You can create firewall rules one by one or import firewall rules in bulk.
On the top navigation bar, click Cloud Services, and then select Firewalls Service from the Network menu.
Click the name of the target firewall.
On the Firewall Rules tab, click Add Rule.
Configure rule parameters and then click OK.
Table-1 Creating a firewall rule
Parameter |
Enable |
Enable or disable the rule. Options include: · Yes—Enables the rule. · No—Disables the rule. A rule takes effect only after it is enabled. |
IP Version |
Select the IP version. |
Match Mode |
Specify the match mode. Options include Five-Tuple and Object Group. If you select Object Group, you must specify a minimum of one object group in the Source Object Group, Destination Object Group, and Service Object Group fields. |
Actions |
Select the action to take on packets matching the rule. Options include:
Five-tuple match mode |
Protocol |
Specify a traffic protocol. Options include TCP, UDP, ICMP, and ANY. If you select ANY, the rule takes effect on traffic of all protocols. |
Source IP |
Specify a source IP address or IP address range. |
Source Port |
Specify a source port number or port number range. This field is available only for TCP and UDP. |
Destination IP |
Specify a destination IP address or IP address range. |
Destination Port |
Specify a destination port number or port number range. This field is available only for TCP and UDP. |
Object group match mode |
Source Object Group |
Select a source IPv4 or IPv6 address object group for source packet address matching. |
Destination Object Group |
Select a source IPv4 or IPv6 address object group for destination packet address matching. |
Service Object Group |
Select a service object group for traffic protocol and port number matching. |
IPS Policies |
Select an IPS policy. |
Anti-Virus Policies |
Select an anti-virus policy. |
You can perform this task to import firewall rules that use five-tuples to match packets. The system provides a file template for import. To use a non-template file, make sure the format of the file content is as required as in the template.
· You can import a maximum of 100 rules at a time. · Only .csv files are supported. · If you uploaded an incorrect file, first delete the file and then reselect the target file. |
To import firewall rules:
On the Firewall Rules tab, click Bulk Import.
Upload the file that contains firewall rules.
To import rules from the template, click Download Template to download the firewall rule template to the local device. Edit the template and save it. Click Select File, and then select the template
To import rules from a file that you have already created, click Select File and select the file.
For more information about the template content, see Table-2.
The system displays obtained rule entries in the rule list.
Import rules to the system.
To import a single rule, click Import for the target rule.
To import multiple rules, select the target rules, and then click OK.
The system might display rules on several pages. If you select all rules by clicking the check box on the table header, only rules on the current page are selected. Make sure you have selected all required rules on all pages before clicking OK.
You can adjust the number of displayed entries per page to display more entries on a page.
To delete multiple rules, select the target rules, and then click Delete.
Table-2 Importing firewall rules
Parameter |
Name |
Enter the rule name. This field is required. |
Protocol |
Select the packet protocol. Options include TCP, UDP, ICMP, ICMPv6, and ANY. If you select ANY, the rule takes effect on packets of all protocols. This field is required. |
IP Version |
Select the IP version. Options include IPv4 and IPv6. This field is required. |
Source IP |
Specify the source IP address or IP address range. This field is optional. |
Source Port |
Specify the source port number or port number range. This field is available only for TCP and UDP. |
Destination IP |
Specify the destination IP address or IP address range. This field is optional. |
Destination Port |
Specify the destination port number or port number range. This field is available only for TCP and UDP. |
Service |
Specify a service object group. This field is optional. |
IPS Policy |
Specify an IPS policy. If you set the action to Inspect, you must specify an IPS policy, anti-virus policy, or both. Leave this field empty if the action is not Inspect. |
Anti-Virus Policy |
Specify an anti-virus policy. If you set the action to Inspect, you must specify an IPS policy, anti-virus policy, or both. Leave this field empty if the action is not Inspect. |
Actions |
Select an action. Options include:
Enable |
Enable or disable the rule. Options include: · Yes—Enables the rule. · No—Disables the rule. A rule takes effect only after it is enabled. This field is required. |
Specify the rule description. This field is optional. |
