Figure-1 Multi-cloud container management configuration workflow
Table-1 Multi-cloud container management configuration workflow
Task |
Procedure |
Prerequisites |
Configure compute nodes, upload images, and configure network settings. |
Create a main cluster instance |
Create a main cluster instance, which is an MCP cluster. |
Add a member cluster |
Obtain the KubeConfig files of the clusters to incorporate member clusters to the MCP cluster. |
(Optional.) Create a namespace |
Make sure a namespace exists before creating Deployments in the multi-cloud container management service. |
Deploy an application |
You can deploy applications by using the following methods:
