Chapters Download(191 KB)
The command index includes all the commands in the VRP Command Manual, which are arranged alphabetically.
A B C D E F G H I J K L M N O P Q R S T U V W X Y Z
3pcc |
Call Services |
14-1 |
aaa enable |
Feature |
4-1 |
access (LS-GW view) |
System Management |
2-5 |
access (LS-OFFICEGROUP view) |
System Management |
2-5 |
access command |
System Management |
2-6 |
access list |
System Management |
2-6 |
acct |
Feature |
4-4 |
adi (abbreviated dialing service view) |
Call Services |
6-1 |
adi (subscriber number view) |
Call Services |
6-1 |
alarm (alarm clock view) |
Call Services |
26-1 |
alarm (subscriber number view) |
Call Services |
26-1 |
area-code (LS-GW view) |
Feature |
1-1 |
area-code (LS-OFFICEGROUP view) |
Feature |
1-1 |
area-code-substitute (LS-GW view) |
Feature |
1-2 |
area-code-substitute (LS-OFFICEGROUP view) |
Feature |
1-3 |
arp static |
IP Performance and Application |
2-1 |
ascii |
System Management |
4-28 |
attribute |
Location Server Configuration |
2-1 |
authentication (LS-GW view) |
1-1 |
authentication-mode |
System Management |
1-1 |
auto-execute command |
System Management |
1-2 |
auto-operator |
Call Services |
22-1 |
bearer-capability (LS-GW view) |
1-1 |
bearer-capability (LS-OFFICEGROUP-OFFICE view) |
1-2 |
belongto |
2-1 |
binary |
System Management |
4-28 |
bootfile backup |
System Management |
4-1 |
bootfile dir |
System Management |
4-2 |
bootfile main |
System Management |
4-3 |
break |
Call Services |
11-1 |
bye |
System Management |
4-29 |
caller-group |
Call Services |
20-1 |
caller-member |
Call Services |
20-1 |
call-limit-group |
Call Services |
4-1 |
call-mode |
1-2 |
call-signal ip-address |
1-3 |
call-signal port |
1-4 |
cb |
Call Services |
15-1 |
cba |
Call Services |
5-1 |
cd |
System Management |
4-4 |
cd |
System Management |
4-29 |
cdup |
System Management |
4-30 |
cfb |
Call Services |
10-9 |
cfb-number |
Call Services |
10-9 |
cfc |
Call Services |
10-4 |
cf-caller |
Call Services |
10-4 |
cfnr |
Call Services |
10-2 |
cfnr-number |
Call Services |
10-3 |
cfo |
Call Services |
10-7 |
cfo-number |
Call Services |
10-8 |
cft (CFT service view) |
Call Services |
10-6 |
cft (subscriber number view) |
Call Services |
10-6 |
cfu |
Call Services |
10-1 |
cfu-number |
Call Services |
10-1 |
change |
Call Services |
4-1 |
clir (CLIR service view) |
Call Services |
8-1 |
clir (subscriber number view) |
Call Services |
8-1 |
clock datetime |
Basic Configuration |
1-1 |
clock summer-time |
1-1 |
clock timezone |
1-2 |
close |
System Management |
4-30 |
codec (LS-GW view) |
1-7 |
codec (LS-GW-PREFIX view) |
1-5 |
codec (LS-GW-SUBSCRIBER view) |
1-6 |
codec (LS-OFFICEGROUP-OFFICE view) |
1-8 |
codec (LS-OFFICEGROUP-PREFIX view) |
1-9 |
command-alias |
1-3 |
command-privilege |
1-4 |
config |
Call Services |
23-1 |
copy |
System Management |
4-5 |
cpu |
Feature |
3-1 |
databits |
System Management |
1-3 |
debugging |
System Management |
3-1 |
debugging |
System Management |
4-31 |
debugging aaa event |
System Management |
5-1 |
debugging aaa primitive |
System Management |
5-1 |
debugging arp packet |
2-2 |
debugging ip |
1-1 |
debugging location-server |
1-10 |
debugging modem |
System Management |
7-1 |
debugging process-server |
Process Server Configuration |
1-1 |
debugging snmp-agent |
System Management |
6-1 |
debugging tcp event |
1-2 |
debugging tcp md5 |
1-3 |
debugging tcp packet |
1-4 |
debugging telnet |
System Management |
1-18 |
debugging udp packet |
1-4 |
debugging vty |
System Management |
1-3 |
default-limit-call-time |
Call Services |
13-1 |
default-ring |
Call Services |
20-2 |
delete |
System Management |
4-6 |
delete |
System Management |
4-31 |
