital Subscriber Line |
AFI |
Address Family Identifier |
ALG |
Application Layer Gateway |
AM |
accounting management |
ANSI |
American National Standard Institute |
AP |
Access Point |
ARP |
Address Resolution Protocol |
AS |
Autonomous System |
ASBR |
Autonomous System Border Router |
ASCII |
American Standard Code for Information Interchange |
ASE |
Application service element |
ASIC |
Application Specific Integrated Circuit |
ASM |
Any-Source Multicast |
ASN |
Auxiliary Signal Network |
AT |
Advanced Technology |
AT |
Adjacency Table |
ATM |
Asynchronous Transfer Mode |
AUX |
Auxiliary (port) |
B Return |
BC |
Bearer Control |
BDR |
Backup Designated Router |
BFD |
Bidirectional Forwarding Detection |
BGP |
Border Gateway Protocol |
BIMS |
Branch Intelligent Management System |
BOOTP |
Bootstrap Protocol |
BPDU |
Bridge Protocol Data Unit |
BRI |
Basic Rate Interface |
BSR |
Bootstrap Router |
BT |
BitTorrent |
BT |
Burst Tolerance |
C Return |
CA |
Call Appearance |
CA |
Certificate Authority |
CAR |
Committed Access Rate |
CBS |
Committed Burst Size |
CBQ |
Class Based Queuing |
CBR |
Constant Bit Rate |
CBT |
Core-Based Tree |
CCITT |
International Telephone and Telegraph Consultative Committee |
CE |
Customer Edge |
CFD |
Connectivity Fault Detection |
CFM |
Configuration File Management |
CHAP |
Challenge Handshake Authentication Protocol |
CIDR |
Classless Inter-Domain Routing |
CIR |
Committed Information Rate |
CIST |
Common and Internal Spanning Tree |
CLNP |
Connectionless Network Protocol |
CPOS |
Channelized POS |
CPU |
Central Processing Unit |
CQ |
Custom Queuing |
CRC |
Cyclic Redundancy Check |
CR-LSP |
Constraint-based Routing LSP |
CR-LDP |
Constraint-based Routing LDP |
CSMA/CD |
Carrier Sense Multiple Access/Collision Detect |
CSNP |
Complete SNP |
CSPF |
Constraint Shortest Path First |
CST |
Common Spanning Tree |
CT |
Call Transfer |
CV |
Connectivity Verification |
D Return |
DAR |
Deeper Application Recognition |
DCE |
Data Circuit-terminal Equipment |
DD |
Database Description |
DDN |
Digital Data Network |
DHCP |
Dynamic Host Configuration Protocol |
DIS |
Designated IS |
DLCI |
Data Link Connection Identifier |
DLDP |
Device Link Detection Protocol |
DNS |
Domain Name System |
DoD |
Downstream on Demand |
DoS |
Denial of Service |
DR |
Designated Router |
DSCP |
Differentiated Services Codepoint Priority |
DSP |
Digital Signal Processor |
DTE |
Data Terminal Equipment |
DU |
Downstream Unsolicited |
D-V |
Distance Vector Routing Algorithm |
DVMRP |
Distance Vector Multicast Routing Protocol |
DWDM |
Dense Wavelength Division Multiplexing |
E Return |
EACL |
Enhanced ACL |
EAD |
Endpoint Admission Defense |
EAP |
Extensible Authentication Protocol |
EAPOL |
Extensible Authentication Protocol over LAN |
EBGP |
External Border Gateway Protocol |
EBS |
Excess Burst Size |
EGP |
Exterior Gateway Protocol |
ES |
End System |
ES-IS |
End System-Intermediate System |
F Return |
FCoE |
Fabric Channel over Ethernet |
FC |
Forwarding Class |
FCS |
Frame Check Sequence |
FDDI |
Fiber Distributed Data Interface |
FDI |
Forward Defect Indication |
FEC |
Forwarding Equivalence Class |
FFD |
Fast Failure Detection |
FG |
Forwarding Group |
FIB |
Forwarding information base |
FIFO |
First In First Out |
FQDN |
