Cloud disks provide persistent block storage resources for power hosts. You can format cloud disks and configure file systems on them like on physical disks. You can attach and detach cloud disks for power hosts. For more information about cloud disks, see "About cloud disks."
On the top navigation bar, click Cloud Services, and then select Power Hosts from the Compute menu.
Click More for a power host and then select Attach Disk.
Click Attach for a cloud disk.
Click More for a power host and then select Detach Disk.
