Chapters Download(1 MB)
Table of Contents
Chapter 2 Installation Preparations
2.1.4 Electromagnetic Environment
2.1.6 Checking the Rack/Workbench/Tabletop
2.3 Tools, Cables, Meters, and Devices
Chapter 3 Installing the VG 31-08
3.2.1 Tabletop/Workbench Mounting
3.3 Connecting the Grounding Cable
3.4 Connecting to the Console Terminal
3.5 Connecting to the Ethernet
3.7 Connecting the Telephone Cable
Chapter 4 Booting and Configuring the VG 31-08
4.1.1 Setting up a Configuration Environment
4.1.2 Powering up the VG 31-08
4.2 Configuration Fundamentals
4.2.1 Basic Configuration Procedures
4.2.2 Features of the Command Line Interface
4.2.3 Features of Web-based Configuration
Chapter 5 Software Maintenance
5.2 Upgrading Application and Boot ROM Programs Using XModem
5.2.1 Upgrading the Application Program
5.2.2 Upgrading the Full Boot ROM Program
5.2.3 Upgrading the Extended Segment of the Boot ROM Program
5.3 Backing up and Restoring the Extended Segment of the Boot ROM Program
5.3.1 Backing up the Extended Segment of Boot ROM Program in Flash Memory
5.3.2 Restoring the Extended Segment of Boot ROM Program from Flash Memory
5.4 Repairing the Extended Segment of Boot ROM
5.5 Upgrading the Application Program Using TFTP
5.5.1 Setting up an Upgrading Environment
5.5.3 Configuring the VG 31-08
5.5.4 Downloading the Application Program
5.6 Uploading/Downloading Configuration File and Program Using FTP
5.6.1 Setting up Uploading/Downloading Environment
5.6.2 Configuring the FTP Service on the VG 31-08
5.6.3 Uploading/Downloading Application/Boot ROM Program/Configuration File
5.7 Solutions when the Password is Lost
5.7.1 When a user password is lost
5.7.2 When the Boot ROM Password is Lost
6.1 Troubleshooting the Power System
6.2 Troubleshooting the Configuration System
List of Figures
Figure 1-1 Appearance of the VG 31-08
Figure 1-2 VG 31-08 front panel
Figure 1-3 VG 31-08 rear panel
Figure 1-4 LEDs on VG 31-08 front panel
Figure 3-1 Installation flowchart
Figure 3-2 Rack mounting of the VG 31-08
Figure 3-3 Console cable assembly
Figure 3-4 Ethernet cable assembly
Figure 4-1 Local configuration through the console port
Figure 4-2 Set up a new connection
Figure 4-3 Set the connection port
Figure 4-4 Set communication parameters
Figure 4-5 Set the terminal type
Figure 5-1 The Send File dialog box
Figure 5-2 The Sending File interface
Figure 5-3 Set up an environment for upgrading through TFTP
Figure 5-4 Set up an environment for local uploading/downloading through FTP
Figure 5-5 Set up an environment for remote uploading/downloading through FTP
List of Tables
Table 1-1 System Specifications
Table 1-3 Attributes of the console port
Table 1-4 Attributes of the FE interface
Table 1-5 Attributes of the FXS port
Table 1-6 Attributes of the FXO port
Table 2-1 Temperature/Humidity requirements in the equipment room
Table 2-2 Requirement on dust content in the equipment room
Table 2-3 Limits on harmful gas contents in the equipment room
H3C VG 31-08 Voice Gateway (hereinafter referred to as VG 31-08) is a new-generation access device intended for enterprise and small office, home office (SOHO) users. It integrates the access of voice, fax, and data signals over Internet protocol (IP) networks, functioning to transform analog voice or fax signals to IP data and forward the data.
The VG 31-08 provides abundant IP telephony features, such as one-to-one FXS-FXO port binding, emergency function, Voice over IP (VoIP), Fax over IP (FoIP), call control, resource management, and maintenance management, as well as multiple coding schemes. It also supports DHCP Client, boasting excellent price/performance ratio.
The VG 31-08 provides eight foreign exchange station (FXS) ports, foreign exchange office (FXO) ports and one Ethernet interface. FXS ports are used to connect analog telephones; FXO ports are used to connect private branch exchanges (PBXes) through trunk lines; the Ethernet interfaces are used to connect to the Internet.
Item |
Fixed interfaces |
One console port Eight FXO ports Eight FXS ports One Ethernet interface |
Boot ROM |
512 KB |
SDRAM |
64 KB (default) 128 MB (maximum) |
Flash memory |
8 MB |
Physical dimensions (H ´ W ´ D) |
42 ´ 436 ´ 360 mm (1.7 ´ 17.2 ´ 14.2 in.) |
Weight |
5 kg (11.0 lb) |
Input voltage |
Rated voltage: 100 VAC to 240 VAC, 50/60 Hz Max. voltage: 90 VAC to 264 VAC, 47/63 Hz |
Max. power consumption |
35 W |
Working temperature |
Operating temperature |
0°C to 40°C (32°F to 104°F) |
Non-operating temperature |
–40°C to +70°C (–40°F to +158°F) |
Operating relative humidity (noncondensing) |
10% to 90% |
Non-operating relative humidity (noncondensing) |
5% to 95% |
& Note:
l Synchronous dynamic random access memory (SDRAM) is where the host applications are running.
l Flash memory stores programs and configuration files.
