On the top navigation bar, click Cloud Services, and then select Power Hosts from the Compute menu.
Click Create if you are a system or organization administrator. Click Request if you are a user.
Configure basic settings, network and security settings, and system settings as described in Table-4.
Click OK.
Table-1 Configuring power host parameters
Parameter |
Creation Method |
Create New |
Customize a new power host. |
Owner |
Select an owner. |
AZ |
Select a compute AZ of which the hypervisor type is PowerVM. |
Select Image |
Select a public or private image. |
System Disk/Data Disk |
Configure storage resources, including a system disk and a data disk. A data disk is a cloud disk used for permanent storage, while the system disk created for a power host provides only temporary storage. When a power host is destroyed, the data on its system disk is deleted, and the data on its data disk remains intact. You can select a data disk during power host creation or attach a cloud disk as a data disk to a power host as described in "Attach a cloud disk" after power host creation. For more information about creating cloud disks, see "About cloud disks." |
Network |
Assign an IP address to the power host. |
Authentication Policy |
Generate |
Enable the
device to generate a VNC password. To view the VNC password, click the name
of the power host in the power host list and then click the |
Set |
Enter a password manually. |
Image Default Password |
Use the default password of the image. The image default password is the password used for logging in to the VM from which the image is created. |
