Create a service chain
  1. On the top navigation bar, click Cloud Services, and then select Service Chains from the Security menu.
  1. From the left navigation pane, select Service Chains.
  1. Click Create.
  1. Configure service chain parameters as described in Table-1.
Table-1 Configuring service chain parameters
Parameter
Organization
Select an organization that uses the resource.
Source/Destination Traffic Feature Group
Select source and destination traffic feature groups. external indicates that the source or destination traffic feature group matches all external traffic. To create traffic feature groups, see "Create a traffic feature group."
Select a service instance type. Options are Firewall and Load Balancers.
Service Instance
Select a firewall. To create firewalls, see "Create a service chain firewall." To create load balancers, see "Create a service chain load balancer."
  1. Click OK.