delete static-routes all |
3-1 |
device-status (LS-GW view) |
1-11 |
device-status (LS-OFFICEGROUP-OFFICE view) |
1-12 |
device-status forever-up attachedps |
2-2 |
device-type (LS-GW view) |
1-13 |
device-type (LS-OFFICEGROUP-OFFICE view) |
1-13 |
dial-test |
Call Services |
18-1 |
dir |
System Management |
4-7 |
dir |
System Management |
4-32 |
disconnect |
System Management |
4-32 |
display arp |
2-2 |
display channel |
System Management |
3-7 |
display clipboard |
1-7 |
display clock |
1-7 |
display command-alias |
1-8 |
display cpu-usage-for-user |
1-8 |
display current-configuration |
1-9 |
System Management |
4-14 |
display debugging |
System Management |
3-2 |
display debugging location-server |
1-14 |
display debugging process-server |
1-3 |
display device manuinfo |
System Management |
3-28 |
display diagnostic-information |
1-10 |
System Management |
3-2 |
display fib |
1-5 |
display fib begin |
1-6 |
display fib longer |
1-7 |
display fib statistics |
1-8 |
display ftp-server |
System Management |
4-22 |
display ftp-user |
System Management |
4-23 |
display gui-user |
System Management |
2-4 |
display history-command |
1-11 |
display info-center |
System Management |
3-8 |
display interface ethernet |
2-1 |
display ip interface |
1-8 |
2-3 |
display ip routing-table |
3-1 |
display ip socket |
1-11 |
display ip statistics |
1-12 |
display location-server 3pcc |
Call Services |
14-1 |
display location-server call-limit-group |
Call Services |
4-2 |
Call Services |
4-3 |
display location-server call-limit-group bind |
Call Services |
4-3 |
display location-server call-list |
Call Services |
11-1 |
display location-server domain |
1-14 |
display location-server gateway |
1-15 |
display location-server media-server |
Media Server |
1-1 |
display location-server notify-config |
Call Services |
23-2 |
display location-server notify-group |
Call Services |
23-3 |
display location-server number-substitute |
Feature |
1-3 |
display location-server office-group |
1-18 |
display location-server process-server |
1-19 |
display location-server statistics |
1-21 |
display location-server subscriber-role |
Call Services |
5-1 |
display location-server subscriber-type |
Call Services |
5-2 |
display location-server substitute |
Feature |
1-4 |
display location-server tunnelpeer |
1-23 |
display logbuffer |
System Management |
3-9 |
display media-server location-server status |
Media Server |
1-2 |
display media-server media-resource |
Media Server |
2-1 |
display media-server media-resource predefine |
Media Server |
2-1 |
display overload |
Feature |
3-1 |
display process-server call-information |
1-4 |
display process-server location-server status |
1-4 |
display process-server statistics |
1-5 |
display saved-configuration |
1-11 |
System Management |
4-16 |
display schedule reboot |
System Management |
3-11 |
display snmp-agent |
System Management |
6-1 |
display snmp-agent community |
System Management |
6-2 |
display snmp-agent group |
System Management |
6-3 |
display snmp-agent mib-view |
System Management |
6-4 |
display snmp-agent statistics |
System Management |
6-5 |
display snmp-agent sys-info |
System Management |
6-6 |
display snmp-agent usm-user |
System Management |
6-6 |
display startup |
System Management |
4-17 |
display subscriber |
Feature |
1-4 |
display tcp statistics |
1-13 |
display tcp status |
System Management |
1-18 |
1-14 |
display this |
1-12 |
display this |
System Management |
4-17 |
display trapbuffer |
System Management |
3-11 |
display udp statistics |
1-15 |
display user-interface |
System Management |
1-4 |
display users |
System Management |
1-5 |
display version |
1-13 |
display xe-service |
