Chapters Download(286 KB)
H3C XE 200/2000 IP PBX |
Operation Manual |
Hangzhou H3C Technologies Co., Ltd. http://www.h3c.com
Manual Version: T2-08162N-20070520-C-3.01 |
Copyright © 2006-2007, Hangzhou H3C Technologies Co., Ltd.
All Rights Reserved
No part of this manual may be reproduced or transmitted in any form or by any means without prior written consent of Hangzhou H3C Technologies Co., Ltd.
Trademarks
H3C,
, Aolynk,
, H3Care,
, TOP G,
, IRF, NetPilot, Neocean, NeoVTL, SecPro, SecPoint,
SecEngine, SecPath, Comware, Secware, Storware, NQA, VVG, V2G, VnG,
PSPT, XGbus, N-Bus, TiGem, InnoVision and HUASAN are trademarks of Hangzhou H3C
All other trademarks that may be mentioned in this manual are the property of their respective owners.
Notice
The information in this document is subject to change without notice. Every effort has been made in the preparation of this document to ensure accuracy of the contents, but all statements, information, and recommendations in this document do not constitute the warranty of any kind, express or implied.
To obtain the latest information, please access:
http://www. h3c.com
Technical Support
http://www. h3c.com
About This Manual
Related Documentation
In addition to this manual, each H3C XE 200/2000 IP PBX documentation set includes the following:
Manual |
H3C XE 200/2000 IP PBX Installation Manual |
It provides information for the hardware features, installation, configuration, maintenance and troubleshooting involved in the XE series. |
H3C XE 200/2000 IP PBX Command Manual |
It provides information for the hardware features, installation, configuration, maintenance and troubleshooting involved in the XE 200/2000. |
H3C XE 200/2000 IP PBX G-Remote User Manual |
It introduces the graphic user interface and the operation through the XE 200/2000. |
Organization
H3C XE 200/2000 IP PBX Operation Manual is organized as follows:
Chapter |
Contents |
1 Basic Configuration |
Profiles the system characteristics and major functions. It also describes command line interfaces (CLIs), required configuration environments, Comware CLI attributes and basic Comware configuration. The interface configuration covers the configuration on Ethernet interfaces and VLANs. The routing configuration involves the configuration on IP unicast static routes. |
2 Process Server Configuration |
Focuses on the functions and configuration procedure of the H.323 GateKeeper and SIP Server. |
3 Location Server Configuration |
Elaborates on the functions and configuration procedure of the Location Server. |
4 Feature |
Describes the unique functions and features that the IP PBX provides including number translation, overload protection and backup and load balancing. |
5 System Management |
Introduces Comware logging and debugging center, file system and file operation, user interface, user management system and NTP configuration. SNMP configuration involves the settings required when the IP PBX serves as NMS Agent. Terminal service presents allowable console terminal types and required settings. System management covers hierarchical command configuration, RADIUS-based AAA security. |
6 IP Performance and Application |
Includes the fundamentals and configuration of the IP address, IP applications, IP performance, as well as the configuration necessary when the IP PBX serves as HDCP Server. |
7 Media Server |
Introduces the functions of the media server, and describes the configuration steps of the media server in details. |
8 Call Services |
Introduces the various voice services provided with the XE voice servers, including Subscriber Management Service, Emergency Call Service, Inter-Group Call Restriction Service, Outgoing Call Authority Control Service, Abbreviated Dialing Service, Do-Not-Disturb Service, Calling Line Identification Services, Password Call Service, Call Forwarding Services , Third Party Call Termination Service, ONLY Service, Time Limit Call Service, Third Party Call Control Service, Callback-On-Busy Service, Call Pickup Service, Call Intervention Service, Dialing Test Service, Time Announcement Service, MyRing Service, CPCP Service, Automatic Operator Service, Group Notification Service, Call Transfer Service, Number Query Service and Alarm Clock Service. |
9 Appendix A |
Introduces usage of the license of the XE 200/2000 IP PBX. |
10 Appendix B |
Lists the acronyms used in the manual. |
Conventions
The manual uses the following conventions:
Convention |
Boldface |
The keywords of a command line are in Boldface. |
italic |
Command arguments are in italic. |
Items (keywords or arguments) in square brackets [ ] are optional. |
{ x | y | ... } |
Alternative items are grouped in braces and separated by vertical bars. One is selected. |
[ x | y | ... ] |
Optional alternative items are grouped in square brackets and separated by vertical bars. One or none is selected. |
{ x | y | ... } * |
Alternative items are grouped in braces and separated by vertical bars. A minimum of one or a maximum of all can be selected. |
[ x | y | ... ] * |
Optional alternative items are grouped in square brackets and separated by vertical bars. Many or none can be selected. |
&<1-n> |
The argument(s) before the ampersand (&) sign can be entered 1 to n times. |
A line starting with the # sign is comments. |
Convention |
Button names are inside angle brackets. For example, click <OK>. |
Window names, menu items, data table and field names are inside square brackets. For example, pop up the [New User] window. |
Multi-level menus are separated by forward slashes. For example, [File/Create/Folder]. |
Convention |
Means reader be extremely careful. Improper operation may cause bodily injury. |
Means reader be careful. Improper operation may cause data loss or damage to equipment. |
& Note |
Means a complementary description. |
