Chapters Download(314 KB)
Table of Contents
Chapter 1 Location Server Commands
1.1.1 authentication (LS-GW view)
1.1.2 bearer-capability (LS-GW view)
1.1.3 bearer-capability (LS-OFFICEGROUP-OFFICE view)
1.1.7 codec (LS-GW-PREFIX view)
1.1.8 codec (LS-GW-SUBSCRIBER view)
1.1.10 codec (LS-OFFICEGROUP-OFFICE view)
1.1.11 codec (LS-OFFICEGROUP-PREFIX view)
1.1.12 debugging location-server
1.1.13 device-status (LS-GW view)
1.1.14 device-status (LS-OFFICEGROUP-OFFICE view)
1.1.15 device-type (LS-GW view)
1.1.16 device-type (LS-OFFICEGROUP-OFFICE view)
1.1.17 display debugging location-server
1.1.18 display location-server domain
1.1.19 display location-server gateway
1.1.20 display location-server office-group
1.1.21 display location-server process-server
1.1.22 display location-server statistics
1.1.23 display location-server tunnelpeer
1.1.26 heartbeat password (LS-PS view)
1.1.28 ip-address (LS-GW view)
1.1.29 ip-address (LS-OFFICEGROUP-OFFICE view)
1.1.33 multiplex (LS-OFFICEGROUP-OFFICE view)
1.1.39 policy random selection
1.1.41 policy unknown-device-admission
1.1.43 port (LS-OFFICEGROUP-OFFICE view)
1.1.45 prefix (LS-OFFICEGROUP view)
1.1.47 priority (LS-OFFICEGROUP-OFFICE view)
1.1.49 priority (subscriber view)
1.1.51 reset location-server statistics
1.1.56 transport (LS-OFFICEGROUP-OFFICE view)
Chapter 2 NAT/FW Tunnel Traversal Configuration Commands
2.1 NAT/FW Tunnel Traversal Configuration Commands
2.1.3 device-status forever-up attachedps
authentication { disable | enable }
undo authentication
View
LS-GW view
Parameter
disable: Disables the gateway from performing authentication.
enable: Enables the gateway to perform authentication.
Use the authentication command to set the authentication mode of a gateway.
Use the undo authentication command to restore the default setting.
Authentication is disabled by default.
Example
# Enable the gateway gw01 to perform the authentication.
[XE-ls-gw-gw01] authentication enable
bearer-capability { audio | video }
undo bearer-capability
View
LS-GW view
Parameter
audio: Specifies audio type only.
video: Specifies video and audio types.
Use the bearer-capability command to specify the bearer capability type for the gateway, that is, to specify the service type (bearer capability type) supported in the Q.931 header of setup messages sent to the terminating side.
By default, the video type is adopted.
Example
# Specify the bearer capability type for the gateway to audio.
[XE-ls-gw-gw001] bearer-capability audio
bearer-capability{ audio | video }
View
Parameter
Use the bearer-capability command to specify the bearer capability type for the office device, that is, to specify the service type (bearer capability type) supported in the Q.931 header of setup messages sent to the terminating side.
Example
# Specify the bearer capability type for the office device to audio.
[XE-ls-og-og01 of01] bearer-capability audio
call-mode { h323 | sip } { redirect | routed }
undo call-mode { h323 | sip }
View
LS view
Parameter
h323: Sets the call mode to H.323.
sip: Sets the call mode to SIP.
redirect: Sets the call mode of LS to redirect.
routed: Sets the call mode of LS to routed.
Use the call-mode command to set the call mode of LS.
Use the undo call-mode command to restore the default setting.
By default, routed mode is adopted for both H.323 and SIP.
Example
# Set the LS to work in redirect mode.
[XE-ls] call-mode h323 redirect
[XE-ls] call-mode sip redirect
call-signal ip-address ip-address
undo call-signal ip-address
View
LS-GW view
Parameter
ip-address: Sets the IP address of call signaling.
ip-address: IP address.
Use the call-signal ip-address command to configure the call signaling of the gateways registered with the LS.
Use the undo call-signal ip-address command to restore the default call signaling setting.
If the gateway does not support dynamic IP address report function or the administrator has disabled the function using the dynamic-ip disable command in LS-GW view, and the gateway is in normal or forever-up status, you need to manually configure the call signaling address of the gateway on the XE IP PBX. Then during registration, the gateway reports its call signaling address to match the configured one.
By default, the IP address of call signaling is reported dynamically by the gateway.
Example
# Set the call signaling IP address of the gateway gw001 to 169.254.10.1.
[XE-ls-gw-gw001] call-signal ip-address 169.254.10.1
call-signal port port
undo call-signal port
View
LS-GW view
Parameter
port: Sets the port number of call signaling.
port: Port number, ranging from 1 to 65535.
Use the call-signal port command to configure the call signaling of the gateways registered with the LS.
Use the undo call-signal port command to restore the default call signaling setting.
If the gateway does not support dynamic IP address report function or the administrator has disabled the function using the dynamic-ip disable command in LS-GW view, and the gateway is in normal or forever-up status, you need to manually configure the call signaling port number of the gateway on the XE IP PBX. Then during registration, the gateway reports its call signaling port number to match the configured one.
By default, the call signaling port number is reported dynamically by the gateway.
The port parameter is 1720 by default.