The VG 31-08 has 19 LEDs in total as described in the following figure.
(1) PWR LED |
(2) Fan LED |
(3) FXO LEDs (0 to 7) |
(4) FXS LEDs (0 to 7) |
(5) Ethernet interface LED |
LED |
PWR |
OFF indicates the VG 31-08 is not powered on. ON means the VG 31-08 is powered on. |
FAN |
ON indicates the fan is running normally. OFF means the fan is not running normally. |
FXO 0 to 7 |
ON indicates there is a call. |
FXS 0 to 7 |
OFF indicates that no LAN link is present. ON indicates a LAN link is present. Fast blinking indicates data is being sent and/or transmitted on the Ethernet interface. |
The VG 31-08 provides one console port, one 10/100 Mbps Ethernet interface, FXS ports and FXO ports. The following subsections describe the attributes of these ports.
Attribute |
Connector |
RJ-45 |
Number of connectors |
1 |
Cable |
Console cable |
Interface standard |
RS232 |
Baud rate |
9600 bps (default) to 115200 bps |
Services |
Connection to an ASCII terminal Connection to a serial port on a local PC to run terminal emulation program on the PC |
Attribute |
Connector |
RJ-45 |
1 |
Cable |
Straight-through cable, crossover cable |
Frame format |
Ethernet_II Ethernet_SNAP |
Operating mode |
10/100 Mbps auto-sensing Full duplex/Half duplex auto-sensing |
Network protocol |
IP |
Attribute |
Connector |
RJ-11 |
Number of ports |
8 |
Cable |
Telephone cable |
Subscriber circuit interface compliant with ITU Q.552 Overcurrent and overvoltage protection compliant with ITU K.20 |
Dial-up mode |
Supports GB3378-compliant DTMF instead of pulse dialup |
Frequency |
300 Hz to 3400 Hz |
Attribute |
Connector |
RJ-11 |
8 |
Cable |
Telephone cable with ferrite bead |
Trunk interface of the loop compliant with ITU Q.552 Overcurrent and overvoltage protection compliant with ITU K.20 |
Dial-up mode |
Bandwidth |
300 Hz to 3400 Hz |
The VG 31-08 is intended for indoor use only. To ensure normal operation and longevity of your device, install it in an environment that meets the requirements below.
You must keep the temperature and humidity in the equipment room within a certain range. Long-term high humidity will lead to bad insulation or even electricity leakage, mechanical property change, and corrosion. However, too low relative humidity is likely to leave captive screws loose due to contraction of insulation washers and static electricity that threatens the CMOS circuit on the device. High temperature accelerates aging of insulation materials and lowers reliability and service life of your VG 31-08.
The following table lists temperature and humidity requirements for the VG 31-08.
Temperature |
Relative humidity |
10% to 90% |
Max. particle size (mm) |
0.5 |
1 |
3 |
5 |
Max. concentration (number of particles per cubic meter) |
1.4×107 |
7×105 |
2.4×105 |
1.3×105 |
Besides dust, there are rigorous limits on harmful gases that can accelerate erosion and aging of metals, such as salts, acids, and sulfides, as shown in the following table.
Gas |
Average (mg/m3) |
Maximum (mg/m3) |
SO2 |
0.2 |
1.5 |
H2S |
0 |
0.03 |
NO2 |
0.04 |
0.15 |
NH3 |
0.05 |
0.15 |
Cl2 |
0.01 |
0.3 |
Although VG 31-08 is designed to be electrostatic discharge (ESD) preventive, it may be damaged by excessive static electricity.
Static electricity affecting the VG 31-08 and the related network mainly comes from outdoor electric fields caused by high-pressure power cables or thunder and lightning, as well as indoor environment, materials and device structure. To prevent ESD damage, observe the following:
l Ensure the unit and the floor is connected to earth ground.
l Keep the equipment room clean.
l Maintain suitable temperature and humidity.
l Wear an ESD-preventive wrist strap and uniform when handling the circuit board.
l Place the removed circuit board on an ESD-preventive workbench or in an antistatic bag right-side up.
l Hold the removed circuit board only by its edge when observing or moving it. Do not touch the components on it.
Warning:
There is an anti-dismantle seal on a screw on the chassis. You must keep the seal intact before your agent maintains your VG 31-08. H3C is not liable for any damage or consequence resulted from users' operation without permission.
Any possible interference source, whether from inside or outside the device, impacts the VG 31-08 negatively in the form of capacitive coupling, inductive coupling, electromagnetic radiation, or common-impedance (including the grounding system) coupling. To resist the interference, make sure to:
l Take effective measures against the interference caused by the electrical power grid.
l Use a grounding system or lightning protection grounding different from that for the power supply system and keep them as far as possible.
l Keep the device far from radio transmitting station, radar station, and high-frequency high-current devices.
l Use electromagnetic shielding when necessary.
