07-System Volume
13-VRRP Configuration
Chapters Download  (261.06 KB)
When configuring VRRP, go to these sections for information you are interested in:
l          VRRP Overview
l          VRRP Standard Protocol Mode
l          Configuring VRRP for IPv4
l          IPv4-Based VRRP Configuration Examples
l          Troubleshooting VRRP
l          The term router in this document refers to a router in a generic sense or a Layer 3 switch.
l          At present, the interfaces that VRRP involves can only be VLAN interfaces.
VRRP Overview
Normally, as shown in Figure 1-1, you can configure a default route with the gateway as the next hop for every host on a network segment. All packets destined to other network segments are sent over the default route to the gateway and then be forwarded by the gateway. However, when the gateway fails, all the hosts using the gateway as the default next-hop router fail to communicate with the external network.
Figure 1-1 LAN networking
Configuring a default route for network hosts facilitates your configuration, but also requires high performance stability of the device acting as the gateway. Using more egress gateways is a common way to improve system reliability, introducing the problem of routing among the multiple egresses.
Virtual Router Redundancy Protocol (VRRP) is designed to address this problem. VRRP adds routers that can act as network gateways to a VRRP group, which forms a virtual router. Routers in the VRRP group elect a master through the VRRP election mechanism to take the responsibility of a gateway, and hosts on a LAN only need to configure the virtual router as their default network gateway.
VRRP is an error-tolerant protocol, which improves the network reliability and simplifies configurations on hosts. Deploying VRRP on multicast and broadcast LANs such as Ethernet, you can ensure that the system can still provide highly reliable default links without changing configurations (such as dynamic routing protocols, route discovery protocols) when a device fails, and prevent network interruption due to failure of a single link.
The S5810 series Switches support VRRPv2 that works in Standard protocol mode based on RFCs. VRRPv2 is based on IPv4.
Introduction to VRRP Group
VRRP combines a group of routers (including a master and multiple backups) on a LAN into a virtual router called VRRP group.
A VRRP group has the following features:
l          A virtual router has an IP address. A host on the LAN only needs to know the IP address of the virtual router and uses the IP address as the next hop of the default route.
l          Every host on the LAN communicates with external networks through the virtual router.
l          Routers in the VRRP group elect the master acting as the gateway according to their priorities. The other routers function as the backups. When the master fails, to ensure that the hosts in the network segment can communicate with the external networks uninterruptedly, the backups in the VRRP group elect a new gateway to undertake the responsibility of the failed master.
Figure 1-2 Network diagram for VRRP
As shown in Figure 1-2, Router A, Router B, and Router C form a virtual router, which has its own IP address. Hosts on the Ethernet use the virtual router as the default gateway.
The router with the highest priority of the three routers is elected as the master to act as the gateway, and the other two are backups.
l          The IP address of the virtual router can be either an unused IP address on the segment where the VRRP group resides or the IP address of an interface on a router in the VRRP group. In the latter case, the router is called the IP address owner.
l          In a VRRP group, you can configure only one IP address owner.
VRRP priority
VRRP determines the role (master or backup) of each router in the VRRP group by priority. A router with a higher priority has more opportunity to become the master.
VRRP priority is in the range of 0 to 255. The greater the number, the higher the priority. Priorities 1 to 254 are configurable. Priority 0 is reserved for special uses and priority 255 for the IP address owner. When a router acts as the IP address owner, its running priority is always 255. That is, the IP address owner in a VRRP group acts as the master as long as it works properly.
Working mode
A router in a VRRP group works in one of the following two modes:
l          Non-preemptive mode
When a router in the VRRP group becomes the master, it stays as the master as long as it operates normally, even if a backup is assigned a higher priority later.
l          Preemptive mode
When a backup finds its priority higher than that of the master, the backup sends VRRP advertisements to start a new master election in the VRRP group and becomes the master. Accordingly, the original master becomes a backup.