Example
# Set the call signaling port number of the gateway gw001 to 2000.
[XE-ls-gw-gw001] call-signal port 2000
codec { audio { g7231 | g729 | pcma | pcmu } [ packet-length packet-length ] } | { video { h261 | h263 } } | { data t38fax }
undo codec { audio | video | data }
View
LS-GW-PREFIX view
Parameter
audio: Sets the audio codec type.
g7231: Sets the audio codec type as G.723.1.
g729: Sets the audio codec type as G.729.
pcma: Sets the audio codec type as G.711 A-law 64K.
pcmu: Sets the audio codec type as G.711 u-law 64K.
packet-length: Packetization time length that ranges from 1 to 18 in units of 10 ms.
video: Sets the video codec type.
h263: Sets the video codec type as H263.
h261: Sets the video codec type as H261.
data: Sets the data codec type.
t38fax: Sets T38 faxing support.
Use the codec command to configure the codec type when the gatekeeper initiates capability negotiation with a gateway device. If a number is not configured with a codec type, the codec type configured for the gateway will be used instead.
Use the undo codec command to restore the default codec type.
By default, the codec type configured on the gateway is adopted.
Example
# For subscriber 8801, set codec type to G.729 so that the gatekeeper uses it to initiate capability negotiation to a gateway device. Set the packetization time length as 40 ms and video codec type as H261.
[XE-ls-gw-gw000 8801]codec audio g729 packet-length 4
[XE-ls-gw-gw000 8801]codec video h261
View
Parameter
Use the codec command to configure the codec type used when the gatekeeper initiates capability negotiation to a gateway device. If a number is not configured with a codec type, the codec type configured for the gateway will be used instead.
Example
# For subscriber 8801, set codec type to G.729 so that the gatekeeper uses to initiate capability negotiation to a gateway device. Set the packetization time length as 40 ms and video codec type as H261.
[XE-ls-gw-gw000 #1 8801]codec audio g729 packet-length 4
[XE-ls-gw-gw000 #1 8801]codec video h261
View
LS-GW view
Parameter
Use the codec command to configure the codec type used when the gatekeeper initiates capability negotiation with a gateway device.
By default, G.729 is adopted for audio codec, the packetization time length is 30 ms, and video codec and data faxing is not supported.
Example
# Set the codec type to G.729 so that the gatekeeper uses to initiate capability negotiation with a gateway device. Set, the packetization time length to 40 ms and video codec to H261.
[XE-ls-gw-gw000]codec audio g729 packet-length 4
[XE-ls-gw-gw000]codec video h261
View
Parameter
Use the codec command to configure the codec type used when the gatekeeper initiates capability negotiation to an office device.
Example
# Set the codec type to G.729 so that the gatekeeper uses to initiate capability negotiation to an office device to G.722. Set the packetization time length to 40 ms and video codec to H261.
[XE-ls-og-og01 off000]codec audio g729 packet-length 4
[XE-ls-og-og01 off000]codec video h261
View
Parameter
packet-length: Packetization time length in 10 milliseconds, in the range of 1 to 18.
By default, the codec type configured on the office device is adopted.
Example
# For subscriber 8801, set codec type to G.729 so that the gatekeeper uses to initiate capability negotiation to an office device to G.729. Set the packetization time length to 40 ms and video codec to H261.
[XE-ls-og-og01 8801]codec audio g729 packet-length 4
[XE-ls-og-og01 8801]codec video h261
debugging location-server { call | heartbeat | register |all } level level-number
undo debugging location-server { call | heartbeat | register |all }
View
Parameter
call: Enables call debugging.
heartbeat: Enables heartbeat, backup management and tunnel debugging.
register: Enables registration debugging.
all: Enables all debugging options.
level level-number: Sets the debugging level of LS, ranging from 0 to 7. Debugging is disabled when the level is 0.
Use the debugging location-server command to set the debugging level of LS.
Use the undo debugging location-server command to restore the default setting.
The call keyword refers to information about calls; the register keyword indicates information about registration; the heartbeat keyword indicates information about heartbeat; the all keyword indicates all debugging levels including call, register and heartbeat.
All debugging options are disabled by default. When set to 4, debugging of level 1 to 4 is enabled; and 0 means to disable the debugging, by which you can hide the debugging information.
About the levels:
Level 0: Disable the debugging.
Level 1: DEBUG_LEVEL_EMERGENCY
Fail to allocate memory
Fail to allocate timer
Level 2: DEBUG_LEVEL_ALERT
Null pointer, invalid memory operation
Switching information about the state of the connection between process server (PS) and LS
Level 3: DEBUG_LEVEL_ERROR
Control block state incorrect/not matched
Invalid/unexpected control block index
Invalid/unexpected PID/Module ID
Fail to return value, the functions of the main function affected.
Invalid message type
Level 4: DEBUG_LEVEL_WARNING
Fail to return value, but the functions of the main function not affected.
Message head received
Abnormal timer timeout message
State transition message
Level 5: DEBUG_LEVEL_NOTIFICATION
Operating properly, but the environment slightly abnormal
Information about key service flow
Message header of the transmitted message
Level 6: DEBUG_LEVEL_INFORMATIONAL
Key processing flow of module/function
Memory allocating/releasing
Timeout message of normal timer
Important information of MD5 algorithm
Important information of Hash algorithm
Level 7: DEBUG_LEVEL_DEBUGGING
General flow information
Extraction/adding processing functions of optional IE
IE list information of message/message content
Calling instruction of function entry/instruction of returned value
Example
# Enable all debugging options and set the debugging level of LS to 5.
<XE> debugging location-server all level 5
device-status { forever-up attachedps ps-id | normal | suspend }
undo device-status
View
LS-GW view
Parameter
forever-up: Sets a gateway to work in forever-up state.
attachedps: Specifies the PS that this forever-up device belongs to.
ps-id: ID of the PS that this forever-up device belongs to.
normal: Sets a gateway to work in normal state.
suspend: Sets a gateway to work in suspend state.
