H3C ET704-B-L EPON ONU User Manual-5W100
DownLoad Chapters Download(435.42 KB)
01-Text
Table of Contents
Chapter 1 Product Overview.. 1-1
1.1 Introduction. 1-1
1.2 Product Features. 1-1
Chapter 2 Command Line Interfaces. 2-1
2.1 Introduction. 2-1
2.2 Command Line Interface Views. 2-1
2.3 Configuring Hierarchical User Passwords. 2-2
2.4 Features of Command Line Interface. 2-3
2.4.1 Command Line Online Help. 2-3
2.4.2 Error Prompts. 2-4
2.4.3 Command History. 2-5
2.4.4 Command Edit 2-5
2.4.5 Terminal Display. 2-6
Chapter 3 Logging into the ET704-B-L. 3-1
Chapter 4 User Configuration. 4-1
4.1 Configuring the VTY User Interface. 4-1
4.1.1 Enter the VTY Interface View. 4-1
4.1.2 Configure Terminal Properties. 4-1
4.1.3 Configure Telnet Login Password. 4-2
4.2 User Interface Display. 4-3
Chapter 5 Ethernet Interface Configuration. 5-1
5.1 Ethernet Interface Configuration Task List 5-1
5.2 Bringing Up/Shutting Down an Ethernet Interface. 5-1
5.3 Enabling the Cable Inspection Function. 5-1
5.4 Ethernet Interface Display and Maintenance. 5-2
Chapter 6 Management VLAN Configuration. 6-1
6.1 Introduction to Management VLAN. 6-1
6.2 Management VLAN Configuration Task List 6-1
6.3 Bringing Up/Shutting Down the Management VLAN Interface. 6-1
Chapter 7 ET704-B-L Management 7-1
7.1 MAC Address Table Management 7-1
7.1.1 MAC Address Table Management Task List 7-1
7.1.2 Modifying MAC Address Table Entries. 7-1
7.1.3 Configuring Aging Time of MAC Address Table Entries. 7-2
7.1.4 Displaying Information of MAC Address Table Entries. 7-3
7.2 Configuration Management 7-4
7.2.1 Configuration Management Task List 7-4
7.2.2 Displaying the Current and Saved Configurations. 7-4
7.2.3 Save the Current Configuration. 7-5
7.2.4 Restoring the Default Configuration. 7-6
7.3 System Management 7-6
7.3.1 System Management Task List 7-6
7.3.2 Rebooting the ET704-B-L. 7-7
7.3.3 Configuring a System Name for the ET704-B-L. 7-7
7.3.4 Displaying /Clearing the ARP Table. 7-8
7.3.5 Displaying the System Version Information. 7-8
7.3.6 Displaying the Board Information of the ET704-B-L. 7-9
7.3.7 Displaying the CPU Status of the ET704-B-L. 7-9
7.3.8 Displaying the TCP Connection Status of the ET704-B-L. 7-9
7.3.9 Upgrading the Local Software of the ET704-B-L. 7-10
7.4 System Log. 7-12
7.4.1 System Log Task List 7-12
7.4.2 Enabling/Disabling Terminal Logging. 7-12
7.4.3 Enabling/Disabling the Information Center 7-13
7.4.4 Exporting Logging Information to the Specified Host 7-13
7.4.5 Configuring the Logging Information Level 7-14
7.4.6 Displaying the Information Center 7-15
Chapter 8 AGMP Configuration. 8-1
8.1 Introduction to AGMP. 8-1
8.2 AGMP Configuration Task List 8-1
8.3 Enabling/Disabling AGMP. 8-1
8.4 Configuring Basic Functions for a Remote Switch. 8-2
8.5 Configuring Ethernet Ports for a Remote Switch. 8-3
8.6 Configuring QoS Settings for a remote Switch. 8-4
8.7 Displaying AGMP Configuration. 8-6
Chapter 9 System Debugging. 9-1
9.1 Introduction to System Debugging. 9-1
9.2 System Debugging Task List 9-1
9.3 Enabling/Disabling Protocol Debugging. 9-2
9.4 Enabling/Disabling Terminal Debugging. 9-2
9.5 Displaying Debugging Status. 9-3
Chapter 10 Configuring Display. 10-1
1.1  Introduction
ET704-B-L optical network unit (ONU) devices (hereinafter referred to as the ET704-B-L), offered by Hangzhou H3C Technologies Co., Ltd. (hereinafter referred to as H3C) for industry and enterprise users, are compliant with Ethernet passive optical network (EPON) interoperability standards and provide outstanding reliability.
The ET704-B-L provides four Ethernet interfaces and one passive optical network (PON) interface, which are compliant with IEEE 802.3ah 1000Base-PX20 transmission specifications. Working with optical line terminals (OLT) through an optical distribution network (ODN), ONUs form a complete EPON system for users, offering various services including data transmission and IPTV. As such, the ET704-B-L offers a good solution for implementing fiber to the home (FTTH) services.
l           Compliant with IEEE 802.3ah EPON standards and IEEE 802.3ah 1000Base-PX20 transmission specifications.
l           Compatible to OLTs that meet the interconnectivity standards, enabling remote management, maintenance and configuration through OLTs.
l           Supporting remote management of Aolynk Group Management Protocol (AGMP) capable switches.
l           Supporting remote maintenance and configuration through Telnet.
l           Supporting online software upgrade.
l           Supporting power outage notification.
l           Supporting security features including hierarchical user management, password protection and black hole MAC address list.
l           Providing various debugging functions for locating and diagnosing errors.
2.1  Introduction
The ET704-B-L provides a series of configuration commands and command line interfaces (CLIs), allowing users to configure and manage it conveniently.