System Management |
8-2 |
dnd |
Call Services |
7-1 |
domain |
2-2 |
do-not-disturb |
Call Services |
7-1 |
duplex |
2-2 |
dynamic-ip |
1-25 |
emergency-call |
Call Services |
3-1 |
emergency-call-number |
Call Services |
3-1 |
enable command-alias |
1-13 |
execute |
System Management |
4-8 |
extension |
Call Services |
22-1 |
file prompt |
System Management |
4-8 |
flow-control |
System Management |
1-5 |
forbid |
Call Services |
4-5 |
format |
Call Services |
23-4 |
format |
System Management |
4-9 |
format |
Media Server |
2-2 |
free user-interface |
System Management |
1-6 |
ftp |
System Management |
4-33 |
ftp server enable |
System Management |
4-23 |
ftp timeout |
System Management |
4-24 |
ftp update |
System Management |
4-24 |
gatekeeper |
1-8 |
gateway (LS view) |
1-25 |
get |
System Management |
4-33 |
gk-config |
1-9 |
group-config (group-notify view) |
Call Services |
23-5 |
group-notify (LS-SRV view) |
Call Services |
23-4 |
gui |
System Management |
2-1 |
gui-config |
System Management |
2-1 |
header |
1-14 |
heartbeat password |
1-9 |
Media Server |
1-3 |
heartbeat password (LS-MS view) |
Media Server |
3-1 |
heartbeat password (LS-PS view) |
1-26 |
heartbeat-time-range |
1-27 |
history-command max-size |
System Management |
1-7 |
hotkey |
1-15 |
idle-timeout |
System Management |
1-7 |
info-center channel |
System Management |
3-12 |
info-center console channel |
System Management |
3-13 |
info-center enable |
System Management |
3-13 |
info-center logbuffer |
System Management |
3-14 |
info-center loghost |
System Management |
3-15 |
info-center loghost source |
System Management |
3-16 |
info-center monitor channel |
System Management |
3-17 |
info-center snmp channel |
System Management |
3-17 |
info-center source |
System Management |
3-18 |
info-center timestamp |
System Management |
3-20 |
info-center trapbuffer |
System Management |
3-21 |
interface |
2-3 |
interval (LS-SRV-CB view) |
Call Services |
15-1 |
ip address |
2-4 |
ip host |
2-4 |
ip route-static |
3-2 |
ip-address (LS-GW view) |
1-27 |
ip-address (LS-OFFICEGROUP-OFFICE view) |
1-28 |
irr-frequency |
1-11 |
join |
Call Services |
23-6 |
language |
Media Server |
1-3 |
language |
Media Server |
2-3 |
language (LS-MS view) |
Media Server |
3-1 |
language-mode |
1-17 |
lcd |
System Management |
4-34 |
limited-call-group (call limit group view) |
Call Services |
4-6 |
limited-call-group (subscriber number view) |
Call Services |
4-6 |
limited-call-time |
Call Services |
13-1 |
limited-group |
Call Services |
4-7 |
limited-time-call |
Call Services |
13-2 |
load-share |
Feature |
2-1 |
local-user ftp-directory |
System Management |
4-25 |
local-user level |
System Management |
1-8 |
local-user password |
System Management |
4-26 |
local-user service-type |
System Management |
4-27 |
lock |
1-17 |
loopback (Ethernet/Gigabitethernet Interface) |
2-5 |
lrq-mode |
1-10 |
ls |
System Management |
4-34 |
ls-back |
Feature |
2-1 |
ls-config |
1-28 |
ls-mode |
1-11 |
ls-mode |
Media Server |
1-4 |
manufacturer |
1-29 |
media-ability |
Media Server |
2-3 |
media-server |
Media Server |
1-4 |
media-server |
Media Server |
3-2 |
member |
Call Services |
23-6 |
mkdir |
System Management |
4-10 |
mkdir |
System Management |
4-35 |
modem |
System Management |
1-9 |
modem |
System Management |
7-1 |
modem auto-answer |
System Management |
1-9 |
modem auto-answer |
System Management |
7-2 |
modem timer answer |
System Management |
1-10 |
more |
System Management |
4-10 |
move |
System Management |
4-11 |
ms-config |
Media Server |
1-5 |
mtu |
1-16 |
mtu (Ethernet/Gigabitethernet Interface) |
2-6 |
multiplex (LS-GW view) |
1-30 |
multiplex (LS-OFFICEGROUP-OFFICE view) |