Use the device-status command to set the state of a gateway.
Use the undo device-status command to restore the default gateway state.
The device state defaults to normal.
Example
# Set the device state of the gateway gw001 to forever-up and specify this gateway belong to the PS named default-ps.
[XE-ls-gw-gw001] device-status forever-up attachedps default-ps
device-status { forever | normal }
View
Parameter
forever: Sets the device status to forever-up.
normal: Sets the device status to normal.
Use the device-status command to set the status of an office device.
By default, the status of an office device is forever.
Example
# Set the device status to normal
[XE-ls-og-og01 of1]device-status normal
device-type { h323 | sip }
undo device-type
View
LS-GW view
Parameter
h323: Sets the gateway type to H.323.
sip: Sets the gateway type to SIP.
Use the device-type command to specify the gateway type.
Use the undo device-type command to restore the default gateway type.
The type of a registered gateway defaults to SIP.
Example
# Set the gateway type to H.323.
[XE-ls-gw-gw001] device-type h323
device-type { h323-gk | h323-gw | sip }
undo device-type
View
Parameter
h323-gk: Sets the office device to H.323 gatekeeper.
h323-gw: Sets the office device to H.323 gateway.
sip: Sets the office device to SIP-grade device.
Use the device-type command to specify the device type of an office device.
Use the undo device-type command to restore the default office device type.
The type of an office device defaults to SIP-grade device.
Example
# Set the office device of1 to H.323 gateway.
[XE-ls-og-og01 of1] device-type h323-gw
View
Parameter
None
Use the display debugging location-server command to display the debugging level of the LS.
Example
# Display the debugging level of the LS.
<XE> display debugging location-server
CALL debugging level 3
REGISTER debugging level 3
HEARTBEAT debugging level 3
display location-server domain { domain-id | all }
View
Parameter
domain-id: ID of the domain whose information is to be displayed.
All: Displays information about all domains.
Use the display location-server domain command to display the information about one domain or all domains on an LS.
Example
# Display information about the PublicDomain domain.
[XE-ls] display location-server domain PublicDomain
-----------Domain Information -----------
Domain Identifier: PublicDomain
Domain Attribute: public
process-server list: ps0
office-group list:
The result shows that the attribute of the PublicDomain domain is public and the PS belonging to it is ps0.
display location-server gateway { device-id | all | h323 | sip | list }
View
Parameter
all: Displays information about all gateways.
device-id: The identifier of the gateway to be displayed.
h323: Displays information about H.323 gateways.
sip: Displays information about SIP user agents.
list: Lists the identifiers and device types of the gateways.
Use the display location-server gateway command to display information about the gateways registered with the LS.
Example
# Display information about all gateways.
<XE> display location-server gateway all
------------ Gateway Information ------------
Identifier: gw02
LoadShare: Disable
SubsLine: 4
PsGroupID:
----------Static Information:
Device Type: SIP-UA
Ip-address: 0.0.0.0:5060
Call Ip-address: 0.0.0.0:1720
Device Status: normal
Device Manufacturer: H3C
Transport: udp
Multiplex: disable
DynamicIp: disable
Subscriber count: 1
Subscriber List:
#2 1002
Static Alias Number: 0
Device Priority: 10
Registration Circle: 180 sec
Authentication: disable
Password: GATEWAY
Area Code Substitute: enable
Nation Code:
Region Code:
----------Dynamic Information:
Registration Status: offline
Registration Transport: auto
Dynamic Alias Number: 0
Dynamic Alias Check Sum: 0
Resource Can Use: Yes
Registration Call Identifier:
RM handle: ffffffff
CAI handle: ffffffff
Notification Bitmap: Confirm: 1 Reject: 1 Blankout: 1 Challenge: 0
Indication Bitmap: Confirm: 0 Reject: 0 Blankout: 0 Challenge: 0
Attached Process Server:
Table 1-1 Description on the fields of the display location-server gateway all command
Identifier |
Identifier of the gateway |
LoadShare |
Load sharing state |
SubsLine |
Capacity of voice subscriber lines |
PsGroupID |
Identifier of the PS group to which the gateway belongs |
Device Type |
Type of the gateway |
Ip-address |
IP address of the gateway |
Call Ip-address |
IP address of call signaling |
Device Status |
State of the gateway |
Device Manufacturer |
Information about the manufacturer |
Transport |
Transport mode of the gateway |
Multiplex |
Multiplexing mode |
DynamicIp |
Whether to enable dynamic IP |
Subscriber count |
Number of entries for subscriber line numbers |
Subscriber List |
List of entries for subscriber line numbers |
# #2 1002 |
Short number and long number |
Static Alias Number |
Number of static number routes |
Static Alias List |
Routing table of static number |
Device Priority |
Device priority |
Registration Circle |
Registration circle |
Authentication |
Authentication mode |
Password |
Authentication password |
Area Code Substitute |
State of the location-based number substitute |
Nation Code |
Country code |
Region Code |
Area code |
Registration Status |
Registration status |
Registration Transport |
Registration transport mode |
Dynamic Alias Number |
Number of dynamic number routes |
Dynamic Alias Check Sum |
Check sum of dynamic number routes |
Resource Can Use |
Whether the gateway resource is available |
Registration Call Identifier |
Registration call identifier |
RM handle |
Registration module handle |
CAI handle |
CAI module handle |
Notification Bitmap |
Notification bitmap |
Indication Bitmap |
Indication bitmap |
Attached Process Server |
Attached PS (the gateway registers with the LS through this PS) |
display location-server office-group { all | officegroup-id | list }
View
Parameter
all: Displays all office group information.
officegroup-id: Identifier of the office group to be displayed.
list: Displays office group information in a list.