Features of command line interfaces include:
l           Hierarchical command protection, preventing unauthorized users from accessing the ET704-B-L.
l           Online help: Users can gain online help at any time by entering a question mark (?).
l           Command history function: This enables users to check the commands that they have lately executed and re-execute the commands.
l           Fuzzy match of key words by command line interpreter: to interpret a key word, the user simply needs to enter a distinct keyword, such as “disp” for “display”.
ET704-B-L CLI views are designed for different configuration tasks. They are both correlated and distinguishing. For example, once a user logs into the ET704-B-L successfully, the user enters user view, where the user can perform some simple operations such as checking the operation status and statistics information of the ONU. By executing the system-view command, the user enters system view, where the user can go to other views by entering corresponding commands.
The command line interface views include:
l           User view
l           System view
l           Ethernet interface view
l           VLAN interface view
l           User interface view
Table 2-1 lists the details of the command line interface views, including the functions, the prompt and the entry and exit commands. Note that the interface numbers are for illustration purpose only.
Table 2-1 Details of command line interface views
View
Function
Prompt
Entry command
Exit command
Simple system management operations such as checking the operation status and statistics information of the ONU
<H3C>
This view is entered once the user logs in to the ONU.
quit: disconnect the ONU.
Configure system parameters
[H3C]
Enter system-view in user view
quit: quit to user view
return: return to user view
Configure Ethernet ports
[H3C-Ethernet0/1]
Enter interface Ethernet0/1 in system view
quit: quit to system view
VLAN interface view
Configure VLAN interfaces
[H3C-Vlan-interface1]
Enter interface vlan-interface 1 in system view or Ethernet interface view
User interface view
Configure user interface parameters
[H3C-Aux0]
Enter user-interface aux 0 in system view
[H3C-vty0]
Enter user-interface vty 0 in system view
The ET704-B-L has two user levels:
l           Guest users: only permitted for some basic query operations in user view.
l           Administrative users: permitted to enter system view and perform monitoring, configuration and management operations to the ET704-B-L.
By default, the user does not need to enter any password to enter system view. It is recommended to configure hierarchical user passwords on the ET704-B-L by executing the super password command. For the sake of security, the password entered for authentication is displayed as cipher text. If the correct password is entered within three attempts, the user will be switched to administrative user level. Otherwise, the user stays at guest user level.
Table 2-2 presents the method of configuring hierarchical user passwords.
Table 2-2 Follow these steps to configure hierarchical user passwords
To do...
Use the command…
Remarks
Enter system view
Configure hierarchical user passwords
super password password
password: a case sensitive string in plain text of 1 to 12 characters
If you lose your password, please contact your local dealer.
Delete hierarchical user passwords
undo super password
When configuring the ONU, you can use the online help to get related help information. The CLI provides two types of online help: complete online help and partial online help.
I. Complete online help
Enter a question mark (?) in any view on your terminal to display all the commands available in the view and their brief descriptions. The following takes user view as an example.
<H3C> ?
  debugging    Enable system debugging functions
  display      Display current system information
  quit         Exit from current command view
  reboot       Reset ONU
  reset        Reset operation
  save         Save current configuration
  system-view  Enter the system view
  terminal     Specify the terminal characteristics
  undo         Cancel current setting
Enter a command, a space, and a question mark (?).If the question mark “?” is at a keyword position in the command, all available keywords at the position and their descriptions will be displayed on your terminal.
<H3C> display ?
  agmp                   AGMP switch information
  agmp-group             AGMP-Group switch information
  arp                    Display ARP information
  cpu                    CPU usage rate
  current-configuration  Current configuration
  debugging              Current setting of debugging switches
  device                 Device
  dhcp-client            Display dhcp clinet information
  dhcp-snooping          Display dhcp snooping information
  igmp-snooping          IGMP snooping
  info-center            Information center status and configuration
                         information
  interface              Interface status and configuration information
  mac-address            MAC address information
  mirror                 display the mirroring port
  saved-configuration    The saved configuration information
  stp                    Spanning tree protocol
  tcp                    TCP status and configuration information
  update-record          display the onu update records
  user-interface         Terminal user interface status and configuration
                         information
  users                  Login users status
  version                System hardware and software version information
II. Partial online help
Enter a character/string, and then a question mark (?) next to it. All the commands beginning with the character/string will be displayed on your terminal. For example:
<H3C> s?
   save   system-view
Enter a command, a space, a character/string and a question mark (?) next to it. All the keywords beginning with the character/string (if available) are displayed on your terminal. For example:
<H3C> display u?
  user-interface   users
Enter the first letter(s) of a command keyword and press Tab. If the letter(s) entered can uniquely represent a keyword, the complete spelling of the keyword will appear on your terminal. For example:
<H3C> disp  ¬Press Tab.
<H3C> display
2.4.2  Error Prompts
If a command passes the syntax check, it will be successfully executed; otherwise, an error message will be displayed.
Table 2-3 lists the commonly displayed error prompts.
Table 2-3 Error prompts
Error prompt
Caused by
Unrecognized command
The command does not exist.
The keyword does not exist.
The parameter type is wrong.
The parameter value is out of range.
Incomplete command
The command entered is incomplete.
Too many parameters
The parameters entered are too many.
Ambiguous command
The parameters entered are ambiguous.
Wrong parameter
The parameter entered is wrong.
The CLI provides the command history function, which automatically saves the commands entered by a user for his/her future use.
The command line interface can store up to 10 commands in the history for each user. Table 2-4 presents the operations of using the command history function.
Table 2-4 Command history
To do...
Use the key
Result
Access the previous command in the history
If there is a previous command, read the previous command.
Access the next command in the history
If there is a next command, read the next command.
2.4.4  Command Edit
The CLI provides basic command edit functions and supports multi-line editing. The maximum number of characters a command can contain is 254. Table 2-5 lists the functions of the keys.
