00-System Volume Organization
Chapters Download (25.25 KB)
6W100-20090626
Release 1102
The System Volume is organized as follows:
Features |
Login |
Upon logging into a device, you can configure user interface properties and manage the system conveniently. This document describes: l How to log in to your Ethernet switch l Introduction to the user interface and common configurations l Logging In Through the Console Port l Logging In Through Telnet l Logging in Through Web-based Network Management System l Specifying Source IP address/Interface for Telnet Packets l Controlling Login Users |
Basic System Configuration |
Basic system configuration involves the configuration of device name, system clock, welcome message, user privilege levels and so on. This document describes: l Configuration display l Basic configurations l CLI features |
Device Management |
Through the device management function, you can view the current condition of your device and configure running parameters. This document describes: l Device management overview l Configuring the Exception Handling Method l Rebooting a device l Configuring the scheduled automatic execution function l Configuring Temperature Alarm Thresholds for a Card l Clearing the 16-bit interface indexes not used in the current system |
File System Management |
A major function of the file system is to manage storage devices, mainly including creating the file system, creating, deleting, modifying and renaming a file or a directory and opening a file. This document describes: l File system management |
HTTP |
Hypertext Transfer Protocol (HTTP) is used for transferring web page information across the Internet. This document describes: l HTTPS Configuration |
SNMP |
Simple network management protocol (SNMP) offers a framework to monitor network devices through TCP/IP protocol suite. This document describes: l SNMP overview l Basic SNMP function configuration l SNMP log configuration l Trap configuration |
RMON |
RMON provides an efficient means of monitoring subnets and allows SNMP to monitor remote network devices in a more proactive and effective way. This document describes: l RMON overview l RMON configuration |
MAC Address Table Management |
A switch maintains a MAC address table for fast forwarding packets. This document describes: l MAC address table overview l Configuring MAC Address Entries |
System Maintenance and Debugging |
For the majority of protocols and features supported, the system provides corresponding debugging information to help users diagnose errors. This document describes: l Maintenance and debugging overview l Maintenance and debugging configuration |
Information Center |
As the system information hub, Information Center classifies and manages all types of system information. This document describes: l Information Center Overview l Setting to Output System Information to the Console l Setting to Output System Information to a Monitor Terminal l Setting to Output System Information to a Log Host l Setting to Output System Information to the Trap Buffer l Setting to Output System Information to the Log Buffer l Setting to Output System Information to the SNMP Module l Configuring Synchronous Information Output l Disabling a Port from Generating Link Up/Down Logging Information |
Track |
The track module is used to implement collaboration between different modules through established collaboration objects. The detection modules trigger the application modules to perform certain operations through the track module. This document describes: l Configuring Collaboration Between the Track Module and the Detection Modules l Configuring Collaboration Between the Track Module and the Application Modules |
NTP |
Network Time Protocol (NTP) is the TCP/IP that advertises the accurate time throughout the network. This document describes: l NTP overview l Configuring the Operation Modes of NTP l Configuring Optional Parameters of NTP l Configuring Access-Control Rights l Configuring NTP Authentication |
VRRP |
Virtual Router Redundancy Protocol (VRRP) combines a group of switches (including a master and multiple backups) on a LAN into a virtual router called VRRP group. VRRP streamlines host configuration while providing high reliability. This document describes: l VRRP overview l IPv4-Based VRRP configuration l IPv6-Based VRRP configuration |
Cluster Management |
A cluster is a group of network devices. Cluster management is to implement management of large numbers of distributed network devices. This document describes: l Cluster Management Overview l Configuring the Management Device l Configuring the Member Devices l Configuring Access Between the Management Device and Its Member Devices l Adding a Candidate Device to a Cluster l Configuring Advanced Cluster Functions |
Stack Management |
A stack is a set of network devices. Administrators can group multiple network devices into a stack and manage them as a whole. Therefore, stack management can help reduce customer investments and simplify network management. This document describes: l Stack Configuration Overview l Configuring the Master Device of a Stack |
Automatic Configuration |
Automatic configuration enables a device to automatically obtain and execute the configuration file when it starts up without loading the configuration file. This document describes: l Introduction to Automatic Configuration l Typical Networking of Automatic Configuration l How Automatic Configuration Works |