Use the display location-server office-group command to display information about office devices configured on the LS.
Example
# Display information about all office groups.
[XE-ls-og-og01 off000]display location-serve office-group all
-------------- Office-group Information --------------
Identifier: og01
Nation Code:
Region Code:
Area Code Substitute: disable
Attached Domain Identifier: default-domain
Static Alias Number: 1
Static Alias List:
prefix 1...
Office Number: 1
Office List:
office off000
acct enable
Table 1-2 Description on the fields of the display location-server office-group all command
Identifier |
Identifier of the office group |
Nation Code |
Country code |
Region Code |
Area code |
State (enabled/disabled) of the location-based number substitute function |
Attached Domain Identifier |
Domain that the office group belongs to |
Static Alias List |
Static route number list |
Office Number |
Number of office devices |
Office List |
Office device list |
display location-server process-server { all | device-id | list }
View
Parameter
all: Display information of all PSs registered with the LS.
device-id: The identifier of the PS to be displayed.
list: Lists the identifiers and IP addresses of the PSs.
Use the display location-server process-server command to display information about the PSs registered with the LS.
Example
# Display information about the PS ps0.
[XE]display location-server process-server ps0
----------- Process Server Information -----------
Identifier: ps0
RelativeCapability: 1
Attached SubsLineNumber: 4
SIP port: 5060
RAS port: 1719
Process Server Group Identifier:
Tunnel function: Disable
HeartBeat Key: XEngine
Transport: auto
Ip-address: 172.31.3.24
Status: Authorized
Attaching Gateway List:
Table 1-3 Description on the fields of the display location-server process-server command
Identifier |
Identifier of the PS |
RelativeCapability |
Relative capability of the PS |
Attached SubsLineNumber |
Number of the subscriber line the PS supports |
SIP port |
SIP port of the PS |
RAS port |
RAS port of the PSs |
Process Server Group Identifier |
Group identifier of the PS |
The domain the PS belongs to |
Tunnel function |
Whether the tunnel function is enabled |
HeartBeat Key |
Heartbeat key of the PS and LS |
Transport |
Transport method of the PS |
Ip-address |
IP address of the PS |
Status |
Status of the PS |
Attaching Gateway List |
List of gateways registered with a PS |
# Display the identifier and IP address of the PS.
[XE-ls] display location-server process-server list
Identifier IP address
gkserver 192.168.80.50:13580
View
Parameter
None
Use the display location-server statistics command to display statistics of the LS.
Example
# Display statistics of the LS.
<XE> display location-server statistics
CAI Message Statistics of LS:
CAI Message total rcv send err dupr dups disc
Register Query Device: 0 0 0 0 0 0 0
Register Response Device: 0 0 0 0 0 0 0
Register Notify Confirm: 0 0 0 0 0 0 0
Register Notify Reject: 0 0 0 0 0 0 0
Register Notify Challenge: 0 0 0 0 0 0 0
Register Indication Device Status: 0 0 0 0 0 0 0
Register Notify BlankOut: 0 0 0 0 0 0 0
Register Indication Device Update: 0 0 0 0 0 0 0
Call Query Number Analysis: 0 0 0 0 0 0 0
Call Response Number Analysis: 0 0 0 0 0 0 0
Call Notify Ring Back: 0 0 0 0 0 0 0
Call Notify Redirect: 0 0 0 0 0 0 0
Call Notify Off Hook: 0 0 0 0 0 0 0
Call Notify Talk: 0 0 0 0 0 0 0
Call Notify Release: 0 0 0 0 0 0 0
Call Notify Release Complete: 0 0 0 0 0 0 0
Call Indication Refer: 0 0 0 0 0 0 0
Call Indication Release: 0 0 0 0 0 0 0
Call Indication Call Forward: 0 0 0 0 0 0 0
Connect Notify HeartBeat: 0 0 0 0 0 0 0
Connect Indication HeartBeat: 0 0 0 0 0 0 0
Call Query Admission: 0 0 0 0 0 0 0
Call Response Admission: 0 0 0 0 0 0 0
Call Notify BandWidth Change: 0 0 0 0 0 0 0
Call Indication BandWidth Change: 0 0 0 0 0 0 0
Invalid CAI: 0 0 0 0 0 0 0
CAI Distribute Message Statistics of LS:
CAI Distribute Message total rcv send err dupr dups disc
CAI Distribute Message between PS and RM: 0 0 0 0 0 0 0
CAI Distribute Message between PS and CM: 0 0 0 0 0 0 0
CAI Distribute Message of LS: 0 0 0 0 0 0 0
CAI Release: 0 0 0 0 0 0 0
CAI Invalid ID: 0 0 0 0 0 0 0
Table 1-4 Description on the fields of the display location-server statistics command
Register Query Device |
Query device information |
Register Response Device |
The LS returns the information of the queried device |
Register Notify Confirm |
Notify the LS of successful registration |
Register Notify Reject |
Notify the LS of failed registration |
Register Notify Challenge |
Notify LS to send Challenge message |
Register Indication DeviceStatus |
The LS prompts the registration status (success, failure or redirect) |
Register Notify BlankOut |
Notify the LS of expired registration |
Register Indication DeviceUpdate |
The LS prompts the update of the device configuration |
Call Query NumberAnalysis |
The PS queries the LS about number analysis |
Call Response NumberAnalysis |
The LS returns the result of number analysis |
Call Notify RingBack |
The PS notifies the subscriber to ring back |
Call Notify Redirect |
The PS notifies the LS to redirect the call |
Call Notify OffHook |
The PS notifies that the called has picked up the phone |
Call Notify Talk |
The PS notifies that the subscriber is on the call |
Call Notify Release |
Notify that the LS is ready to release the call |
Call Notify ReleaseComplete |
Notify that the call release completes |
Call Indication Refer |
Information of the calling and called parties |
Call Indication Release |
Indicate the PS to terminate the call |
Call Indication CallForward |
Indicate call forwarding |
Connect Notify HeartBeat |
The PS sends periodical heartbeat message to the LS |
Connect Indication HeartBeat |
The LS sends periodical heartbeat message to the PS. |
Call Query Admission |
Admission of the called party |
Call Response Admission |
Response to the admission of the called party |
Call Notify BandWidth Change |
Notification of the bandwidth change request |
Call Indication BandWidth Change |
Indication of the bandwidth change request |
display location-server tunnelpeer { tunnelpeer-id | all }
View
Parameter
tunnelpeer-id: ID of the tunnel end pair whose information is to be displayed.
