01-Access Volume
11-GVRP Configuration
Chapters Download  (141.39 KB)
1  GVRP Configuration
The GARP VLAN Registration Protocol (GVRP) is a GARP application. It functions based on the operating mechanism of GARP to maintain and propagate dynamic VLAN registration information for the GVRP devices on the network.
When configuring GVRP, go to these sections for information you are interested in:
l          Introduction to GVRP
l          GVRP Configuration Task List
l          Configuring GVRP Functions
l          Configuring GARP Timers
l          Displaying and Maintaining GVRP
l          GVRP Configuration Examples
GARP
The Generic Attribute Registration Protocol (GARP) provides a mechanism that allows participants in a GARP application to distribute, propagate, and register with other participants in a LAN the attributes specific to the GARP application, such as the VLAN or multicast address attribute.
GARP itself does not exist on a device as an entity. GARP-compliant participants are known as GARP applications. One example is GVRP. When a GARP participant is present on a port on your device, the port is regarded as a GARP participant.
GARP messages and timers
1)        GARP messages
A GARP application entity exchanges information with other GARP application entities by:
l          Sending Join messages to register with other entities its attributes, the attributes received from other GARP application entities, and the attributes manually configured on it.
l          Sending Leave messages to have its attributes deregistered on other devices. A GARP participant also sends Leave messages when it receives Leave messages from other GARP participants or when attributes are manually deregistered on it.
l          Sending LeaveAll messages to deregister all the attributes so that all GARP participants can re-register all attributes with each other. A LeaveAll message is sent upon expiration of a LeaveAll timer, which starts upon the startup of a GARP application entity.
Join messages, Leave messages, and LeaveAll message make sure the reregistration and deregistration of GARP attributes are performed in an orderly way.
Through message exchange, all attribute information that needs registration propagates to all GARP participants on the LAN.
2)        GARP timers
GARP uses the following four timers to set the interval for sending GARP messages:
l          Hold timer –– When a GARP application entity receives the first registration request, it starts a Hold timer and collects succeeding requests. When the timer expires, the entity sends all these requests in one Join message. This helps you save bandwidth.
l          Join timer –– A GARP participant sends a Join message at most twice for reliability sake and uses a Join timer to set the sending interval. If the first Join message has not been acknowledged before the Join timer expires, the GARP participant sends the second Join message.
l          Leave timer –– Starts upon receipt of a Leave message sent for deregistering some attribute information. If no Join message is received before this timer expires, the GARP participant removes the attribute information as requested.
l          LeaveAll timer –– Starts when a GARP participant starts. When this timer expires, the entity sends a LeaveAll message so that other participants can re-register its attribute information. Then, a LeaveAll timer starts again.
l          The settings of GARP timers apply to all GARP applications, such as GVRP, on a LAN.
l          On a GARP-enabled network, a device may send LeaveAll messages at the interval set by its LeaveAll timer or the LeaveAll timer on another device on the network, whichever is smaller. This is because each time a device on the network receives a LeaveAll message it resets its LeaveAll timer.
Operating mechanism of GARP
The GARP mechanism allows the configuration of a GARP application entity to propagate throughout a LAN quickly. In GARP, a GARP application entity registers or deregisters its attributes with other entities by making or withdrawing declarations of attributes and at the same time, based on received declarations or withdrawals, handles attributes of other entities. When a port receives an attribute declaration, it registers the attribute; when a port receives an attribute withdrawal, it deregisters the attribute.
GARP application entities send protocol data units (PDUs) with a particular multicast MAC address as destination. Based on this address, a device can identify to which GVRP application (GVRP for example) a GARP PDU will be delivered.
GARP message format
Figure 1-1 GARP message format
Figure 1-1 illustrates the GARP message format. Table 1-1 describes the GARP message fields.
