You can perform this task to edit the enabling status, IP version, action, IPS policy, anti-virus policy, and description of a firewall rule. If the match mode is Five-Tuple, you can edit the protocol, source IP and destination IP. If the match mode is Object Group, you can edit the source object group, destination object group, and service object group.
Editing a firewall rule sets the audit state of the firewall to deactivated. For the changes to take effect, you must set the audit state to activated manually. |
To edit a firewall rule:
On the top navigation bar, click Cloud Services, and then select Firewalls Service from the Network menu.
Click the name of the target firewall.
On the Firewall Rules tab, click Edit for the target firewall rule.
Edit rule parameters and then click OK.
For more information, see "Create firewall rules."
You can export firewall rules for backup or for bulk rule adding to another firewall. You can export selected rules on one page, export all rules on one page, or export all rules of a firewall.
To export firewall rules:
On the Firewall Rules tab, perform one of the following tasks:
To export selected rules on the current page, select the target rules, click Export, and then click OK.
To export all rules on the current page, click Export and then click Export Rules on This Page.
To export all rules of the firewall, click Export and then click Export All Rules.
The rules will be exported as a .csv file.
Deleting firewall rules sets the audit state of the firewall to deactivated. For the changes to take effect, you must set the audit state to activated manually. |
On the Firewall Rules tab, perform either of the following tasks:
To delete a single rule, click Delete for the target rule.
To delete multiple rules, select the target rules and then click Delete.