Table 2-5 Command edit
Key
Function
A common key
If the edit buffer is not full, pressing a key will insert the character on it to where the cursor is and move the cursor one character to the right
Backspace key
Pressing the backspace key will delete the character on the left of the cursor and move the cursor one character to the left.
The CLI provides the screen splitting feature to have display output suspended when the screen is full. Table 2-6 lists the options available for a suspended display.
Table 2-6 Terminal Display
Press the key
Function
The Enter key
Display information of the next command line.
The space key
Display the next screen.
Some other key
Exit the display.
Users can telnet to the ET704-B-L for remote management and maintenance.
To telnet to the ET704-B-B, both the ET704-B-L and the user terminal need to be properly configured, as listed in Table 3-1.
Table 3-1 Configurations on the ET704-B-L and the user terminal
Object
Configurations required
ET704-B-L
l      If the Telnet user terminal and the ET704-B-L interface where the terminal is connected are in the same local area network (LAN), their IP addresses must be in the same network segment. Otherwise, the Telnet user terminal and the ET704-B-L must be mutually reachable.
l      By default, the Ethernet interface and management VLAN of the ET704-B-L are down. The user needs to bring them up through operations on the OLT remotely.
Telnet user
The Telnet program is installed and started.
It has obtained the IP address of the management VLAN of the ET704-B-L, for which you can refer to Management VLAN Configuration.
&  Note:
l      Only one user can Telnet to the ET704-B-T at a time.
l      By default, the ET704-B-L requires no password for login through Telnet. You are recommended to configure a password after the first time login.
The following gives an example on how to Telnet to the ET704-B-L.
1)         As shown in Figure 3-1, connect the Ethernet interface of the Telnet user terminal to that of the ET704-B-L through a LAN.
Figure 3-1 Establish the configuration environment
2)         Run Telnet on the user terminal, and enter the IP address of the management VLAN of the Ethernet interface on the ET704-B-L that connects with the terminal (assuming it is 192.168.0.234), as shown in Figure 3-2.
Figure 3-2 Run Telnet
3)         The user terminal displays “Password” (assuming that a password is configured). After the user enters the correct password, a command line prompt will appear (such as <H3C>). If themessage “Vty user is busy now” appears, it means there is already a user logged into the ET704-B-T through Telnet.
After logging into the ET704-B-T, you can use the commands to configure it or check its operation status. To obtain the help information, enter a question mark “?” at any place. For detailed information of the configuration commands, refer to the following chapters.
Configuring VTY user interface involves the following three steps:
l           Enter VTY user interface view
l           Configure terminal properties
l           Configure Telnet login password
The VTY user interface view stores the properties of the interface when a specified user Telnets to the ET704-B-L. The ET704-B-L supports only one VTY user interface.
Table 4-1 User interface view
To do...
Use the command...
Remarks
Enter system view
Enter VTY Interface View
user-interface vty number
number: the number of user interface to be configured. Available option is 0.
The following gives the example of entering VTY user interface.
<H3C> system-view
[H3C] user-interface vty 0
[H3C-vty0]
Table 4-2 Configure terminal properties
To do...
Use the command...
Remarks
Enter system view
Enter VTY interface view
Configure the idle timeout value
minutes: the number of minutes in the idle timeout value, in the range 1 to 35791.
seconds: the number of seconds in the idle timeout value, in the range 0 to 59.
By default, the idle timeout value is 10 minutes, which means the user will be automatically disconnected if no operation is performed within 10 minutes on the VTY user interface.
Restore the idle timeout value to the default
undo idle-timeout
The following shows an example of setting the idle timeout value for the VTY user interface to 7 minutes.
<H3C> system-view
[H3C-vty0] idle-timeout 7
To prevent access by unauthorized users, you can configure a Telnet login password by executing the set authentication password command on the ONU.
Table 4-3 Configure Telnet login password
To do...
Use the command...
Remarks
Enter system view
set authentication password password
password: a case sensitive string in plain text of 1 to 16 characters
By default, there is no Telnet login password.
Remove the Telnet login password configured
undo set authentication password
The following gives an example of setting the Telnet login password to H3C in VTY system view.
<H3C> system-view
[H3C-vty0] set authentication password H3C
Table 4-4 User interface display
To do...
Use the command...
Remarks
Display the current user on the interface
display users
Available in any view
Display user interface status and the configurations
display user-interface
The following gives an example of displaying the current user on the interface.
<H3C> display users
      UI      Delay     Type   IPaddress        Username
F 0   VTY 0   00:00:00
Table 4-5 display users command output description
F
The current user interface in use, which is operating in asynchronous mode.
UI
The first line is the absolute number of the user interface, displayed as VTY.
The second line is the relative number of the user interface, displayed as 0.
Delay
The time elapsed since the user’s most recent entry, in the format “hh:mm:ss”.
User type
IPaddress
The IP address of the user terminal that is currently connected with the ET704-B-L
Username
The user name which is currently logged into the ET704-B-L
Complete the following tasks to configure Ethernet interfaces:
Remarks
Optional
Optional
Optional
Follow these steps to bring up/shut down an Ethernet interface:
To do...
Use the command...
Remarks
Enter system view
Enter Ethernet interface view
interface Ethernet interface-number
Shut down an Ethernet interface
shutdown
By default, an Ethernet interface is down.
Bring up an Ethernet interface
The following gives an example of shutting down an Ethernet interface Ethernet 0/3.
<H3C> system-view
[H3C] interface Ethernet0/3
[H3C-Ethernet0/3] shutdown
You can enable the cable inspection function of the ET704-B-L, which will return the inspection result of the cable connecting the Ethernet interface within 5 seconds: The inspection items include:
l           Cable status: results including normal, open, short and test-failure.
l           Cable length
l           Cable pair
Follow these steps to enable the cable inspection function:
To do...
