10-High Availability Configuration Examples
01-S12500_VRRP_Configuration_Examples
Chapters Download  (311.23 KB)
01-S12500_VRRP_Configuration_Examples 311.23 KB
Introduction· 1
Prerequisites 1
Example: Configuring a single IPv4 VRRP group· 1
Network requirements 1
Requirements analysis 2
Software version used· 2
Configuration restrictions and guidelines 2
Configuration procedures 3
Configuring Switch A·· 3
Configuring Switch B· 4
Configuring the Layer 2 switch· 5
Verifying the configuration· 5
Configuration files 6
Example: Configuring multiple IPv4 VRRP groups 8
Network requirements 8
Requirements analysis 8
Software version used· 8
Configuration restrictions and guidelines 9
Configuration procedures 9
Configuring Switch A·· 9
Configuring Switch B· 10
Verifying the configuration· 12
Configuration files 14
Example: Configuring IPv4 VRRP load balancing mode· 16
Network requirements 16
Requirements analysis 17
Software version used· 17
Configuration restrictions and guidelines 17
Configuration procedures 18
Configuring Switch A·· 18
Configuring Switch B· 19
Configuring Switch C·· 20
Verifying the configuration· 21
Configuration files 24
Example: Configuring a single IPv6 VRRP group· 26
Network requirements 26
Requirements analysis 27
Software version used· 27
Configuration restrictions and guidelines 27
Configuration procedures 28
Configuring Switch A·· 28
Configuring Switch B· 29
Configuring the Layer 2 switch· 30
Verifying the configuration· 30
Configuration files 31
Example: Configuring multiple IPv6 VRRP groups 33
Network requirements 33
Requirements analysis 33
Software version used· 33
Configuration restrictions and guidelines 34
Configuration procedures 34
Configuring Switch A·· 34
Configuring Switch B· 35
Verifying the configuration· 37
Configuration files 39
Example: Configuring IPv6 VRRP load balancing mode· 42
Network requirements 42
Requirements analysis 42
Software version used· 43
Configuration restrictions and guidelines 43
Configuration procedures 43
Configuring Switch A·· 43
Configuring Switch B· 44
Configuring Switch C·· 45
Verifying the configuration· 46
Configuration files 49
Related documentation· 51
Introduction
This document provides VRRP configuration examples.
VRRP operates in either of the following modes:
·     Standard modeComplies with RFCs. In this mode, only the master can forward packets and the backups are in listening state.
·     Load balancing mode—Extends the VRRP standard mode to distribute load across VRRP group members.
You can also implement load sharing by configuring multiple standard-mode VRRP groups. Each group has one master and multiple backups.
This document assumes that you have basic knowledge of H3C VRRP.
As shown in Figure 1, configure a VRRP group on Switch A and Switch B as the gateway for the hosts, and implement the following requirements:
·     Switch A operates as the master to forward packets from the hosts to the external network. When Switch A fails, Switch B takes over to forward packets for the hosts.
·     When the uplink interface of Switch A fails, hosts can access the external network through Switch B.
·     To avoid loops between Switch A, Switch B, and the Layer 2 switch, enable MSTP on them, and specify the master as the root bridge.
Figure 1 Network diagram
Configure VRRP tracking on Switch A so that when its uplink is not available, Switch A decreases its priority for Switch B to take over quickly.
This configuration example was created and verified on S12500-CMW710-R7129.
When you configure a single IPv4 VRRP group, follow these restrictions and guidelines:
·     The virtual IP address of the IPv4 VRRP group and the IP address of the downlink interface of the VRRP group must be in the same subnet. Otherwise, the hosts in the subnet cannot access external networks.
·     If you associate a track entry with the VRRP group on an IP address owner, the association does not take effect until the switch is not an IP address owner.
·     Make sure the VRRP versions on all switches in the VRRP group are the same. Otherwise, the VRRP group cannot operate correctly.
# Configure VLAN 101.
[SwitchA] vlan 101
[SwitchA-vlan101] port Gigabitethernet 2/0/1
[SwitchA-vlan101] port Gigabitethernet 2/0/24
[SwitchA-vlan101] quit
[SwitchA] interface GigabitEthernet 2/0/1
[SwitchA-GigabitEthernet2/0/1] undo shutdown
[SwitchA-GigabitEthernet2/0/1] quit
[SwitchA] interface GigabitEthernet 2/0/24
[SwitchA-GigabitEthernet2/0/24] undo shutdown
[SwitchA-GigabitEthernet2/0/24] quit
[SwitchA–Vlan-interface101] undo shutdown
[SwitchA-Vlan-interface101] ip address 10.0.0.2 24
[SwitchA–Vlan-interface101] quit
# Configure VLAN 4094.
[SwitchA] vlan 4094
[SwitchA-vlan4094] port Gigabitethernet 2/0/2
[SwitchA-vlan4094] quit
[SwitchA-GigabitEthernet2/0/2] undo shutdown
[SwitchA-GigabitEthernet2/0/2] quit
[SwitchA] interface vlan-interface 4094
[SwitchA–Vlan-interface4094] undo shutdown
[SwitchA-Vlan-interface4094] ip address 100.0.0.2 24
[SwitchA-Vlan-interface4094] quit
# Create VRRP group 1, and set the virtual IP address of the VRRP group to 10.0.0.1.
[SwitchA-Vlan-interface101] vrrp vrid 1 virtual-ip 10.0.0.1
# Set the priority of Switch A in VRRP group 1 to 120.
[SwitchA-Vlan-interface101] vrrp vrid 1 priority 120
# Create track entry 1 and associate it with the link state of VLAN-interface 4094.
[SwitchA] track 1 interface Vlan-interface 4094
# Associate VRRP group 1 on VLAN-interface 101 with track entry 1 and decrease the priority of the switch in the VRRP group by 255 when the state of track entry 1 changes to negative.