Authentication mode
To avoid being attacked by unauthorized users, VRRP authenticates the received packets by adding authentication keys into the packets. VRRP provides two authentication modes:
l          simple: Simple text authentication
A router sending a packet fills an authentication key into the packet, and the router receiving the packet compares its local authentication key with that of the received packet. If the two authentication keys are the same, the received VRRP packet is considered real and valid; otherwise, the received packet is considered invalid.
l          md5: MD5 authentication
The router encrypts a packet to be sent using the authentication key and MD5 algorithm and saves the encrypted packet in the authentication header. The router receiving the packet uses the authentication key to decrypt the packet and checks the validity of the packet.
On a secure network, you do not need to set the authentication mode.
VRRP Timers
VRRP timers include VRRP advertisement interval timer and VRRP preemption delay timer.
The master in a VRRP group sends VRRP advertisements periodically to inform the other routers in the VRRP group that it operates properly.
You can adjust the interval for sending VRRP advertisements by setting the VRRP advertisement interval timer. If a backup receives no advertisements in a period three times the interval, the backup regards itself as the master and sends VRRP advertisements to start a new master election.
To avoid members in a VRRP group from changing their states frequently and make backups have enough time to collect information (such as routing information), each backup waits for a period of time (the preemption delay time) after it receives an advertisement with the priority lower than the local priority, then sends VRRP advertisements to start a new master election in the VRRP group and finally becomes the master.
Packet Format
The master multicasts VRRP packets periodically to declare its existence. VRRP packets are also used for checking the parameters of the virtual router and electing the master.
Figure 1-3 Format of a VRRPv2 packet
As shown in Figure 1-3, an IPv4-based VRRP packet consists of the following fields:
l          Version: Version number of the protocol, 2 for VRRPv2.
l          Type: Type of the VRRPv2 packet. Only one VRRP packet type is present, that is, VRRP advertisement, which is represented by 1.
l          Virtual Rtr ID (VRID): Serial number of the virtual router, that is, serial number of the VRRP group. It ranges from 1 to 255.
l          Priority: Priority of the router in the VRRP group, in the range 0 to 255. A greater value represents a higher priority.
l          Count IP Addrs: Number of virtual IP addresses for the VRRP group. A VRRP group can have multiple virtual IP addresses.
l          Auth Type: Authentication type. 0 means no authentication, 1 means simple text authentication, and 2 means MD5 authentication.
l          Adver Int: Interval for sending advertisement packets, in seconds. The default is 1.
l          Checksum: 16-bit checksum for validating the data in VRRP packets.
l          IP Address: Virtual IP address entry of the VRRP group. The Count IP Addrs field defines the number of the virtual IP addresses.
l          Authentication Data: Authentication key. Currently, this field is used only for simple authentication and is 0 for any other authentication modes.
Principles of VRRP
l          With VRRP enabled, the routers decide their respective roles in the VRRP group by priority. The router with the highest priority becomes the master, and the others are the backups. The master sends VRRP advertisements periodically to notify the backups that it is working properly, and each of the backups starts a timer to wait for advertisements from the master.
l          In preemptive mode, when a backup receives a VRRP advertisement, it compares the priority in the packet with that of its own. If the priority of the backup is higher, the backup becomes the master; otherwise, it remains a backup.
l          In non-preemptive mode, the router in the VRRP group remains as a master or backup as long as the master does not fail. The backup does not become the master even if the backup is configured with a higher priority.
l          If the timer of a backup expires but the backup still does not receive any VRRP advertisement, it considers that the master fails. In this case, the backup considers itself as the master and sends VRRP advertisements to start a new master election.
VRRP Tracking
Tracking a specified interface
The interface tracking function expands the backup functionality of VRRP. It provides backup not only when the interface to which a VRRP group is assigned fails but also when other interfaces (such as uplink interfaces) on the router become unavailable.
If the uplink interface of a router in a VRRP group fails, normally the VRRP group cannot be aware of the uplink failure. If the router is the master of the VRRP group, hosts on the LAN are not able to access the external network because of the uplink failure. You can solve the problem through the function of tracking a specified interface. In this case, it is the uplink interface. After you configure to monitor the uplink interface, when the uplink interface goes down, the priority of the master is automatically decreased by a specified value and a higher priority router in the VRRP group becomes the master.
