Figure-1 Configuration flow
Task |
Optional. After connecting the system to a VMware vCenter, you can view the CPU usage and memory usage information about the nodes in the vCenter. |
Required. Customize alarm rules. |
Optional. Configure the system to send alarm notifications to users. The system supports only email notifications. If you do not configure notification destination email addresses, the system only displays alarms in the alarm list. |
Required. View the alarms generated by the system. The system refreshes the alarm list every minute. |
