Chapters Download(323 KB)
H3C XE 200/2000 IP PBX |
Command Manual |
Hangzhou H3C Technologies Co., Ltd. http://www.h3c.com
Manual Version: T2-08192B-20070520-C-3.01 |
Copyright 2006-2007, Hangzhou H3C Technologies Co., Ltd.
All Rights Reserved
No part of this manual may be reproduced or transmitted in any form or by any means without prior written consent of Hangzhou H3C Technologies Co., Ltd.
Trademarks
H3C,
, Aolynk,
, H3Care,
, TOP G,
, IRF, NetPilot, Neocean, NeoVTL, SecPro, SecPoint,
SecEngine, SecPath, Comware, Secware, Storware, NQA, VVG, V2G, VnG,
PSPT, XGbus, N-Bus, TiGem, InnoVision and HUASAN are trademarks of Hangzhou H3C
All other trademarks that may be mentioned in this manual are the property of their respective owners.
Notice
The information in this document is subject to change without notice. Every effort has been made in the preparation of this document to ensure accuracy of the contents, but all statements, information, and recommendations in this document do not constitute the warranty of any kind, express or implied.
To obtain the latest information, please access:
http://www. h3c.com
Technical Support
http://www. h3c.com
About This Manual
Related Documentation
In addition to this manual, each H3C XE 200/2000 IP PBX documentation set includes the following:
Manual |
H3C XE 200/2000 IP PBX Installation Manual |
It provides information for the hardware features, installation, configuration, maintenance and troubleshooting involved in the XE series. |
H3C XE 200/2000 IP PBX Operation Manual |
It presents the functional features, operating fundamentals and configuration guide involved in the XE 200/2000. |
H3C XE 200/2000 IP PBX G-Remote User Manual |
It introduces the graphic user interface and the operation through the XE 200/2000. |
Organization
H3C XE 200/2000 IP PBX Command Manual is organized as follows:
Chapter |
Contents |
1 Basic Configuration |
Describes the commands involved in basic configuration, interface configuration and static route configuration. |
2 Process Server Configuration |
Describes the commands involved in the configuration on H.323 GateKeeper and SIP Server. |
3 Location Server Configuration |
Describes the commands involved in Location Server configuration. |
4 Feature |
Describes the commands involved in the unique functions and features that the IP PBX provides. |
5 System Management |
Describes the commands involved in terminal service and user interface configuration, system maintenance and management, file management, user management, as well as SNMP configuration. |
6 IP Performance and Application |
Describes the commands involved in the configuration on static routes, RIP, OSPF, BGP, MBGP, IGMP, PIM, MSDP and routing policies. |
7 Media Server |
Describes the commands involved in IP PBX Media Server configuration. |
8 Call Services |
Describes the commands involved in the configuration on call services. |
9 Appendix |
Lists the indexes of the commands involved in this manual. |
Conventions
The manual uses the following conventions:
Convention |
Boldface |
The keywords of a command line are in Boldface. |
italic |
Command arguments are in italic. |
Items (keywords or arguments) in square brackets [ ] are optional. |
{ x | y | ... } |
Alternative items are grouped in braces and separated by vertical bars. One is selected. |
[ x | y | ... ] |
Optional alternative items are grouped in square brackets and separated by vertical bars. One or none is selected. |
{ x | y | ... } * |
Alternative items are grouped in braces and separated by vertical bars. A minimum of one or a maximum of all can be selected. |
[ x | y | ... ] * |
Optional alternative items are grouped in square brackets and separated by vertical bars. Many or none can be selected. |
&<1-n> |
The argument(s) before the ampersand (&) sign can be entered 1 to n times. |
A line starting with the # sign is comments. |
Convention |
Boldface |
Window names, button names, field names, and menu items are in Boldface. For example, the New User window appears; click OK. |
Convention |
Button names are inside angle brackets. For example, click <OK>. |
Window names, menu items, data table and field names are inside square brackets. For example, pop up the [New User] window. |
Multi-level menus are separated by forward slashes. For example, [File/Create/Folder]. |
Convention |
Means reader be extremely careful. Improper operation may cause bodily injury. |
Means reader be careful. Improper operation may cause data loss or damage to equipment. |
& Note |
Means a complementary description. |