All: Displays information about all tunnel end pairs.
Use the display location-server tunnelpeer command to display the information about one or all tunnel end pairs (that is, one or all pairs of PSs) on an LS.
Example
# Display the information about all tunnel end pairs.
[XE-ls] display location-server tunnelpeer all
-------****------ TunnelPeer Information -------****------
Tunnelpeer Identifier: tunnel01
current state: initial
***Private Domain Process Server Information***
belongto domain: PrivateDomain
map to firewall IP: 1.1.1.2
map to firewall port: 9600
***Public Domain Process Server Information***
belongto domain: PublicDomain
map to firewall IP: 192.168.1.22
Table 1-5 Description on the fields of the display location-server tunnelpeer command
Tunnelpeer Identifier |
ID of the tunnel end pair. |
current state |
The status of the tunnel end pair. |
Private Domain Process Server Information |
belongto domain |
The domain that the private network PS of this tunnel end pair belongs to. |
map to firewall IP |
The destination IP address that the public network PS uses to send IP packets to the private network PS. Usually it is the public IP address on the firewall that corresponds to the private network PS. |
map to firewall port |
The destination port that the public network PS uses to send IP packets to the private network PS. |
Public Domain Process Server Information |
belongto domain |
The domain that the public network PS of this tunnel end pair belongs to. |
The destination IP address that the private network PS uses to send IP packets to the public network PS. |
The destination port that the private network PS uses to send IP packets to the public network PS. |
dynamic-ip { disable | enable }
undo dynamic-ip
View
LS-GW view
Parameter
enable: Enables the dynamic update of the gateway’s IP address.
disable: Disables the dynamic update of the gateway’s IP address.
Use the dynamic-ip command to enable or disable the dynamic update of the gateway’s IP address.
Use the undo dynamic-ip command to restore the default setting.
By default, the dynamic update of the gateway’s IP address is disabled.
& Note:
l If you use the manufacturer command to set the manufacturer of the gateway to other, the system will disable the dynamic update of the gateway’s IP address.
l After enabling the dynamic update of the gateway’s IP address with the dynamic-ip command, you cannot use the manufacturer command to change the manufacturer setting of the gateway; in addition, the ip, port, call-signal ip, and call-signal port commands become invalid.
Example
# Enable the dynamic update of the gateway’s IP address.
[XE-ls-gw-gw001] dynamic-ip enable
gateway device-id
undo gateway { device-id | all }
View
LS view
Parameter
device-id: The identifier of the gateway. It is case sensitive.
all: Deletes all gateways.
Use the gateway command to add a gateway or enter the device view of a gateway.
Use the undo gateway command to remove one or all gateways.
Example
# Add a gateway named gw001.
[XE-ls] gateway gw001
[XE-ls-gw-gw001]
heartbeat password password
undo heartbeat password
View
LS-PS view
Parameter
password: Heartbeat password that consists of 1 to 16 characters and is case-sensitive.
Use the heartbeat password command to set the heartbeat password for a PS registered with the LS.
Use the undo heartbeat password command to restore the default password.
By default, the password is XEngine.
Example
# Set the heartbeat password for the PS ps0 to pass1.
[XE-ls-ps-ps0] heartbeat password pass1
heartbeat-time-range time
undo heartbeat-time-range
View
LS view
Parameter
time: Allowed time difference between the LS and the PS/MS, in the range of 0 to 36000 seconds.
Use the heartbeat-time-range command to set the allowed time difference between the LS and the PS/MS.
Use the undo heartbeat-time-range command to restore the default value.
By default, this value is 0, indicating the time difference is not limited.
Example
# Set the allowed time difference between the LS and the PS/MS to 3600 seconds.
[XE-ls] heartbeat-time-range 3600
undo ip-address
View
LS-GW view
Parameter
Use the ip-address command to set the IP address of a gateway registered with the LS.
Use the undo ip-address command to restore the default IP address.
By default, the IP address is 0.0.0.0.
Example
# Set the IP address of the gateway gw001 to 192.168.1.33.
[XE-ls-og-og01 of1] ip-address 192.168.1.33
undo ip-address
View
Parameter
Use the ip-address command to set the IP address of an office device.
Example
# Set the IP address of the office device of1 to 192.168.1.33.
[XE-ls-office-of1] ip-address 192.168.1.33
ls-config interface interface-type slot-number [ port port ]
undo ls-config
View
LS view
Parameter
interface: Specifies the interface.
interface-type: Interface type.
slot-number: Interface number.
port: Specifies the port number, which ranges from 1 to 65535.
Use the ls-config command to specify the interface and port number of the LS.
Use the undo ls-config command to restore the default interface and port number.