Full Qualified Domain Name |
FR |
Frame Relay |
FRR |
Fast ReRoute |
FRTT |
Fairness Round Trip Time |
FT |
Functional Test |
FTP |
File Transfer Protocol |
G Return |
GARP |
Generic Attribute Registration Protocol |
GE |
Gigabit Ethernet |
GR |
Graceful Restart |
GRE |
Generic Routing Encapsulation |
GTS |
Generic Traffic Shaping |
GVRP |
GARP VLAN Registration Protocol |
H Return |
HA |
High Availability |
HABP |
HW Authentication Bypass Protocol |
HDLC |
High-level Data Link Control |
HEC |
Header Error Control |
HoPE |
Hiberarchy of PE |
HoVPN |
Hiberarchy of VPN |
HQoS |
Hierarchical Quality of Service |
HSB |
Hot Standby |
HTTP |
Hyper Text Transport Protocol |
H-VPLS |
Hiberarchy of VPLS |
HVRP |
Hierarchy VLAN Register Protocol |
HWTACACS |
HUAWEI Terminal Access Controller Access Control System |
I Return |
IA |
Incoming Access |
IANA |
Internet Assigned Number Authority |
IBGP |
Internal BGP |
IBM |
International Business Machines |
ICMP |
Internet Control Message Protocol |
ICMPv6 |
Internet Control Message Protocol for IPv6 |
ID |
IDentification/IDentity |
IEEE |
Institute of Electrical and Electronics Engineers |
IETF |
Internet Engineering Task Force |
IGMP |
Internet Group Management Protocol |
IGMP-Snooping |
Internet Group Management Protocol Snooping |
IGP |
Interior Gateway Protocol |
ILM |
Incoming Label Map |
ILS |
Internet Locator Service |
IN |
Intelligent Network |
IP |
Internet Protocol |
IPng |
IP Next Generation |
IPSec |
IP Security |
IPTN |
IP Phone Telephony Network |
IPv6 |
Internet protocol version 6 |
IPX |
Internet Packet Exchange |
IS |
ISATAP |
Intra-Site Automatic Tunnel Addressing Protocol |
ISDN |
Integrated Services Digital Network |
IS-IS |
Intermediate System-to-Intermediate System intra-domain routing information exchange protocol |
ISO |
International Organization for Standardization |
ISP |
Internet service provider |
ISSU |
In Service Software Upgrade |
IST |
ITU-T |
International Telecommunication Union - Telecommunication Standardization Sector |
K Return |
KB |
Kilobyte |
KEK |
Key-encrypting key |
L Return |
L2TP |
Layer 2 Tunneling Protocol |
L2VPN |
Layer 2 VPN |
L3VPN |
Layer 3 VPN |
LACP |
Link Aggregation Control Protocol |
LACPDU |
Link Aggregation Control Protocol Data Unit |
LAN |
Local Area Network |
LCP |
Link Control Protocol |
LDAP |
Lightweight Directory Access Protocol |
LDP |
Label Distribution Protocol |
LER |
Label Edge Router |
LFIB |
Label Forwarding Information Base |
LIB |
Label Information Base |
LLC |
Link Layer Control |
LLDP |
Link Layer Discovery Protocol |
LOC |
Loss of continuity |
LOG |
Call Logging |
LR |
Line Rate |
LRTT |
Loop Round Trip Time |
LSA |
Link State Advertisement |
LSAck |
Link State Acknowledgment |
LSDB |
Link State Database |
LSP |
Label Switch Path |
LSPAGENT |
Label Switched Path AGENT |
LSPDU |
Link State Protocol Data Unit |
LSPM |
Label Switch Path Management |
LSR |
Link State Request |
LSR |
Label Switch Router |
LSR-ID |
Label Switch Router Identity |
LSU |
Link State Update |
M Return |
MAC |
Media Access Control |
MAN |
Metropolitan Area Network |
MaxBC |
Max Bandwidth Constraints |
MBGP |
Multiprotocol Border Gateway Protocol |
MD |
Multicast Domain |
MDI |
Medium Dependent Interface |
MDT |
Multicast Distribution Tree |