[SwitchA-Vlan-interface101] vrrp vrid 1 track 1 reduced 255
# Configure MSTP.
[SwitchA] stp region-configuration
[SwitchA-mst-region] region-name vrrp
[SwitchA-mst-region] instance 1 vlan 101
[SwitchA-mst-region] active region-configuration
[SwitchA-mst-region] quit
[SwitchA] stp instance 1 root primary
[SwitchA] stp global enable
[SwitchB] vlan 101
[SwitchB-vlan101] port Gigabitethernet 3/0/1
[SwitchB-vlan101] port Gigabitethernet 3/0/24
[SwitchB-vlan101] quit
[SwitchB] interface GigabitEthernet 3/0/1
[SwitchB-GigabitEthernet3/0/1] undo shutdown
[SwitchB-GigabitEthernet3/0/1] quit
[SwitchB] interface GigabitEthernet 3/0/24
[SwitchB-GigabitEthernet3/0/24] undo shutdown
[SwitchB-GigabitEthernet3/0/24] quit
[SwitchB] interface Vlan-interface 101
[SwitchB-Vlan-interface101] undo shutdown
[SwitchB-Vlan-interface101] ip address 10.0.0.3 24
[SwitchB] vlan 4094
[SwitchB-vlan4094] port Gigabitethernet 3/0/2
[SwitchB-vlan4094] quit
[SwitchB-GigabitEthernet3/0/2] undo shutdown
[SwitchB-GigabitEthernet3/0/2] quit
[SwitchB] interface Vlan-interface 4094
[SwitchB-Vlan-interface4094] undo shutdown
[SwitchB-Vlan-interface4094] ip address 100.0.0.3 24
[SwitchB-Vlan-interface4094] quit
[SwitchB-Vlan-interface101] vrrp vrid 1 virtual-ip 10.0.0.1
# Configure MSTP.
[SwitchB] stp region-configuration
[SwitchB-mst-region] region-name vrrp
[SwitchB-mst-region] instance 1 vlan 101
[SwitchB-mst-region] active region-configuration
[SwitchB-mst-region] quit
[SwitchB] stp global enable
Configure MSTP on the Layer 2 switch in the same way MSTP is configured on Switch B.
# Ping the external network from Host A and Host B. (Details not shown.)
# Display detailed information about VRRP group 1 on Switch A.
[SwitchA] display vrrp verbose
     Running  Mode       : Standard
   Interface Vlan-interface101
     VRID           : 1                    Adver Timer  : 100
     Admin Status   : Up                   State        : Master
     Config Pri     : 120                  Running Pri  : 120
     Preempt Mode   : Yes                  Delay Time   : 0
     Auth Type      : None
     Virtual IP     : 10.0.0.1
     Virtual MAC    : 0000-5e00-0101
     Master IP      : 10.0.0.2
   VRRP Track Information:
     Track Object: 1             State : Positive        Pri Reduced : 255
The output shows that Switch A is the master in VRRP group 1.
# Display detailed information about VRRP group 1 on Switch B.
[SwitchB] display vrrp verbose
     Admin Status   : Up                   State        : Backup
     Config Pri     : 100                  Running Pri  : 100
     Auth Type      : None
The output shows that Switch B is the backup in VRRP group 1.
# Display the MSTP status on the Layer 2 switch.
<L2Switch> display stp instance 1 brief
 MSTID      Port                         Role  STP State     Protection
   1        GigabitEthernet3/0/1         ROOT  FORWARDING    NONE
   1        GigabitEthernet3/0/2         ALTE  DISCARDING    NONE
The output shows that the port that connects the Layer 2 switch to Switch B is blocked.
# Display detailed information about the VRRP group on Switch B when Switch A fails or the uplink VLAN interface is down.
     Auth Type      : None
     Master IP      : 10.0.0.3
The output shows that Switch B has become the master.
Configuration files
·     Switch A:
vlan 101
vlan 4094
 region-name vrrp
 instance 1 vlan 101
 stp global enable
interface Vlan-interface101
 ip address 10.0.0.2 255.255.255.0
interface Vlan-interface4094
 ip address 100.0.0.2 255.255.255.0
interface GigabitEthernet2/0/1
 port link-mode bridge
 port access vlan 101
interface GigabitEthernet2/0/2
 port access vlan 4094
interface GigabitEthernet2/0/24
·     Switch B:
vlan 101
vlan 4094
 region-name vrrp
 instance 1 vlan 101
stp global enable
 ip address 10.0.0.3 255.255.255.0
 ip address 100.0.0.3 255.255.255.0
interface GigabitEthernet3/0/1
interface GigabitEthernet3/0/2
interface GigabitEthernet3/0/24
As shown in Figure 2, Switch A and Switch B form two VRRP groups. Implement the following requirements:
·     Switch A operates as the master of VRRP group 1 to forward packets from Area A, and Switch B operates as the master of VRRP group 2 to forward packets from Area B. When one of the switches fails, the other switch provides gateway service for both areas.