Tracking a Track object
By monitoring a Track object, you can:
l          Monitor an uplink and modify the priority of the router according to the state of the uplink. If there is a fault on the uplink, hosts in the LAN cannot access the external network through the router. In this case, the state of the monitored Track object changes to negative and the priority of the router decreases by a specified value. After that, a higher priority router in the VRRP group becomes the master to maintain the proper communication between the hosts in the LAN and the external network.
l          Monitor the master on a backup. If there is a fault on the master, the backup working in the mode switches to the master immediately to maintain normal communication.
For details of Track object tracking, refer to Track Configuration in the System Volume.
VRRP Application
Master/backup
In master/backup mode, only one router, the master, provides services. When the master fails, a new master is elected from the original backups. This mode requires only one VRRP group, in which each router holds a different priority and the one with the highest priority becomes the master, as shown in Figure 1-4.
Figure 1-4 VRRP in master/backup mode
At the beginning, Router A is the master and therefore can forward packets to external networks, whereas Router B and Router C are backups and are thus in the state of listening. If Router A fails, Router B and Router C elect for a new master. The new master takes over the forwarding task to provide services to hosts on the LAN.
Load sharing
You can create more than one VRRP group on an interface of a router, and allow the router to be the master of one VRRP group but a backup of another at the same time.
In load sharing mode, multiple routers provide services at the same time. This mode requires two or more VRRP groups, each of which includes a master and one or more backups. The masters of the VRRP groups are assumed by different routers, as shown in Figure 1-5.
Figure 1-5 VRRP in load sharing mode
A router can be in multiple VRRP groups and hold a different priority in different group.
In Figure 1-5, three VRRP groups are present:
l          VRRP group 1: Router A is the master; Router B and Router C are the backups.
l          VRRP group 2: Router B is the master; Router A and Router C are the backups.
l          VRRP group 3: Router C is the master; Router A and Router B are the backups.
For load sharing among Router A, Router B, and Router C, hosts on the LAN need to be configured to use VRRP group 1, 2, and 3 as the default gateways respectively. When configuring VRRP priorities, make sure that each router holds such a priority in each VRRP group that it will take the expected role in the group.
VRRP for IPv4 Configuration Task List
Complete these tasks to configure VRRP for IPv4:
Remarks
Configuring the Association Between Virtual IP Address and MAC Address
Optional
Creating VRRP Group and Configuring Virtual IP Address
Required
Configuring Router Priority, Preemptive Mode and Tracking Function
Optional
Configuring VRRP Packet Attributes
Optional
Enabling the Trap Function of VRRP
Optional
After the virtual IP address of a VRRP group is associated with a MAC address, the master takes the configured MAC address as the source MAC address of the packets to be sent, so that the hosts in the internal network can learn the association between the IP address and the MAC address and thus forward the packets to be forwarded to the other network segments to the master.
There are two types of association between virtual IP address and MAC address:
l          Virtual IP address is associated with virtual router MAC address
By default, a MAC address is created for a VRRP group after the VRRP group is created, and the virtual IP address is associated with the virtual MAC address. With such association adopted, the hosts in the internal network do not need to update the association between IP address and MAC address when the master changes.
l          Virtual IP address is associated with real MAC address of the interface
If an IP address owner exists in a VRRP group and you associate the virtual IP address with the virtual MAC address, two MAC addresses are associated with an IP address. In this case, you can associate the virtual IP address of the VRRP group with the real MAC address, so that the packets from a host are forwarded to the IP address owner according the real MAC address.
Follow these steps to configure the association between MAC address and virtual IP address:
To do…
Use the command…
Remarks
Enter system view
Configure the association between virtual IP address  and MAC address
vrrp method { real-mac | virtual-mac }
Optional
The virtual MAC address is associated with the virtual IP address by default.
You should configure this function before creating a VRRP group. Otherwise, you cannot modify the mapping between the virtual IP address and the MAC address.
