H3C VG 31-08 Voice Gateway Installation Manual(V1.00)
DownLoad Chapters Download(297 KB)
00-1Cover
Installation Manual
Hangzhou H3C Technology Co., Ltd
http://www.huawei-3com.com
Manual Version: T2-08042Y-20060707-C-1.00
Copyright © 2006, Hangzhou H3C Technology Co., Ltd. and its licensors
All Rights Reserved
No part of this manual may be reproduced or transmitted in any form or by any means without prior written consent of Hangzhou H3C Technology Co., Ltd.
Trademarks
H3C, Aolynk, , IRF, H3Care, , Neocean, , TOP G, SecEngine, SecPath, COMWARE, VVG, V2G, VnG, PSPT, NetPilot, and XGbus are trademarks of Hangzhou H3C Technology Co., Ltd.
All other trademarks that may be mentioned in this manual are the property of their respective owners.
Notice
The information in this document is subject to change without notice. Every effort has been made in the preparation of this document to ensure accuracy of the contents, but all statements, information, and recommendations in this document do not constitute the warranty of any kind, express or implied.
To obtain the latest information, please access:
http://www.h3c.com
Technical Support
[email protected]
http://www.h3c.com
About This Manual
Related Documentation
In addition to this manual, each H3C VG Series Voice Gateways documentation set includes the following:
Manual
Content
H3C VG Series Voice Gateways ?Operation Manual
It provides guidelines to user operations on the H3C VG Series Voice Gateways.
H3C VG Series Voice Gateways ?Command Manual
It provides all commands available in the H3C VG Series Voice Gateways as well as the command usage and examples.
H3C VG Series Voice Gateways? Web-based Configuration Manual
It provides guidelines to Web-based configuration on the H3C VG Series Voice Gateways.
Organization
H3C VG 31-08 Voice Gateway Installation Manual is organized as follows:
Chapter
1 Product Overview
Profiles the core technology and hardware features.
2 Installation Preparations
Focuses on the site requirements, precautions, and tools for installation.
3 Installing the VG 31-08
Elaborates on the installation flowchart and how to install H3C VG 31-08 Voice Gateway.
4 Booting and Configuring the VG 31-08
Presents booting and configuration fundamentals of H3C VG 31-08 Voice Gateway including setting up, powering up the device, and basic configuration procedures.
5 Software Maintenance
Lists the way to maintain the software of H3C VG 31-08 Voice Gateway.
6 Troubleshooting
Introduces possible symptoms and the solutions to them.
Conventions
The manual uses the following conventions:
I. Command conventions
Convention
Boldface
The keywords of a command line are in Boldface.
italic
Command arguments are in italic.
Items (keywords or arguments) in square brackets [ ] are optional.
{ x | y | ... }
Alternative items are grouped in braces and separated by vertical bars. One is selected.
[ x | y | ... ]
Optional alternative items are grouped in square brackets and separated by vertical bars. One or none is selected.
{ x | y | ... } *
Alternative items are grouped in braces and separated by vertical bars. A minimum of one or a maximum of all can be selected.
[ x | y | ... ] *
Optional alternative items are grouped in square brackets and separated by vertical bars. Many or none can be selected.
A line starting with the # sign is comments.
II. GUI conventions
Convention
Button names are inside angle brackets. For example, click <OK>.
Window names, menu items, data table and field names are inside square brackets. For example, pop up the [New User] window.
Multi-level menus are separated by forward slashes. For example, [File/Create/Folder].
III. Symbols
Convention
? Warning
Means reader be extremely careful. Improper operation may cause bodily injury.
? Caution
Means reader be careful. Improper operation may cause data loss or damage to equipment.
&? Note
Means a complementary description.
Environmental Protection
This product has been designed to comply with the requirements on environmental protection. For the proper storage, use and disposal of this product, national laws and regulations must be observed.
H3C reserves the right to modify its collaterals without any prior notice. For the latest information of the collaterals, please consult H3C sales or call 400 hotline.
