Manage cloud host snapshots
Cloud host snapshot is a replica for the cloud host state at a specific time. You can save cloud host settings and disk data for cloud host data restoration and recovery. Before operating system upgrade, application software installation, or application software upgrade for a cloud host, you can create a snapshot for the cloud host. If the system cracks because of the previous operations or the software fails to run correctly, you can fast restore the cloud host through the snapshot. To periodically create snapshots for a cloud host, you can create a snapshot policy. For more information, see "Manage snapshot policies."
Cloud host snapshots include external snapshots and internal snapshots. Internal snapshots are stored in the disk files. External snapshots are used for storing incremental data through creating incremental disks. You can use both snapshot types at the same time. If the cloud host has an internal snapshot created, you can only create internal snapshots afterwards. Similarly, if the cloud host has an external snapshot created, you can only create external snapshots afterwards.
Create a snapshot
  1. On the top navigation bar, click Cloud Services, and then select Cloud Hosts from the Compute menu.
  1. Click More for the target cloud host, and then click Create Snapshot.
  1. Specify the parameters.
Table-1 Creating a snapshot
Parameter
Creation Mode
Specify the creation mode, Manual or Auto. If you select Manual, you can select a snapshot policy for the cloud host.
Snapshot Type
Select External Snapshot or Internal Snapshot. Internal snapshots are stored in the disk files. External snapshots are used for storing incremental data through creating incremental disks. If the cloud host has an internal snapshot created, you can only create internal snapshots afterwards. Similarly, if the cloud host has an external snapshot created, you can only create external snapshots afterwards.
Memory Snapshot
Specify whether to take a snapshot for the cloud host memory. The default setting is No. When the cloud host memory usage is too high, taking snapshot for the memory might suspend services on the cloud host. This parameter is available only when the collaborated CAS version supports memory snapshot. If the CAS version does not support memory snapshot, you will create a normal snapshot even if you select memory snapshot.
  1. Click OK
View detailed snapshot information
  1. Click the name of the target cloud host.
  1. Click the Snapshots tab.
  1. Select the target snapshot and view its details in the Snapshot Details area.
Edit a snapshot
  1. Select the target snapshot and click Modify.
  1. Edit the parameters and then click OK.
Restore a snapshot
If you restore a snapshot for a cloud host with a NIC mounted, the NIC will be rolled back. If you restore a snapshot for a cloud host after editing its flavor, the flavor settings will be restored. If you attach a data disk and then restore the snapshot, the data disk will be lost.
To restore a snapshot:
  1. Select the target snapshot and click Restore.
  1. Click OK.
Delete a snapshot
  1. Select the target snapshot and click Delete.
  1. Click OK.