You need to configure a virtual IP address for a VRRP group when creating the VRRP group on an interface. If the interface connects to multiple sub-networks, you can configure multiple virtual IP addresses for the VRRP group to realize router backup on different sub-networks.
A VRRP group is created automatically when you specify the first virtual IP address for the VRRP group. If you specify another virtual IP address for the VRRP group later, the virtual IP address is added to the virtual IP address list of the VRRP group.
Configuration prerequisites
Before creating a VRRP group and configuring a virtual IP address on an interface, you should first configure an IP address for the interface and ensure that the virtual IP address to be configured is in the same network segment as the IP address of the interface.
Configuration procedure
Follow these steps to create VRRP group and configure virtual IP address:
To do…
Use the command…
Remarks
Enter system view
Enter the specified interface view
Create VRRP group and configure virtual IP address of the VRRP group
vrrp vrid virtual-router-id virtual-ip virtual-address
Required
VRRP group is not created by default.
l          For the S5810 series, the maximum number of VRRP groups on a switch is 16; and the maximum number of virtual IP addresses for a VRRP group is 6.
l          A VRRP group is removed after you remove all the virtual IP addresses in it. In addition, configurations on that VRRP group no longer take effect.
l          The virtual IP address of the virtual router can be either an unused IP address on the segment where the VRRP group resides or the IP address of an interface on a router in the VRRP group. In the latter case, the router is called the IP address owner.
l          Removal of the VRRP group on the IP address owner will cause IP address collision. In such a case, it is recommended to modify the IP address of the interface on the IP address owner to resolve the collision.
l          The virtual IP address of the VRRP group cannot be 0.0.0.0, 255.255.255.255, loopback addresses, non class A/B/C addresses or other illegal IP addresses such as 0.0.0.1.
l          Only when the configured virtual IP address and the interface IP address belong to the same segment and are legal host addresses can the VRRP group operate normally. If the configured virtual IP address and the interface IP address do not belong to the same network segment, or the configured IP address is the network address or network broadcast address of the network segment that the interface IP address belongs to, the state of the VRRP group is always initialize though you can perform the configuration successfully, that is, VRRP does not take effect in this case.
Before you configure these features, you should first create a VRRP group on the interface and configure a virtual IP address for it.
By configuring router priority, preemptive mode, interface tracking, or a Track object, you can decide which router in the VRRP group serves as the Master.
Follow these steps to configure router priority, preemptive mode and the Track object tracking function:
To do…
Use the command…
Remarks
Enter system view
Enter interface view
Configure router priority in the VRRP group
Optional
100 by default.
Configure the router in the VRRP group to work in preemptive mode and configure preemption delay
vrrp vrid virtual-router-id preempt-mode [ timer delay delay-value ]
Optional
The router in the VRRP group works in preemptive mode and the preemption delay is 0 seconds by default.
Configure the  interface to be tracked
vrrp vrid virtual-router-id track interface interface-type interface-number [ reduced priority-reduced ]
Optional
No interface is being tracked by default.
Configure VRRP to track a specified Track object
vrrp vrid virtual-router-id track track-entry-number [ reduced priority-reduced | switchover ]
Optional
Not configured by default.
l          The running priority of an IP address owner is always 255 and you do not need to configure it. An IP address owner always works in the preemptive mode.
l          Do not configure VRRP tracking of an interface or an object on an IP address owner.
l          The tracked interface can only be a VLAN interface.
l          If the state of the interface under tracking changes from down to up, the priority of the device corresponding to the interface is restored automatically.
l          If the state of a Track object changes from negative to positive, the priority of the device corresponding to the Track object is restored automatically.
Before configuring the relevant attributes of VRRP packets, you should first create a VRRP group and configure a virtual IP address for it.