Although the VG 31-08 is designed to be lightning resistant, excessive lightning interference can damage your device. To protect your device against lightning,
l Ensure the chassis is connected to earth ground.
l Ensure the earth point of the power socket is well connected to earth ground.
l Add a lightning arrester to the front end of the power input to better protect the power supply against lightning strikes.
When installing the VG 31-08, make sure that:
l There is adequate clearance around the air exhaust vents for ventilation.
l The rack/workbench/tabletop has a good ventilation system.
l The rack/workbench/tabletop is firm enough to support the device and its accessories.
l The rack/workbench/tabletop is well earthed.
Be sure that you observe all safety precautions when you install your device and pay special attention to the following icons:
Warning appears in operations
that, if performed incorrectly, might cause bodily injury or equipment damage.
Caution means care must be taken
in these operations during installation and use. Incorrect operations may
result in abnormal running of the device.
Observe these safety precautions when installing and using the VG 31-08:
l Keep the device far away from any heat source.
l Make sure that the device is connected to earth ground.
l Wear an ESD-preventive wrist strap when installing and maintaining the device, and ensure that the strap is in good contact with your skin.
l Do not hot-swap any cable.
l Correctly connect interface cables. Be careful not to misconnect the telephone cable to the Ethernet interface.
l You are recommended to use uninterrupted power supply (UPS) for your device.
l ESD-preventive wrist strap
l Grounding cable and power cord
l Console cable
l Ethernet cable
l Telephone cable
l Hub or Ethernet switch
l Telephone or PBX
l Configuration terminal (or PC)
l Multimeter
Caution:
The installation tools, meters, and devices are not provided with the VG 31-08.
You can install your device in a standard 19-inch rack or on a workbench/tabletop.
Place the VG 31-08 on a clean and flat workbench/tabletop. To prevent any damage, observe the following:
l Ensure the workbench/tabletop is stable enough.
l Allow 10 cm (3.9 in.) of clearance around the VG 31-08.
l Do not stack the VG 31-08 on any other equipment.
The VG 80-20 is designed with the following dimensions to be mounted in a standard 19-inch rack:
H × W × D = 42 × 360 × 436 mm (1.7 × 14.2 × 17.2 in.) (without feet)
Follow these steps to install the VG 80-20 (see Figure 3-2):
Step 1: Ensure that the rack is stable enough and properly grounded. Attach the rack-mount brackets to the front or rear of the chassis with screws.
Step 2: Place the VG 31-08 on a shelf in the rack and slide it to a proper position along the guide rails.
Step 3: Fix the rack-mount brackets to the rack posts with suitable antirust pan-head screws. Make sure that the device is in level position and securely fixed.
(1) Screws (4) |
(2) Rack-mount bracket |
(3) Guide rail |
Warning:
Properly connect the grounding cable before connecting other cables and shorten the grounding cable as much as possible to protect the VG 31-08 and the peer device against lightning strikes.
The AC input end of the VG 31-08 is connected to an AC noise filter whose neutral point is connected to the chassis directly, thus forming a protection ground (PGND). The PGND must be connected to earth ground properly to safely channel the faradic current and leakage current to the ground and to make the whole device less susceptible to electromagnetic interference (EMI). The lightning high voltage introduced from the exterior network is also channeled to the ground through the grounding cable.
The grounding screw of PGND is located on the rear panel. Connect this screw to earth ground using a grounding cable. The grounding resistance should not be greater than 5 ohm.
The VG 31-08 provides a console port, through which you can configure the device.
The console cable is an 8-core shielded cable. At one end of the cable is an RJ-45 connector that can be plugged to the console port of the VG 31-08; at the other end is a DB9 (female) connector, which can be plugged to the serial port of the console terminal.
The following figure illustrates a console cable:
When configuring the VG 31-08 through a console terminal, follow these steps to connect the console cable:
Step 1: Select a console terminal.
The console terminal can be either a standard ASCII terminal with an RS232 serial port or more commonly, a PC.
Step 2: Connect the cable.
Power down the console terminal, and then connect the RS232 serial port on the console terminal to the console port on the VG 31-08 through the console cable.
For a 100BASE-TX Ethernet interface, you can use a category-5 twisted pair cable, as shown in the following figure:
Ethernet cables fall into two types: straight-through (standard) and crossover. Use a crossover cable if you are connecting the voice gateway to a PC or router; use a straight-through cable if you are connecting the device to a Hub or an Ethernet switch.
& Note:
When preparing network cables, use shielded cables preferentially for the sake of electromagnetic compatibility.
Caution:
Read the mark above the interface carefully to avoid misconnection.
Follow these steps to connect the Ethernet cable:
Step 1: Insert one end of the Ethernet cable to the Ethernet port of the VG 31-08 and connect the other end to a hub, an Ethernet switch, or a router.
