Obtain the export path of a file share
The export path of a file share is required for file share mounting and file sharing.
To obtain the export path of a file share:
  1. On the top navigation bar, click Cloud Services, and then select File Shares from the Storage menu.
  1. Click the name of the target file share.
  1. View detailed file share information.
If a host can ping the IP address in the export path successfully, the host can access or mount the file share.