·     When the uplink interface of one switch fails, hosts can access the external network through the other switch.
·     To avoid loops between Switch A, Switch B, and the Layer 2 switch, enable MSTP on them, and specify the masters as the root bridges.
Figure 2 Network diagram
Configure VRRP tracking on the master so that when its uplink is not available, the master decreases its priority for the backup to take over quickly.
When you configure multiple IPv4 VRRP groups, follow these restrictions and guidelines:
·     The virtual IP addresses of an IPv4 VRRP group and the IP address of the downlink interface of the VRRP group must be in the same subnet. Otherwise, the hosts in the subnet cannot access external networks.
·     If you associate a track entry with a VRRP group on an IP address owner, the association does not take effect until the switch is not an IP address owner.
[SwitchA] vlan 101
[SwitchA-Vlan-interface101] undo shutdown
# Configure VLAN 102.
[SwitchA] vlan 102
[SwitchA-vlan102] port Gigabitethernet 2/0/3
[SwitchA-vlan102] quit
[SwitchA] interface GigabitEthernet 2/0/3
[SwitchA-GigabitEthernet2/0/3] undo shutdown
[SwitchA-GigabitEthernet2/0/3] quit
[SwitchA-Vlan-interface102] undo shutdown
[SwitchA-Vlan-interface102] ip address 11.0.0.2 24
[SwitchA] vlan 4094
[SwitchA-Vlan-interface4094] undo shutdown
# Configure GigabitEthernet 2/0/24 as a trunk port, and assign it to VLAN 101 and VLAN 102.
[SwitchA] interface GigabitEthernet2/0/24
[SwitchA-GigabitEthernet2/0/24] port link-type trunk
[SwitchA-GigabitEthernet2/0/24] undo port trunk permit vlan 1
[SwitchA-GigabitEthernet2/0/24] port trunk permit vlan 101 to 102
[SwitchA-GigabitEthernet2/0/24] port trunk pvid vlan 101
# Create VRRP group 2, and set the virtual IP address of the VRRP group to 11.0.0.1.
[SwitchA-Vlan-interface102] vrrp vrid 1 virtual-ip 11.0.0.1
# Configure MSTP.
[SwitchA-mst-region] instance 2 vlan 102
[SwitchB] vlan 101
[SwitchB] vlan 102
[SwitchB-vlan102] port Gigabitethernet 3/0/3
[SwitchB-vlan102] quit
[SwitchB] interface GigabitEthernet 3/0/3
[SwitchB-GigabitEthernet3/0/3] undo shutdown
[SwitchB-GigabitEthernet3/0/3] quit
[SwitchB-Vlan-interface102] undo shutdown
[SwitchB-Vlan-interface102] ip address 11.0.0.3 24
[SwitchB] vlan 4094
[SwitchB] interface vlan-interface 4094
# Configure GigabitEthernet 3/0/24 as a trunk port, and assign it to VLAN 101 and VLAN 102.
[SwitchB] interface GigabitEthernet3/0/24
[SwitchB-GigabitEthernet3/0/24] port link-type trunk
[SwitchB-GigabitEthernet3/0/24] undo port trunk permit vlan 1
[SwitchB-GigabitEthernet3/0/24] port trunk permit vlan 101 to 102
[SwitchB-GigabitEthernet3/0/24] port trunk pvid vlan 101
[SwitchB-Vlan-interface102] vrrp vrid 1 virtual-ip 11.0.0.1
# Set the priority of Switch B in VRRP group 2 to 120.
[SwitchB-Vlan-interface102] vrrp vrid 1 priority 120
[SwitchB] track 1 interface Vlan-interface 4094
# Associate VRRP group 2 on VLAN-interface 102 with track entry 1. Decrease the priority of the switch in the VRRP group by 255 when the state of track entry 1 changes to negative.
[SwitchB-Vlan-interface102] vrrp vrid 1 track 1 reduced 255
# Configure MSTP.
[SwitchB-mst-region] instance 2 vlan 102
[SwitchB] stp instance 2 root primary
# Ping the external network from hosts in area A and area B. (Details not shown.)
# Display detailed information about the VRRP groups on Switch A.
     Auth Type      : None
     Track object: 1             State : Positive      Pri Reduced : 255
   Interface Vlan-interface102
     Auth Type      : None
     Virtual IP     : 11.0.0.1
     Master IP      : 11.0.0.3
The output shows that Switch A is the master in VRRP group 1 and is the backup in VRRP group 2.
# Display detailed information about the VRRP groups on Switch B.
     Auth Type      : None
     Auth Type      : None
     Track object: 1             State :positive         Pri Reduced : 255
The output shows that Switch B is the backup in VRRP group 1 and is the master in VRRP group 2.
# Display the MSTP status on Switch A.
[SwitchA] display stp brief
   0        GigabitEthernet2/0/1         DESI  FORWARDING    NONE
   0        GigabitEthernet2/0/24        DESI  FORWARDING    NONE
   0        GigabitEthernet2/0/3         ROOT  FORWARDING    NONE
   1        GigabitEthernet2/0/1         DESI  FORWARDING    NONE
   1        GigabitEthernet2/0/24        DESI  FORWARDING    NONE
   2        GigabitEthernet2/0/24        ROOT  FORWARDING    NONE
   2        GigabitEthernet2/0/3         ALTE  DISCARDING    NONE
The output shows that GigabitEthernet 2/0/3 on Switch A is blocked in MSTI 2.