Step 2: Check that the LINK LED on the front panel is ON. ON means the network cable is correctly connected.
The VG 31-08 can connect dual-tone multi-frequency (DTMF) phones through its eight telephone ports. You may simply connect the FXS ports of the VG 31-08 with the telephone through the telephone cable.
& Note:
You are recommended to set the telephone to DTMF mode, as the VG 31-08 does not support pulse dialing; otherwise, you cannot place calls with the telephone.
The cables used for connecting FXO ports are telephone cables with ferrite bead and RJ-11 connectors at both ends. You can simply connect the VG 31-08 to a PBX through the telephone cable.
The VG 31-08 uses a built-in power supply with these specifications:
Rated voltage: 100-240 VAC; 50/60 Hz
Max. voltage: 90-264 VAC; 47/63 Hz
You are recommended to use a 3-core single-phase power socket with neutral point. The neutral point of the socket must be grounded reliably. Normally, the neutral point of the power supply system in a building was buried in the ground during construction and cabling. Before you connect the AC power cord, make sure that the power supply system in the building has been well grounded.
Step 1: Connect one end of the power cord to the AC-input socket on the VG 31-08 and the other end to the AC power outlet.
Step 2: Power up the VG 31-08.
Step 4: Check that the PWR LED on the front panel is ON, which means the power connection is correct.
Caution:
Normally, the startup information is displayed on the terminal screen after you power on the VG 31-08. For more information, refer to section 4.1.3 “Startup Process”.
Each time before you power up the VG 31-08 during installation, verify that:
l Enough clearance has been reserved around the VG 31-08 for ventilation, and the tabletop/workbench is stable enough.
l Proper power supply is used.
l The grounding cable has been correctly connected.
l The VG 31-08 has been correctly connected to other devices, such as a console terminal.
Caution:
Installation verification is extremely important, because operations of the VG 31-08 depend on its stability, grounding, and power supply.
As shown in Figure 4-1, connect the RJ-45 connector of the console cable to the console port on the VG 31-08, and the DB9 connector to the serial port on the PC.
Step 1: Start the PC and select [Start/Programs/Accessories/Communications/HyperTerminal].
Step 2: The HyperTerminal window displays the Connection Description dialog box, as shown in Figure 4-2.
Step 2: Enter the name of the new connection in the Name field and click <OK>. The dialog box, as shown in Figure 4-3, displays.
Step 4: Select the serial port to be used from the Connect Using dropdown menu. The serial port must be the same port connected by the console cable.
Step 5: Click <OK>. The Port Settings tab, shown in Figure 4-4, appears and you can set the serial port parameters. Set the following parameters:
l Bits per second = 9600
l Data bits = 8
l Parity = None
l Stop bits = 1
l Flow control = None
Step 6: Click <OK>. The HyperTerminal dialog box appears.
Step 7: Select Properties.
Step 8: In the H3C Properties dialog box, select the Settings tab, as shown in Figure 4-5.
Step 9: Select VT100 or Auto detect in the Emulation dropdown menu.
Step 10: Click <OK>.
Before powering up the VG 31-08, verify that:
l Both the power cord and the grounding cable are correctly connected.
l The console cable is correctly connected. The console terminal (or PC) has been started and the related parameters have been set on it.
Warning:
Locate the power switch in the room before powering up the VG 31-08. Then, if an accident occurs, you can quickly shut off the power.
After powering up the VG 31-08, check to ensure that:
l The LEDs on the VG 31-08 front panel are in normal state.
l The console terminal display is correct.
After powering up the device, you can see the startup interface on the console terminal (refer to section 4.1.3 “Startup Process”). After the system passes power-on self-test (POST), press <Enter> as prompted. When the command line prompt “[VG]” is displayed, you can proceed to configure the VG 31-08.
After being powered up, the VG 31-08 first runs the Boot ROM program. The following system information will be displayed on the terminal screen.
& Note:
The contents displayed on the terminal could vary with different Boot ROM versions.
* H3C Voice Gateway Bootrom, Version 1.04 *
Copyright(c) 2004-2006 Hangzhou H3C Tech. Co., Ltd.
Creation date : Jan 7 2006, 11:59:55.
Testing memory...OK!
64M bytes SDRAM
8192k bytes Flash Memory
Hardware Version is MTR 2.0
CPLD Version is CPLD 1.0
Bootrom Version is 1.04
Press Ctrl-B to enter Boot Menu
Press <Ctrl+B> right away to enter the boot menu. Otherwise, the system starts decompressing the software.
& Note:
After “H3C Voice Gateway Boot ROM, V1.04” appears, “Voice Gateway starts booting ... ” disappears immediately.
To enter the boot menu, you should press <Ctrl+B> within eight seconds after the prompt “Press Ctrl-B to Enter Boot Menu…” appears.
The system displays:
Press ENTER key to get started when you see ATS0=1.
System is starting...ATS0=1
Press <Enter>, and the system displays:
[VG]
This prompt means that the VG 31-08 enters system view and is ready for configuration.