Use the command...
Remarks
Enter system view
Enable the cable inspection function
virtual-cable-test
Required
By default, the cable inspection function is not enabled.
The following gives an example of enabling cable inspection function for interface Etherent0/3.
<H3C> system-view
[H3C-Ethernet0/3] virtual-cable-test
MDI pair         Cable status         Dist (meters)
1,2              Normal               N/A
3,6              Normal               N/A
4,5              N/A                  N/A
7,8              N/A                  N/A
&  Note:
l      When the cable status is normal, the display for dist (distance) is N/A (not available).
l      When the cable status is open, the distance displayed is the total length of the cable.
l      When the cable status is short, the distance displayed is the length from the interface to the place where the abnormity occurs.
l      When the returned result is test-failure, the distance displayed is 0.
By performing this task, you can check the status information of the ET704-B-L Ethernet interface and clear all Ethernet interface statistics.
Follow these steps to display Ethernet interface information and clear interface statistics.
To do...
Use the command...
Remarks
Clear all Ethernet interface statistics
reset counters
Optional
Available in user view.
Display Ethernet interface status information
display interface interface-type interface-number
Optional
The following gives an example of displaying information of interface Ethernet0/1.
<H3C> display interface Ethernet0/1
Ethernet0/1  current state: UP
IP Sending Frames' Format is PKTFMT_ETHNT_2, Hardware address is 000f-e200-0008
Description: Ethernet0/1 Interface
Mac-address learning is enabled
Media type is twisted pair
Port hardware type is 100_BASE_TX
100Mbps-speed mode, full-duplex mode
Inbound line-rate is disabled
Outbound line-rate is disabled
Flow control is disabled
The Maximum Frame Length is 1600
Input(normal):  269186946 packet(s), 48095360 byte(s)
        1716 broadcast(s), 0 multicast(s)
Input(error):  0 input error(s), 0 runt(s), 0 giant(s), 0 CRC
Output(normal):  156075193 packet(s), 2797051840 byte(s)
        4 broadcast(s), 9426 multicast(s)
Output(error):  0 output error(s), 0 collision(s), 0 late collision(s)
Table 5-1 display interface command output description
Mdi type
Media dependent interface (MDI) type
Number of input/output packets and error statistics
To Telnet to the ET704-B-L for remote management, the ET704-B-L must have an IP address configured. The ET704-B-L has only one VLAN interface that can be configured with an IP address and this VLAN is the management VLAN.
Complete the following tasks to configure the management VLAN:
Remarks
Optional
Follow these steps to bring up/shut down the management VLAN interface:
To do...
Use the command...
Remarks
Enter system view
Enter management VLAN interface view
interface vlan-interface vlan-id
vlan-id: ID of the management VLAN, in the range 1 to 4094.
By default, the management VLAN ID of the ET704-B-L is 1, its IP address is 192.168.0.100/24. To modify information of the management VLAN of the ET704-B-L, you need to make the modification through the OLT.
Shut down the management VLAN interface
shutdown
Bring up the management VLAN interface
To forward packets, the ET704-B-L needs to maintain a port-based Layer 2 MAC address table, which is the basis of fast forwarding on the ET704-B-L. An entry of the MAC address includes:
l           The destination MAC address
l           VLAN ID of the interface
l           Forwarding interface number
By looking up the MAC address table, the ET704-B-L can find the forwarding interface number for a Layer 2 packet quickly, so as to achieve fast forwarding of Layer 2 packets.
When receiving a packet whose destination MAC address is a black hole MAC address (a special MAC address), the ET704-B-L will discard the packet directly, instead of forwarding it.
The ET704-B-L also provides the MAC address aging function. If no packets are received within a certain time from a device whose MAC address is already in the MAC address table, the ET704-B-L will delete the corresponding entry from the table. The MAC address aging function only applies to entries learned and dynamic entries configured by the user. It does not apply to entries of static MAC addresses and black hole MAC addresses.
Complete the following tasks to manage the MAC address table:
Remarks
Optional
Optional
Optional
You can manually add, modify or delete MAC address table entries as needed.
Follow these steps to modify MAC address table entries:
To do...
Use the command...
Remarks
Enter system view
Add MAC address table entries
mac-address blackhole mac-address
blackhole: Packet whose destination address is the specified MAC address will be discarded by the ET704-B-L.
static: A static entry will not be aged out. A saved static entry will not be lost after a restart
dynamic: dynamic addresses will be aged out.
mac-address: in the H-H-H format, excluding multicast MAC addresses, the ET704-B-L’s MAC address and broadcast MAC address.
interface-number: interface number
mac-address { dynamic | static } mac-address interface Ethernet interface-number
Delete MAC address table entries
undo mac-address [ interface Ethernet interface-number | mac-address ]
The following gives an example of adding a new entry, with the MAC address 000a-eb7f-aaab and interface number Ethernet0/1, and configuring it as a static entry.
<H3C> system-view
[H3C] mac-address static 000a-eb7f-aaab interface Ethernet 0/1
The aging time is very important for implementing the MAC address aging function of the ET704-B-L. An aging time being too long or too short will result in a large number of packets which cannot match any entry and need to be broadcast. This will affect the performance of the ET704-B-L. The following gives the reasons:
l           If the aging time is too long, the ET704-B-L may keep many MAC address entries that are outdated, consuming the MAC address table resource and disabling the ET704-B-L from updating the MAC address table according to network changes.
l           If the aging time is too short, the ET704-B-L may delete valid MAC address entries, thus decreasing its forwarding efficiency.
Follow these steps to configure the aging time of MAC address table entries:
To do...
Use the command...
Remarks
Enter system view
Configure the aging time of MAC address table entries
mac-address timer { aging age | no-aging }
age: the aging time of MAC address table entries, in the range 10 to 3825, in seconds.
no-aging: no aging.