MED |
multi-exit discrimination (MED) |
MIB |
Management Information Base |
MLD |
Multicast Listener Discovery Protocol |
MLD-Snooping |
Multicast Listener Discovery Snooping |
MMC |
Meet-Me Conference |
MODEM |
MOdulator-DEModulator |
MP |
Multilink PPP |
MP-BGP |
Multiprotocol extensions for BGP-4 |
MPE |
Middle-level PE |
MP-group |
Multilink Point to Point Protocol group |
MPLS |
Multiprotocol Label Switching |
MPLSFW |
Multi-protocol Label Switch Forward |
MPM |
Multicast Port Management |
MSC |
Mobile Switching Center |
MSDP |
Multicast Source Discovery Protocol |
MSOH |
Multiplex Section Overhead |
MSTI |
Multi-Spanning Tree Instance |
MSTP |
Multiple Spanning Tree Protocol |
MT |
Multicast Tunnel |
MTBF |
Mean Time Between Failure |
MTI |
Multicast Tunnel Interface |
MTU |
Maximum Transmission Unit |
MVRF |
Multicast VPN Routing and Forwarding |
N Return |
NAPT |
Network Address Port Translation |
NAS |
Network Access Server |
NAT |
Net Address Translation |
NBMA |
Non Broadcast Multi-Access |
NBT |
NetBIOS over TCP/IP |
NCP |
Network Control Protocol |
ND |
Neighborhood discovery |
NDA |
NetStream Data Analyzer |
NDC |
Network Data Collector |
NDP |
Neighbor Discovery Protocol |
NetBIOS |
Network Basic Input/Output System |
NHLFE |
Next Hop Label Forwarding Entry |
NLPID |
Network Layer Protocol Identifier |
NLRI |
Network Layer Reachable Information |
NMS |
Network Management Station |
NPDU |
Network Protocol Data Unit |
NPE |
Network Provider Edge |
NQA |
Network Quality Analyzer |
NSAP |
Network Service Access Point |
NSC |
NetStream Collector |
N-SEL |
NSAP Selector |
NSSA |
Not-So-Stubby Area |
NTDP |
Neighbor Topology Discovery Protocol |
NTP |
Network Time Protocol |
O Return |
OAM |
Operation Administration and Maintenance |
OAMPDU |
OAM Protocol Data Units |
OC-3 |
OC-3 |
OID |
Object Identifier |
OL |
Optical Line |
OSI |
Open Systems Interconnection |
OSPF |
Open Shortest Path First |
P Return |
P2MP |
Point to MultiPoint |
P2P |
Point To Point |
PAP |
Password Authentication Protocol |
PCB |
Printed Circuit Board |
PCM |
Pulse Code Modulation |
PD |
Powered Device |
PDU |
PE |
Provider Edge |
PHP |
Penultimate Hop Popping |
PHY |
Physical layer |
PIM |
Protocol Independent Multicast |
PIM-DM |
Protocol Independent Multicast-Dense Mode |
PIM-SM |
Protocol Independent Multicast-Sparse Mode |
PIR |
Peak Information Rate |
PKCS |
Public Key Cryptography Standards |
PKI |
Public Key Infrastructure |
PMTU |
Path MTU |
PoE |
Power over Ethernet |
POP |
Point Of Presence |
POS |
Packet Over SDH |
PPP |
Point-to-Point Protocol |
PPTP |
Point to Point Tunneling Protocol |
PPVPN |
Provider-provisioned Virtual Private Network |
PQ |
Priority Queuing |
PRC |
Primary Reference Clock |
PRI |
Primary Rate Interface |
PS |
Protection Switching |
PSE |
Power Sourcing Equipment |
PSNP |
Partial SNP |
PVC |
Permanent Virtual Channel |
PW |
Pseudo wires |
Q Return |
QACL |
QoS/ACL |
QinQ |
802.1Q in 802.1Q |
QoS |
QQIC |
Querier's Query Interval Code |
QRV |
Querier's Robustness Variable |
R Return |
RA |
Registration Authority |
RADIUS |
Remote Authentication Dial in User Service |
RAM |
random-access memory |
RD |
Routing Domain |
RD |
Router Distinguisher |
RED |
Random Early Detection |
RFC |
Request For comments |
RIP |