Following are the basic steps that you can follow to configure you VG 31-08.
Step 1: Figure out networking requirements.
Step 2: Draw a networking topology based on the requirements.
Step 3: Configure voice parameters according to the requirements.
Step 4: Configure routes and other features.
For more information on the configuration related to protocols and functions for the VG 31-08, refer to H3C VG Series Voice Gateways Operation Manual.
The VG series voice gateways provide the command line interface (CLI), which allows you to implement hierarchical protections against unauthorized users. In system view, all the commands are put into different groups for the convenience of management, each group being associated to a view. You can switch between the views by executing particular commands. In normal circumstances, you can only execute the commands appropriate to the view that you access. However, you are allowed to execute in any view some common commands, such as ping, display, and interface. The CLI offers a series of configuration commands for you to configure and manage your voice gateway. It allows you to:
l Configure the device locally through the console port.
l Telnet to configure the voice gateway locally or remotely, and then telnet to access and manage other devices.
l Assign different users with different levels (guest, operator, and administrator) to prevent unauthorized users. Only administrator users are allowed to configure and manage the voice gateway.
l Get on-line help whenever you enter ?.
l Refer to the prompts and help information presented in English.
l Test network connectivity quickly with network diagnostic tools, such as tracert and ping.
l Have detailed debugging information to troubleshoot your network.
l Enter the non-conflicting keyword instead of the whole command for searching, because the CLI supports command prompting. For example, you can simply enter dis to search for the display command.
VG series voice gateways provide Web-based configuration, which is more direct and more convenient to use for primary or common users, compared to command lines configuration. Web-based configuration supports:
l Parameters settings for basic system functions, like Ethernet interface, static routing, and so on.
l Parameter settings for basic voice features.
l User login authentication for security.
l Telnet link on the Web-based configuration page, so that users can access the device through Telnet.
l Bilingual display in English and Chinese.
For details, refer to H3C VG Series Voice Gateways Web-based Configuration Manual
The VG 31-08 maintains three types of files:
l Boot ROM program files
l Application files
l Configuration files
Software maintenance of the VG 31-08 mainly involves upgrading/downloading Boot ROM and application program files, as well as uploading/downloading configuration files.
This section introduces the boot menu that you use when maintaining the software of the VG 31-08.
Set up a configuration environment (see Figure 4-1) and then boot the VG 31-08. The console terminal displays:
64M bytes SDRAM
Press <Ctrl+B>, and the system prompts:
Please input Bootrom password :
Caution:
l Press <Ctrl+B> within eight seconds to access the boot menu after the prompt “Press Ctrl-B to Enter Boot Menu...” appears. Otherwise, the system starts decompressing the software.
l To access the boot menu after the system starts decompressing the program, you need to reboot the device.
Input the correct password and press <Enter>. (If no Boot ROM password has been set, just press <Enter>.) The system accesses the boot menu shown as follows:
Boot Menu:
1: Download application program with XMODEM
2: Download application program with NET
3: Clear configuration
4: Start up and ignore configuration
5: Bootrom Operation Menu
6: Do not check the version of the software
7: Exit and reboot
Enter your choice(1-7):
Options in the boot menu are described as follows:
1: Download the application program with XModem. Refer to section 5.2 “Upgrading Application and Boot ROM Programs Using XModem” for details.
2: Download the application program through the Ethernet.
3: Clear the configuration files.
4: Ignore the configuration file and start up with the initial configurations.
5: Enter the Boot ROM submenu.
6: Do not check the software version of the extended segment of Boot ROM (this option is provided for backward compatibility in version upgrade).
7: Exit the boot menu and reboot the VG 31-08.
The following sections describe the two software upgrading methods provided in the boot menu and the operations in the Boot ROM submenu.
Caution:
You are recommended to upgrade the software under the guidance of technical support engineers. In addition, when upgrading the VG 31-08, make sure the version of the Boot ROM software is consistent with that of the application software.
You can use the console port to upgrade the software through XModem without the need of setting up a configuration environment..
Step 1: Enter the boot Menu (refer to section 5.1 “Boot Menu”) and enter 1 to download an application program through XModem. The VG 31-08 supports the following downloading rates:
Please choose your download speed:
1: 9600 bps
2: 19200 bps
3: 38400 bps
4: 57600 bps
5: 115200 bps
6: Exit to Main Menu
Enter your choice(1-6):
Step 2: Select an appropriate downloading rate, (for example, 115200 bps by entering 5). The system displays:
Download speed is 115200 bps. Change the termin,and select XMODEM protocol. Press <Enter> key when ready.
Step 3: Change your terminal’s baud rate (see Figure 4-4) to the same baud rate for software downloading (115200 bps in this example). After that, disconnect the terminal ([Dial-in/Disconnect]), reconnect it ([Dial-in/Dialing]), and press <Enter> to start downloading. The system displays:
Now Downloading Program File.
Please Start Transfer Program File And Use Xmodem Protocol.
If You Want To Exit. Press <Ctrl+X>.