Restore the aging time of MAC address table entries to default
undo mac-address timer aging
By default, the aging time of MAC address table entries is 300 seconds.
The following gives an example of configuring the aging time of MAC address table entries as 500 seconds.
<H3C> system-view
[H3C] mac-address timer aging 500
After completing the configurations described in the sections above, you can display the information of MAC address entries learned and configured by executing the display mac-address command in any view, so that you can verify the configurations. The information includes the VLAN ID, the address state (static or dynamic), the corresponding interface and the aging time.
Follow the step to display information of MAC address table entries.
To do...
Use the command...
Remarks
Display information of MAC address table entries
display mac-address [ mac-address | interface Ethernet interface-number | blackhole | aging-time | count ]
l      mac-address: MAC address
l      interface-number: interface number
l      blackhole: blackhole address entry
l      aging-time: aging time
l      count: number of MAC addresses
The following gives an example of displaying the information of an MAC address table entry with the MAC address 000a-eb7f-aaab.
<H3C> display mac-address 000a-eb7f-aaab
Reading entire MAC table. Please wait...
MAC ADDR           VLAN ID    STATE          PORT INDEX      AGING TIME(s)
000a-eb7f-aaab     N/A        Learned        Ethernet0/1     AGING
 --- 1 mac address(es) found ---
The information above indicates that packets with destination MAC address 000a-eb7f-aaab will be forwarded out from interface Ethernet0/1.
Complete the following tasks to manage the configuration:
Remarks
Optional
Optional
Optional
After being powered up, the ET704-B-L reads the configuration from the Flash for initialization. The configuration in the Flash is called the saved configuration. If there is no configuration in the Flash, the ET704-B-L will use the default parameters for initialization. As compared to the saved configuration, the configuration which is in effect during the operation of the ET704-B-L is called the current configuration.
Follow these steps to display the current and saved configurations:
To do...
Use the command...
Remarks
Display the saved configuration
display saved-configuration
Display the current configuration
display current-configuration
&  Note:
The following gives an example of displaying the current configuration of the ET704-B-L.
<H3C> display current-configuration
 sysname H3C
interface vlan-interface1
 ip address 192.168.1.10 255.255.255.0
 ip gateway 192.168.1.1
 shutdown
 igmp-snooping enable
 stp enable
interface Ethernet0/2
interface Ethernet0/4
To make the current configuration effective after the next power-up, you need to save the current configuration to the Flash of the ET704-B-L.
Follow the step to save the current configuration:
To do...
Use the command...
Remarks
Save the current configuration
save
l      Available in user view
l      You are recommended to perform this operation to save the current configuration when you finish a set of parameters and they are proved to be correct.
The following gives an example of saving the current configuration to the Flash.
<H3C> save
This will save the configuration in the Flash
Are you sure?[Y/N]y
Now saving current configuration to Flash
Please wait for a while...
Current configuration saved to Flash successfully
You can restore the ET704-B-L to the factory default configuration.
Follow these steps to restore the default configuration:
To do...
Use the command...
Remarks
Enter system view
Restore the default configuration
restore default
Required
After being restored to the default configuration, the ET704 will be automatically reset.
The following gives an example of restoring the ET704-B-L to default configuration.
<H3C> system-view
[H3C] restore default
This will restore the default configuration in the Flash
Are you sure?[Y/N]y
Now saving default configuration to Flash
The system management tasks include:
Remarks
Optional
Optional
Optional
Optional
Optional
Optional
Optional
Optional
Follow the step to reboot the ET704-B-L:
To do...
Use the command...
Remarks
Reboot the ET704-B-L
reboot
The following gives an example of rebooting the ET704-B-L.
<H3C> reboot
Follow these steps to configure a system name for the ET704-B-L:
To do...
Use the command...
Remarks
Enter system view
Configure a system name for the ET704-B-L
sysname sysname
sysname: system name, 1 to 30 characters. The default system name of the ET704-B-L is H3C.
Restore the default system name of the ET704-B-L
undo sysname
&  Note:
The system name of the ET704-B-L will be the prompt for the command lines. For example, if the system name is H3C, the prompt for all command lines is <H3C>. Therefore, modifying the system name will change the prompt for the command lines.
The following gives an example of configuring the system name of the ET704-B-L as ONU.
<H3C> system-view
[H3C] sysname ONU
[ONU]
Follow these steps to display/clear the address resolution protocol (ARP) table.
To do...
Use the command...
Remarks
Display the ARP table of the ET704-B-L
display arp [ ip-address ]
ip-address: displays the IP address of the specified ARP table entry.
Clear the ARP table of the ET704-B-L
reset arp
The following gives an example of displaying all ARP table entries.
<H3C> display arp
IP Address        MAC Address     VLAN ID  Port Name            Aging
192.168.0.101     000a-eb66-0cff     1     Ethernet0/2          20
192.168.0.99      000f-e200-0155     1     Ethernet0/1          20
--- 2 entries found ---
Different software versions provide different specifications. By displaying the system version information, you can know the specifications of the current system version.
Follow the step to display the system version information:
To do...
Use the command...
Remarks
Display the system version information
display version
The following gives an example of displaying the system version information.
<H3C> display version
ET704 Product Version ET704-T5601
Copyright (c) 2007 Hangzhou H3C Technologies Co., Ltd.
All rights reserved.
ET704 uptime is 0 week(s), 0 day(s), 17 hour(s), 8 minute(s)
ET704 with 140M ARM Processor
SDRAM:              8M bytes
FLASH:              4M bytes
Hardware Version:   VER.A
Bootrom  Version:   100
Follow the step to display the board information of the ET704-B-L:
To do...
Use the command...