By default, the port number is 13579, the interface is Ethernet 0/0 for XE 200 IP PBX and GigabitEthernet 0/0 for XE 2000 IP PBX.
Example
# Specify the interface and port number of the LS.
[XE200-ls] ls-config interface ethernet 0/0 port 12345
manufacturer { other | h3c }
undo manufacturer
View
LS-GW view
Parameter
other: Sets the manufacturer of a gateway to other.
h3c: Sets the manufacturer of a gateway to H3C.
Use the manufacturer command to set the manufacturer for a gateway registered with the LS.
Use the undo manufacturer command to restore the default manufacturer.
By default, the manufacturer is h3c.
& Note:
l If you use the dynamic-ip command to enable the dynamic update of the gateway’s IP address, you cannot use the manufacturer command to change the manufacturer setting of the gateway.
Example
# Set the manufacturer of the gateway gw001 to other.
[XE-ls-gw-gw001] manufacturer other
multiplex { disable | enable }
undo multiplex
View
LS-GW view
Parameter
disable: Disables multiplexing.
enable: Enables multiplexing.
Use the multiplex command to specify the multiplexing mode of a gateway registered with the LS.
By default, multiplexing is disabled.
Example
# Enable multiplexing on the gateway gw001.
[XE-ls-gw-gw001] multiplex enable
undo multiplex
View
Parameter
Use the multiplex command to specify the multiplexing mode of an office device configured on the LS.
Example
# Enable multiplexing on the office device of1.
[XE-ls-og-og01 of1] multiplex enable
undo multiplex
View
LS-PS view
Parameter
Use the multiplex command to specify the multiplexing mode of a PS registered with the LS.
Example
# Enable multiplexing on the PS ps0.
[XE-ls-ps-ps0] multiplex enable
office device-id
undo office { device-id | all }
View
LS-OFFICEGROUP view
Parameter
device-id: The identifier of the office device. It is case sensitive.
all: Deletes all offices.
If the office mapping device-id does not exist, use the office command to create a new office on the LS and enter the LS-OFFICEGROUP-OFFICE view.
If the office mapping device-id exists, use the office command to enter the LS-OFFICEGROUP-OFFICE view directly.
Use the undo office command to delete the office.
You need to enter the LS-OFFICE view first to configure an office.
Example
# Enter the view of the office of1.
[XE-ls-og-og01] office of1
[XE-ls-og-og01 of1]
office-group office-group-id
undo office-group { office-group-id | all }
View
LS view
Parameter
office-group-id: Office group ID. It is case sensitive.
all: Deletes all office groups configured on the LS.
Use the office-group command to create an office group and enter its LS-OFFICEGROUP view, or directly enter the LS-OFFICEGROUP view if an office group with the specified name exists.
Use the undo office-group command to delete the specified or all office groups.
Example
# Create an office group og01 and then enter its LS-OFFICEGROUP view.
[XE2000-ls]office-group og01
[XE2000-ls-og-og01]
otapc
undo otapc { fxs | relay }
View
Prefix view
Parameter
fxs: Specifies the static route number to be the subscriber number.
relay: Specifies the static route number to be the relay number.
Use the otapc command to configure the attribute of a static route number of a gateway.
Use the undo otapc command to restore the default attribute of a static route number.
By default, the static route number is the subscriber number.
Example
# Configure the static router number 9 to be the relay number on gateway gw01.
[XE-ls] gateway gw02
[XE-ls-gw-gw02] prefix 9...
[XE-ls-gw-gw02 9...] otapc relay
password password
undo password
View
LS-GW view
Parameter
password: Authentication password consisting of 1 to 16 characters.
Use the password command to set the authentication password for a gateway registered with the LS.
Use the undo password command to restore the default password.
By default, the authentication password for a gateway is GATEWAY.
Example
# Set the authentication password of the gateway gw001 to pass1.
[XE-ls-gw-gw001] password pass1
policy random-selection { enable | disable }
View
LS view
Parameter
random-selection: Configures random selection of numbers.
enable: Enables random selection.
disable: Disables random selection.
Use the policy random-selection enable command to enable random selection.
Use the policy random-selection disable command to disable random selection.
By default, the random selection is enabled.
Example
# Disable random selection.
[XE-LS] policy random-selection disable
policy select-rule {number-first | priority-first}
undo policy select-rule
View
LS view
Parameter
number-first: Configures the longest number at a higher priority.
priority-first: Configures the priority number at a higher priority.
Use the policy select-rule command to configure the longest number or the priority number at a higher priority.
Use the undo policy select-rule command to restore the default call-matching criterion.
By default, the call-matching criterion sets the priority number at a higher priority.
Example
# Configure the longest number at a higher priority.
[XE-ls] policy select-rule number-first
[XE-ls]
policy unknown-device-admission {enable | disable}
undo policy unknown-device-admission
View
LS view
Parameter
Enable: Enables the XE IP PBX to accept requests from unknown devices.
Disable: Disables the XE IP PBX to accept requests from unknown devices.
Use the policy unknown-device-admission command to enable or disable to accept requests for unknown devices.
Use the undo policy unknown-device-admission command to restore the default.
By default, accepting requests from unknown devices is enabled.
Example
# Disable to accept requests from unknown devices.
[XE-ls]policy unknown-device-admission disable
[XE-ls]
port port
undo port
View
LS-GW view
Parameter
port: Port number, ranging from 1 to 65535. By default, it is 5060.
Use the port command to set the port number of a gateway registered with the LS.
Use the undo port command to restore the default port.
By default:
For an H.323 device, port 1719 is used;
For a SIP device (User-Agent), port 5060 is used.