Table 1-1 Description on the GARP message fields
Value
Protocol ID
Protocol identifier for GARP
1
Message
One or multiple messages, each containing an attribute type and an attribute list
Attribute Type
Defined by the concerned GARP application
0x01 for GVRP, indicating the VLAN ID attribute
Attribute List
Contains one or multiple attributes
Attribute
Consists of an Attribute Length, an Attribute Event, and an Attribute Value
Attribute Length
Number of octets occupied by an attribute, inclusive of the attribute length field
2 to 255 (in bytes)
Attribute Event
Event described by the attribute
l      0: LeaveAll event
l      1: JoinEmpty event
l      2: JoinIn event
l      3: LeaveEmpty event
l      4: LeaveIn event
l      5: Empty event
Attribute Value
Attribute value
VLAN ID for GVRP
If the Attribute Event is LeaveAll, Attribute Value is omitted.
End Mark
Indicates the end of a GARP PDU
0x00
GVRP
GVRP enables a device to propagate local VLAN registration information to other participant devices and dynamically update the VLAN registration information from other devices to its local database about active VLAN members and through which port they can be reached. It thus ensures that all GVRP participants on a bridged LAN maintain the same VLAN registration information. The VLAN registration information propagated by GVRP includes both manually configured local static entries and dynamic entries from other devices.
GVRP provides the following three registration types on a port:
l          Normal––Enables the port to dynamically register and deregister VLANs, and to propagate both dynamic and static VLAN information.
l          Fixed––Disables the port to dynamically register and deregister VLANs or propagate information about dynamic VLANs, but allows the port to propagate information about static VLANs. A trunk port with fixed registration type thus allows only manually configured VLANs to pass through even though it is configured to carry all VLANs.
l          Forbidden––Disables the port to dynamically register and deregister VLANs and to propagate VLAN information except information about VLAN 1. A trunk port with forbidden registration type thus allows only VLAN 1 to pass through even though it is configured to carry all VLANs.
Protocols and Standards
GVRP is described in IEEE 802.1Q.
Complete these tasks to configure GVRP:
Remarks
Required
Optional
l          GVRP configuration made in Ethernet interface view or Layer-2 aggregate interface view takes effect on the current interface only; .GVRP configuration made in port group view takes effect on all the member ports in the group.
l          GVRP configuration made on a member port in an aggregation group takes effect only after the port is removed from the aggregation group.
Before enabling GVRP on a port, you must enable GVRP globally.
Follow these steps to configure GVRP functions on a trunk port:
To do…
Use the command…
Remarks
Enter system view
Enable GVRP globally
gvrp
Required
Globally disabled by default
Enter Ethernet interface view, Layer 2 aggregate interface view, or port-group view
Enter Ethernet interface view or Layer 2 aggregate interface view
Required
Perform either of the commands.
Enter port-group view
port-group manual port-group-name
Enable GVRP on the port or port group
gvrp
Required
Disabled by default
Configure the GVRP registration mode on the port or port group
gvrp registration { fixed | forbidden | normal }
Optional
The default is normal.
l          GVRP can be configured only on trunk ports.
l          In an MSTP network, GVRP can run on only the CIST. In addition, blocked ports on the CIST cannot receive/send GVRP packets.
l          If both GVRP and remote port mirroring are used, GVRP may register the remote probe VLAN to unexpected ports, resulting in undesired duplicates to be received by the monitor port. For more information about port mirroring, refer to Port Mirroring Configuration in the Access Volume.
l          Enabling GVRP on a Layer 2 aggregate interface enables both the aggregate interface and all selected member ports in the corresponding link aggregation group to participate in dynamic VLAN registration and deregistration.
l          On a GVRP-enabled trunk port, you need to configure the port trunk permit vlan all command on the port to ensure that the traffic of all dynamically registered VLANs can pass through the port.
Among the four GARP timers, the LeaveAll timer is configured in system view and takes effect on all ports, while the other three are configured on a port basis.
Follow these steps to configure GARP timers:
To do…
Use the command…
Remarks
Enter system view
Configure the GARP LeaveAll timer
garp timer leaveall timer-value
Optional
The default is 1000 centiseconds.
Enter Ethernet or Layer 2 aggregate interface view
Required
Depending on the view you accessed, the subsequent configuration takes effect on a port or all ports in a port-group.