Follow these steps to configure VRRP packet attributes:
To do…
Use the command…
Remarks
Enter system view
Configure the authentication mode and authentication key when the VRRP groups send and receive VRRP packets
vrrp vrid virtual-router-id authentication-mode { md5 | simple } key
Optional
Authentication is not performed by default
Configure the time interval for the Master in the VRRP group to send VRRP advertisement
Optional
1 second by default
Disable TTL check on VRRP packets
vrrp un-check ttl
Optional
Enabled by default
You do not need to create a VRRP group before executing this command.
l          You may configure different authentication modes and authentication keys for the VRRP groups on an interface. However, the members of the same VRRP group must use the same authentication mode and authentication key.
l          Excessive traffic or different timer setting on routers can cause the Backup timer to time out abnormally and trigger a change of the state. To solve this problem, you can prolong the time interval to send VRRP packets.
After the trap function is enabled for a VRRP module, the VRRP module will generate traps with severity level errors to report its key events. The generated traps will be sent to the information center of the device, where you can configure whether to output the trap information and the output destination. For information center configurations, refer to Information Center Configuration in the System Volume.
Follow these steps to enable the trap function of VRRP:
To do…
Use the command…
Remarks
Enter system view
Enable the trap function of VRRP
snmp-agent trap enable vrrp [ authfailure | newmaster ]
Optional
Enabled by default.
For detailed description on the snmp-agent trap enable vrrp command, refer to command snmp-agent trap enable in SNMP Commands in the System Volume.
Displaying and Maintaining VRRP for IPv4
To do…
Use the command…
Remarks
Display VRRP group status
display vrrp [ verbose ] [ interface interface-type interface-number [ vrid virtual-router-id ] ]
Available in any view
Display VRRP group statistics
Clear VRRP group statistics
Available in user view
This section provides these configuration examples:
l          Single VRRP Group Configuration Example
l          VRRP Interface Tracking Configuration Example
l          Multiple VRRP Group Configuration Example
Network requirements
l          Host A needs to access Host B on the Internet, using 202.38.160.111/24 as its default gateway.
l          Switch A and Switch B belong to VRRP group 1 with the virtual IP address of 202.38.160.111/24.
l          If Switch A operates normally, packets sent from Host A to Host B are forwarded by Switch A; if Switch A fails, packets sent from Host A to Host B are forwarded by Switch B.
Figure 1-6 Network diagram for single VRRP group configuration
1)        Configure Switch A
# Configure VLAN 2.
[SwitchA] vlan 2
[SwitchA-vlan2] port gigabitethernet 1/0/5
[SwitchA-vlan2] quit
[SwitchA-Vlan-interface2] ip address 202.38.160.1 255.255.255.0
# Create VRRP group 1 and set its virtual IP address to be 202.38.160.111.
[SwitchA-Vlan-interface2] vrrp vrid 1 virtual-ip 202.38.160.111
# Set the priority of Switch A in VRRP group 1 to 110.
[SwitchA-Vlan-interface2] vrrp vrid 1 priority 110
# Set Switch A to work in preemptive mode. The preemption delay is five seconds.
[SwitchA-Vlan-interface2] vrrp vrid 1 preempt-mode timer delay 5
2)        Configure Switch B
# Configure VLAN 2.
[SwitchB] vlan 2
[SwitchB-Vlan2] port gigabitethernet 1/0/5
[SwitchB-vlan2] quit
[SwitchB-Vlan-interface2] ip address 202.38.160.2 255.255.255.0
[SwitchB-Vlan-interface2] vrrp vrid 1 virtual-ip 202.38.160.111
# Set Switch B to work in preemptive mode. The preemption delay is five seconds.
[SwitchB-Vlan-interface2] vrrp vrid 1 preempt-mode timer delay 5
3)        Verify the configuration
After the configuration, Host B can be pinged through on Host A. You can use the display vrrp verbose command to verify the configuration.