# Display the MSTP status on Switch B.
[SwitchB] display stp brief
   0        GigabitEthernet3/0/1         DESI  FORWARDING    NONE
   0        GigabitEthernet3/0/24        ALTE  DISCARDING    NONE
   0        GigabitEthernet3/0/3         ROOT  FORWARDING    NONE
   1        GigabitEthernet3/0/1         ALTE  DISCARDING    NONE
   1        GigabitEthernet3/0/24        ROOT  FORWARDING    NONE
   2        GigabitEthernet3/0/24        DESI  FORWARDING    NONE
   2        GigabitEthernet3/0/3         DESI  FORWARDING    NONE
The output shows that GigabitEthernet 3/0/1 on Switch B is blocked in MSTI 1.
# Display detailed information about the VRRP groups on Switch B when Switch A fails or the uplink VLAN interface is down.
     Auth Type      : None
     Auth Type      : None
The output shows that Switch B has become the master in VRRP group 1.
Configuration files
·     Switch A:
vlan 101 to 102
vlan 4094
 region-name vrrp
 instance 1 vlan 101
 instance 2 vlan 102
 stp global enable
interface Vlan-interface102
 ip address 11.0.0.2 255.255.255.0
interface GigabitEthernet2/0/3
 port access vlan 102
·     Switch B:
vlan 101 to 102
vlan 4094
 region-name vrrp
 instance 1 vlan 101
 instance 2 vlan 102
 stp global enable
 ip address 11.0.0.3 255.255.255.0
interface GigabitEthernet3/0/3
As shown in Figure 3, Switch A, Switch B, and Switch C form a load-balanced VRRP group and use the virtual IP address 10.1.1.1/24 to provide gateway service. Implement the following requirements:
·     Switch A operates as the master to forward packets from Host A. When Switch A fails, Switch B or Switch C takes over to forward packets for Host A.
·     Packets from the hosts are forwarded by different switches to reduce the burden of the master.
·     When the upstream link of the active virtual forwarder (AVF) fails, the AVF can notify a listening virtual forwarder (LVF) to take over.
Figure 3 Network diagram
For the AVF to notify an LVF to take over its role when the upstream link of the AVF fails, configure VF tracking on each gateway to monitor the uplink.
Use BFD to monitor the upstream link state of the VF owner, and use the tracking function to establish the collaboration between the VFs and BFD. When the upstream link fails, the state of the track entry changes to Negative, and the weights of the VFs (including the AVF) on the switch decrease by a specified value. The corresponding LVF with a higher priority on another switch becomes the AVF and forwards packets.
When you configure IPv4 VRRP load balancing mode, follow these restrictions and guidelines:
·     In load balancing mode, the virtual IP address of a VRRP group can be any unassigned IP address of the subnet where the VRRP group resides. The virtual IP address of a VRRP group cannot be the IP address of any interface in the VRRP group. No IP address owner can exist in a VRRP group.
·     The source IP address of BFD echo packets cannot be on the same network segment as any local interface's IP address.
# Configure VLAN 2.
[SwitchA] vlan 2
[SwitchA-vlan2] port Gigabitethernet 3/0/1
[SwitchA-vlan2] quit
[SwitchA] interface GigabitEthernet 3/0/1
[SwitchA-GigabitEthernet3/0/1] undo shutdown
[SwitchA-GigabitEthernet3/0/1] quit
[SwitchA–Vlan-interface2] undo shutdown
[SwitchA-Vlan-interface2] ip address 10.1.1.2 24
[SwitchA–Vlan-interface2] quit
[SwitchA] vlan 4094
[SwitchA-vlan4094] port Gigabitethernet 3/0/5
[SwitchA] interface GigabitEthernet 3/0/5
[SwitchA-GigabitEthernet3/0/5] undo shutdown
[SwitchA-GigabitEthernet3/0/5] quit
[SwitchA–Vlan-interface4094] quit
# Configure VRRP to operate in load balancing mode.
[SwitchA] vrrp mode load-balance
# Create VRRP group 1, and set the virtual IP address for the group to 10.1.1.1.
[SwitchA-Vlan-interface2] vrrp vrid 1 virtual-ip 10.1.1.1
[SwitchA-Vlan-interface2] vrrp vrid 1 priority 120
# Configure VRRP tracking for the VF.
[SwitchA-Vlan-interface2] vrrp vrid 1 weight track 1 reduced 255
# Configure the source IP address of BFD echo packets as 45.45.45.45.
[SwitchA] bfd echo-source-ip 45.45.45.45
# Configure the minimum interval for receiving BFD echo packets as 100 milliseconds.
[SwitchA-Vlan-interface4094] bfd min-echo-receive-interval 100
# Configure the single-hop detection time multiplier as 3.
[SwitchA-Vlan-interface4094] bfd detect-multiplier 3
# Create track entry 1, which uses BFD to monitor the link between local IP address 100.0.0.1 and remote IP address 100.0.0.2 by sending BFD echo packets out from the VLAN-interface 4094.
