01-Cover
Chapters Download (57.22 KB)
H3C S3600 Series EPON OLT Switches |
Quick Start |
Hangzhou H3C Technologies Co., Ltd. http://www.h3c.com
Manual Version: T2-08011V-20090511-C-1.03 |
Copyright © 2008-2009, Hangzhou H3C Technologies Co., Ltd. and its licensors
All Rights Reserved
No part of this manual may be reproduced or transmitted in any form or by any means without prior written consent of Hangzhou H3C Technologies Co., Ltd.
Trademarks
H3C,
, Aolynk,
, H3Care,
, TOP G,
, IRF, NetPilot, Neocean, NeoVTL, SecPro,
SecPoint, SecEngine, SecPath, Comware, Secware, Storware, NQA, VVG, V2G, VnG, PSPT, XGbus, N-Bus, TiGem, InnoVision and HUASAN are trademarks of Hangzhou H3C Technologies Co., Ltd.
All other trademarks that may be mentioned in this manual are the property of their respective owners.
Notice
The information in this document is subject to change without notice. Every effort has been made in the preparation of this document to ensure accuracy of the contents, but all statements, information, and recommendations in this document do not constitute the warranty of any kind, express or implied.
Technical Support
http://www.h3c.com
About This Manual
Organization
H3C S3600 Series EPON OLT Switches Quick Start is organized as follows:
Chapter |
Contents |
1 Product Overview |
Introduces the characteristics and technical specifications of S3600 Series EPON OLT Switches. |
2 Installation Preparations |
Introduces the installation preparation and precaution of S3600 Series EPON OLT Switches. |
Introduces the procedures to install an S3600 Series EPON OLT Switches, including the setup of the mainframe, power cord, ground wire and console cables. |
Introduces the installation of lightning arrester for AC power and for network port |
Introduces the regulatory compliance information of S3600 Series EPON OLT Switches. |
Introduces the safety information of S3600 Series EPON OLT Switches. |
Conventions
The manual uses the following conventions:
Convention |
Means reader be careful. Improper operation may cause data loss or damage to equipment. |
Means a complementary description. |
Related Documentation
In addition to this manual, each H3C S3600 Series EPON OLT Switches documentation set includes the following:
Manual |
H3C S3600 Series EPON OLT Switches Operation Manual |
It is used for assisting the users in data configurations and typical applications |
H3C S3600 Series EPON OLT Switches Command Manual |
It is used for assisting the users in using various commands. |
H3C S3600 Series EPON OLT Switches Installation Manual |
It is used for assisting the users in switch installation, booting up, hardware and software maintenance. |
Obtaining Documentation
You can access the most up-to-date H3C product documentation on the World Wide Web at this URL: http://www.h3c.com.
The following are the columns from which you can obtain different categories of product documentation:
[Products & Solutions]: Provides information about products and technologies, as well as solutions.Provides information about products and technologies
[Technical Support & Document > Technical Documents]: Provides several categories of product documentation, such as installation, configuration, and maintenance.
[Technical Support & Document > Software Download]: Provides the documentation released with the software version.
Documentation Feedback
We appreciate your comments.
Environmental Protection
This product has been designed to comply with the requirements on environmental protection. For the proper storage, use and disposal of this product, national laws and regulations must be observed.
