Chapters Download(72.93 KB)
H3C ET704-B-L EPON ONU |
User Manual |
Hangzhou H3C Technologies Co., Ltd. http://www.h3c.com
Manual Version: 5W100-20080118 |
Copyright © 2008, Hangzhou H3C Technologies Co., Ltd.
All Rights Reserved
No part of this manual may be reproduced or transmitted in any form or by any means without prior written consent of Hangzhou H3C Technologies Co., Ltd.
Trademarks
H3C, , Aolynk,
, H3Care,
, TOP G,
, IRF, NetPilot, Neocean,
NeoVTL, SecPro, SecPoint, SecEngine, SecPath, Comware, Secware, Storware, NQA, VVG,
V2G, VnG, PSPT, XGbus, N-Bus, TiGem, InnoVision and HUASAN are trademarks of Hangzhou H3C Technologies Co., Ltd.
All other trademarks that may be mentioned in this manual are the property of their respective owners.
VCCI
この装置は、情報処理装置等電波障害自主規制協議会(VCCI)の基準に基づくクラスB 情報技術装置です。この装置は、家庭環境で使用することを目的としていますが、この装置がラジオやテレビジョン受信機に近接して使用されると、受信障害を引き起こすことがあります。
CE
This equipment complies with the following European Directives: 89/336/EEC (electromagnetic compatibility), 73/23/EEC (low voltage).
Notice
The information in this document is subject to change without notice. Every effort has been made in the preparation of this document to ensure accuracy of the contents, but all statements, information, and recommendations in this document do not constitute the warranty of any kind, express or implied.
To obtain the latest information, please access:
http://www.h3c.com
Technical Support
http://www.h3c.com
About This Manual
Purpose
This document is used to guide you through configuring, maintaining and managing this product. Please read it carefully before your operation.
Intended Audience
This document is intended for network administrators who know well of the basic network knowledge and network terms.
Organization
This document is organized as follows:
Chapter |
Content |
This chapter describes the overview of the ET704-B-L. |
This chapter describes the configuration commands and command line interfaces of the ET704-B-L. |
This chapter describes how to telnet to the ET704-B-L for remote management and maintenance. |
This chapter describes how to configure Telnet users of the ET704-B-L and describes the configuration commands. |
This chapter describes how to configure the Ethernet interface of the ET704-B-L and describes the configuration commands. |
This chapter describes how to configure the management VLAN of the ET704-B-L and describes the configuration commands. |
This chapter describes how to manage the ET704-B-L, including MAC address table, configuration, system and system log, and describes the configuration commands. |
This chapter describes how to use the AGMP feature of the ET704-B-L to manage lower-level switch, and describes the configuration commands. |
This chapter describes system debugging operations and the related commands. |
This chapter lists all display commands that are supported by the ET704-B-L. |
Conventions
The manual uses the following conventions:
Convention |
Boldface |
The keywords of a command line are in Boldface. |
italic |
Command arguments are in italic. |
Items (keywords or arguments) in square brackets [ ] are optional. |
{ x | y | ... } |
Alternative items are grouped in braces and separated by vertical bars. One is selected. |
[ x | y | ... ] |
Optional alternative items are grouped in square brackets and separated by vertical bars. One or none is selected. |
{ x | y | ... } * |
Alternative items are grouped in braces and separated by vertical bars. A minimum of one or a maximum of all can be selected. |
[ x | y | ... ] * |
Optional alternative items are grouped in square brackets and separated by vertical bars. Many or none can be selected. |
&<1-n> |
The argument(s) before the ampersand (&) sign can be entered 1 to n times. |
A line starting with the # sign is comments. |
Convention |
Means reader be careful. Improper operation may cause data loss or damage to equipment. |
& Note |
Means a complementary description. |