[SwitchA] track 1 bfd echo interface Vlan-interface4094 remote ip 100.0.0.1 local ip 100.0.0.2
# Configure VLAN 2.
[SwitchB] vlan 2
[SwitchB-vlan2] port Gigabitethernet 3/0/1
[SwitchB-vlan2] quit
[SwitchB–Vlan-interface2] undo shutdown
[SwitchB-Vlan-interface2] ip address 10.1.1.3 24
[SwitchB] vlan 4094
[SwitchB-vlan4094] port Gigabitethernet 3/0/5
[SwitchB] interface GigabitEthernet 3/0/5
[SwitchB-GigabitEthernet3/0/5] undo shutdown
[SwitchB-GigabitEthernet3/0/5] quit
[SwitchB–Vlan-interface4094] undo shutdown
[SwitchB–Vlan-interface4094] quit
[SwitchB] vrrp mode load-balance
[SwitchB-Vlan-interface2] vrrp vrid 1 virtual-ip 10.1.1.1
# Set the priority of Switch B in VRRP group 1 to 110.
[SwitchB-Vlan-interface2] vrrp vrid 1 priority 110
[SwitchB-Vlan-interface2] vrrp vrid 1 weight track 1 reduced 255
# Configure the source IP address of BFD echo packets as 56.56.56.56.
[SwitchB] bfd echo-source-ip 56.56.56.56
[SwitchB-Vlan-interface4094] bfd min-echo-receive-interval 100
[SwitchB-Vlan-interface4094] bfd detect-multiplier 3
[SwitchB] track 1 bfd echo interface Vlan-interface4094 remote ip 100.0.0.1 local ip 100.0.0.3
# Configure VLAN 2.
[SwitchC] vlan 2
[SwitchC-vlan2] port Gigabitethernet 3/0/1
[SwitchC-vlan2] quit
[SwitchC] interface GigabitEthernet 3/0/1
[SwitchC-GigabitEthernet3/0/1] undo shutdown
[SwitchC-GigabitEthernet3/0/1] quit
[SwitchC-Vlan-interface2] undo shutdown
[SwitchC-Vlan-interface2] ip address 10.1.1.4 24
[SwitchC] vlan 4094
[SwitchC-vlan4094] port Gigabitethernet 3/0/5
[SwitchC-vlan4094] quit
[SwitchC] interface GigabitEthernet 3/0/5
[SwitchC-GigabitEthernet3/0/5] undo shutdown
[SwitchC-GigabitEthernet3/0/5] quit
[SwitchC] interface vlan-interface 4094
[SwitchC-Vlan-interface4094] undo shutdown
[SwitchC-Vlan-interface4094] ip address 100.0.0.4 24
[SwitchC-Vlan-interface4094] quit
[SwitchC] vrrp mode load-balance
[SwitchC-Vlan-interface2] vrrp vrid 1 virtual-ip 10.1.1.1
[SwitchC-Vlan-interface2] vrrp vrid 1 weight track 1 reduced 255
# Configure the source IP address of BFD echo packets as 67.67.67.67.
[SwitchC] bfd echo-source-ip 67.67.67.67
[SwitchC-Vlan-interface4094] bfd min-echo-receive-interval 100
[SwitchC-Vlan-interface4094] bfd detect-multiplier 3
[SwitchC–Vlan-interface4094] quit
# Create track entry 1. Track entry 1 uses BFD to monitor the link between local IP address 100.0.0.1 and remote IP address 100.0.0.2 by sending BFD echo packets out from the VLAN-interface 4094.
[SwitchC] track 1 bfd echo interface Vlan-interface4094 remote ip 100.0.0.1 local ip 100.0.0.4
# Ping the external network from Host A, Host B, and Host C. (Details not shown.)
     Running Mode       : Load Balance
   Interface Vlan-interface2
     Auth Type      : None
     Virtual IP     : 10.1.1.1
     Master IP      : 10.1.1.2
   Forwarder Information: 3 Forwarders 1 Active
     Config Weight  : 255
     Running Weight : 255
    Forwarder 01
     State          : Active
     Virtual MAC    : 000f-e2ff-0011 (Owner)
     Owner ID       : 6697-1250-0100
     Priority       : 255
     Active         : local
    Forwarder 02
     State          : Listening
     Virtual MAC    : 000f-e2ff-0012 (Learnt)
     Owner ID       : 00e0-6405-3100
     Priority       : 127
     Active         : 10.1.1.3
    Forwarder 03
     State          : Listening
     Virtual MAC    : 000f-e2ff-0013 (Learnt)
     Owner ID       : 0001-0002-0103
     Priority       : 127
     Active         : 10.1.1.4
   Forwarder Weight Track Information:
     Track Object   : 1          State : Positive   Weight Reduced : 255
     Config Pri     : 110                  Running Pri  : 110
     Auth Type      : None
     Config Weight  : 255
    Forwarder 01
     State          : Listening
     Virtual MAC    : 000f-e2ff-0011 (Learnt)
     Priority       : 127
     Active         : 10.1.1.2
    Forwarder 02
     State          : Active
     Virtual MAC    : 000f-e2ff-0012 (Owner)
     Priority       : 255
     Active         : local
    Forwarder 03
     State          : Listening
     Priority       : 127
     Active         : 10.1.1.4
# Display detailed information about VRRP group 1 on Switch C.
[SwitchC] display vrrp verbose
     Auth Type      : None
     Config Weight  : 255
    Forwarder 01
     State          : Listening
     Priority       : 127
     Active         : 10.1.1.2
    Forwarder 02
     State          : Listening
     Priority       : 127
     Active         : 10.1.1.3
    Forwarder 03
     State          : Active
     Virtual MAC    : 000f-e2ff-0013 (Owner)
     Priority       : 255
     Active         : local
The output shows that in VRRP group 1, Switch A is the master, and Switch B and Switch C are the backups. An active VF and two listening VFs exist on each switch.