# Display detailed information of VRRP group 1 on Switch A.
[SwitchA-Vlan-interface2] display vrrp verbose
 IPv4 Standby Information:
     Run Mode       : Standard
     Run Method     : Virtual MAC
   Interface Vlan-interface2
     VRID           : 1                    Adver Timer  : 1
     Admin Status   : Up                   State        : Master
     Config Pri     : 110                  Running Pri  : 110
     Preempt Mode   : Yes                  Delay Time   : 5
     Auth Type      : None
     Virtual IP     : 202.38.160.111
     Virtual MAC    : 0000-5e00-0101
     Master IP      : 202.38.160.1
# Display detailed information of VRRP group 1 on Switch B.
[SwitchB-Vlan-interface2] display vrrp verbose
     Run Mode       : Standard
     Admin Status   : Up                   State        : Backup
     Config Pri     : 100                  Running Pri  : 100
     Auth Type      : None
The above information indicates that in VRRP group 1 Switch A is the master, Switch B is the backup and packets sent from Host A to Host B are forwarded by Switch A.
If Switch A fails, you can still ping through Host B on Host A. Use the display vrrp verbose command to view the detailed information of the VRRP group on Switch B.
# If Switch A fails, the detailed information of VRRP group 1 on Switch B is displayed.
     Run Mode       : Standard
     Auth Type      : None
     Master IP      : 202.38.160.2
The above information indicates that if Switch A fails, Switch B becomes the master, and packets sent from Host A to Host B are forwarded by Switch B.
l          If Switch A operates normally, packets sent from Host A to Host B are forwarded by Switch A; if VLAN-interface 3 through which Switch A connects to the Internet is not available, packets sent from Host A to Host B are forwarded by Switch B.
Figure 1-7 Network diagram for VRRP interface tracking
# Configure VLAN 2.
[SwitchA] vlan 2
# Create a VRRP group 1 and set its virtual IP address to 202.38.160.111.
# Configure the priority of Switch A in the VRRP group to 110.
# Configure the authentication mode of the VRRP group as simple and authentication key as hello.
[SwitchA-Vlan-interface2] vrrp vrid 1 authentication-mode simple hello
# Set the interval for Master to send VRRP advertisement to five seconds.
[SwitchA-Vlan-interface2] vrrp vrid 1 timer advertise 5
# Set the interface to be tracked.
[SwitchA-Vlan-interface2] vrrp vrid 1 track interface vlan-interface 3 reduced 30
# Configure VLAN 2.
[SwitchB] vlan 2
[SwitchB-vlan2] port gigabitethernet 1/0/5
[SwitchB-Vlan-interface2] vrrp vrid 1 authentication-mode simple hello
[SwitchB-Vlan-interface2] vrrp vrid 1 timer advertise 5
After the configuration, Host B can be pinged successfully on Host A. You can use the display vrrp verbose command to verify the configuration.
     Run Mode       : Standard
     VRID           : 1                    Adver Timer  : 5
     Preempt Mode   : Yes                  Delay Time   : 0
     Auth Type      : Simple               Key          : hello
   VRRP Track Information:
     Track Interface: Vlan3                State : Up         Pri Reduced : 30
     Run Mode       : Standard
If interface VLAN-interface 3 through which Switch A connects to the Internet is not available, you can still ping Host B successfully on Host A. Use the display vrrp verbose command to view the detailed information of the VRRP group.
# If VLAN-interface 3 on Switch A is not available, the detailed information of VRRP group 1 on Switch A is displayed.
     Run Mode       : Standard
     Config Pri     : 110                  Running Pri  : 80
     Track Interface: Vlan3                State : Down       Pri Reduced : 30
# If VLAN-interface 3 on Switch A is not available, the detailed information of VRRP group 1 on Switch B is displayed.
     Run Mode       : Standard
The above information indicates that if VLAN-interface 3 on Switch A is not available, the priority of Switch A is reduced to 80 and it becomes the backup. Switch B becomes the master and packets sent from Host A to Host B are forwarded by Switch B.
l          Hosts in VLAN 2 use 202.38.160.100/25 as their default gateway and hosts in VLAN 3 use 202.38.160.200/25 as their default gateway.
l          Switch A and Switch B belong to both VRRP group 1 and VRRP group 2. The virtual IP address of VRRP group 1 is 202.38.160.100/25, and that of VRRP group 2 is 202.38.160.200/25.
l          In VRRP group 1, Switch A has a higher priority than Switch B. In VRRP group 2, Switch B has a higher priority than Switch A. In this case, hosts in VLAN 2 and VLAN 3 can communicate with the outside through Switch A and Switch B respectively, and if Switch A or Switch B fails, the hosts can use the other switch to communicate with the outside, so as to avoid communication interruption.