Remarks
Display the board information of the ET704-B-L
display device
The following gives an example of displaying the board information of the ET704-B-L
<H3C> display device
SlotNo SubSNo PortNum PCBVer FPGAVer CPLDVer BootRomVer Type
0       0       4     Ver.A  NULL    NULL    100        MAIN
Follow the step to display the CPU status of the ET704-B-L:
To do...
Use the command...
Remarks
Display the CPU status of the ET704-B-L
display cpu
The following gives an example of displaying the CPU status of the ET704-B-L.
<H3C> display cpu
CPU busy status:
  16 percent in last 5 seconds.
  16 percent in last 1 minute.
  16 percent in last 5 minutes.
By performing this task, you can display the status of all TCP connections on the ET704-B-L.
Follow the step to display the TCP connection status of the ET704-B-L:
To do...
Use the command...
Remarks
Display the TCP connection status of the ET704-B-L
display tcp status
For example:
<Sysname> display tcp status
TCPNO         Local Add:port       Foreign Add:port     State
1           100.0.0.204:23       100.0.0.253:65508    Established
Table 7-1 display tcp status command output description
TCPNO
Number of the TCP control module
Local Add:port
Local IP address and interface number
Foreign Add:port
Peer IP address and interface number
  Caution:
l      By default, the Ethernet interface and management VLAN of the ET704-B-L are down. You need to bring them up through operations on the OLT remotely first, so that you can Telnet to the ET704-B-L for local software upgrade.
l      Before upgrading the software, make sure that the TFTP server and the ET704-B-L are mutually reachable.
l      After upgrading the software, you must reboot the ET704-B-L with the reboot command to make the software take effect.
l      Before rebooting the ET704-B-L, make sure that you have saved all necessary configuration.
l      Do not power off the ET704-B-L when upgrading the software, for fear of upgrade failure.
You can use the Trivial File Transfer Protocol (TFTP) on the Ethernet interface of the ET704-B-L to upgrade the local software of the ET704-B-L.
Follow these steps to upgrade the local software of the ET704-B-L:
To do...
Use the command...
Remarks
Enter system view
Upgrade the local software of the ET704-B-L
update tftp tftp-server file
Required
tftp-server: the IP address of the TFTP server
file: the file name of the update software, containing 1 to 64 characters
Display upgrade records
display update-record
Optional
The following gives an example of upgrading the local software of the ET704-B-L:
1)         As shown in Figure 7-1, connect the one Ethernet interface of the ET704-B-L with the TFTP server and another Ethernet interface to a PC (the PC and the TFTP server can be the same machine).
Figure 7-1 Download the software to the ET704-B-L through a TFTP server
2)         Run the server program on the TFTP server and specify the file directory of the software to be downloaded (for the operation of TFTP program, refer to the related guidance of the software).
&  Note:
The default management VLAN of the ET704-B-L is VLAN 1, and the interface IP address is 192.168.0.100/24. In the network above, assume that the IP address of the TFTP server is 192.168.0.200/24.
3)         Configure the ET704-B-L remotely on the OLT to bring up the management VLAN interface and the Ethernet interfaces connecting the PC and the TFTP server (detailed operation description is omitted here).
4)         Telnet to the ET704-B-L to download the update software (assuming it is named file.APP) from the TFTP server to the ET704-B-L.
<H3C> system-view
[H3C] update tftp 192.168.0.200 file.APP
This will read software from tftp server and override image 0. Continue? [Y/N]y
TFTP server IP: 192.168.0.200
TFTP client IP: 192.168.0.100
TFTP client port: 13073.
Update file name: file.APP
Please wait until the updating process is over.
To burn the softwre to flash...
Do flash burning successfully.
Upgrading is over, please reboot the device.
5)         Reboot the ONU.
[H3C] quit
<H3C> reboot
7.4  System Log
The system log stores the information of the ET704-B-T system module. It manages most of the system information output and classifies the information for effective information selection. Together with the debugging program, the system log greatly helps the network administrator to monitor the network operation status and diagnose network failures.
System log tasks include:
Remarks
Optional
Optional
Optional
Optional
Optional
Follow these steps to enable/disable terminal logging:
To do...
Use the command...
Remarks
Enable terminal logging
terminal logging
l      By default, terminal logging is enabled for console users, and is disabled for terminal users.
Disable terminal logging
undo terminal logging
The system exports system logging information to the host and/or the console only when the information center is enabled.
Follow these steps to enable/disable the information center:
To do...
Use the command...
Remarks
Enter system view
Enable information center
info-center enable
By default, the info-center function is enabled on the ET704-B-L.
Disable information center
undo info-center enable
&  Note:
With the information center enabled, the system needs to classify and output information, which will have an impact on the system performance when the amount of information to be processed is large.
You can export the logging information of multiple ONUs to the same host.
Follow these steps to export logging Information to the specified host:
To do...
Use the command...
Remarks
Enter system view
Export logging information to the specified host
info-center loghost host-ip-addr
host-ip-addr: the IP address of the log host (to which the logging information will be sent)
By default, the ET704-B-L does not export logging information to any log host.
Disable exporting logging Information to the specified host
undo info-center loghost
&  Note:
l      When using the info-center loghost command to configure the IP address of the log host, you need to enter the correct IP address. A loopback address is invalid.
l      The ET704-B-L will only export the warning information to the log host. For information about the system logging information categories, refer to Configuring the Logging Information Level.
The following gives an example of configuring the ET704-B-L to export logging information to the log host with the IP address 202.38.160.1 (configurations on the log host are omitted here).
<H3C> system-view
[H3C] info-center enable
[H3C] info-center loghost 202.38.160.1
You can specify that only the information higher than the specified level is to be exported to the log host.
Follow these steps to configure the logging information level:
To do...
Use the command...