1-30 |
multiplex (LS-PS view) |
1-31 |
myring |
Call Services |
20-3 |
nat&fw |
2-3 |
notify-config |
Call Services |
23-7 |
number-substitute |
Feature |
1-5 |
office |
1-31 |
office-group |
1-32 |
only |
Call Services |
12-1 |
open |
System Management |
4-35 |
otapc |
1-33 |
overload-protection |
Feature |
3-2 |
parity |
System Management |
1-10 |
participant |
Call Services |
14-2 |
passive |
System Management |
4-36 |
password (LS-GW view) |
1-33 |
ping |
System Management |
3-3 |
policy area-code-substitute |
Feature |
1-6 |
policy call-interrupt-by-long-time |
1-12 |
policy call-interrupt-time |
1-13 |
policy num-substitute |
Feature |
1-6 |
policy random selection |
1-34 |
policy select-rule |
1-34 |
policy substitute-inherit |
Feature |
1-7 |
policy unknown-device-admission |
1-35 |
port (LS-GW view) |
1-36 |
port (LS-OFFICEGROUP-OFFICE view) |
1-36 |
prefix (LS-GW view) |
1-37 |
prefix (LS-OFFICEGROUP view) |
1-38 |
prefix-rule (Prefix view) |
Feature |
1-8 |
priority (LS-GW view) |
1-38 |
priority (LS-OFFICEGROUP-OFFICE view) |
1-39 |
priority (prefix view) |
1-39 |
priority (subscriber view) |
1-40 |
process-server |
1-41 |
promiscuous |
2-6 |
prompt |
Call Services |
22-2 |
ps-config |
1-13 |
psgroup-id (LS-GW view) |
Feature |
2-2 |
psgroup-id (LS-PS view) |
Feature |
2-3 |
put |
System Management |
4-36 |
pwd |
System Management |
4-11 |
pwd |
System Management |
4-37 |
pwd-call-password |
Call Services |
9-1 |
quit |
1-18 |
quit |
System Management |
4-37 |
radius server |
Feature |
4-1 |
radius shared-key |
Feature |
4-2 |
radius source-address |
Feature |
4-2 |
radius timer response-timeout |
Feature |
4-3 |
ras-port |
Feature |
2-3 |
reboot |
System Management |
3-5 |
redirect |
System Management |
1-11 |
register-port |
Feature |
2-4 |
relative-capability |
Feature |
2-5 |
remotehelp |
System Management |
4-38 |
rename |
System Management |
4-12 |
repair-tcp |
1-14 |
reset arp |
2-5 |
reset ip statistics |
1-17 |
reset location-server statistics |
1-41 |
reset logbuffer |
System Management |
3-22 |
reset process-server statistics |
1-14 |
reset recycle-bin |
System Management |
4-13 |
reset saved-configuration |
System Management |
4-18 |
reset tcp statistics |
1-17 |
reset trapbuffer |
System Management |
3-22 |
reset udp statistics |
1-18 |
reset-ual |
System Management |
2-3 |
response-irr |
1-15 |
retry(LS-SRV-CB view) |
Call Services |
15-2 |
return |
1-19 |
ring |
Call Services |
20-3 |
rmdir |
System Management |
4-13 |
rmdir |
System Management |
4-38 |
rule (LS-GW view) |
Feature |
1-9 |
rule (LS-OFFICEGROUP view) |
Feature |
1-10 |
rule (Substitute table view) |
Feature |
1-11 |
save |
System Management |
4-18 |
save-now |
System Management |
4-19 |
schedule reboot at |
System Management |
3-22 |
schedule reboot delay |
System Management |
3-24 |
screen-length |
System Management |
1-12 |
script trigger connect |
System Management |
7-3 |
script trigger dial |
System Management |
7-3 |
script trigger init |
System Management |
7-4 |
script trigger login |
System Management |
7-5 |
script trigger logout |
System Management |
7-5 |
script-string |
System Management |
7-6 |
send |
System Management |
1-12 |
service |
Call Services |
1-1 |
service modem-callback |
System Management |
3-24 |
set authentication password |
System Management |
1-13 |
set-media |
Media Server |
2-4 |
shell |
System Management |
1-14 |
shutdown |
Call Services |
23-7 |
sip |
1-16 |
sip-config |
1-16 |
sip-port |
Feature |
2-5 |
snmp-agent |
System Management |
6-7 |
System Management |
6-8 |
snmp-agent group |
System Management |
6-9 |
snmp-agent local-engineid |
System Management |
6-10 |
System Management |
6-11 |