Downloading ... CCCCC
& Note:
The new baud rate takes effect only after you disconnect and reconnect the terminal emulation program.
Step 4: Select [Transmit/Send file] in the terminal window. The following dialog box pops up:
Step 5: Click <Browse>, select the application file to be downloaded, set the protocol to XModem, and click <Send>. The following interface pops up:
Step 6: After completing the downloading, the system begins writing data to the Flash memory and then displays the following information in the terminal interface, indicating the completion of the downloading:
Download completed.
Writing to flash memory...
Please wait,it needs a long time .Please wait...
Writing into Flash Succeeds..
Please use 9600 bps.Press <ENTER> key to reboot the system.
Restore the speed of the console terminal to 9600 bps as prompted, disconnect and reconnect the terminal. The system starts up normally.
The Boot ROM program includes a basic segment and extended segment. The full Boot ROM upgrade program provided for the user includes both segments, while the extended segment upgrading program only includes the extended segment of the Boot ROM program. If an error occurs during the upgrade of the full Boot ROM program, the system may fail to start after the upgrade, and special equipment must be used to repair the system. However, if an error occurs during the upgrade of the extended segment, you can repair the system through some simple methods. Therefore, try to avoid upgrading the full Boot ROM program if an upgrade of the extended segment suffices.
Step 1: Enter the boot menu (refer to section 5.1 “Boot Menu”), and enter 5 to enter the Boot ROM submenu.
Bootrom Download Menu:
1: Download Bootrom with XModem
2: Download Extended Segment of Bootrom with XModem
3: Restore Extended Segment of Bootrom from FLASH
4: Backup Extended Segment of Bootrom to FLASH
5: Exit to Main Menu
Enter your choice(1-5):
Step 2: Enter 1 to download the Boot ROM program through XModem. The VG 31-08 provides several speed options. The subsequent operation steps are the same as those described in section 5.2.1 “Upgrading the Application Program”.
Caution:
You cannot restore the Boot ROM program on site if you fail to upgrade the full Boot ROM program. Therefore, you are recommended not to upgrade the full Boot ROM program unless necessary and under the direction of technical support engineers.
Step 1: Enter the boot menu (refer to section 5.1 "Boot Menu”), and enter 5 to enter the Boot ROM submenu, as shown in section 5.2.2 “Upgrading the Full Boot ROM Program”.
Step 2: Enter 2 in the Boot ROM submenu to upgrade the extended segment of Boot ROM program through XModem. The VG 31-08 provides several rate options. The subsequent operation steps are the same as those described in section 5.2.1 “Upgrading the Application Program”.
& Note:
This upgrade approach is only used to upgrade a portion of the Boot ROM program, so you may make a second attempt once an error occurs.
Follow these steps to back up the Boot ROM program.
Step 2: Enter 4 in the Boot ROM submenu to copy the current extended segment of the Boot ROM program to Flash memory.
If the backup attempt is successful, the following message appears:
Please wait, it may take a long time####
Backuping Bootrom program to FLASH successed!
Step 3: When the Boot ROM submenu appears again, enter 5 to exit and reboot the VG 31-08.
If faults occur to the extended segment of the Boot ROM program or you upgrade it wrongly, you can restore the extended segment saved in the Flash memory to the Boot ROM by following these steps:
Step 2: Enter 3 in the Boot ROM submenu to restore the extended segment of the Boot ROM program from the Flash memory.
If the operation is successful, the system displays:
Please wait, it may take a long time######
Restoring Bootrom program successed!
If an error has occurred during the upgrade of the Boot ROM extended segment, and you are not able to enter the related menus by pressing <N> or <Ctrl+B> when the system boots, you can press <Ctrl+D> to enter the Boot ROM menu and reload the Boot ROM extended segment program or restore the program previously backed up.
Follow these steps:
Step 1: Press < Ctrl+D> to enter the Boot ROM menu.
When the VG system boots, the system prompts “Voice Gateway starts booting ...”. If you press <Ctrl+D> at this moment, the system will display:
Input the correct password and then press <Enter> (If no Boot ROM password has been set, directly press <Enter>). The system will display the boot menu, as follows:
Boot Menu:
1: Download Extended Segment of Bootrom with XModem
2: Modify Bootrom password
3: System booting from Flash
4: Do not check the version of Extended Segment of Bootrom
5: Exit and reboot
Options of the boot menu are described below:
1: Download the extended segment of Boot ROM with XModem;
2: Modify the Boot ROM password;
3: Load the Boot ROM program previously backed up to the Flash memory;
4: Do not check the version of the extended segment of Boot ROM (this option is provided for backward compatibility in version upgrade);
5: Exist the boot menu and reboot the VG 31-08.
Step 2: Enter 1 to reload the extended segment of Boot ROM, or enter 3 to boot from the Boot ROM backed up to the Flash memory.
The VG 31-08 supports application program upgrade using TFTP. The steps of application program upgrade using TFTP are as follows:
Step 1: Connect the Ethernet interface to a PC using a crossover cable.