Remarks
Enter system view
Configure the logging information level
info-center monitor level level
level: the level of the logging information. For details, refer to Table 7-2.
By default, the logging information level at the information center is 5.
Restore the logging information level to the default value
undo info-center monitor level
Table 7-2 Levels of logging information at the information center
Severity level
Value
emergencies
1
The system is not operable.
alerts
2
Operator’s immediate action is required.
critical
3
Critical information
errors
4
Error information
warnings
5
Warning information
notifications
6
Normal but important information
informational
7
Informational information
debugging
8
Information generated in the debugging process
The following gives an example of setting the logging information level at the information center to 7.
<H3C> system-view
[H3C] info-center level 7
Follow the step to display the information center :
To do...
Use the command...
Remarks
Display the information center
display info-center
The following gives an example of displaying the information center .
<H3C> display info-center
 Sysname H3C
 Terminal logging enable
 Info-center loghost 202.38.160.1
 Info-center enable
 Info-center level 5
Table 7-3 display info-center command output description
Sysname
System name of the ET704-B-L
Terminal logging is enabled
Info-center loghost
Info-center
Status of the information center
Info-center level
Information center level
The Aolynk Group Management Protocol (AGMP), a proprietary protocol of H3C for link layer-based LAN management, implements remote management to AGMP-capable switches in a LAN.
The management functions of AGMP include:
l           Configuring the basic functions of remote switches, including saving the configuration, restoring factory default configuration, rebooting the configuration and IGMP Snooping.
l           Configuring the ports of remote switches, including broadcast storm suppression, flow control, VLAN and rate limit.
l           Configuring QoS settings for remote switches, including QoS trust mode and queueing scheme.
Complete these tasks to configure AGMP:
Remarks
Optional
Optional
Optional
Optional
Follow these steps to enable/disable AGMP:
To do...
Use the command...
Remarks
Enter system view
Enable AGMP
agmp enable
By default, AGMP is enabled.
Disable AGMP
undo agmp enable
Follow these steps to configure basic functions for a remote switch:
To do...
Use the command...
Remarks
Enter system view
Configure loopback detection for the remote switch
agmp { switch-id switch-id | switch-mac mac-address } loopback-detection { enable | disable }
enable: enable the function
disable: disable the function
switch-id is the ID of the remote switch, mac-address is the MAC address of the remote switch. You can use the display agmp-group brief command to obtain these information. For details, refer to Displaying AGMP Configuration.
Description for the parameters above applies to the following commands as well.
Configure IGMP Snooping for the remote switch
agmp { switch-id switch-id | switch-mac mac-address } igmp-snooing { enable | disable }
Save the configuration for the remote switch
agmp { switch-id switch-id | switch-mac mac-address } save-config
Restore the default configuration for the remote switch
agmp { switch-id switch-id | switch-mac mac-address } restore-default
Reboot the remote switch
agmp { switch-id switch-id | switch-mac mac-address } reboot
The following gives an example of enabling IGMP Snooping for the remote switch whose ID is 1.
<H3C> system-view
[H3C] agmp switch-id 1 igmp-snooing enable
Follow these steps to configure Ethernet ports for a remote switch:
To do...
Use the command...
Remarks
Enter system view
Enable/disable Ethernet ports for a remote switch
agmp { switch-id switch-id | switch-mac mac-address } port port-id { enable | disable }
port-id: specified port ID. Description for this parameter, if any, is omitted for other commands in this section.
Configure the broadcast suppression function
agmp { switch-id switch-id | switch-mac mac-address } broadcast-suppression { enable | disable }
This command applies to all ports on the remote switch.
Configure the flow control function
agmp { switch-id switch-id | switch-mac mac-address } flow-contrl { enable | disable }
Configure the line rate
agmp { switch-id switch-id | switch-mac mac-address } port port-id line-rate { inbound | outbound } kbps
l      inbound: inbound direction
l      outbound: outbound direction
l      kbps: available values are 128, 256, 512, 1024, 2048, 4096, 8192 and 102400.
Configure the speed and duplex mode
agmp { switch-id switch-id | switch-mac mac-address } port port-id speed-duplex  { 10full I 10half I 100full I 100half I auto }
l      10full: 10 Mbps, full duplex
l      10half: 10 Mbps, half duplex
l      100full: 100 Mbps, full duplex
l      100half: 100 Mbps, half duplex
l      auto: automatic
Configure the Ethernet port priority
agmp { switch-id switch-id | switch-mac mac-address } port port-id priority { low | high }
l      low: low priority
l      high: high priority
Configure the Ethernet VLAN mode
agmp { switch-id switch-id | switch-mac mac-address } port port-id link-type { tagged | untagged | transparent }
l      tagged: for inbound packets, forward them with no processing; for outbound packets with VLAN tags, forward them with no processing; for packets with no VLAN tags, append the VLAN tag of the PVID of the packet inbound port and then forward them.
l      untagged: For inbound packets, forward them with no processing; for outbound packets with VLAN tags, remove the tags and then forward them; for outbound packets with no VLAN tags, forward them with no processing.
l      transparent: Forward inbound and outbound packets with no processing.
Configure the default VLAN ID of Ethernet ports
agmp { switch-id switch-id | switch-mac mac-address } port port-id pvid pvid
pvid: the default VLAN ID.
Configure the virtual cable test (VCT) function for Ethernet ports
agmp { switch-id switch-id | switch-mac mac-address } [ port port-id] virtual-cable-test
Reset the counters for Ethernet ports
agmp { switch-id switch-id | switch-mac mac-address } [ port port-id ] reset-counters
If no port ID is specified, reset the counters for all Ethernet ports on the switch.
The following gives an example of configuring the default VLAN ID of Ethernet port 2 as 10 for the switch with the ID 1.