snmp-agent packet max-size |
System Management |
6-11 |
System Management |
6-12 |
snmp-agent target-host |
System Management |
6-13 |
snmp-agent trap enable |
System Management |
6-14 |
snmp-agent trap life |
System Management |
6-15 |
snmp-agent trap queue-size |
System Management |
6-16 |
snmp-agent trap source |
System Management |
6-17 |
System Management |
6-17 |
speed |
2-7 |
speed |
System Management |
1-15 |
srv-switch |
Call Services |
1-1 |
srv-switch adi |
Call Services |
6-2 |
srv-switch alarm |
Call Services |
26-2 |
srv-switch announce |
Call Services |
19-1 |
srv-switch cb |
Call Services |
15-2 |
srv-switch cba |
Call Services |
5-3 |
srv-switch cfb |
Call Services |
10-10 |
srv-switch cf-caller |
Call Services |
10-5 |
srv-switch cfnr |
Call Services |
10-3 |
srv-switch cfo |
Call Services |
10-8 |
srv-switch cft |
Call Services |
10-7 |
srv-switch cfu |
Call Services |
10-2 |
srv-switch ci |
Call Services |
17-1 |
srv-switch clip |
Call Services |
8-2 |
srv-switch clir |
Call Services |
8-2 |
srv-switch cp |
Call Services |
16-1 |
srv-switch cpcp |
Call Services |
21-1 |
srv-switch ct |
Call Services |
24-1 |
srv-switch do-not-disturb |
Call Services |
7-2 |
srv-switch group-limited-call |
Call Services |
4-7 |
srv-switch limited-time-call |
Call Services |
13-2 |
srv-switch myring |
Call Services |
20-4 |
srv-switch pwd-call |
Call Services |
9-1 |
srv-switch query-self |
Call Services |
25-1 |
srv-switch rio |
Call Services |
8-3 |
srv-switch tcir |
Call Services |
8-3 |
sscb-manage |
Call Services |
2-1 |
sscb-rule (Subscriber view) |
Feature |
1-12 |
start |
Call Services |
23-8 |
start |
1-42 |
start |
Feature |
3-3 |
start |
System Management |
2-2 |
start |
Media Server |
1-5 |
start (PS view) |
1-17 |
start (PS-GK view) |
1-17 |
start (PS-SIP view) |
1-18 |
start-script |
System Management |
7-9 |
startup saved-configuration |
System Management |
4-20 |
stop |
1-42 |
stop |
Feature |
3-3 |
stop |
System Management |
2-2 |
stop |
Media Server |
1-6 |
stop (PS view) |
1-19 |
stop (PS-GK view) |
1-18 |
stop (PS-SIP view) |
1-19 |
stopbits |
System Management |
1-15 |
subscriber |
1-43 |
subscriber-role (LS view) |
Call Services |
5-4 |
subscriber-role (outgoing call control service view) |
Call Services |
5-4 |
subscriber-status |
Call Services |
2-1 |
subscriber-type (LS view) |
Call Services |
5-5 |
subscriber-type (user role view) |
Call Services |
5-5 |
subsline-sum |
Feature |
2-6 |
substitute (LS view) |
Feature |
1-14 |
Feature |
1-13 |
Feature |
1-14 |
substitute (Prefix view) |
Feature |
1-15 |
substitute (Subscriber view) |
Feature |
1-16 |
super |
1-19 |
super password |
1-20 |
sysname |
1-21 |
system-view |
1-22 |
tcp mss |
1-18 |
tcp timer fin-timeout |
1-19 |
tcp timer syn-timeout |
1-19 |
tcp window |
1-20 |
telnet |
System Management |
1-19 |
tel-number |
Call Services |
12-1 |
terminal debugging |
System Management |
3-25 |
terminal logging |
System Management |
3-26 |
terminal monitor |
System Management |
3-26 |
terminal trapping |
System Management |
3-27 |
tftp |
System Management |
4-40 |
timeout callee |
1-20 |
timeout caller |
1-21 |
tracecall |
1-21 |
tracert |
System Management |
3-5 |
transport (LS-GW view) |
1-44 |
transport (LS-OFFICEGROUP-OFFICE view) |
1-44 |
ttl |
1-45 |
tunnel |
2-4 |
tunnelpeer |
2-4 |
type |
Call Services |
5-6 |
undelete |
System Management |
4-14 |
upgrade |
System Management |
3-27 |
upgrade |
System Management |
4-21 |
user |
System Management |
4-38 |
user privilege |
System Management |
1-16 |
user-interface |
System Management |
1-17 |
verbose |
System Management |
4-39 |
web |
System Management |
2-3 |
xe-license |
System Management |
8-1 |