# Display detailed information about VRRP group 1 on Switch C when Switch A fails.
     Auth Type      : None
     Master IP      : 10.1.1.3
   Forwarder Information: 3 Forwarders 2 Active
     Config Weight  : 255
    Forwarder 01
     State          : Active
     Virtual MAC    : 000f-e2ff-0011 (Take Over)
     Priority       : 85
     Active         : local
     Redirect Time  : 588 secs
     Time-out Time  : 1788 secs
    Forwarder 02
     State          : Listening
     Priority       : 85
     Active         : 10.1.1.3
    Forwarder 03
     State          : Active
     Priority       : 255
     Active         : local
The output shows that Switch B becomes the master after Switch A fails. Switch C becomes an AVF with virtual MAC address 000f-e2ff-0011 mapped to it and forwards packets sent by Host A.
Configuration files
·     Switch A:
vlan 2
vlan 4094
interface Vlan-interface2
 port access vlan 2
interface GigabitEthernet3/0/5
·     Switch B:
vlan 2
vlan 4094
 ip address 10.1.1.3 255.255.255.0
 port access vlan 2
·     Switch C:
vlan 2
vlan 4094
 ip address 10.1.1.4 255.255.255.0
 ip address 100.0.0.4 255.255.255.0
 port access vlan 2
As shown in Figure 4, configure a VRRP group on Switch A and Switch B as the gateway for the hosts, and implement the following requirements:
Figure 4 Network diagram
When you configure a single IPv6 VRRP group, follow these restrictions and guidelines:
·     The virtual IPv6 addresses of the VRRP group and the IPv6 address of the downlink interface of the VRRP group must be in the same subnet. Otherwise, the hosts in the subnet cannot access external networks.
[SwitchA] vlan 101
[SwitchA-Vlan-interface101] ipv6 address 10::2 64
[SwitchA] vlan 4094
[SwitchA-Vlan-interface4094] ipv6 address 100::2 64
# Create VRRP group 1, and set the virtual IPv6 addresses of the VRRP group to FE80::1 and 10::1.
[SwitchA-Vlan-interface101] vrrp ipv6 vrid 1 virtual-ip FE80::1 link-local
[SwitchA-Vlan-interface101] vrrp ipv6 vrid 1 virtual-ip 10::1
[SwitchA-Vlan-interface101] vrrp ipv6 vrid 1 priority 120
[SwitchA] track 1 interface vlan-interface 4094
# Associate VRRP group 1 on VLAN-interface 101 with track entry 1. Decrease the priority of the switch in the VRRP group by 255 when the state of track entry 1 changes to negative.
[switchA] interface vlan-interface 101
[SwitchA-Vlan-interface101] vrrp ipv6 vrid 1 track 1 reduced 255
# Configure MSTP.
[SwitchB] vlan 101
[SwitchB-Vlan-interface101] ipv6 address 10::3 64
[SwitchB] vlan 4094
[SwitchB-Vlan-interface4094] ipv6 address 100::3 64
[SwitchB-Vlan-interface101] vrrp ipv6 vrid 1 virtual-ip FE80::1 link-local
[SwitchB-Vlan-interface101] vrrp ipv6 vrid 1 virtual-ip 10::1
# Configure MSTP.
[SwitchA] display vrrp ipv6 verbose
IPv6 virtual Router Information:
     Auth Type      : None
     Virtual IP     : FE80::1
                      10::1
     Virtual MAC    : 0000-5e00-0201
     Master IP      : FE80::2E0:64FF:FE05:3100
[SwitchB] display vrrp ipv6 verbose
     Auth Type      : None
                      10::1
The output shows that the interface connecting to Switch B is blocked.
     Auth Type      : None
                      10::1
     Master IP      : FE80::6697:12FF:FE50:100
The output shows that Switch B becomes the master in VRRP group 1.
Configuration files
·     Switch A:
vlan 101
vlan 4094
 region-name vrrp
 instance 1 vlan 101
 stp global enable
 ipv6 address 10::2/64
 ipv6 address 100::2/64
·     Switch B:
vlan 101
vlan 4094
 region-name vrrp
 instance 1 vlan 101
stp global enable
 ipv6 address 10::3/64
 ipv6 address 100::3/64
As shown in Figure 5, Switch A and Switch B form two VRRP groups. Implement the following requirements:
·     Switch A operates as the master of VRRP group 1 to forward packets from Area A. Switch B operates as the master of VRRP group 2 to forward packets from Area B. When one of the switches fails, the other switch provides gateway service for both areas.
