To create a service chain load balancer, you need to create a load balancer, virtual server, listener, real server group, as well as configuring health monitoring settings.
To access the load balancer from the public network, you need to create and assign an elastic public network IP address to the load balancer.
On the top navigation bar, click Cloud Services, and then select Load Balancers from the Network menu.
From the left navigation pane, select Service Chain LB.
Perform the following operations as needed:
To create a load balancer, click Load Balancer.
To create a listener, click Listener.
To create a real server group, click Real Server Groups.
To create a health monitor, click Health Monitors.
Click Create.