Configure the Hold timer
garp timer hold timer-value
Optional
10 centiseconds by default
Configure the Join timer
garp timer join timer-value
Optional
20 centiseconds by default
Configure the Leave timer
garp timer leave timer-value
Optional
60 centiseconds by default
As shown in Table 1-2, the values of GARP timers are dependent on each other:
l          If you want to set a value beyond the value range for a timer, you may change the value range by tuning the value of another related timer.
l          If you want to restore the default settings of the timers, restore the Hold timer first, and then the Join, Leave, and LeaveAll timers.
Table 1-2 Dependencies of GARP timers
Timer
Lower limit
Upper limit
Hold
10 centiseconds
No greater than half of the Join timer setting
Join
No less than two times the Hold timer setting
Less than half of the leave timer setting
Leave
Greater than two times the Join timer setting
Less than the LeaveAll timer setting
LeaveAll
Greater than the Leave timer setting
32765 centiseconds
To do…
Use the command…
Remarks
Display statistics about GARP
display garp statistics [ interface interface-list ]
Available in any view
Display GARP timers for specified or all ports
display garp timer [ interface interface-list ]
Display the local VLAN information maintained by GVRP
display gvrp local-vlan interface interface-type interface-number
Display the current GVRP state
display gvrp state interface interface-type interface-number vlan vlan-id
Display statistics about GVRP
display gvrp statistics [ interface interface-list ]
Display the global GVRP state
display gvrp status
Display the information about dynamic VLAN operations performed on a port
display gvrp vlan-operation interface interface-type interface-number
Clear the GARP statistics
reset garp statistics [ interface interface-list ]
Available in user view
GVRP Configuration Example I
Network requirements
Configure GVRP for dynamic VLAN information registration and update among devices, adopting the normal registration mode on ports.
Figure 1-2 Network diagram for GVRP configuration
Configuration procedure
1)        Configure Device A
# Enable GVRP globally.
[DeviceA] gvrp
# Configure port GigabitEthernet 1/0/1 as a trunk port, allowing all VLANs to pass through.
[DeviceA-GigabitEthernet1/0/1] port trunk permit vlan all
# Enable GVRP on trunk port GigabitEthernet 1/0/1.
[DeviceA-GigabitEthernet1/0/1] gvrp
# Create VLAN 2 (a static VLAN).
[DeviceA] vlan 2
2)        Configure Device B
[DeviceB] gvrp
[DeviceB-GigabitEthernet1/0/1] port trunk permit vlan all
[DeviceB-GigabitEthernet1/0/1] gvrp
# Create VLAN 3 (a static VLAN).
[DeviceB] vlan 3
3)        Verify the configuration
# Display dynamic VLAN information on Device A.
[DeviceA] display vlan dynamic
 Now, the following dynamic VLAN exist(s):
  3
# Display dynamic VLAN information on Device B.
[DeviceB] display vlan dynamic
  2
GVRP Configuration Example II
Configure GVRP for dynamic VLAN information registration and update among devices. Specify fixed GVRP registration on Device A and normal GVRP registration on Device B.
Figure 1-3 Network diagram for GVRP configuration
[DeviceA] gvrp
# Enable GVRP on GigabitEthernet 1/0/1 and set the GVRP registration type to fixed on the port.
[DeviceA-GigabitEthernet1/0/1] gvrp registration fixed
[DeviceA] vlan 2
[DeviceB] gvrp
# Enable GVRP on GigabitEthernet 1/0/1.
[Sysname] vlan 3
 No dynamic vlans exist!
  2
GVRP Configuration Example III
To prevent dynamic VLAN information registration and update among devices, set the GVRP registration mode to forbidden on Device A and normal on Device B.
Figure 1-4 Network diagram for GVRP configuration
[DeviceA] gvrp
# Enable GVRP on GigabitEthernet 1/0/1 and set the GVRP registration type to forbidden on the port.
[DeviceA-GigabitEthernet1/0/1] gvrp registration forbidden
[DeviceA] vlan 2
[DeviceB] gvrp
[DeviceB] vlan 3
H3C reserves the right to modify its collaterals without any prior notice. For the latest information of the collaterals, please consult H3C sales or call 400 hotline.