Figure 5 Network diagram
When you configure multiple IPv6 VRRP groups, follow these restrictions and guidelines:
·     The virtual IPv6 addresses of a VRRP group and the IPv6 address of the downlink interface of the VRRP group must be in the same subnet. Otherwise, the hosts in the subnet cannot access external networks.
[SwitchA] vlan 101
[SwitchA] vlan 102
[SwitchA-Vlan-interface102] ipv6 address 11::2 64
[SwitchA] vlan 4094
# Create VRRP group 1, and set the virtual IPv6 address of the VRRP group to FE80::1 and 10::1.
# Create VRRP group 2, and set the virtual IPv6 address of the VRRP group to FE80::1 and 11::1.
[SwitchA-Vlan-interface102] vrrp ipv6 vrid 1 virtual-ip FE80::1 link-local
[SwitchA-Vlan-interface102] vrrp ipv6 vrid 1 virtual-ip 11::1
# Configure MSTP.
[SwitchB] vlan 101
[SwitchB] vlan 102
[SwitchB-Vlan-interface102] ipv6 address 11::3 64
[SwitchB] vlan 4094
[SwitchB-Vlan-interface102] vrrp ipv6 vrid 1 virtual-ip FE80::1 link-local
[SwitchB-Vlan-interface102] vrrp ipv6 vrid 1 virtual-ip 11::1
# Set the priority for VRRP group 2 to 120.
[SwitchB-Vlan-interface102] vrrp ipv6 vrid 1 priority 120
[SwitchB-Vlan-interface102] vrrp ipv6 vrid 1 track 1 reduced 255
# Configure MSTP.
# Ping the external network from the hosts in Area A and Area B. (Details not shown.)
IPv6 Virtual Router Information:
     Auth Type      : None
                      10::1
     Auth Type      : None
                      11::1
     Master IP      : FE80::6697:12FF:FE50:3100
The output shows that Switch A is the master in VRRP group 1 and the backup in VRRP group 2.
     Auth Type      : None
                      10::1
     Auth Type      : None
                      11::1
The output shows that Switch B is the backup in VRRP group 1 and the master in VRRP group 2.
# Display the MSTP status on Switch A. The output shows that GigabitEthernet 2/0/3 is blocked in MSTI 2.
# Display the MSTP status on Switch B. The output shows that GigabitEthernet 3/0/1 is blocked in MSTI 1.
# Display detailed information about the VRRP groups on Switch B when Switch A fails.
     Auth Type      : None
                      10::1
     Auth Type      : None
                      11::1
The output shows that Switch B becomes the master of VRRP group 1.
Configuration files
·     Switch A:
vlan 101 to 102
vlan 4094
 region-name vrrp
 instance 1 vlan 101
 instance 2 vlan 102
 stp  global enable
 ipv6 address 11::2/64
·     Switch B:
vlan 101 to 102
vlan 4094
 region-name vrrp
 instance 1 vlan 101
 instance 2 vlan 102
 stp global enable
 ipv6 address 11::3/64
As shown in Figure 6, Switch A, Switch B, and Switch C form a load-balanced VRRP group and use the virtual IPv6 address FE80::10 to provide gateway service. Implement the following requirements:
·     When the upstream link of the AVF fails, the AVF can notify an LVF to take over.
Figure 6 Network diagram
For the AVF to notify an LVF to take over its role when the upstream link of the AVF fails, configure VF tracking on each gateway to monitor the uplink. Use interface management to monitor the upstream link state of the VF owner. Use the tracking function to establish the collaboration between the VFs and interface management. When the upstream link fails, the state of the track entry changes to Negative, and the weights of the VFs (including the AVF) on the switch decrease by a specified value. The corresponding LVF with a higher priority on another switch becomes the AVF and forwards packets.
When you configure IPv6 VRRP load balancing mode, follow these restrictions and guidelines:
·     In load balancing mode, the virtual IP address of a VRRP group can be any unassigned IP address of the subnet where the VRRP group resides. The virtual IP address cannot be the IP address of any interface in the VRRP group. No IP address owner can exist in a VRRP group.
·     To enable hosts to learn their default gateway from RA messages sent by the switches, enable RA message sending on the VLAN interfaces of all the gateways connecting to the hosts.
# Configure VLAN 2.
[SwitchA] vlan 2
[SwitchA-Vlan-interface2] ipv6 address fe80::1 link-local
[SwitchA-Vlan-interface2] ipv6 address 1::1 64
[SwitchA] vlan 4094
[SwitchA-Vlan-interface4094] ipv6 address 2001::1/64
[SwitchA] vrrp ipv6 mode load-balance
# Create VRRP group 1 and set its virtual IPv6 addresses to FE80::10 and 1::10.
[SwitchA-Vlan-interface2] vrrp ipv6 vrid 1 virtual-ip fe80::10 link-local
[SwitchA-Vlan-interface2] vrrp ipv6 vrid 1 virtual-ip 1::10
[SwitchA-Vlan-interface2] vrrp ipv6 vrid 1 priority 120
# Enable Switch A to send RA messages.
[SwitchA-Vlan-interface2] undo ipv6 nd ra halt
# Associate VRRP group 1 on VLAN-interface 2 with track entry 1. Decrease the priority of the switch in the VRRP group by 255 when the state of track entry 1 changes to negative.