Routing Information Protocol |
RIPng |
RIP next generation |
RM |
Route management |
RMON |
Remote Monitoring |
ROM |
Read Only Memory |
RP |
Rendezvous Point |
RPC |
Remote Procedure Call |
RPF |
Reverse Path Forwarding |
RPR |
Resilient Packet Ring |
RPT |
Rendezvous Point Tree |
RRPP |
Rapid Ring Protection Protocol |
RSB |
Reservation State Block |
RSOH |
Regenerator Section Overhead |
RSTP |
Rapid Spanning Tree Protocol |
RSVP |
Resource ReserVation Protocol |
RTCP |
Real-time Transport Control Protocol |
RTE |
Route Table Entry |
RTP |
Real-time Transport Protocol |
RTP |
S Return |
SA |
Source Active |
SBM |
Subnetwork Bandwidth Management |
SCFF |
Single Choke Fairness Frame |
SD |
Signal Degrade |
SDH |
Synchronous Digital Hierarchy |
SETS |
Synchronous Equipment Timing Source |
SF |
Sampling Frequency |
SFM |
Source-Filtered Multicast |
SFTP |
Secure FTP |
Share-MDT |
Share-Multicast Distribution Tree |
SIP |
Session Initiation Protocol |
Site-of-Origin |
Site-of-Origin |
SLA |
Service Level Agreement |
SMB |
Standby Main Board |
SMTP |
Simple Mail Transfer Protocol |
SNAP |
Sub Network Access Point |
SNMP |
Simple Network Management Protocol |
SNP |
Sequence Number Packet |
SNPA |
Subnetwork Points of Attachment |
SOH |
Section Overhead |
SONET |
Synchronous Optical NETwork |
SOO |
Site-of-Origin |
SP |
Strict Priority Queueing |
SPE |
Superstratum PE/Sevice Provider-end PE |
SPF |
SPT |
Shortest Path Tree |
SSH |
Secure Shell |
SSM |
Synchronization Status Marker |
SSM |
Source-Specific Multicast |
ST |
Shared Tree |
STM-1 |
SDH Transport Module -1 |
STM-16 |
SDH Transport Module -16 |
STM-16c |
SDH Transport Module -16c |
STM-4c |
SDH Transport Module -4c |
STP |
SVC |
Signalling Virtual Connection |
Switch-MDT |
Switch-Multicast Distribution Tree |
T Return |
TA |
Terminal Adapter |
TACACS |
TDM |
Time Division Multiplexing |
TCP |
Transmission Control Protocol |
TE |
Traffic Engineering |
TEDB |
TE DataBase |
TFTP |
Trivial File Transfer Protocol |
TLS |
Transparent LAN Service |
TLV |
Type-Length-Value |
ToS |
Type of Service |
TPID |
Tag Protocol Identifier |
TRIP |
Trigger RIP |
TS |
Traffic Shaping |
TTL |
Time to Live |
TTY |
True Type Terminal |
U Return |
UDP |
User Datagram Protocol |
UPE |
Underlayer PE or User-end PE |
URL |
Uniform Resource Locators |
URPF |
Unicast Reverse Path Forwarding |
USM |
User-Based Security Model |
V Return |
VBR |
Variable Bit Rate |
VCI |
Virtual Channel Identifier |
VE |
Virtual Ethernet |
VFS |
Virtual File System |
VLAN |
Virtual Local Area Network |
VLL |
Virtual Leased Lines |
VOD |
Video On Demand |
VoIP |
Voice over IP |
VOS |
Virtual Operate System |
VPDN |
Virtual Private Dial-up Network |
VPDN |
Virtual Private Data Network |
VPI |
Virtual Path Identifier |
VPLS |
Virtual Private Local Switch |
VPN |
VRID |
Virtual Router ID |
VRRP |
Virtual Router Redundancy Protocol |
VSI |
Virtual Switch Interface |
VT |
Virtual Tributary |
VTY |
Virtual Type Terminal |
W Return |
WAN |
Wide Area Network |
WFQ |
Weighted Fair Queuing |
WINS |
Windows Internet Naming Service |
WLAN |
wireless local area network |
WRED |
Weighted Random Early Detection |
WRR |
Weighted Round Robin |
WTR |
Wait-to-Restore |
WWW |
World Wide Web |
X Return |
XGE |
Z Return |
ZBR |
Zone Border Router |