Example
# Set the port number of the gateway gw001 to 1234.
[XE-ls-gw-gw001] port 1234
port port
undo port
View
Parameter
Use the port command to set the port number of an office device configured on the LS.
By default, the port number of an office device is 5060.
& Note:
By default, the port number is 5060. When the dynamic-ip disable command is used and the type of the gateway is SIP, you can keep this number unchanged; while if the type is h323-gw, you should use the port command to set the port number to 1720, and if the type is h323-gk, you should use the port command to set the port number to 1719.
Example
# Set office device of1 using port 1720.
[XE-ls-og-og01 of1] port 1720
prefix number
undo prefix { number | all }
View
LS-GW view
Parameter
number: Static route number consisting of 1 to 31 characters, which can be numbers from 0 to 9, letters A, B, C, D or signs * and #.
all: Deletes all route numbers.
Use the prefix command to configure a static route number for a gateway registered with the LS and enter the view of this number.
Use the undo prefix command to delete one or all of the static route numbers of a gateway.
Example
# Configure the static route number 8801 for the gateway gw01.
[XE-ls-gw-gw01]prefix 8801
[XE-ls-gw-gw01 8801]
prefix number
View
LS-OFFICEGROUP view
Parameter
Use the prefix command to configure a static route number for an office device configured on the LS and enter the view of this number.
Use the undo prefix command to delete one or all of the static route numbers of an office group.
Example
# Configure the static route number 8803 for office group og01.
[XE2000-ls-og-og01] prefix 8803
[XE2000-ls-og-og01 8803]
priority level
undo priority
View
LS-GW view
Parameter
level: Priority of a gateway, which ranges from 0 to 1000 and defaults to 10. The larger the value, the higher the priority.
Use the priority command to set the priority of a gateway registered with the LS.
Use the undo priority command to restore the default priority.
The default priority is 10.
Example
# Set the priority of the gateway gw001 to 11.
[XE-ls-gw-gw001] priority 11
priority priority-level
undo priority
View
Parameter
level: Priority of an office device, which ranges from 0 to 1000 and defaults to 10. The larger the value, the higher the priority.
Use the priority command to set the priority of an office device configured on the LS.
Example
# Set the priority of the office device of1 to 11.
[XE-ls-og-og01 of1] priority 11
undo priority
View
Prefix view
Parameter
level: Priority of a static route number, which ranges from 0 to 1000, and the default is the same as that of a gateway.
Use the priority command to set the priority of a static route number registered with the LS.
The default priority of a static route number is the same as that of a gateway or an office device, refer to priority (LS-GW view) for details.
Example
# Set the priority of the static route number 1101 to 11.
[XE-ls-gw-gw01] prefix 1101
[XE-ls-gw-gw01 1101] priority 11
undo priority
View
Subscriber view
Parameter
level: Priority of a voice subscriber line number entry, which ranges from 0 to 1000, and the default is the same as that of a gateway.
Use the priority command to set the priority of a voice subscriber line number entry registered with the LS.
The default priority of a voice subscriber line number is the same as that of a gateway, refer to priority (LS-GW view) for details.
Example
# Set the priority of the voice subscriber line number entry #01 9901 to 11.
[XE-ls-gw-gw01] subscriber #01 9901
[XE-ls-gw-gw01 #01 9901] priority 11
process-server device-id
undo process-server { device-id | all }
View
LS view
Parameter
device-id: The identifier of a PS. It is case sensitive.
all: Deletes all PSs.
Use the process-server command to add a PS and enter the LS-PS view of the LS. If this PS exists, this command brings you into the LS-PS view of the LS.
Use the undo process-server command to delete the PSs registered with the LS.
Before deleting a PS to which a permanently online gateway connects, you need to change the status of the gateway.
You need to enter LS-PS view first before configuring the PS.
Example
# Enter the view of the PS ps0.
[XE-ls] process-server ps0
[XE-ls-ps-ps0]
View
Parameter
None
Use the reset location-server statistics command to clear the statistics about the LS, that is, to clear the information displayed by the display location-server statistics command.
Example
# Clear the statistics about the LS.
<XE> reset location-server statistics
start
View
LS view
Parameter
None
Use the start command to start the LS.
The LS is not started by default.
Example
# Start the LS.
[XE-ls] start
stop
View
LS view
Parameter
None
Use the stop command to disable the LS.
Example
# Disable the LS.
[XE-ls] stop
subscriber short-number long-number
undo subscriber { short-number long-number | all }
View
LS-GW view
Parameter
short-number: Short number of a voice subscriber line number entry corresponding to a long number, which starts with a "#" and consists of two to three characters (including the "#"). The value of this number ranges from 0 to 31.
long-number: Long number, corresponding to the short number of the voice subscriber line number, which contains one to 31 digits. The long number can be numbers from 0 to 9, signs *, #, and letters A, B, C, or D.
all: Deletes all voice subscriber line number entry.
Use the subscriber command to create a number entry for a voice subscriber line of a gateway registered with the LS.
Use the undo subscriber command to delete all subscriber line number entries of the gateway.
Example
# Create a number entry for a voice subscriber line of the gateway gw001, with #31 as the short number and 68835641 as the long number.
[XE-ls-gw-gw001] subscriber #31 68835641
[XE-ls-gw-gw01 #31 68835641]
# Create a number entry for a voice subscriber line of the subscriber whose long number is 68835641, with #11 as the short number.
[XE-ls-gw-gw01 #31 68835641] quit
[XE-ls-gw-gw01]subscriber #11 68835641
[XE-ls-gw-gw01 #11 68835641]
transport { auto | tcp | udp }
undo transport
View
LS-GW view
Parameter
auto: Specifies to select transport mode automatically.
tcp: Specifies to transport using TCP.
udp: Specifies to transport using UDP.