Figure 1-8 Network diagram for multiple VRRP group configuration
# Configure VLAN 2.
[SwitchA] vlan 2
[SwitchA-Vlan-interface2] ip address 202.38.160.1 255.255.255.128
# Create a VRRP group 1 and set its virtual IP address to 202.38.160.100.
[SwitchA-Vlan-interface2] vrrp vrid 1 virtual-ip 202.38.160.100
# Configure the priority of Switch A in VRRP group 1 as 110.
# Configure VLAN 3.
[SwitchA] vlan 3
[SwitchA-vlan3] port gigabitethernet 1/0/6
[SwitchA-vlan3] quit
[SwitchA-Vlan-interface3] ip address 202.38.160.130 255.255.255.128
# Create a VRRP group 2 and set its virtual IP address to 202.38.160.200.
[SwitchA-Vlan-interface3] vrrp vrid 2 virtual-ip 202.38.160.200
# Configure VLAN 2.
[SwitchB] vlan 2
[SwitchB-Vlan-interface2] ip address 202.38.160.2 255.255.255.128
[SwitchB-Vlan-interface2] vrrp vrid 1 virtual-ip 202.38.160.100
# Configure VLAN 3.
[SwitchB] vlan 3
[SwitchB-vlan3] port gigabitethernet 1/0/6
[SwitchB-vlan3] quit
[SwitchB-Vlan-interface3] ip address 202.38.160.131 255.255.255.128
[SwitchB-Vlan-interface3] vrrp vrid 2 virtual-ip 202.38.160.200
# Configure the priority of Switch B in VRRP group 2 to 110.
[SwitchB-Vlan-interface3] vrrp vrid 2 priority 110
# Display detailed information of the VRRP group on Switch A.
[SwitchA-Vlan-interface3] display vrrp verbose
     Run Mode       : Standard
     Auth Type      : None
     Virtual IP     : 202.38.160.100
   Interface Vlan-interface3
     VRID           : 2                    Adver Timer  : 1
     Auth Type      : None
     Virtual IP     : 202.38.160.200
     Master IP      : 202.38.160.131
# Display detailed information of the VRRP group on Switch B.
[SwitchB-Vlan-interface3] display vrrp verbose
     Run Mode       : Standard
     Auth Type      : None
     Auth Type      : None
     Virtual MAC    : 0000-5e00-0102
The above information indicates that in VRRP group 1 Switch A is the master, Switch B is the backup and hosts with the default gateway of 202.38.160.100/25 accesses the Internet through Switch A; in VRRP group 2 Switch A is the backup, Switch B is the master and hosts with the default gateway of 202.38.160.200/25 accesses the Internet through Switch B.
Symptom 1:
The console screen displays error prompts frequently.
Analysis:
This error is probably caused by the following:
l          Inconsistent configuration of the devices in the VRRP group.
l          A device is attempting to send illegitimate VRRP packets.
Solution:
l          In the first case, modify the configuration.
l          In the latter case, you have to resort to non-technical measures.
Symptom 2:
Multiple masters are present in the same VRRP group.
Analysis:
l          Multiple masters coexist for a short period: This is normal and requires no manual intervention.
l          Multiple masters coexist for a long period: This is because devices in the VRRP group cannot receive VRRP packets, or the received VRRP packets are illegal.
Solution:
Ping between these masters, and do the following:
l          If the ping fails, check network connectivity.
l          If the ping succeeds, check that their configurations are consistent in terms of number of virtual IP addresses, virtual IP addresses, advertisement interval, and authentication.
Symptom 3:
Frequent VRRP state transition.
Analysis:
The VRRP advertisement interval is set too short.
Solution:
Increase the interval to sent VRRP advertisement or introduce a preemption delay.
H3C reserves the right to modify its collaterals without any prior notice. For the latest information of the collaterals, please consult H3C sales or call 400 hotline.