[SwitchA-Vlan-interface2] vrrp ipv6 vrid 1 weight track 1 reduced 255
[SwitchA] track 1 interface Vlan-interface4094 protocol ipv6
# Configure VLAN 2.
[SwitchB] vlan 2
[SwitchB-Vlan-interface2] undo shutdown
[SwitchB-Vlan-interface2] ipv6 address fe80::2 link-local
[SwitchB-Vlan-interface2] ipv6 address 1::2 64
[SwitchB] vlan 4094
[SwitchB-Vlan-interface4094] ipv6 address 2001::2/64
[SwitchB] vrrp ipv6 mode load-balance
# Create VRRP group 1 and set its virtual IP addresses to FE80::10 and 1::10.
[SwitchB-Vlan-interface2] vrrp ipv6 vrid 1 virtual-ip fe80::10 link-local
[SwitchB-Vlan-interface2] vrrp ipv6 vrid 1 virtual-ip 1::10
[SwitchB-Vlan-interface2] vrrp ipv6 vrid 1 priority 110
# Enable Switch B to send RA messages.
[SwitchB-Vlan-interface2] vrrp ipv6 vrid 1 weight track 1 reduced 255
[SwitchB] track 1 interface Vlan-interface4094 protocol ipv6
# Configure VLAN 2.
[SwitchC] vlan 2
[SwitchC-Vlan-interface2] ipv6 address fe80::3 link-local
[SwitchC-Vlan-interface2] ipv6 address 1::3 64
[SwitchC] vlan 4094
[SwitchC-Vlan-interface4094] ipv6 address 2001::3/64
[SwitchC] vrrp ipv6 mode load-balance
[SwitchC-Vlan-interface2] vrrp ipv6 vrid 1 virtual-ip fe80::10 link-local
[SwitchC-Vlan-interface2] vrrp ipv6 vrid 1 virtual-ip 1::10
# Enable Switch C to send RA messages.
[SwitchC-Vlan-interface2] undo ipv6 nd ra halt
[SwitchC-Vlan-interface2] vrrp ipv6 vrid 1 weight track 1 reduced 255
[SwitchC] track 1 interface Vlan-interface4094 protocol ipv6
     Auth Type      : None
     Virtual IP     : FE80::10
                      1::10
     Master IP      : FE80::1
     Config Weight  : 255
    Forwarder 01
     State          : Active
     Virtual MAC    : 000f-e2ff-4011 (Owner)
     Priority       : 255
     Active         : local
    Forwarder 02
     State          : Listening
     Virtual MAC    : 000f-e2ff-4012 (Learnt)
     Priority       : 127
     Active         : FE80::2
    Forwarder 03
     State          : Listening
     Virtual MAC    : 000f-e2ff-4013 (Learnt)
     Owner ID       : 00e0-3948-0100
     Priority       : 127
     Active         : FE80::3
     Auth Type      : None
                      1::10
     Master IP      : FE80::1
     Config Weight  : 255
    Forwarder 01
     State          : Listening
     Virtual MAC    : 000f-e2ff-4011 (Learnt)
     Priority       : 127
     Active         : FE80::1
    Forwarder 02
     State          : Active
     Virtual MAC    : 000f-e2ff-4012 (Owner)
     Priority       : 255
     Active         : local
    Forwarder 03
     State          : Listening
     Priority       : 127
     Active         : FE80::3
[SwitchC] display vrrp ipv6 verbose
     Auth Type      : None
                      1::10
     Master IP      : FE80::1
     Config Weight  : 255
    Forwarder 01
     State          : Listening
     Priority       : 127
     Active         : FE80::1
    Forwarder 02
     State          : Listening
     Priority       : 127
     Active         : FE80::2
    Forwarder 03
     State          : Active
     Virtual MAC    : 000f-e2ff-4013 (Owner)
     Priority       : 255
     Active         : local
     Auth Type      : None
                      1::10
     Master IP      : FE80::2
     Config Weight  : 255
    Forwarder 01
     State          : Active
     Virtual MAC    : 000f-e2ff-4011 (Take Over)
     Priority       : 85
     Active         : local
     Redirect Time  : 549 secs
     Time-out Time  : 1749 secs
    Forwarder 02
     State          : Listening
     Priority       : 85
     Active         : FE80::2
    Forwarder 03
     State          : Active
     Priority       : 255
     Active         : local
The output shows that Switch B becomes the master after Switch A fails; Switch C becomes an active VF with virtual MAC address 000F-E2FF-4011 mapped to it and forwards packets sent by Host A.
Configuration files
·     Switch A:
vlan 2
vlan 4094
 ipv6 address 1::1/64
 ipv6 address FE80::1 link-local
 vrrp ipv6 vrid 1 virtual-ip FE80::10 link-local
 port access vlan 2
·     Switch B:
vlan 2
vlan 4094
 Vrrp ipv6 mode load-balance
 ipv6 address 1::2/64
 ipv6 address FE80::2 link-local
 port access vlan 2
·     Switch C:
vlan 2
vlan 4094
 ipv6 address 1::3/64
 ipv6 address FE80::3 link-local
 port access vlan 2
·     H3C S12500 Routing Switch Series High Availability Configuration Guide
·     H3C S12500 Routing Switch Series High Availability Command Reference
·     H3C S12500 Routing Switch Series Layer 2—LAN Switching Configuration Guide
·     H3C S12500 Routing Switch Series Layer 2—LAN Switching Command Reference