<H3C> system-view
[H3C] agmp switch-id 1 port 2 pvid 10
Follow these steps to configure QoS settings for a remote switch:
To do...
Use the command...
Remarks
Enter system view
Configure the priority trust mode for the remote switch
agmp { switch-id switch-id | switch-mac mac-address } priority-trust { port I 802.1p }
l      port: the port priority is used for queueing, that is, packets are put into outgoing queues based on the corresponding port priorities.
l      802.1p: the COS priority is used for queueing, that is, packets are put into outgoing queues based on the corresponding COS priorities.
Configure the queue scheduler for the remote switch
agmp { switch-id switch-id | switch-mac mac-address } queue-scheduler { 4:1 I 8:1 I 16:1| high-first}
l      4:1: packets are enqueued by priority with the ratio of 4:1.
l      8:1: packets are enqueued by priority with the ratio of 8:1.
l      16:1: packets are enqueued by priority with the ratio of 16:1.
l      high-first: packets of high priority are enqueued first.
&  Note:
4:1/8:1/16:1 means that the queueing algorithm used is weighted round robin (WRR), and high-first means the queueing algorithm used is strict priority (SP).
l      The WRR algorithm specifies a weight (w0, w1…) for each queue, which represents the weight of resources assigned. With 4:1 configured, if the traffic in two outgoing queues exceeds the capacity of the port, the switch will schedule the packets between the two queues in a ratio of 4:1. That is, out of every 5 packets sent by the switch, 4 are from the high priority queue and one from the low priority queue. The principle is the same for other two ratios 8:1 and 16:1.
l      With the strict priority algorithm enabled, if the traffic in two queues exceeds the capacity of the port, the switch will send out packets in the high priority queue first and will send low priority packets after all high priority queues are sent.
The following gives an example of configuring the WRR queueing algorithm with the ratio 4:1 for the switch whose ID is 1.
<H3C> system-view
[H3C] agmp switch-id 1 queue-scheduler 4:1
Follow these steps to display the AGMP configuration:
To do...
Use the command...
Remarks
Display the switch discovered by AGMP
Display the configuration information of a remote switch
display agmp { switch-id switch-id | switch-mac mac-address } sys-info
Display the configuration and status information of a specified port on a remote switch
display agmp { switch-id switch-id | switch-mac mac-address } port port-id brief
Display the configuration and basic information of all ports on a remote switch
display agmp { switch-id switch-id | switch-mac mac-address } brief
The following gives an example of displaying the switch discovered by AGMP.
<H3C> display agmp-group brief
Switch ID       MAC Address     Layer Num    Local Port  Uplink MAC
1                                                    0000-e8f5-6a4a  1            1           0000-e8f5-6a44
2                                                    0000-e8f5-6a4b  2            1           0000-e8f5-6a4a
Table 8-1 display agmp group brief command output description
Switch ID
MAC Address
Layer  Num
Number of the layer that the remote switch resides at
Local Port
Number of the local port connected
Uplink mac
MAC address of the uplink switch
The ET704-B-L provides various debugging functions covering most of the supported protocols and features, facilitating failure locating and diagnosis.
The export of debugging information can be controlled by either of the following two switches:
l           Protocol debugging: controls whether to export the debugging information of a specified protocol.
l           Terminal output switch: controls whether to output the debugging information to a specified user terminal.
As shown in Figure 9-1, assume that the ET704-B-L can provide debugging information for modules 1, 2 and 3. However, you need to turn both switches to on to have the debugging information displayed on the terminal.
Figure 9-1 Debugging information export
Complete the following tasks to display system debugging information:
Remarks
Optional
Optional
Optional
By performing this task, you can control the debugging for an individual protocol or all protocols.
Follow these steps to enable/disable the protocol debugging:
To do...
Use the command...
Remarks
Enable protocol debugging
debugging { all | module-name }
all: specifies to enable/disable debugging for all modules.
module-name: name of the specified module. Available modules include igmp-snooping, dhcp-snooping, stp and agmp.
By default, debugging is enabled for none of the modules.
Disable protocol debugging
undo debugging { all | module-name }
&  Note:
System debugging affects the system operation performance. Therefore, only use the debugging function, especially the debugging all command, when it is necessary. After the debugging finishes, disable the debugging function.
Follow these steps to enable/disable terminal debugging:
To do...
Use the command...
Remarks
Enable terminal debugging
terminal debugging
By default, terminal debugging is not enabled.
Disable terminal debugging
undo terminal debugging
&  Note:
Follow the step to display debugging status:
To do...
Use the command...
Remarks
Display debugging status
display debugging
&  Note:
This chapter lists all the display commands supported by the ET704-B-L, through which the user can display the status and configuration information of the functional modules.
Table 10-1 Display commands and description
Module
User interface
display users
Display the users on the interface
Display the status and configuration of the user interface
Ethernet interface
System management
Display the information of MAC address table entries learned and configured
display version
Display software upgrade record
display device
display cpu
display tcp status
display info-center
System debugging
display debugging
Interface mirroring
display mirror
Display Ethernet interface mirroring configuration
DHCP
display dhcp-client
Display address assignment information for DHCP clients
display dhcp-snooping
Display the matching relationship between the user IP address and MAC address recorded through DHCP-Snooping
IGMP
display igmp-snooping configuration
Display the current IGMP Snooping configuration
display igmp-snooping statistics
Display the statistics by IGMP Snooping for packets received and sent
display igmp-snooping group
Display information about IP multicast group and MAC multicast group
VLAN
display interface vlan-interface [ vlan-id ]
Display VLAN interface information
STP
display stp
Display the status of the current RSTP
ARP
AGMP
H3C reserves the right to modify its collaterals without any prior notice. For the latest information of the collaterals, please consult H3C sales or call 400 hotline.