Step 2: Connect the console port of the VG 31-08 to an external console terminal (it can be an external PC connected to the Ethernet interface), and configure HyperTerminal with reference to section 4.1.1 II. “Setting terminal parameters”.
Step 3: Install the TFTP Server on the PC.
& Note:
The VG 31-08 does not provide the TFTP Server program, and you should purchase and install it by yourself.
Step 4: Copy the new application file to a directory, “C:\H3C” for example.
Step 5: Configure the IP address for the fast Ethernet (FE) interface on the PC, 10.110.10.13 for example.
Step 1: Run the TFTP Server on the PC.
Step 2: Specify a directory for the new application program.
Step 1: Boot the VG 31-08 and press <N> upon appearance of the message “Voice Gateway starts booting ... ”. The system displays the following message:
(M)odify any of Voice Gateway configuration or (C)ontinue? [M]
Press <Enter>. The following message appears:
For each of the following questions, you can press <Return> to select the value shown in braces, or you can Enter a new value.
& Note:
For the displayed messages that ask for your interaction, you can press <Enter> to adopt the default value in the brackets ([]), or input the desired value.
Step 2: Configure TFTP parameters.
NETWORK INTERFACE PARAMETERS:
Configure the network interface parameters for the VG 31-08, including the port to be used, its IP address and the subnet mask.
Do you want a LAN interface? [N] y
This board's LAN IP address? [169.254.10.10]10.110.10.10
Subnet mask for LAN (0 for none)? [255.255.0.0]
TFTP SERVER PARAMETERS:
Configure the TFTP Server parameters, including the IP address of the Ethernet interface on the PC, the filename of the application program, and CPU delay.
IP address of the TFTP server? [169.254.75.166]10.110.10.13
What is the name of the file to be loaded and started? [VG20X.BIN]
How long (in seconds) should CPU delay before starting up? [5]
Caution:
l The IP address in “IP address of the TFTP server ? [10.110.10.13]” must be the IP address of the PC connected to the FE port of the VG.
l The IP address and subnet mask set in “This board's LAN IP address(0.0.0.0 = RARP)? [10.110.10.10], Subnet mask for LAN (0 for none)? [255.255.0.0]” must be the IP address and subnet mask of LAN0.
l The IP addresses of the PC network interface and the LAN port of the VG 31-08 must reside in the same network segment.
Step 3: Confirm parameter settings.
After you enter the last parameter, the system displays the following information and requests you to confirm the parameter settings:
IP address on LAN is 10.110.10.10
LAN interface's subnet mask is 0xffffff00
HARDWARE PARAMETERS:
Processor type is MPC852T
Internal Clock Rate 100 Mhz
External Clock Rate 50 Mhz
Serial channels will use a baud rate of 9600
IP address of the TFTP host is 10.110.10.13
The file to download and start is VG20X.BIN
After board is reset, start-up code will wait 5 seconds
(M)odify any of this or (C)ontinue? [M]
Press <C> to confirm the configurations.
Step 1: Boot the system and enter the boot menu.
Step 2: Enter 2 in the boot menu to download the application program using TFTP. The following message appears:
Download application program, are you sure?[Y/N]Y
If the PC running the TFTP Server is ready, press <Y> to download the program.
Starting the TFTP download...
After the downloading is completed, the system displays:
TFTP download completed...
read len = [06031367]
Please wait, it may take a long time...
Writing FLASH Success.
Press <Enter> key to exit to Main Menu .
Press <Enter> to reboot the system.
The VG 31-08 can act as an FTP server, providing another way for users to update the configuration file and upgrade the application and Boot ROM program. Any FTP client (local or remote) connected to the VG 31-08 can update configuration files or upgrade application/Boot ROM program using FTP. After passing the authentication, you can update the configuration file or upgrade the application/Boot ROM program, as described below.
& Note:
l Uploading is to transfer files from an FTP client to the VG, that is, the “put” operation.
l Downloading is to transfer files from the VG to an FTP client, that is, the “get” operation.
l Setting up an environment for local uploading/downloading through FTP
Step 1: Connect the VG 31-08 to a PC with an Ethernet cable.
Step 2: Assign an IP address, 10.110.10.13 for example, to the FE interface on the VG 31-08.
Step 3: Assign an IP address, 10.110.10.10 for example, to the Ethernet interface on the PC.
Step 4: Copy the application/Boot ROM program/configuration file to the destination directory, “C:\version” for example.
Caution:
The IP addresses assigned to the interfaces on the PC and the VG 31-08 must reside on the same network segment.
l Setting up an environment for remote uploading/downloading through FTP
Step 1: Connect the PC and the VG 31-08 to the Internet respectively, and make sure that the PC and the VG are accessible to each other.
Step 2: Copy the application/Boot ROM program/configuration file to the destination directory, “C:\version” for example.
Step 1: Set an authentication method.
& Note:
You can make AAA configurations as needed. For information about related operations, refer to H3C VG Series Voice Gateways Operation Manual.