Use the transport command to specify the transport mode of a gateway registered with the LS.
Use the undo transport command to restore the default transport mode.
By default, udp mode is selected.
Example
# Specify the gateway gw001 to transport using TCP.
[XE-ls-gw-gw001] transport tcp
undo transport
View
Parameter
Use the transport command to specify the transport mode of an office device configured on the LS.
By default, auto mode is selected.
Example
# Specify the office device of1 to transport using UDP.
[XE-ls-og-og01 of1] transport tcp
ttl time-length
undo ttl
View
LS-GW view
Parameter
time-length: TTL time length in seconds, ranging from 10 to 65535. It defaults to 180 seconds.
Use the ttl command to set the time-to-live value of the registration information of a gateway registered with the LS.
Use the undo ttl command to restore the default value.
Example
# Set the time-to-live value of the registration information of the gateway gw001 to 200 seconds.
[XE-ls-gw-gw001] ttl 200
attribute {private | public}
undo attribute
View
LS-domain view
Parameter
private: Specifies that the domain belongs to a private network.
public: Specifies that the domain belongs to a public network.
Use the attribute command to configure the attribute of a domain to specify the type (public network or private network) of the domain.
Use the undo attribute command to cancel the attribute configuration of the domain.
Example
# Specify that domain001 belongs to a private network.
[XE-ls-domain-domain001] attribute private
belongto domain-id
undo belongto
View
LS-OFFICEGROUP view
LS-office view
Parameter
domain-id: ID of the domain to which the PS or office group is to belong.
Use the belongto command to specify the domain to which the PS or office group is to belong.
Use the undo belongto command to specify that the PS or office group belongs to the default-domain domain.
By default, a PS or an office group belongs to the default-domain domain.
Example
# Specify that ps0 belongs to domain001.
[XE-ls-ps-ps0] belongto domain001
device-status forever-up attachedps ps-id
View
LS-GW view
Parameter
ps-id: ID of the PS to which the gateway device is to belong.
Use the device-status forever-up attachedps ps-id command to specify the PS to which a forever-up gateway device is to belong.
Example
# Specify that gw01, a forever-up gateway device, belongs to ps01.
[XE-ls-gw-gw01] device-status forever-up attachedps ps01
domain domain-id
undo domain { domain-id | all } [ no-confirm ]
View
LS view
Parameter
domain-id: ID of the domain to be created, deleted , or ID of the domain whose view you want to enter. It is case sensitive.
all: Removes all domains.
no-confirm: Removes a domain without user confirmation.
Use the domain command to create a domain (if the domain identified by the domain-id argument does not exist.) or enter the corresponding domain view (if the domain identified by the domain-id argument already exists).
Use the undo domain command to remove a specified domain or all domains as well as the office devices belonging to the domain.
Example
# Create a domain with an ID of domain001.
[XE-ls] domain domain001
# Delete a domain.
[XE-ls] undo domain domain001
NOTICE:This command will delete all offices belonged to the domain! Continue?[Y/N]:y
Delete Domain domain001
# Delete a domain directly without user confirmation.
[XE-ls]undo domain domain002 no-confirm
Delete Domain domain002
nat&fw
View
LS view
Parameter
None
Use the nat&fw command to enter LS-NAT&FW view.
Example
# Enter LS-NAT&FW view.
[XE-ls] nat&fw
tunnel { enable | disable }
undo tunnel
View
LS-PS view
Parameter
enable: Enables NAT/FW tunnel traversal on current PS.
disable: Disables NAT/FW tunnel traversal on current PS.
Use the tunnel command to enable/disable NAT/FW (firewall) tunnel traversal on current PS.
By default, NAT/FW tunnel traversal is disabled on a PS.
Example
# Enable NAT/FW tunnel traversal on PS0.
[XE-ls-ps-ps0] tunnel enable
tunnelpeer tunnelpeer-id private private-ps-id private-to-public-add port private-to-public-port public public-ps-id public-to-private-add port public-to-private-port
undo tunnelpeer { tunnelpeer-id | all }
View
LS-NAT&FW view
Parameter
tunnelpeer-id: ID of the tunnel end pair to be created.
private-ps-id: ID of the specified PS in the private network.
private-to-public-add: Destination address of the IP packets sourced from the PS in the private network and destined for the PS in the public network.
private-to-public-port: Destination port number of the IP packets sourced from the PS in the private network and destined for the PS in the public network.
public-ps-id: ID of the specified PS in the public network.
public-to-private-add: Destination address of the IP packets sourced from the PS in the public network and destined for the PS in the private network. Normally, it is the public network IP address that the PS in the private network is mapped to on the NAT/FW.
public-to-private-port: Destination port number of the IP packets sourced from the PS in the public network and destined for the PS in the private network. Normally, it is the port number of the firewall used by the PS in the private network.
Use the tunnelpeer command to configure a tunnel end pair (that is, a pair of PSs, with one in the private network and another in the public network, which will communicate with each other across the firewall).
Use the undo tunnelpeer command to delete all tunnel end pairs or a specified tunnel end pair.
Example
# PS0 resides in the private network and its IP address is 192.168.1.2. PS1 resides in the public network and its IP address is 220.10.10.2. NAT is enabled between the private and public networks, and the public network IP address is exposed to the private network. Specify PS0 and PS1 to be a tunnel end pair using port 11998 at both ends. PS0 uses the following IP address and port number of the firewall: 220.10.10.1 and 11998.
[XE-ls-nat&fw] tunnelpeer tunnelpeer01 private PS0 220.10.10.2 port 11998 public PS1 220.10.10.1 port 11998
