Access the Linux host from a console or through SSH.
Create a file folder.
[root@testmanila-1 ~]# mkdir nfs
Mount a file share to the host.
[root@testmanila-1 ~]# mount -t nfs 172.25.20.246:/NAS/CAPFS/data/share-fac2bf0d-2505-45cb-b72e-a6ddcc9c8297 nfs
Verify that the mounting succeeded.
[root@testmanila-1 ~]# df -h
Filesystem Size Used Avail Use% Mounted on
/dev/mapper/centos_testmanila--1-root 50G 1.1G 49G 3% /
devtmpfs 1.9G 0 1.9G 0% /dev
tmpfs 1.9G 0 1.9G 0% /dev/shm
tmpfs 1.9G 8.5M 1.9G 1% /run
tmpfs 1.9G 0 1.9G 0% /sys/fs/cgroup
/dev/vda1 1014M 189M 826M 19% /boot
/dev/mapper/centos_testmanila--1-home 26G 33M 26G 1% /home
tmpfs 379M 0 379M 0% /run/user/0
172.25.20.246:/NAS/CAPFS/data/share-fac2bf0d-2505-45cb-b72e-a6ddcc9c8297 6.5T 21G 6.4T 1% /root/nfs
For a Windows host, you can access the file share directly from the host or mount the file share to the host.
Open a folder and enter the export path of the file share in the address bar.
To obtain the export path, see "Obtain the export path of a file share."
Enter the username and password to access the file share.
Open the Start menu, right click Computer, and then click Map network drive.
Enter the export path of the file share to the Folder field and then click Finish.
Enter the management username and password created at file node creation. For more information, see "Prerequisites" and "Configure a share node."
Open File Browser to verify that the file share has been mounted successfully.