Step 2: Add a username and its password.
[VG] local-user H3C password simple 123 service-type ftp
“H3C” is the username and “123” is the password.
Step 3: Start the FTP server.
[VG] ftp-server enable
After the FTP server is enabled and the user is added on the VG 31-08, any FTP client can log onto the FTP server with the username and password.
Step 1: Change to the directory containing the application/Boot ROM program/configuration file in the MS-DOS command prompt window. Carry out the ftp command to set up an FTP connection with the VG 31-08. For example:
C:\version>ftp 10.110.10.13
If the connection is successfully set up, the following information appears (taking Windows 98 for example):
Connected to 10.110.10.13
220 FTP server ready on Voice Gateway at
User(10.110.10.13:(none)):
Step 2: Log on to the FTP server using the username and password set on the VG 31-08.
User(10.110.10.13:(none)): H3C Input the user name
331 Password required for ftp
Password: Input the password (the password is not echoed on the screen)
230 User H3C logged in
ftp>
When the “ftp>” prompt appears, you can proceed with the uploading/downloading.
Step 3: Upload/download the application/Boot ROM program/configuration file.
& Note:
On the VG 31-08, the default file names are as follows:
l Application program: system
l Configuration file: config
l Extended segment of the Boot ROM program: bootrom
l Full Boot ROM program: bootromfull
l Upload the application/Boot ROM program/configuration file
ftp> put Input put to perform uploading.
local file Input the name of the application/Boot ROM program/configuration file to be uploaded.
remote file Input the name used to save the application/Boot ROM program/configuration file to be uploaded on the VG.
Upon the completion of the uploading, the “ftp>” prompt appears again. Enter dir to view the names and sizes of the uploaded files on the VG 31-08. The configuration file has the same size as that of the original file on the host if the uploading is successful.
l Download the application/Boot ROM program/configuration file
ftp> get Input get to perform downloading.
remote file Input the name of the application/Boot ROM program/configuration file on the VG.
local file Input the name used to save the application program/Boot ROM program/configuration file locally.
Step 4: Upon completion of uploading/downloading, quit the FTP client program.
ftp>quit Enter quit to terminate the ftp connection.
If you have lost the VG 31-08 Boot ROM password or a user password, use one of the following methods:
Step 1: Enter the boot menu and enter 3 to clear the system configuration.
Clear config, are you sure?[Y/N]y
Press <Y>. The system displays the following message to indicate the system configuration has been erased:
Erasing...Success!
Step 2: When the boot menu appears again, enter 7 to from the boot menu.
Exit and reboot, are you sure?[Y/N]y
Press <Y>. The system displays:
System is rebooting now...
Step 3: Configure a new user password in system view after the VG reboots.
[VG] local-user h3c password simple 123 service-type administrator
“h3c” is the username, “123” is the new user password, and “administrator” means that it is a super user password.
Step 4: Save the new configurations.
[VG] save
& Note:
It is required to carry out the save command to save the new password.
Step 1: Enter the boot menu and enter 4 to start the system while ignoring configurations.
Boot Menu:
7: Exit and reboot
Enter your choice(1-7): 4
Start up and ignore configuration, are you sure?[Y/N]y
Press <Y>. The system displays the following message to indicate the current system configurations has been saved:
Saving...Success!
Boot Menu:
7: Exit and reboot
Enter your choice(1-7): 7
Step 2: When the boot menu appears again, enter 7 to exit the boot menu.
Step 3: Configure a new user password in system view after the VG 31-08 reboots.
& Note:
After being rebooted, the system starts with the default configurations, but the last configuration file is still saved in the Flash memory. To restore the last configurations, you can use the display saved-configuration command to display the configurations, and then copy and apply them.
[VG] save
& Note:
It is required to execute the save command to save the new password.
Contact your agent if you have lost the Boot ROM password, so that support engineers will help you access the VG 31-08 to set a new password.
1) Symptom:
The PWR LED is OFF.
2) Solution:
Check to make sure that:
l The power switch on the VG 31-08 is turned on.
l The power cord is connected correctly.
l Correct mains supply is used.
Caution:
Do not hot-swap the power cord. Contact your agent if the PWR LED is still OFF after the above items are confirmed.
If the system operates normally after being powered up, it displays the start-up information on the console terminal. If the configuration system has failed, it displays illegible characters or nothing at all.
1) Symptom:
The powered-up VG 31-08 displays nothing on the console terminal.
2) Solution:
Step 1: Check whether the power system is operating normally and the console cable is connected correctly.
Step 2: If you cannot locate the problem yet, check the console cable and the terminal (e.g., HyperTerminal) parameter settings.
1) Symptom:
The powered-up VG 31-08 displays illegible characters on the console terminal.
2) Solution:
Make sure you have set the following parameters on your terminal (HyperTerminal):
l Baud rate = 9600
l Data bits = 8
l Parity = none
l Stop bits = 1
l Flow control = none
l Terminal emulation = VT100 or Auto detect
Reconfigure the parameters if their values are different.
